MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
NHA Series
Solventproof
• 1 0 5℃ 1 , 0 0 0 ~ 2 , 0 0 0 H r s a s s u r e d .
WV≦100VDC
•For Digital Household Appliance.
•RoHS compliant.
•Halogen-free capacitors are also available.
NHA
KMG
Downsized
SPECIFICATIONS
Item
Characteristics
Rated Voltage Range
6.3
Operating Temperature Range
160
100 VDC
-55 ~ +105℃
Capacitance Tolerance
400 VDC
450
(at 20℃, 120Hz)
After 1 minute
CV≦1,000
CV›1,000
0.1CV+40 0.04CV+100
After 2 minutes:I=0.01CV(μA) or 3μA, whichever is greater.
After 5 minutes
CV≦1,000
CV›1,000
0.03CV+15 0.02CV+25
Where, I:Max. Leakage current(μA), C:Nominal capacitance(μ
F), V:Rated voltage(VDC)
Dissipation Factor (Tanδ)
(at 20℃)
Rated Voltage(VDC)
6.3
10
16
25
35
50
63
100
160~250
350~500
Tanδ(Max.)
0.34
0.24
0.20
0.16
0.14
0.12
0.10
0.09
0.20
0.24
When the capacitance exceeds 1,000㎌, 0.02 shall be added every 1,000㎌ increase.
Temperature Characteristics
(Max . Impedance ratio)
500 VDC
-25 ~ +105℃
±20% (M)
After 1 minute:I=0.03CV(μA) or 4μA, whichever is greater.
Leakage Current
-40 ~ +105℃
Rated Voltage(V DC )
6.3
10
16
25
35
50
Z(-25℃)/Z(20℃)
Z(-40℃)/Z(20℃)
5
12
4
10
3
8
2
5
2
4
2
3
(at 20℃, 120Hz)
63~100 160 200~400 450~500
3
4
3
5
6
6
6
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated
voltage is applied for 2,000 hours at 105℃.(where, 1,000 hours ≤ Ø8)
Load Life
Shelf Life
Capacitance change ≦ ±20% of the initial value
Tanδ
≦ 200% of the initial specified value
Leakage current
≦ The initial specified value
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing
them for 1,000 hours at 105℃ without voltage applied.(where, 500 hours ≤ Ø8)
The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not
more than 48 hours before the measurements.
Tan δ
Leakage current
≦ The initial specified value (where, 200% for ≧ WV 160 VDC)
Others
Satisfied characteristics KS C IEC 60384-4
DIMENSIONS OF NHA Series
Unit(mm)
Marking : BROWN SLEEVE, WHITE INK
ØD
18
10 12.5 16
8
6.3
5
Ød 0.5 0.5 0.6 0.6 0.6 0.8 0.8
F
2.0 2.5 3.5 5.0 5.0 7.5 7.5
ØD′
ØD+0.5 max.
L′
L+1.5 max.
L+2.0 max.
100
22
0.8
10.0
RATINGS OF NHA Series
μF
VDC
6.3
10
16
50
63
100
1
5×11
13
5×11
15
5×11
16
2.2
5×11
18
5×11
19
5×11
21
3.3
5×11
30
5×11
33
5×11
34
6.3×11
35
35
5×11
35
5×11
53
5×11
60
6.3×11
146
68
5×11
69
5×11
83
5×11
92
5×11
113
5×11
122
6.3×11
138
6.3×11
156
8×11.5
207
4,700
6,800
15,000
5 x 11
141
6.3× 11
159
5×11
6.3×11
5×11
6.3×11
153
238
170
213
6.3× 11
6.3×11 6.3×11
293
6.3×11
216
8×11.5
239
265
340
8×11.5
6.3×11 6.3×11 8×11.5
406
258
8×15
286
366
447
8×11.5
8×11.5 8×11.5
10×16
413
365
620
405
8×15
455
8×11.5
10×16
8×15
10×16
443
756
542
680
10×16
10×20 12.5×16 12.5×20
772
1,188
886
1,019
10×20 12.5×20 12.5×20 16×20
1,032
1,535
1,205
1,275
12.5×20 12.5×25 16×20
16×25
1,280
1,865
1,492
1,610
12.5×25 16×20 16 ×25 18×31.5
1,554
2,374
1,699
1,929
16×25 16×31.5 18×31.5 18×35.5
1,897
2,649
2,082
2,365
16×31.5
2,297
5×11
125
6.3×11
168
8×11.5
294
8×11
360
8×15
398
10×20
202
6.3×11
27
12.5 ×16 12.5×20
206
218
10×12.5 12.5×16 12.5×20
252
265
239
16×20
300
6.3×11
28
8×11.5
29
6.3×11
38
8×11.5
38
16×20
246
16×25
322
8×11.5
216
16×25 16×35.5
10×16 12.5×25 16×20
8×11.5
360
10 ×12.5
366
405
321
447
229
251
10×12.5 10×16 12.5×20 16×25 16×31.5 18×35.5 22×45
656
474
684
719
572
780
395
18×31.5 18×35.5
848
866
10×16
529
10×20
633
16×20
810
10×20
690
12.5×20
886
16×25
1,072
22×35
1,130
12.5×16 12.5×20 12.5×25
973
1,160
777
16×31.5
1,364
22×45
1,463
12.5×16 12.5×25 16×25
1,287
1,565
940
16×20 16×31.5 18×35.5
1,724
1,938
1,394
16×31.5 18 ×31.5
2,190
1,808
18×31.5
2,262
18×40
2,642
18×35.5
1,987
10×16
547
6.3×11
28
8×11.5
30
8×11
39
6.3×11 6.3×11
10×12.5
36
37
41
8×11.5
6.3×11
46
6.3×11
44
8×11.5
10 ×12.5
43
8×11.5
45
48
45
8×11.5 8×11.5 10×12.5 10×12.5
59
54
56
58
10×16
8×11.5 10×12.5 10×16
79
62
67
73
10 ×12.5 10×16 12.5×16 10×25
157
102
117
138
10 ×16 12.5×16 12.5×25 16×20
210
145
169
189
6.3×11
24
16×25
280
500
6.3×11
22
8×11.5
8×11.5
22
25
8×11
30
10×12.5
10×12.5
29
35
10×12.5 10×12.5
38
36
10×16
10×16
54
50
10×16 12.5×16
70
66
12.5×20 16×20
125
123
12.5×30 16×25
189
165
16×25
222
18×25
188
16×31.5 18×31.5
376
338
18×35.5
453
22×30
414
22×35
880
22×40
1,156
NHA
10,000
6.3×11
14
8×11.5
52
8×11.5
60
10×12.5
101
10×16
143
6.3×11
133
3,300
6.3×11
19
5×11
49
5×11
59
6.3×11
100
8×11.5
144
8×11.5
171
8×15
189
5×11
101
2,200
6.3×11
18
5×11
48
5×11
59
5×11
87
6.3×11
122
5×11
80
1,000
5×11
15
6.3×11
17
5×11
44
5×11
54
5×11
79
5×11
97
5×11
77
680
5×11
13
6.3×11
15
5×11
33
5×11
40
5×11
67
5×11
80
5×11
66
470
5×11
12
6.3×11
14
5×11
17
6.3×11
5×11
31
5×11
37
5×11
56
5×11
75
5×11
61
330
450
6.3×11
41
47
220
400
5×11
40
5×11
52
5×11
100
350
5×11
39
33
5×11
90
250
5×11
37
5×11
48
5×11
56
100
200
5×11
27
6.8
22
160
5×11
25
4.7
10
25
Case Size ØD×L(mm)
Rated Ripple Current(mArms/105℃, 120Hz)
Series
RATED RIPPLE CURRENT MULTIPLIERS
Frequency Multipliers
Freq.(Hz)
Cap.(㎌)
1~6.8
10~68
100~1,000
2,200~15,000
60
120
300
1k
10k~
0.65
0.75
0.80
0.85
1.00
1.00
1.00
1.00
1.35
1.25
1.15
1.03
1.75
1.50
1.30
1.05
2.30
1.75
1.40
1.08
SMT Products are available upon request.
Please check with us about individual characteristics.
101
