3R-8-S SERIES
Gas Discharge Tube (GDT) Data Sheet
Features
■ Provide ultra-fast response to surge voltage from slow-rising
surge of 100V/s to rapid-rising surge of 1KV/μs
Stable breakdown voltage
High insulation resistance
Low capacitance (≤2pF)
High holdover voltage
Large absorbing transient current capability
Micro-Gap Design
Storage and operating temperature: -40℃ ~ +85℃
Meets MSL level 1, per J-STD-020
Safety certification: E244458
Applications
Repeaters, Modems
Telephone Interface, Line cards
Data communication equipment
Line test equipment
Part Number Code
3
M
R
Electrical
Characteristics
M:10KA
P: 20KA
Electrode Numbers
3R: 3 Electrodes
8
Lead Type
M: SMD
DC
Spark-over
Voltage
S
S:Square electrode
Dimensions
8: 8.0mm×10.0mm
Marking
: BrightKing Logo
3RM090-8 : Device Marking Code
YXXX
: Date Code
Revision: GDT-3R-8-S SERIES-001(A1)
2/5
http://brightking.pulseelectronics.com
3R-8-S SERIES
Dimensions
10.6
D
8
Spec.
Tolerance
D
8.0
±0.2
D1
7.5
±0.2
D2
9.0
±0.2
T
10.0
±0.3
B
0.5
±0.2
B1
1.5
±0.2
B1
D
2
D
D1
T
Dimension (mm)
Symbol
B
2.1
1.1
Recommended Pad Size
Electrical Characteristics
Part
Number
DC
Spark-over
Voltage
Maximum
Impulse
Spark-over
Voltage
Nominal
Impulse
Discharge
Current
Alternating
Discharge
Current
Impulse
Life
100V/s
1000V/μs
8/20μs
10times
50Hz,1sec
10/1000μs
100A
Test
Voltage
Minimum
Insulation
Resistance
Maximum
Capacitance
1MHz
Device
Marking
Code
(GΩ)
(V)
(V)
(KA)
(A)
(times)
DC(V)
3RM075M-8-S
75±20%
700
10
10
300
25
1.0
2.0
3RM075-8
3RM090M-8-S
90±20%
700
10
10
300
50
1.0
2.0
3RM090-8
3RM150M-8-S
150±20%
700
10
10
300
100
1.0
2.0
3RM150-8
3RM200M-8-S
200±20%
700
10
10
300
100
1.0
2.0
3RM200-8
3RM230M-8-S
230±20%
800
10
10
300
100
1.0
2.0
3RM230-8
3RM350M-8-S
350±20%
900
10
10
300
100
1.0
2.0
3RM350-8
3RM400M-8-S
400±20%
1000
10
10
300
100
1.0
2.0
3RM400-8
3RM470M-8-S
470±20%
1100
10
10
300
250
1.0
2.0
3RM470-8
3RM600M-8-S
600±20%
1300
10
10
300
250
1.0
2.0
3RM600-8
3RP075M-8-S
75±20%
700
25
1.0
2.0
3RP075-8
3RP090M-8-S
90±20%
700
50
1.0
2.0
3RP090-8
3RP150M-8-S
150±20%
700
100
1.0
2.0
3RP150-8
3RP200M-8-S
200±20%
700
100
1.0
2.0
3RP200-8
3RP230M-8-S
230±20%
800
100
1.0
2.0
3RP230-8
3RP350M-8-S
350±20%
900
100
1.0
2.0
3RP350-8
3RP400M-8-S
400±20%
1000
100
1.0
2.0
3RP400-8
3RP470M-8-S
470±20%
1100
250
1.0
2.0
3RP470-8
3RP600M-8-S
600±20%
1300
250
1.0
2.0
3RP600-8
3/5
(pF)
3R-8-S SERIES
Electrical Ratings
Items
Test Condition/Description
Requirement
DC Spark-over
Voltage
The voltage is measured with voltage ramp dv/dt=100V/s. Test is between
each side electrode and center electrode.
Maximum Impulse
Spark-over Voltage
The maximum impulse spark-over voltage is measured with voltage ramp
dv/dt=1000V/μs. Test is between each side electrode and center electrode.
Maximum surge current that can be applied through center electrode with
8/20μs waveform, for 10 times with 3min interval time, which will be equally
divided between each side electrode to center electrode.
Crest value
Current (%)
100
90
Impulse
Discharge Current
To meet
50
the specified
20µs
10
value
8µs
Time
Impulse Width
Alternating
Discharge Current
Insulation
Resistance
Rated RMS value of AC current at 50Hz, 1 sec. for 10 times with interval
time 3 min. Test is between each side electrode and center electrode.
The resistance of gas tube shall be measured between each side electrodes
Capacitance
The capacitance of gas tube shall be measured between each side
electrodes and center electrode.
Test frequency: 1MHz
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
4/5
3R-8-S SERIES
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
150℃
200℃
60-180 seconds
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
20-40 seconds
6℃/second max.
Time 25℃ to Peak Temperature
8 minutes max.
Packaging
SMD Packing (Tape & Reel)
Tape
W
P0
P
P2
D0
E
F
A0
K0
B0
T
Dimension (mm)
Spec.
Tolerance
16.00
±0.20
4.00
±0.10
16.00
±0.10
2.00
±0.10
1.55
±0.10
1.75
±0.10
7.50
±0.10
10.30
±0.10
8.40
±0.10
8.40
±0.10
0.50
±0.05
D
330.00
±2.00
d
13.00
±0.50
L
20.00
±2.00
t
2.00
±0.20
Symbol
Reel
t
D
d
Quantity: 300pcs
L
5/5
很抱歉,暂时无法提供与“3RP090M-8-S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.90960
- 10+3.17520
- 30+2.79720
- 国内价格
- 10+7.71120
- 100+4.60000
- 200+3.22000
- 300+2.30000
- 600+2.18500
- 3000+2.02400
