WAS4729QB-10/TR
WAS4729QB-10/TR
    WILLSEMI(韦尔)
    QFN-10(1.4x1.8)
    WAS4729QB是一款高性能双单刀双掷(SPDT)模拟开关,具备负摆幅音频能力,在3.6V VCC电压下典型导通电阻(Ron)超低,仅为0.8Ω。WAS4729QB的VCC工作电压范围宽广,为2.3...
WAS4729QB-10/TR 数据手册
WAS4729QB WAS4729QB Low On Resistance (0.8Ω) Dual SPDT Analog Switch with Negative Swing Audio Capability Http//:www.sh-willsemi.com Descriptions The WAS4729QB is a high performance, dual Single Pole Double Throw (SPDT) analog switch with negative swing audio capability that features ultra-low Ron of 0.8Ω (typical) at 3.6V VCC. The WAS4729QB QFN1418-10L operates over a wide VCC range of 2.3V to 5.5V and is designed for break-before-make operation. The select input is TTL-level compatible. WAS4729QB is also featured with smart circuitry to minimize VCC leakage current even when the control voltage is lower than VCC supply voltage. This feature suits mobile handset applications by allowing direct WAS4729QB interface with baseband processor general-purpose IO with minimal battery consumption. In other word, there QB is no need of additional device to shift control level to * = Month (A~Z) be the same as that of VCC in real application. Marking The WAS4729QB is available in QFN1418-10L package. Standard product is Pb-Free = Device code and halogen-Free. Order information Features  Supply voltage : 2.3 ~ 5.5V  ultra-low On Resistance : 0.8Ω  High Off isolation : -81dB @ 1KHz  Crosstalk Rejection : -83dB @ 1KHz  -3dB Bandwidth : 80MHz  Rail-to-Rail Signal Range  Break-Before-Make Switching  HBM JEDEC: JESD22-A114  IO to GND : ±8KV  Power to GND : ±5KV @ 3.6V Device Package Shipping WAS4729QB-10/TR QFN1418-10L 3000/Reel&Tape Applications  Cell phones, PDA, Digital Camera and Notebook  LCD Monitor, TV and Set-Top Box  Audio and Video Signal Routing Will Semiconductor Ltd. 1 Jan, 2018 - Rev. 1.1 WAS4729QB Pin configuration (Top view) IN2 8 COM2 9 NO2 10 NC2 GND 7 6 1 2 VCC NO1 5 NC1 4 IN1 3 COM1 WAS4729QB Pin descriptions Pin Number Symbol Descriptions 2,10 NOX Data Port(Normally open) 6 GND Ground 5,7 NCX Data Port(Normally closed) 3,9 COMX 1 VCC 4,8 INX Common Data Port Positive Power Supply Logic Control Function descriptions Logic Input(INX) Function 0 NCX Connected to COMX 1 NOX Connected to COMX Note: X=1 or 2 Functional Block Diagram Will Semiconductor Ltd. 2 Jan, 2018 - Rev. 1.1 WAS4729QB Application Block Diagram WAS4729 Note: WAS4729 switches feature negative signal capability that allows signals below ground to pass through without distortion. These analog switches operate from a signal +2.3V to 5.5V supply. The input/output signal swing of device is dependent of the supply voltage V+: the device pass signals as high as V+ and as low as V+ - 6.5, including signals below ground with minimal distortion. Table 1 shows the input/output signal swing the user can get with different supply voltages. Min. Max. (VNC, VNO, VCOM) = V+ - 6.5V (VNC, VNO, VCOM) = V+ 5.5V -1.0 V 5.5 V 5.0V -1.5 V 5.0 V 4.5V -2.0 V 4.5 V 4.0V -2.5 V 4.0 V 3.5V -3.0 V 3.5 V 3.0V -3.5 V 3.0 V 2.5V -4.0 V 2.5 V SUPPLY VOLTAGE, V+ Will Semiconductor Ltd. 3 Jan, 2018 - Rev. 1.1 WAS4729QB Absolute Maximum Ratings (1) Parameter Symbol Value Unit Supply Voltage VCC -0.3 ~ 6.5 V Control Input Voltage VINX -0.3 ~ 5.5 V Continuous Current NO_NC_COM_ ±300 mA Peak Current NO_NC_COM_ (pulsed at 1ms 50% duty cycle) ±400 mA Peak Current NO_NC_COM_ (pulsed at 1ms 10% duty cycle) ±500 mA Storage Temperature Range Junction Temperature under Bias TSTG -55 ~ 150 o TJ 150 o C C Lead Temperature (Soldering, 10 seconds) TL 260 oC Power Dissipation PD 250 mW Symbol Value Unit Supply Voltage Operating VCC 2.3 ~ 5.5 V Control Input Voltage VIN 0.0 ~ VCC V Input Signal Voltage VIS 0.0 ~ 5.5 Operating Temperature TA -40 ~ 85 Input Raise and Fall Time(Control Input VCC=2.3~3.6V) tr,tf 0 ~ 10 RθJA 350 Recommend operating ratings (3) Parameter Thermal Resistance V C o ns/V C/W o Note: 1. “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions beyond those indicated in the operational sections of this specification is not implied. 2. The input and output negative voltage ratings may be exceeded if the input and output diode current ratings are observed. 3. Control input must be held high or Low, it must not float. Will Semiconductor Ltd. 4 Jan, 2018 - Rev. 1.1 WAS4729QB DC Electronics Characteristics (Ta=25oC, VCC=3.6V, unless otherwise noted) Parameter Symbol Input logic high level VIH Input logic low level VIL Supply quiescent current ICC Increase in ICC per input ICCT Input leakage current IIN Conditions Min. Typ. Max. Unit VCC: 3.0 ~ 4.5 1.6 V VCC: 2.3 ~ 3.0 1.4 V VCC: 3.0 ~ 4.5 0.6 V VCC: 2.3 ~ 3.0 0.4 V IOUT=0, VIN =0 or VIN =VCC 1.0 uA 2.0 uA ±1.0 uA IOUT=0, VCC=4.5 VIN>1.8 or VIN
WAS4729QB-10/TR 价格&库存
很抱歉,暂时无法提供与“WAS4729QB-10/TR”相匹配的价格&库存,您可以联系我们找货
