BPC-1009
BPC-1009
    BRTLED(佰鸿)
    SOP4-2.54mm
    BPC - 10XX系列是光耦合隔离器,包含一个红外发光二极管和一个NPN硅光电晶体管。引脚间距为2.54mm。
BPC-1009 数据手册
BRIGHT LED ELECTRONICS CORP. BPC-10XX Specification for Approval ● ● SAMPLES  ATTACHED AREA  DEVICE NUMBER:BPC-10XX CUSTOMER: PAGE DATE 2018/4/11 2018/11/10 1 2 3 4 5 1.0 1.0 1.0 1.0 1.0 6 7 1.0 1.0 CONTENTS Initial Released Add UL&VDE&CQC Certificate Number 1.1 FOR CUSTOMER’S APPROVAL STAMP OR SIGNATURE APPROVED PURCHASE 佰鴻工業股份有限公司 MANUFACTURE ISSUED QUALITY APPROVED ENGINEERING PREPARED BRIGHT LED ELECTRONICS CORP. 新北市板橋區和平路 19 號 3 樓 3F., No.19, He Ping Road, Ban Qiao Dist., New Taipei City, Taiwan Tel: +886-2-29591090 Fax: +886-2-29547006/29558809 www.brtled.com 張 郭 2018.11.10 2018.11.10 孝 嚴 初 榮 BRIGHT LED ELECTRONICS CORP. BPC-10XX ● Features: ● Outline Dimensions 1. Current transfer ratio: (CTR:50~600% at IF=5mA, VCE=5V) 2. High input-output isolation voltage (Viso=5,000Vrms) 3. Creepage distance >8mm 4. Long Mini-flat package:2.3mm profile 5. UL/CUL approved:E236324 6. VDE approved:40007240 7. CQC approved:CQC18001204187 8. This product doesn't contain restriction substance,comply RoHS standard ● Description ●NOTES: 1. The BPC-10XX series are optically coupled isolators containing a infrared emitting diode and an NPN silicon phototransistor 2. The lead pitch is 2.54mm ● Applications: 1.XX:CTR Rank 2.YY:Year date code. 3.WW:2-digit work week. 4.V:VDE option 5.All dimensions are in millimeters (inches). 6.Tolerance is ±0.25mm (0.01”) unless otherwise specified. 1. Programmable controllers. 2. System appliances, measuring instruments. 3. Hybrid substrates that require high density mounting 4. Telecommunication equipments 5. Fast charger 6. Electric home appliances, such as fan heaters, etc. 7. Signal transmission between circuits of different potentials and impedances. ●Absolute Maximum Ratings (Ta=25℃) Parameter Forward Current Reverse Voltage Power Dissipation Collector-Emitter Voltage Emitter- Collector Voltage OUTPUT Collector Current Collector Power Dissipation Total Power Dissipation *1 Isolation Voltage Operating Temperature Storage Temperature *2 Soldering Temperature INPUT Symbol Rating Unit IF VR P VCEO VECO IC PC Ptot Viso Topr Tstg Tsol 60 6 100 80 7 50 150 250 5,000 -30 to + 110 -55 to + 125 260 mA V mW V mA mW mW Vrms ℃ *1. AC For minute, R.H. =40~60% Isolation voltage shall be measured using the following method. (1) Short between anode and cathode on the primary side and between collector and emitter on the secondary side. (2) The isolation voltage tester with zero-cross circuit shall be used. (3) The waveform of applied voltage shall be a sine wave. *2. For 10 Seconds Ver.1.1 Page 1 of 7 BRIGHT LED ELECTRONICS CORP. BPC-10XX ●Electro-Optical Characteristics (Ta=25℃) Parameter INPUT Symbol Conditions Forward Voltage VF IF=50mA --- 1.25 1.5 V Reverse Current IR VR=6V --- --- 10 µA Terminal Capacitance Ct V=0, f=1KHz --- 50 --- pF Collector Dark Current ICEO VCE=20V, IF=0 --- --- 100 nA 80 --- --- V 7 --- --- V Collector-Emitter OUTPUT Breakdown Voltage Emitter-Collector Breakdown Voltage IC=0.1mA BVCEO IF=0 IE=100µA BVECO IF=0 MIN. TYP. MAX. Unit Collector Current Ic IF=5mA 2.5 --- 30 mA *1 Current Transfer Ratio CTR VCE=5V 50 --- 600 % --- --- 0.3 V --- Ω Collector-Emitter IF=10mA VCE(sat) IC= 1mA TRANSFER Saturation Voltage CHARACTERIS TICS Isolation Resistance Riso Floating Capacitance Cf V=0, f=1MHz --- 0.6 1 pF Response Time(Rise) tr VCE=2V, IC=2mA --- --- 18 µs Response Time(Fall) tf RL=100Ω --- --- 18 µs DC500V 40~60%R.H. 5×1010 1×1011 *1 CTR= IC / IF × 100% ●RANK TABLE OF CURRENT TRANSFER RATIO(CTR) CTR Rank Min Typ Max BPC-1000 50 - 600 BPC-1007 80 - 160 BPC-1008 130 - 260 BPC-1009 200 - 400 BPC-1002 22 - - BPC-1003 34 - - BPC-1014 56 - - BPC-1002 63 - 125 BPC-1003 100 - 200 BPC-1014 160 - 320 Unit Condition % IF=5mA,VCE=5V % IF=1mA,VCE=5V % IF=10mA,VCE=5V Ver.1.0 Page 2 of2 7of 7 Ver.1.0 Page BRIGHT LED ELECTRONICS CORP. BPC-10XX ●Characteristics Curves Figure2. IF vs VF 50 300 Coupled device Forward Current, IF(mA) Total Power Dissipation, P tot(mW) Figure1. Ptot vs TA 250 200 150 100 Photoransistor IR-diode 50 0 -60 -40 -20 0 20 40 100 80 60 40 110° C -55° C 20 10 0 0.6 120 1 0.8 Ambient Temperature,TA(° C) I F =10mA I F =5mA 0.8 I F=2mA 0.6 I F =1mA 0.4 0.2 -60 -40 -20 0 20 40 60 80 100 1 0.1 0.01 0.001 1 Figure6. Normalized Ic vs.I Normalized to V CE =0.4v,T A=25°C 1.2 IF =10mA I F=5mA 0.6 I F =2mA 0.4 0.2 -60 -40 -20 0 20 Ambient Temperature,T 40 A(°C) 60 IF=1mA 80 100 Normalized Current Tranfer, Ratio,CTR(%) Normalized Current Transfer Ratio ,CTR 1.6 0.8 100 10 Forward Current,I F(mA) Figure5. Non-Saturated Normalized CTR vs. TA 1 1.8 Normalized to 10 VCE=5V,IF=5mA TA=25°C Ambient Temperature,TA(° C) 1.4 1.6 100 Normalized Collector Current, I C(mA) Normalized Current Transfer Ratio ,CTR 1.2 1 1.4 Figure4. Normalized Ic vs.IF Normalized to VCE =0.4v,T A=25°C 1.4 1.2 Forward Voltage,V F (V) Figure3. Saturated Normalized CTR vs. TA 1.6 25° C 30 10 1 F Normalized to V CE=5V,I F =5mA TA =25°C 0.1 0.01 0.1 1 10 100 Forward Current,IF(mA) Ver.1.0 Page 3 of 7 BRIGHT LED ELECTRONICS CORP. BPC-10XX Figure8. TON/TOFF vs. IF Turn on/off Time, TON/TOFF(£g S) Collector Dark Current,ICEO(nA) Figure7.ICEO vs. TA 100000 10000 VCE=40V 1000 VCE=20V 100 10 1 20 40 60 80 100 24 Saturated Operation Vs=5V,RL=1K£ [ 20 TOFF 16 8 4 TON 0 120 0 Ambient Temperature,TA(°C) 16 12 Figure10.Frequency Response 0 1000 Voltage Gain Av(dB) IF=50mA IF=20mA 100 IF=10mA IF=5mA 1 IF=2mA 0.1 0.1 20 Foward Current,IF(mA) Figure9.IC vs. VCE Collector Current, IC(mA) 4 IF=1mA VCE=40V,IC=2mA TA=25° C 1K ohm -12 100ohm -20 10 1 1 Collector Emitter Voltage,VCE(V) 10 100 1000 Frequency(kHz) Turn on/off time,TON/TOFF(us) Figure11.TON/TOFF vs. IC 8 Non Saturated Operation VS=5V,RL=100? 2 0 0 12 20 Collector Current, IC(mA) Ver.1.0 Page 5 4 of 8 7 BRIGHT LED ELECTRONICS CORP. BPC-10XX ● Reliability Test Classification Test Item Reference Standard MIL-STD-750:1026 MIL-STD-883:1005 JIS C 7021 :B-1 Operation Life Endurance Test High Temperature High Humidity Reverse Bias (H3TRB) High Temperature Reverse Bias (HTRB) High Temperature Storage Low Temperature Storage Autoclave JIS C 7021 :B-11 JIS C 7021 :B- 8 MIL-STD-883:1008 JIS C 7021 :B-10 JIS-C-7021 :B-12 JESD 22-A102-B MIL-STD-202:107D Temperature MIL-STD-750:1051 Cycling MIL-STD-883:1010 JIS C 7021 :A-4 MIL-STD-202:107D Environmental Thermal Shock MIL-STD-750:1051 Test MIL-STD-883:1011 MIL-STD-202:201A Solder Resistance MIL-STD-750:2031 JIS C 7021 :A-1 MIL-S-883:2003 Solder Ability JIS C 7021 :A-2 Test Conditions Result Connect with a power If=50mA Ta=Under room temperature Test time=1,000hrs Ta=+85℃±5℃, RH=85% PTR=VCE absolute max rating*80% Test time=1000hrs Ta=+105℃±5℃ PTR=VCE absolute max rating Test time=1000hrs High Ta=+125℃±5℃ Test time=1,000hrs Low Ta=-55℃±5℃ Test time=1,000hrs P=15PSIG, Ta=121℃ Humi. =100%RH, 48hrs 125℃ ~ 25℃ ~ -55℃ ~ 30min 5min 30min Test Time=20cycle 25℃ 5min 0/20 0/20 0/20 0/20 0/20 0/20 0/20 125℃ ~-55℃ 20min 20min Test Time=20cycle 0/20 Operation heating: 260℃, within 10±1seconds. 0/20 Operation heating: 235℃, within 5±1seconds. 0/20 ●Judgment Criteria Of Failure For The Reliability Symbol Measuring conditions Judgment criteria for failure VF (V) IF=20mA Over Ux1.0 Ir(uA) Vr=6V Over Ux1.0 CTR(%) IF=5mA, VCE=5V Shift>1.2 VCE(sat) IF=20mA, IC= 1mA Over Ux1.0 BVCEO IC=0.1mA, IF=0 Over Lx1.0 BVECO IE=10µA, IF=0 Over Lx1.0 Ver.1.0 Page 5 of 7 BRIGHT LED ELECTRONICS CORP. BPC-10XX ● Packaging Box Dimensions (Units: mm) 2.00 B 1.55±0.05 2.4 .1 A A B 0.2 8.00 +0 7.50 4.00 . 50 ?1 16.00±0.3 1.75 z Packaging Tube Dimensions Ver.1.0 Page 67 of of 77 Ver.1.0 Page BRIGHT LED ELECTRONICS CORP. BPC-10XX Inner box 340 (13 .38 5)± 3.0 3.0 ± ) 4 .46 3 1 ( 342 Carton ( 353 8 13. ±3 98) .0 " C/ NO K1 363 C" (14 .29 1)± : N O: DVC Y: O 'T N BPC 3.0 7V S - 81 P CS KG : .W . G KG : .W. ME AS :3 6 3 3* 53 *3 65 mm 365(14.370)±3.0 ● 30(1.181)±3.0 ● Notes: 1、3000 PCS per reel, 10reels per Carton. 2、All dimensions are in millimeters (inches). 3. Tolerance is ±0.10mm (0.004’’) unless otherwise specified. 4、Specifications are subject to change without notice. Ver.1.0 Page 7 of 7
BPC-1009 价格&库存
很抱歉,暂时无法提供与“BPC-1009”相匹配的价格&库存,您可以联系我们找货
