PMS-03V-S
PMS-03V-S
    JST
    Housings
    2.0MM间距连接器,线对板/线对线连接
PMS-03V-S 数据手册
ラジアル PA FAMILY SERIES/PA•PAF•PAL CONNECTOR 2.0mm pitch/Wire-to-board (Crimp style/IDC) / Wire-to-wire (Crimp style/IDC) Standards –––––––––––––––––––––– 0 Retainer PA Receptacle (Crimp style Standard type) Retainer Retainer PAF Receptacle (IDC style) PA Shorouded header (Top entry type) PAF Receptacle (IDC style) PAL (Crimp style Wire-to-wire) PA Receptacle (Crimp style   Retainer    mountable type) PA Shorouded header (Side entry type) PA Shorouded header (Top entry type) Retainer Based upon wire-to-board crimp style PA connectors, the PA series family of connector have been expanded to meet the requirement of complex wire harness of 2.0 mm pitch connectors with secure locking mechanism thanks to the additional line up of wire-to-board IDC style PAF connectors and wire-to-wire crimp style PAL connectors. • Secure locking device • Interchangeable between crimp and IDC socket • Secondary retainers • Harness variation PA connector (Standard type, Retainer mountable type) • Highly reliable contact • Insertion guide mechanism • Flanged press pin Recognized E60389 1 Certified LR20812 Specifications ––––––––––––––––––– PA Connector (Standard type) • Current rating: 3 A AC, DC (AWG #22) • Voltage rating: 250 V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: Initial/ 1,000 MΩ min. • Withstanding voltage: 800 VAC/minute • Applicable wire: Conductor size/ AWG #28 to #22 Insulation O.D./ 0.76 to 1.5 mm • Applicable PC board thickness: 1.6 mm PA Connector (Retainer mountable type) • Current rating: 3 A AC, DC (AWG #22) • Voltage rating: 100 V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 15 mΩ max. After environmental tests/ 25 mΩ max. • Insulation resistance: Initial/ 1,000 MΩ min. • Withstanding voltage: 800 V AC/minute • Applicable wire: AWG #26 to #22 PAF Connector • Current rating: 1.0 A AC, DC (AWG #26) • Voltage rating: 100 V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 15 mΩ max. After environmental tests/ 25 mΩ max. • Insulation resistance: Initial/ 1,000 MΩ min. • Withstanding voltage: 800 VAC/minute • Applicable wire: UL1061(Contact JST for details regarding other UL wires.) AWG #26 Conductor/ 7 strands, tin-coated annealed copper Insulation O.D./ 0.9 to 1.0 mm PAL Connector PAF connector • The industry's first secure lock ID connectors • Metallic strain relief • Retainer with four locking points PAL connector • The industry's first wire to wire 2.0 mm pitch retainer mountable type connector. • Either with or without panel lock can be selected according to application. 1 • Current rating: 3 A AC, DC (AWG #22) • Voltage rating: 100 V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 15 mΩ max. After environmental tests/ 25 mΩ max. • Insulation resistance: Initial/ 1,000 MΩ min. • Withstanding voltage: 800 VAC/minute • Applicable wire: AWG #28 to #22 • Applicable panel thickness : 0.5 to 2.0 mm * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. PA FAMILY SERIES /PA•PAF•PAL CONNECTOR List of combinations Crimp style Standard type Contact SPHD-001T-P0.5 SPHD-002T-P0.5 Shrouded header Top entry type Side entry type B( )B-PASK B( )B-PASK-1 B( )B-PASK-N B( )B-PASK-1N Housing PAP-( )V-S S( )B-PASK-2 Shrouded header Bottom type BE( )B-PASK BE( )B-PASK-C Shrouded header High box type BH( )B-PASK BH( )B-PASK-1 Crimp style Retainer mountable type Contact Shrouded header SPA-001T-P0.5 BM( )B-PASS SMT type Top entry type BM( )B-PASS-1 Housing SM( )B-PASS PARP-( )V SM( )B-PASS-1 Side entry type Retainer PMS-( )V-S Insulation displacement type Receptacle Contact ( )PAF-6S SPAL-001T-P0.5 Wire to wire Connectors SPAL-002T-P0.5 Retainer PAFS-( )V-S Receptacle housing PALR-( )V(F) Retainer PMS-( )V-S 2 PA FAMILY SERIES /PA•PAF•PAL CONNECTOR PC board layout and Assembly layout (5.8) 7.2 Top entry type 1.5 ±0.05 A±0.05 9.9 φ1.1+0.1  0 2 ±0.05 1.7±0.05 φ0.7 +0.1  0 (14.9) (14.7)retainer included 5.8 PA Receptacle (Standard type) + PA Header PAF Receptacle + PA Header PA Receptacle (Retainer mountable type) + PA Header Side entry type (18.8)retainer included 13.8 φ0.7+0.1  0 (7) 7 2.1±0.05 φ1.1+0.1  0 (8.4) 1.5±0.05 A±0.05 2±0.05 (18.9) 8.2 8.2 PA Receptacle (Standard type) + PA side entry type header 8.2 PA Receptacle (Retainer mountable type) + PA side entry type header PAF Receptacle + PA side entry type header Bottom type (14.9) 1.6 (10.8) (10.6) (5.8) 5.5+0.1  0 (9.3) (14.7)retainer included (9.9) φ0.7+0.1  0 0 1.6  -0.1 2 1.6 A±0.05 ±0.05 (10.9) 1.6 (9.5) (5.8) 1.5+0.1  0 (7.2) D+0.1  0 Note: Dimensions C and D; Refer to the header bottom type. PAF Receptacle + PA bottom type header (Extended lenght type) PA Receptacle (Retainer mountable type) + PA bottom type header (Extended lenght type) PA Receptacle (Standard type) + PA bottom type header (Extended lenght type) C+0.1  0 (5.8) Bottom type with extended length (13.95) (14.9) 1.6 (14.7) retainer included (9.9) 1.6 (5.8) 0 4.65 -0.1 +0.1 0 5.5 +0.1 0 2.1 13.65 (10.8) 13.65 1.6 +0.1 0 φ0.75 (10.6) A±0.05 2 ±0.05 (5.8) 5.5 C +0.1 0 +0.1 0 Note: Dimensions C; Refer to the header bottom type. (7.2) PA Receptacle (Standard type) + PA bottom type header (Extended lenght type) PA Receptacle (Retainer mountable type) + PA bottom type header (Extended lenght type) (5.8) PAF Receptacle + PA bottom type header (Extended lenght type) Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ±0.05 mm for all centers. 3. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. 3 PA FAMILY SERIES /PA•PAF•PAL CONNECTOR PC board layout and Assembly layout High box type 7.2 7.1 A ±0.05 1.5 ±0.05 φ1.1 +0.1  0 2 ±0.05 1.7 ±0.05 15.9 φ0.7 +0.1  0 20.9 (20.7)retainer included 7.1 PAF Receptacle + PA high box type header PA Receptacle (Retainer mountable type) + PA high box type header PA Receptacle (Standard type) + PA high box type header Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ±0.05 mm for all centers. 3. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. (7.6) Top entry type (6.2) (6.2) (1.4) (1.4) (1.4) 1.7 ±0.1 2.2 ±0.05 φ0.8+0.1  0 MIN 1 11.1 5 ±0.1 MIN 0.3 1.45±0.1 2 ±0.05 3.6±0.1 4.9 ±0.1 Connector outline 2.9 R0.4 +0.1 0 (16.2) A ±0.1 (16.0)retainer included 1±0.1 1.8±0.1 PAF Receptacle + PA Header PA Receptacle (Retainer mountable type) + PA Header PA Receptacle (Standard type) + PA Header Side entry type 1.7±0.1 1 2±0.05 2.2±0.05 PA Receptacle (Retainer mountable type) + PA side entry type header (16.2) (6.2) 8.9 5.7 5.7 5.7 MIN (1.1) 8.9 PA Receptacle (Standard type) + PA side entry type header φ0.8+0.1  0 1±0.1 (1.1) (16)retainer included (7.6) R0.4 +0.1 0 11.1 8.9 7.95±0.1 3.8±0.1 2.8 7.8±0.1 1.8±0.1 2.7 MIN (1.1) 1.45±0.1 Connector outline (6.2) A±0.1 PAF Receptacle + PA side entry type header Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances for the centers of pattern on PCB is ±0.05, and shall be not cumulative more than ±0.1. 3. The dimensions above should serve as a guideline. Contact JST for details. PA Receptacle (Standard type) + PAL Receptacle PA Receptacle (Retainer mountable type) + PAL Receptacle retainer included (8.9) (26)retainer included retainer included retainer included (8.4) (25.8)retainer included (7.6) (21.5)retainer included PAF Receptacle + PAL Receptacle 4 PA FAMILY SERIES /PA CONNECTOR (Crimp style Standard type) Contact Applicable wire Model No. Insulation O.D. (mm) Q'ty/ reel 26∼22 1.0∼1.5 8,000 28∼24 0.76∼1.5 8,000 AWG # SPHD-001T-P0.5 0.13∼0.33 SPHD-002T-P0.5 0.08∼0.21 1.5 mm2 Material and Finish Phosphor bronze, tin-plated (reflow treatment) 6.5 RoHS compliance 2.85 1.3 Contact Crimping machine Crimp applicator MKS-L-10 SPHD-002T-P0.5 AP-K2N SPHD-001T-P0.5 Applicator Dies Crimp applicator with dies MK/SPHD-002-05 APLMK SPHD002-05 *MKS-SC-10 SC/SPHD-002-05 APLSC SPHD002-05 MKS-L-10 MK/SPHD-001-05 APLMK SPHD001-05 *MKS-SC-10 SC/SPHD-001-05 APLSC SPHD001-05 Note:*Strip-crimp applicator Housing B (2) A 2 Model No. 2 PAP-02V-S PAP-03V-S PAP-04V-S PAP-05V-S PAP-06V-S PAP-07V-S PAP-08V-S PAP-09V-S PAP-10V-S PAP-11V-S PAP-12V-S PAP-13V-S PAP-14V-S PAP-15V-S PAP-16V-S 3 5.8 4.6 4 5 8 7.3 6 7 8 9 Circuit No.1 10 11 12 B (2) A 13 5.8 2 14 4.6 15 16 8 7.3 Dimensions (mm) A B Circuits Q’ty/ bag 2.0 6.0 1,000 4.0 8.0 1,000 6.0 10.0 1,000 8.0 12.0 1,000 10.0 14.0 1,000 12.0 16.0 1,000 14.0 18.0 1,000 16.0 20.0 1,000 18.0 22.0 1,000 20.0 24.0 1,000 22.0 26.0 1,000 24.0 28.0 1,000 26.0 30.0 1,000 28.0 32.0 1,000 30.0 34.0 1,000 Material PA 66, UL94V-0, natural (white) Circuit No.1 RoHS compliance As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. B (2) A 5.8 2 8 7.3 4.6 Circuit No.1 5 ex. PAP-02V-SS…natural (white) K…black R…red E…blue M…green O…orange N…brown P…purple PK…pink Y…yellow L…lemon yellow FY…vivid yellow LE…light blue H…gray TR…tomato red PA FAMILY SERIES Through-hole type shrouded header Top entry type Side entry type Circuit No.1 6.5 B (3.4) 11.7 5.9 6.1 5.9 3 1.2 8.2 A 7.7 A 5.3 7.7 B φ0.8 0.5 2 1.7 2 Circuit No.1 1.5 Circuit No.1 B B 5.3 A 6.5 (3.4) 8.2 11.7 6.1 5.9 7.7 3 1.2 5.9 7.7 A φ0.8 0.5 2 2 1.7 Circuit No.1 1.5 Circuit No.1 B 5.3 6.5 B A (3.4) φ0.8 0.5 2 1.7 2 1.5 Top entry type Circuits 2(Note1) 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 11.7 8.2 6.1 5.9 7.7 5.9 3 1.2 7.7 A Circuit No.1 Side entry type Model No. Without boss With a boss B02B-PAFYK-A B02B-PAFYK-1A B02B-PASK B02B-PASK-1 B03B-PASK B03B-PASK-1 B04B-PASK B04B-PASK-1 B05B-PASK B05B-PASK-1 B06B-PASK B06B-PASK-1 B07B-PASK B07B-PASK-1 B08B-PASK B08B-PASK-1 B09B-PASK B09B-PASK-1 B10B-PASK B10B-PASK-1 B11B-PASK B11B-PASK-1 B12B-PASK B12B-PASK-1 B13B-PASK B13B-PASK-1 B14B-PASK B14B-PASK-1 B15B-PASK B15B-PASK-1 B16B-PASK B16B-PASK-1 Dimensions (mm) A B Q’ty/ box Circuits Model No. S02B-PASK-2 S03B-PASK-2 S04B-PASK-2 S05B-PASK-2 S06B-PASK-2 S07B-PASK-2 S08B-PASK-2 S09B-PASK-2 S10B-PASK-2 S11B-PASK-2 S12B-PASK-2 S13B-PASK-2 S14B-PASK-2 S15B-PASK-2 S16B-PASK-2 2.0 6.0 1,000 2 2.0 6.0 1,000 3 4.0 8.0 1,000 4 6.0 10.0 1,000 5 8.0 12.0 500 6 10.0 14.0 500 7 12.0 16.0 500 8 14.0 18.0 500 9 16.0 20.0 500 10 18.0 22.0 500 11 20.0 24.0 250 12 22.0 26.0 250 13 24.0 28.0 250 14 26.0 30.0 250 15 28.0 32.0 250 16 30.0 34.0 250 Dimensions (mm) A B Q'ty/ box 2.0 6.0 1,000 4.0 8.0 1,000 6.0 10.0 500 8.0 12.0 500 10.0 14.0 500 12.0 16.0 250 14.0 18.0 250 16.0 20.0 250 18.0 22.0 250 20.0 24.0 250 22.0 26.0 250 24.0 28.0 200 26.0 30.0 200 28.0 32.0 200 30.0 34.0 200 Material and Finish Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PBT, UL94V-0, natural (white) (Note1) PA 66, UL94V-0, vivid yellow RoHS compliance This product displays (LF)(SN) on a label. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B02B-PASKS…natural (white) K…black R…red E…blue M…green O…orange N…brown P…purple PK…pink Y…yellow L…lemon yellow FY…vivid yellow LE…light blue H…gray TR…tomato red Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PBT, UL94V-0, natural (white) RoHS compliance This product displays (LF)(SN) on a label. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. S03B-PASK-2S…natural (white) K…black R…red E…blue M…green O…orange N…brown P…purple PK…pink Y…yellow L…lemon yellow LE…light blue H…gray TR…tomato red 6 PA FAMILY SERIES Through-hole type shrouded header N type N type Circuits Circuit No.1 B A 2 5.3 3 5 1.2 5.9 7.7 4 6 3 7 8 φ0.8 0.5 2 1.7 9 1.5 10 11 Circuit No.1 B 12 13 5.3 A 14 16 1.2 5.9 7.7 15 3 2 Dimensions (mm) A B Q'ty/ box 2.0 6.0 1,000 4.0 8.0 1,000 6.0 10.0 1,000 8.0 12.0 500 10.0 14.0 500 12.0 16.0 500 14.0 18.0 500 16.0 20.0 500 18.0 22.0 500 20.0 24.0 250 22.0 26.0 250 24.0 28.0 250 26.0 30.0 250 28.0 32.0 250 30.0 34.0 250 Material and Finish φ0.8 0.5 Model No. Without boss With a boss B02B-PASK-1N B02B-PASK-N B03B-PASK-N B03B-PASK-1N B04B-PASK-N B04B-PASK-1N B05B-PASK-N B05B-PASK-1N B06B-PASK-N B06B-PASK-1N B07B-PASK-N B07B-PASK-1N B08B-PASK-N B08B-PASK-1N B09B-PASK-N B09B-PASK-1N B10B-PASK-N B10B-PASK-1N B11B-PASK-N B11B-PASK-1N B12B-PASK-N B12B-PASK-1N B13B-PASK-N B13B-PASK-1N B14B-PASK-N B14B-PASK-1N B15B-PASK-N B15B-PASK-1N B16B-PASK-N B16B-PASK-1N Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0, natural 1.7 1.5 RoHS compliance This product displays (LF)(SN) on a label. Circuit No.1 B A 5.9 3 1.2 7.7 5.3 1.7 φ0.8 0.5 2 1.5 Bottom type Bottom type Circuit No.1 B 9 A 0.5 5.3 2 Model No. 5 BE05B-PASK BE08B-PASK BE11B-PASK BE12B-PASK 8 11 A B C D Q’ty/ bag 8.0 12.0 12.4 5.5 300 14.0 18.0 18.4 5.5 200 20.0 24.0 24.4 12.0 150 22.0 26.0 26.4 12.0 150 (2.5) 3 7.7 12 5.9 Dimensions (mm) Circuits Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PBT, UL94V-0, natural Circuit No.1 B A RoHS compliance This product displays (LF)(SN) on a label. Note: Dimemsions C and D; Refer to the PCB layout bottom type (page 3). 9 0.5 5.9 (2.5) 3 5.3 7.7 2 Bottom type with extended lenght Circuits Model No. 4 BE04B-PASK-C BE05B-PASK-C BE06B-PASK-C Bottom type with extended lenght Circuit No.1 B A 5 12.05 1.6 2 5.3 6 4.75 0.5 Dimensions (mm) A B C Q'ty/ box 6.0 10.0 10.4 1,050 8.0 12.0 12.4 875 10.0 14.0 14.4 750 Material and Finish 7 7.7 (2.5) 3 5.9 Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0, natural RoHS compliance This product displays (LF)(SN) on a label. Note: 1. Dimemsions C; Refer to the PCB layout bottom type (page 3). 2. Not UL/CSA approved. PA FAMILY SERIES Shrouded header 7.1 B A B 7.1 A 5.3 5.3 3 3 13.9 13.9 2 Circuit No.1 Circuit No.1 B B A 7.1 2 7.1 A 5.3 2 3 3 13.9 13.9 5.3 Circuit No.1 Circuit No.1 B B A 7.1 2 A 5.3 7.1 5.3 3 3 13.9 13.9 2 Circuit No.1 Circuits 2 3 4 5 6 7 8 9 10 11 12 15 Model No. Without a boss With a boss BH02B-PASK BH03B-PASK BH04B-PASK BH05B-PASK BH06B-PASK BH07B-PASK BH08B-PASK BH09B-PASK BH10B-PASK BH11B-PASK BH12B-PASK BH15B-PASK BH02B-PASK-1 BH03B-PASK-1 BH04B-PASK-1 BH05B-PASK-1 BH06B-PASK-1 BH07B-PASK-1 BH08B-PASK-1 BH09B-PASK-1 BH10B-PASK-1 BH11B-PASK-1 BH12B-PASK-1 BH15B-PASK-1 Circuit No.1 Dimensions(mm) Q'ty/ box B A 2.0 6.0 900 4.0 8.0 675 6.0 10.0 525 8.0 12.0 450 10.0 14.0 375 12.0 16.0 325 14.0 18.0 300 16.0 20.0 250 18.0 22.0 225 20.0 24.0 225 22.0 26.0 200 28.0 32.0 150 Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PBT, UL94V-0, natural (white) RoHS compliance This product displays (LF)(SN) on a label. 8 PA FAMILY SERIES SMT type shrouded header Top entry type Side entry type B B A A 2 5.7 2 7.1 7.1 1.8 1.8 5.7 Circuit No.1 Circuit No.1 B B A A 2 5.7 2 7.1 7.1 1.8 1.8 5.7 Circuit No.1 Circuit No.1 B B A A 2 2 5.7 7.1 7.1 1.8 1.8 5.7 Circuit No.1 Circuit No.1 Top entry type Circuits 2 3 4 5 6 7 8 9 10 11 12 13 15 Side entry type Model No. Without a boss With a boss BM02B-PASS-(*) BM03B-PASS-(*) BM04B-PASS-(*) BM05B-PASS-(*) BM06B-PASS-(*) BM07B-PASS-(*) BM08B-PASS-(*) BM09B-PASS-(*) BM10B-PASS-(*) BM11B-PASS-(*) BM12B-PASS-(*) BM13B-PASS-(*) BM15B-PASS-(*) BM02B-PASS-1-(*) BM03B-PASS-1-(*) BM04B-PASS-1-(*) BM05B-PASS-1-(*) BM06B-PASS-1-(*) BM07B-PASS-1-(*) BM08B-PASS-1-(*) BM09B-PASS-1-(*) BM10B-PASS-1-(*) BM11B-PASS-1-(*) BM12B-PASS-1-(*) BM13B-PASS-1-(*) BM15B-PASS-1-(*) Dimensions(mm) Q'ty/ reel A B 2.0 8.0 500 2 4.0 10.0 500 3 6.0 12.0 500 4 8.0 14.0 500 5 10.0 16.0 500 6 12.0 18.0 500 7 14.0 20.0 500 8 16.0 22.0 500 9 18.0 24.0 500 10 20.0 26.0 500 11 22.0 28.0 500 12 24.0 30.0 500 13 28.0 34.0 500 15 Model No. Without a boss With a boss SM02B-PASS-(*) SM03B-PASS-(*) SM04B-PASS-(*) SM05B-PASS-(*) SM06B-PASS-(*) SM07B-PASS-(*) SM08B-PASS-(*) SM09B-PASS-(*) SM10B-PASS-(*) SM11B-PASS-(*) SM12B-PASS-(*) SM13B-PASS-(*) SM15B-PASS-(*) SM02B-PASS-1-(*) SM03B-PASS-1-(*) SM04B-PASS-1-(*) SM05B-PASS-1-(*) SM06B-PASS-1-(*) SM07B-PASS-1-(*) SM08B-PASS-1-(*) SM09B-PASS-1-(*) SM10B-PASS-1-(*) SM11B-PASS-1-(*) SM12B-PASS-1-(*) SM13B-PASS-1-(*) SM15B-PASS-1-(*) Dimensions(mm) Q'ty/ reel A B 2.0 8.0 1,000 4.0 10.0 1,000 6.0 12.0 1,000 8.0 14.0 1,000 10.0 16.0 1,000 12.0 18.0 1,000 14.0 20.0 1,000 16.0 22.0 1,000 18.0 24.0 1,000 20.0 26.0 1,000 22.0 28.0 1,000 24.0 30.0 1,000 28.0 34.0 1,000 Material and Finish Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: PA, UL94V-0, natural (ivory) Solder tab: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: PA, UL94V-0, natural (ivory) Solder tab: Copper alloy, copper-undercoated, tin-plated (reflow treatment) RoHS compliance This product displays (LF)(SN) on a label. Note: (*): TF…taping product TFT…taping product with suction tape. 9 Circuits RoHS compliance This product displays (LF)(SN) on a label. Note: (*): TB…taping product TBT…taping product with suction tape. PA FAMILY SERIES /PA CONNECTOR (Crimp style Retainer mountable type) Contact Applicable wire mm2 AWG # Insulation O.D. (mm) Q'ty/ reel 0.13∼0.33 26∼22 0.9∼1.5 10,000 Model No. 1.5 SPA-001T-P0.5 Material and Finish Phosphor bronze, tin-plated (reflow treatment) 8.4 RoHS compliance 2.85 1.3 2.2 Contact SPA-001T-P0.5 Crimping machine Crimp applicator AP-K2N Applicator Dies Crimp applicator with dies MKS-L MK/SPA-001-05 APLMK SPA001-05 ― ― ― Housing B B A A 7.2 7.2 2 Circuits Model No. 2 PARP-02V PARP-03V PARP-04V PARP-05V PARP-06V PARP-07V PARP-08V PARP-09V PARP-10V PARP-15V 3 11.4 11.4 4 5 6 Circuit No.1 7 Circuit No.1 8 9 B 10 B A A 7.2 15 7.2 2 2 Q'ty/ bag 2.0 5.4 1,000 4.0 7.4 1,000 6.0 9.4 1,000 8.0 11.4 1,000 10.0 14.0 1,000 12.0 16.0 1,000 14.0 18.0 1,000 16.0 20.0 1,000 18.0 22.0 1,000 28.0 32.0 500 Material PA 66, UL94V-0, natural (white) 11.4 11.4 Circuit No.1 Dimensions (mm) A B RoHS compliance Note: Contact JST for Glow Wire compliant connectors. Circuit No.1 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. B B A ex. 7.2 A 7.2 PARP-02V-oo(blank)…natural (white) R…red E…blue Y…yellow M…green 2 11.4 11.4 2 Circuit No.1 Circuit No.1 Retainer Model No. 2 PMS-02V-S PMS-03V-S PMS-04V-S PMS-05V-S PMS-06V-S PMS-07V-S PMS-08V-S PMS-09V-S PMS-10V-S PMS-15V-S 3 2 4 5 B A A B 2 6 7 8 3.1 2.4 9 2.4 1.5 7 10 15 Q'ty/ bag 2.0 7.3 1,000 4.0 9.3 1,000 6.0 11.3 1,000 8.0 13.3 1,000 10.0 11.55 1,000 12.0 13.55 1,000 14.0 15.55 1,000 16.0 17.55 1,000 18.0 19.55 1,000 28.0 29.55 1,000 Material 1.5 2.85 Dimensions (mm) A B Circuits 7 Glass-filled PA 66, UL94V-0, natural (ivory) RoHS compliance 10 PA FAMILY SERIES /PAF CONNECTOR (Insulation displacement type) Receptacle Circuits Model No. 2 02PAF-6S 03PAF-6S 04PAF-6S 05PAF-6S 06PAF-6S 07PAF-6S 08PAF-6S 09PAF-6S 10PAF-6S 11PAF-6S 12PAF-6S 13PAF-6S 14PAF-6S 15PAF-6S 16PAF-6S 3 4 5 6 7 B 2 A 8 13 9 2 10 3.1 5.1 11 12 13 14 8 Circuit No.1 15 *16 Dimensions (mm) A B Q'ty/ box 2.0 6.0 1,000 4.0 8.0 1,000 6.0 10.0 500 8.0 12.0 500 10.0 14.0 500 12.0 16.0 500 14.0 18.0 250 16.0 20.0 250 18.0 22.0 250 20.0 24.0 250 22.0 26.0 250 24.0 28.0 250 26.0 30.0 250 28.0 32.0 250 30.0 34.0 250 Material and Finish Contact: Phosphor bronze, tin-plated (reflow treatment) Housing: PA 66, UL94V-0, natural (white) RoHS compliance Note: *Marked product is not UL/CSA approved. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 02PAF-6SS…natural (white) R…red E…blue M…green Y…yellow Retainer Model No. 2 PAFS-02V-S PAFS-03V-S PAFS-04V-S PAFS-05V-S PAFS-06V-S PAFS-07V-S PAFS-08V-S PAFS-09V-S PAFS-10V-S PAFS-11V-S PAFS-12V-S PAFS-13V-S PAFS-14V-S PAFS-15V-S 3 4 5 2 6 7 * 9 A B 8 *10 *11 *12 *13 *14 *15 4.1 Dimensions (mm) A B Circuits 2.0 7.4 1,000 4.0 9.4 1,000 6.0 11.4 1,000 8.0 13.4 1,000 10.0 15.4 1,000 12.0 17.4 1,000 14.0 19.4 1,000 16.0 21.4 1,000 18.0 23.4 1,000 20.0 25.4 1,000 22.0 27.4 1,000 24.0 29.4 1,000 26.0 31.4 1,000 28.0 33.4 1,000 8.9 Material Glass-filled PA 66, UL94V-0, natural (ivory) RoHS compliance Note: *Marked products are not UL/CSA approved. 11 Q’ty/ bag PA FAMILY SERIES /PAL CONNECTOR (Wire-to-wire type) Contact Applicable wire 0.5 1.6 Model No. Insulation O.D. (mm) Q'ty/ reel mm2 AWG # SPAL-001T-P0.5 0.13∼0.33 26∼22 1.0∼1.5 10,000 SPAL-002T-P0.5 0.08∼0.21 28∼24 0.9∼1.5 10,000 Material and Finish Phosphor bronze, tin-plated (reflow treatment) 12.8 RoHS compliance 2.85 1.3 0.5 Contact Crimping machine Crimp applicator 2.4 Dies ― AP-K2N ― ― MKS-L SPAL-002T-P0.5 Crimp applicator with dies MK/SPAL-001-05 APLMK SPAL001-05 MKS-L SPAL-001T-P0.5 Applicator MK/SPAL-002-05 APLMK SPAL002-05 ― ― ― Housing Without panel locks B A 6.3 3.4 3.7 A 2 2 2 PALR-02VF PALR-03VF PALR-04VF PALR-05VF PALR-06VF PALR-07VF PALR-08VF 4 3.4 3.7 Model No. 3 6.3 B 5 6 7 20 8 Q'ty/ bag 2.0 9.4 1,000 4.0 11.4 1,000 6.0 13.4 1,000 8.0 15.4 1,000 10.0 17.4 1,000 12.0 19.4 1,000 14.0 21.4 1,000 Material 11.2 20 Dimensions (mm) A B Circuits PA 66, UL94V-0, natural (white) RoHS compliance Circuit No.1 Circuit No.1 4.7 4.4 With panel locks 3.2 3.7 3.4 1 Panel layout 20 4.6±0.05 A 2 6.3 Circuits Model No. 2 PALR-02V PALR-03V PALR-04V PALR-06V PALR-07V PALR-08V 3 4 6.5+0.1 0 B 6 7 8 C+0.1 0 Dimensions (mm) A B C D Q'ty/ bag 2.0 9.4 9.8 13.4 1,000 4.0 11.4 11.8 15.4 1,000 6.0 13.4 13.8 17.4 1,000 10.0 17.4 19.8 21.4 1,000 12.0 19.4 21.8 23.4 1,000 14.0 21.4 23.8 25.4 1,000 D±0.1 4 Material Circuit No.1 3.25 PA 66, UL94V-0, natural (white) RoHS compliance A 3.2 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 6.3 3.7 3.4 Panel layout ex. 20 5.1±0.05 2 6.5+0.1 0 B PALR-02V(F)-oo(blank)…natural (white) R…red E…blue M…green Y…yellow C+0.1 0 5.8 D±0.1 5.15 Circuit No.1 1.6 4.4 Retainer Retainers are interchangeable with those of the PA crimp style retainer mountable type. 12
PMS-03V-S 价格&库存
很抱歉,暂时无法提供与“PMS-03V-S”相匹配的价格&库存,您可以联系我们找货
PMS-03V-S
    • 1000+0.15400
    库存:288000
    PMS-03V-S
      • 1000+0.11550
      库存:36700
      PMS-03V-S
        • 1000+0.11583
        库存:1000
