140000480509
140000480509
    NIDEC(尼得科)
    9.3MMWIDEWHITEROCKERCAP
140000480509 数据手册
EIGHT SWITCH SERIES 8 Switch Series Selection Table Part No. Name 8H Lever・Rocker Actuator shape Number of poles Switching function Terminal style 338 1・2 S/D 8HD 8M Lever・Rocker (Dust Proof) Small Lever Rocker 1・2 1・2・3・4 Page ON   −   ON ON − OFF − ON (ON) − OFF − (ON) ON   −  (ON) P/C 340 S/D P/C 342 S/D 8V−M Small Lever・Rocker PC 344 1・2 P/C ●S/D : Show Solder terminal. ●P/C : Show PC terminal. Note: For overseas standards, see page 575. (ON) :Momentary. 8 switch series ■ 8 Switch Series Common Specifications Contact specs. Rating Max. Silver Gold plated 125VAC 6A 250VAC 3A 30VAC 4A 20VDC 25mA 10mΩ Max. (2∼4VDC 1A) Initial contact resistance Initial dielectric strength 1000MΩMin.              (500VDC) Initial insulation resistance Altternate type Electrical life AC1500V 1 Minute 50,000 cycles Momentary type Operating temperature range Strage temperature range 25,000 cycles −30∼+85℃ −40∼+85℃ ■Part Numbering 8   H   1  01   1   Actuator shape Series code 20mΩ Max. (200 μVAC 1.5mA) Number of poles Code Type Fig. Number of poles H Lever・Rocker 1 1 pole HD Lever・Rocker 2 2 poles M Small Lever・Rocker 3 3 poles V-M Small Lever・Rocker 4 4 poles Fig. Switching function Switching function 01 ON  ー  ON 02 ON ー OFF ー ON ーOFFー (ON) 04 (ON) 06 ON  ー (ON) Terminal style C - Contact material and plating Fig. Terminal style Code Contact material Plating 1 Solder Terminal None Bs+Ag or Cu+Ag Ag 2 PC Straight C Bs+Ag or Cu+Ag Ni+Au Bs=Brass. Cu=Copper. Ag=Silver. Ni=Nickel. Au=Gold Note : For some products, the part numbers according to the above-stated combinations are not registered yet. Check the Table of Part Numbers for availability. ■PC Hole Layouts ■Terminal Styles Terminal style Solder Terminal (Style : 1) PC Straight (Style : 2) Dimensions Dimensions poles 8V−M/PC Hole Layouts 1-pole (ON) :Momentary. 2-poles Z 8M Small Lever & Rocker Switches UL CSA RoHS Compliant ■Features The 8M Small Lever & Rocker Switch is similar to the 8A type except that 8M type has a mounting plate. Levers and rockers are available in four matted colors that give a sober atmosphere. Choose the suitable one for the panel design. For the mounting method, see the following figure. Mounting Method ■Mounting ■ Standard Accessories Part name 《Supplied separately》 Lever Rocker Matte finish Matte finish Dimensions White Red Black Gray polycarbonate resin polycarbonate resin 140000050427 140000050428 140000050429 140000050450 140000480509 140000480510 140000480511 140000480522 Panel Cut-Out Dimensions ● Specify either one of Lever or Rocker in part number when placing an order. ■Mounting the Lever & Rocker Press the selvage part of the lever/rocker with a screwdriver to fix it. Some products in the Table of UL and CSA-Approved Products are not registered yet. Before placing the order, check with our Sales Department. 8M SPDT Switching function Viewed from rating marking side 9.3 7 ±0.5 22.3 2-Φ2.3 ±1 13.4 定格表示側 ±1 Ratingmarkingside Part No. 0.6 ±1 (1) 13 4.5 4.5 8M1011−Z ON − ON Connecting terminals 2−3 − 2−1 ±1 ±6° ±0.5 23.8 24゚ ±0.5 29.3 0.8 9 (2) (3) 3.5 .5 C1 Mount with Lever 8 ±1 Terminal numbers are not shown on the bottom of the switch. Switching function DPDT 9.3 ±1 10 ±0.5 13.4 ±0.5 8.3 9 ±0.5 定格表示側 ±1 Ratingmarkingside Part No. ±1 8M2011−Z .3 φ2 (1) (4) (2) (5) Connecting terminals ON 2−3 5−6 − − ON 2−1 5−4 13 ±1 4.5 4.5 ±0.5 23.8 13. 4 ±6゚ 24゚ ±0.5 29.3 0.8 7 Viewed from rating marking side (6) (3) 4.8 3.5 12.6 C1.5 13 Mount with Rocker ±1 Terminal numbers are not shown on the bottom of the switch. Switching function 3PDT 9.3 7 ±0.5 22.3 2-Φ2.3 ±1 15.7 定格表示側 ±1 Ratingmarkingside 0.6 Part No. ±1 ☆8M3011−Z (4) (1) Connecting terminals (7) ±1 13 4.5 4.5 ±6° ±0.5 23.8 24゚ ±0.5 29.3 0.8 11.3 Viewed from rating marking side (2) (5) (3) (8) (6) ON 2−3 5−6 8−9 − − ON 2−12 5−4 8−7 (9) 3.5 .5 C1 4.8 4.8 17.8 Mount with Lever ±1 Terminal numbers are not shown on the bottom of the switch. 4PDT Switching function 9.3 10 ±0.5 15.7 Ratingmarkingside ±0.5 8.3 ±0.5 ±1 11.3 Part No. ☆8M4011−Z C1.5 3 (7) (4) (10) ±1 (1) 13 4.5 4.5 13. 4 ±6゚ 24゚ ±0.5 29.3 ±0.5 23.8 φ 2. Viewed from rating marking side 定格表示側 ±1 0.8 7 ±1 (5) (2) (3) (8) (6) (11) (9) (12) Connecting terminals ON 2−3 5−6 8−9 11−12 − − ON 2−1 5−4 8−7 11−10 3.5 12.6 4.8 4.8 4.8 22.6 Mount with Rocker ±1 Terminal numbers are not shown on the bottom of the switch. ●For Soldering Specifications and Flux Cleaning, see page 349. (ON) :Momentary. ☆:Semi-standard products. UL、CSA認定品一覧表 UL and CSA listed (Lever・Rocker Type Only) ■エイトスイッチシリーズ/8Switch Series Poles 1−pole 2−poles (File No.E43275) Switching function 8H 8HD 8M 8V−M 8H 8HD 8M 8V−M ○ ○ ○ ○ ○ ○ ○ 101□ ON − ON ○ 102□ ON − OFF − ON ○ 104□ (ON)− OFF − (ON) ○ ○ ○ 106□ ON − (ON) ○ 201□ ON − ON ○ ○ 202□ ON − OFF − ON ○ ○ 204□ (File No.LR38341) (ON)− OFF − (ON) ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ 206□ ON − (ON) 3−poles 301□ ON − ON ○ ○ 4−poles 401□ ON − ON ○ ○ ○ ○ ○ (1) □ shows the terminal type of 1 : Solder terminal; 2 : PC terminal. (2) Some products in the Table of UL and CSA Listed are not registered yet. Before placing the order, check with our Sales Department. (3) For the registered products, refer to Table of Part Numbers of respective Series products. (4) When the UL and CSA approved products are required, specify UL /CSA approved Product when placing the order. The products will be delivered with the UL or CSA marking. ■Handling Precautions (EIGHT switch series) 1. Soldering Specifications ⑴Soldering Specifications Device : Soldering iron ①420℃, Max.; 3 sec., Max. ⑵Auto Soldering ②275℃ ± 10℃, Max.; 5 seconds, Max. Note that the above-stated soldering conditions should be applied to the PC terminal type only. 3. Mounting ● Do not bend the terminals before mounting the switch on the PC board. ● After mounting the switch, do not place the device in such a way that the device weight will be applied on the knob of the switch. ● To fix the PC terminal type, solder it on the PC board after fixing the switch body on the panel with the screw. 2. Flux Cleaning ⑴For the solvent, use the fluorine- or alcohol-based solvent. Solvent: Fluorine or Alcohol type ⑵Since the 8 Switch Series switches are not waterproof-structured, if the PC board is to be cleaned, clean the soldering surface of substrate with a brush so that the switch is not exposed to the cleaning solution. (ON) :Momentary.
140000480509 价格&库存
很抱歉,暂时无法提供与“140000480509”相匹配的价格&库存,您可以联系我们找货
