GBJ35005
THRU
GBJ3510
Technical Data
Data Sheet N1805, Rev. A
GBJ35005-GBJ3510
Single-Phase 35.0A Glass Passivated Bridge Rectifier
Features
Glass passivated die construction
Low forward voltage drop
High current capability
High surge current capability
Plastic material-UL flammability 94V-0
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
GBJ
Circuit Diagram
Mechanical Data
Case: GBJ, Molded plastic
Terminals: Plated leads solderable per MIL-STD-202,
Method 208
Polarity: as marked on case
Mounting Position: Any
Lead Free: For RoHS / Lead Free Version
Maximum Ratings @TA=25°C unless otherwise specified
Type Number
Symbol
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
VRRM
VRWM
VDC
RMS Reverse Voltage
VRMS
Average forward rectified output current
@TA =100°C
I(AV)
Peak Forward Surge Current,8.3ms single halfsine-wave superimposed on rated load
(JEDEC method)
IFSM
GBJ
35005
50
35
GBJ
3501
5
3
GBJ
3502
GBJ
3504
GBJ
3506
GBJ
3508
GBJ
Units
3510
100
1
200
2
400
4
600
6
800
8
1000
1
V
70
7
140
1
280
2
420
4
560
5
700
1
V
35.0
320
China - Germany - Korea - Singapore - United States
http://www.smc-diodes.com - sales@ smc-diodes.com
A
A
GBJ35005
THRU
GBJ3510
Technical Data
Electrical Characteristics@TA=25°C unless otherwise specified
Type Number
Symbol
GBJ
35005
GBJ
3501
GBJ
3502
GBJ
3504
GBJ
3506
GBJ
3508
GBJ
Units
3510
@IF =17.5A
@IF =35A
VF
1.0
1.1
V
Peak Reverse Current
@TA = 25°C
At Rated DC Blocking Voltage @TA = 125°C
IRM
5
500
µA
Typical Junction Capacitance(per leg)
(Note 1)
CJ
75
pF
Forward Voltage (per element)
* Pulse width < 300 µs, duty cycle < 2%
Thermal-Mechanical Specifications:
Type Number
Symbol
Between Junction and Ambient, Without heatsink
Between Junction and Case, Without heatsink
Operating and Storage Temperature Range
GBJ
35005
GBJ
3501
GBJ
3502
GBJ
3504
GBJ
3506
GBJ
3508
GBJ
Units
3510
RθJA
RθJc
22
0.8
°C/W
TJ, TSTG
-55 to +150
°C
Note: 1- Measured at 1 MHZ and applied reverse voltage of 4.0 VDC.
Ratings and Characteristics Curves
GBJ35005
THRU
GBJ3510
Technical Data
Ordering Information
Device
GBJ35005
THRU
GBJ3510
Marking Diagram
Package
Plating
Shipping
GBJ(Pb-Free)
Pure Sn
15pcs / tube
For information on tape and reel specifications, including part
orientation and tape sizes, please refer to our tape and reel
packaging specification.
Where XXXXX is YYWWL
SSG
YY
WW
L
GBJ35005
= SSG
= Year
= Week
= Lot Number
= Type Number
Cautions:Molding resin
Epoxy resin UL:94V-0
GBJ35005
THRU
GBJ3510
Technical Data
Mechanical Dimensions GBJ (Inches/Millimeters)
GBJ35005
THRU
GBJ3510
Technical Data
DISCLAIMER:
1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product
characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of
the datasheet(s).
2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment,
medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by
means of users’ fail-safe precautions or other arrangement .
3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during
operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property
claims or any other problems that may result from applications of information, products or circuits described in the datasheets.
4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use
at a value exceeding the absolute maximum rating.
5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions.
6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC
Diode Solutions.
7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will
hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third
party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and
regulations.
很抱歉,暂时无法提供与“GBJ3506”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+7.12800
- 10+5.77800
- 30+5.10840
- 100+4.43880
- 500+4.03920
- 1000+3.83400
