P6SMB6.8(C)A P6SMB550(C)A
Stand-off Voltage - 6.8 to 550 Volts
Peak Pulse Power: 600 Watts
SURFACE MOUNT TRANSISIENT VOLTAGE SUPPRESSOR
Features
DO-214AA/SMB
For surface mounted applications in order to optimize board
space Low profile package
Built-in strain relief
Glass passivated junction
0.155(3.94)
0.130(3.30)
0.086 (2.20)
0.071 (1.80)
Low inductance
Excellent clamping capability
600W peak pulse power capability at 10/1000μs waveform,
0.185(4.70)
0.160(4.06)
repetition rate (duty cycle): 0.01%
Fast response time
0.012(0.305)
0.006(0.152)
Typical IR less than 1μA above 12V
High Temperature soldering: 260℃/ 40 seconds at terminals
Plastic package has underwriters laboratory flammability 94V-0
0.096(2.44)
0.084(2.13)
0.060(1.52)
0.030(0.76)
0.008(0.203)MAX.
Mechanical Data
0.220(5.59)
0.200(5.08)
Case : JEDEC DO-214AA/SMB molded plastic body
Terminals : Solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Dimensions in inches and (millimeters)
Mounting Position : Any
Weight : 0.003 ounce, 0.095 grams
Applications
I/O interface
AC/DC power supply
Industrial and Consumer electronic applications.
MAXIMUM RATINGS AND CHARACTERISTICS
Ratings at 25℃ ambient temperature unless otherwise specified.
Peak Pulse Power Dissipation at TA=25ºC by 10x1000μs waveform (Fig.1)
(Note 1), (Note 2)
Power Dissipation on infinite heat sink at TA=50O
C
Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 3)
Maximum Instantaneous Forward Voltage at 50A for Unidirectional only (Note 4)
Operating Junction and Storage Temperature Range
PPPM
600
Watts
PM(AV)
5.0
Watts
IFSM
100
Amps
VF
3.5V/5.0
V
TJ,TSTG
-65 to +150
Typical Thermal Resistance Junction to Lead
RθJL
℃/W
Typical Thermal Resistance Junction to Ambient
RθJA
100
℃/W
Notes:
(1)Non-repetitive current pulse , per Fig. 3 and derated above TA = 25℃per Fig. 2.
(2) Mounted on 0.2 x 0.2" (5.0 x 5.0 mm) copper pads to each terminal
(3) VF
很抱歉,暂时无法提供与“P6SMB6.8A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.43038
- 100+0.36213
- 300+0.32811
- 3000+0.26871
- 6000+0.24819
- 9000+0.23793
