SMC5359A
SMC5359A
    ZHIDE(志得)
    SMC(DO-214AB)
    耐压:24V 电流:0.5UA@18.2V
SMC5359A 数据手册
SMC53xxA SERIES Surface Mount Silicon Zener Diodes Zener Voltage 3.3 ~ 200 V DO214AB(SMC) 5.0 Watt Power Dissipation Features ● Glass passivated chip ● Built-in strain relief ● Low inductance ● High peak reverse power dissipation ● Low reverse leakage ● For use in stabilizing and clipping with high power rating ● RoHS compliant Mechanical Data ● Case: DO214AB Molded plastic ● Lead: Solderable per MIL-STD-750, method 2026 ● Epoxy: UL 94V-0 rate flame retardant Unit: inch(mm) ● Polarity: Color band denotes cathode end ● Mounting position: Any Parameter Symbols Value Unit DC Power dissipation at TL = 75 °C PD 5.0 W Maximum forward voltage at if=200mA VF 1.2 V Junction temperature range TJ,TSTG -55 to +150 ℃ Storage temperature range TJ,TSTG -55 to +150 ℃ (1) Note: (1)TL=Lead temperature at 3/8'' (9.5mm)from body REV.1.1,2017-07 Changzhou zhide Electronics CO.,LTD www.cz-zhide.com SMC53xxA SERIES Ratings and Characteristics Curves (TA=25℃ unless otherwise noted) REV.1.1,2017-07 Changzhou zhide Electronics CO.,LTD www.cz-zhide.com SMC53xxA SERIES Part Number SMC5333A SMC5334A SMC5335A SMC5336A SMC5337A SMC5338A SMC5339A SMC5340A SMC5341A SMC5342A SMC5343A SMC5344A SMC5345A SMC5346A SMC5347A SMC5348A SMC5349A SMC5350A SMC5351A SMC5352A SMC5353A SMC5354A SMC5355A SMC5356A SMC5357A SMC5358A SMC5359A SMC5360A SMC5361A SMC5362A SMC 363A SMC5363A SMC5364A SMC5365A SMC5366A SMC5367A SMC5368A SMC5369A SMC5370A SMC5371A SMC5372A SMC5373A SMC5374A SMC5375A SMC5376A SMC5377A SMC5378A SMC5379A SMC5380A SMC5381A SMC5382A SMC5383A SMC5384A SMC5385A SMC5386A SMC5387A SMC5388A Device Marking Code 333A 334A 335A 336A 337A 338A 339A 340A 341A 342A 343A 344A 345A 346A 347A 348A 349A 350A 351A 352A 353A 354A 355A 356A 357A 358A 359A 360A 361A 362A 363A 364A 365A 366A 367A 368A 369A 370A 371A 372A 373A 374A 375A 376A 377A 378A 379A 380A 381A 382A 383A 384A 385A 386A 387A 388A REV.1.1,2017-07 Nominal Zener Voltage @IT Maximum Zener Impedance IZT(mA) VZ AVE.(V) VZ MIN.(V) VZ MAX.(V) 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.0 6.2 6.8 7.5 8.2 8.7 9.1 10.0 11.0 12.0 13.0 14.0 15.0 16.0 17.0 18.0 19.0 20.0 22.0 24.0 25.0 27.0 28.0 30 0 30.0 33.0 36.0 39.0 43.0 47.0 51.0 56.0 60 0 60.0 62.0 68.0 75.0 82.0 87.0 91.0 100.0 110 0 110.0 120.0 130.0 140.0 150.0 160.0 170.0 180.0 190.0 200.0 3.14 3.42 3.71 4.09 4.47 4.85 5.32 5.70 5.89 6.46 7.13 7.79 8.27 8.65 9.50 10.45 11.40 12.35 13.30 14.25 15.20 16.15 17.10 18.05 19.00 20.90 22.80 23.75 25.65 26.60 28 0 28.50 31.35 34.20 37.05 40.85 44.65 48.45 53.20 57 00 57.00 58.90 64.60 71.25 77.90 82.65 86.45 95.00 104 50 104.50 114.00 123.50 133.00 142.50 152.00 161.50 171.00 180.50 190.00 3.47 3.78 4.10 4.52 4.94 5.36 5.88 6.30 6.51 7.14 7.88 8.61 9.14 9.56 10.50 11.55 12.60 13.65 14.70 15.75 16.80 17.85 18.90 19.95 21.00 23.10 25.20 26.25 28.35 29.40 31 0 31.50 34.65 37.80 40.95 45.15 49.35 53.55 58.80 63 00 63.00 65.10 71.40 78.75 86.10 91.35 95.55 105.00 115 50 115.50 126.00 136.50 147.00 157.50 168.00 178.50 189.00 199.50 210.00 380 350.0 320.0 290.0 260.0 240.0 220.0 200.0 200.0 175.0 175.0 150.0 150.0 150.0 125.0 125.0 100.0 100.0 100.0 75.0 75.0 70.0 65.0 65.0 65.0 50.0 50.0 50.0 50.0 50.0 40 0 40.0 40.0 30.0 30.0 30.0 25.0 25.0 20.0 20 0 20.0 20.0 20.0 20.0 15.0 15.0 15.0 12.0 12 0 12.0 10.0 10.0 8.0 8.0 8.0 8.0 5.0 5.0 5.0 ZZT MAX.(Ω) @IZT ZZK MAX.(Ω) @IZK 3.0 2.5 2.0 2.0 2.0 1.5 1.0 1.0 1.0 1.0 1.5 1.5 2.0 2.0 2.0 2.5 2.5 2.5 2.5 2.5 2.5 2.5 2.5 3.0 3.0 3.5 3.5 4.0 5.0 6.0 80 8.0 10.0 11.0 14.0 20.0 25.0 27.0 35.0 40 0 40.0 42.0 44.0 45.0 65.0 75.0 75.0 90.0 125 0 125.0 170.0 190.0 230.0 330.0 350.0 380.0 430.0 450.0 480.0 400 500 500 500 450 400 400 300 200 200 200 200 200 150 125 125 125 100 75 75 75 75 75 75 75 75 100 110 120 130 140 150 160 170 190 210 230 280 350 400 500 620 720 760 760 800 1000 1150 1250 1500 1500 1650 1750 1750 1850 1850 Changzhou zhide Electronics CO.,LTD Maximum Reverse Leakage Current Maximum DC Zener Current IZK(mA) IR(uA) @VR VR(V) IZM(mA) 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1 00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1 00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1 00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 300 150 50 10 5 1.0 1.0 1.0 1.0 10.0 10.0 10.0 10.0 7.5 5 5 2 1 1 1 1 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 05 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 05 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 1.0 1.0 1.0 1.0 1.0 1.0 2.0 3.0 3.0 5.2 5.7 6.2 6.6 6.9 7.6 8.4 9.1 9.9 10.6 11.5 12.2 12.9 13.7 14.4 15.2 16.7 18.2 19.0 20.6 21.2 22 8 22.8 25.1 27.4 29.7 32.7 35.8 38.8 42.6 42 5 42.5 47.1 51.7 56.0 62.2 66.0 69.2 76.0 83 6 83.6 91.2 98.8 106.0 114.0 122.0 129.0 137.0 144.0 152.0 1437.0 1317.0 1216.0 1103.0 1009.0 930.0 846.0 790.0 765.0 700.0 630.0 580.0 545.0 520.0 475.0 430.0 395.0 365.0 340.0 315.0 295.0 280.0 265.0 250.0 237.0 216.0 198.0 190.0 176.0 170.0 1 80 158.0 144.0 132.0 122.0 110.0 100.0 93.0 86.0 79 0 79.0 76.0 70.0 63.0 58.0 54.5 52.5 47.5 43 0 43.0 39.5 36.6 34.0 31.6 29.4 28.0 26.4 25.0 23.6 www.cz-zhide.com
SMC5359A 价格&库存
很抱歉,暂时无法提供与“SMC5359A”相匹配的价格&库存,您可以联系我们找货
