ES2BF-SMAF
ES2BF-SMAF
    MDD(辰达半导体)
    SMAF
    ES2BF-SMAF
ES2BF-SMAF 数据手册
ES2AF THRU ES2JF SURFACE MOUNT SUPER FAST RECTIFIER Reverse Voltage - 50 to 1000 Volts Forward Current - 2.0 Amperes SMAF FEATURES Cathode Band Top View 0.106(2.70) 0.094(2.40) The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 For surface mounted applications Super fast switching for high efficiency Low reverse leakage Built-in strain relief,ideal for automated placement High forward surge current capability High temperature soldering guaranteed: 260 C/10 seconds at terminals Glass passivated chip junction 0.063(1.60) 0.051(1.30) 0.146(3.7) 0.130(3.3) 0.051(1.30) 0.043(1.10) 0.0091(0.23) 0.0071(0.18) 0.051(1.30) 0.039(1.0) MECHANICAL DATA 0.193(4.90) 0.173(4.40) Dimensions in inches and (millimeters) Case: JEDEC SMAF molded plastic body over passivated chip Terminals: Solder plated, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight:0.0018 ounce, 0.064 grams MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. MDD Catalog Number SYMBOLS Maximum average forward rectified current at TL=55 C Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 2.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=100 C Maximum reverse recovery time (NOTE 1) Typical junction capacitance (NOTE 2) Typical thermal resistance (NOTE 3) Operating junction and storage temperature range UNITS MDD MDD MDD MDD MDD MDD MDD ES2AF ES2BF ES2CF ES2DF ES2EF ES2GF ES2JF Marking code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage ES2AF ES2BF ES2CF ES2DF ES2EF ES2GF ES2JF VRRM VRMS VDC 50 35 50 100 70 100 150 105 150 200 140 200 300 210 300 400 280 400 600 420 600 VOLTS VOLTS VOLTS I(AV) 2.0 Amps IFSM 50.0 Amps VF IR 0.95 1.25 5.0 50.0 1.7 Volts µA trr 35 ns CJ 60.0 40.0 -50 to +150 pF C/W C RθJA TJ,TSTG Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A 2.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas FIG. 1- FORWARD CURRENT DERATING CURVE 2 1.6 1.2 Single Phase Half Wave 60Hz Resistive or inductive Load 0.8 0.4 0 0 25 50 75 100 125 150 PEAK FORWARD SURGE CURRENT, AMPERES AVERAGE FORWARD RECTIFIED CURRENT, AMPERES RATINGS AND CHARACTERISTIC CURVES ES2AF THRU ES2JF FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 50 40 30 20 10 175 0 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 1 10 AMBIENT TEMPERATURE, C TJ=25 C PULSE WIDTH=300 µs 1%DUTY CYCLE 1 0.1 ES2AF-ES2DF ES2EF-ES2GF ES2JF 0.01 0 0.4 0.8 1.2 1.6 1.8 FIG. 4-TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 20 10 1,000 100 10 TJ=100 C 1 TJ=25 C 0.1 0.01 INSTANTANEOUS FORWARD VOLTAGE, VOLTS 0 20 40 60 80 100 10 TJ=25 C TRANSIENT THERMAL IMPEDANCE, C/W 200 FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE 100 10 1 0.1 0.01 0.1 1 10 1 0.1 1.0 10 REVERSE VOLTAGE,VOLTS 100 PERCENTAGE OF PEAK REVERSE VOLTAGE,% FIG. 5-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE, pF 100 NUMBER OF CYCLES AT 60 Hz 100 t,PULSE DURATION,sec. The cruve graph is for reference only, can't be the basis for judgment(曲线图仅供参考)! 100
ES2BF-SMAF 价格&库存
很抱歉,暂时无法提供与“ES2BF-SMAF”相匹配的价格&库存,您可以联系我们找货
