SMBJ3.3A
SMBJ3.3A
    JKSEMI(金开盛)
    SMB
    SMBJ3.3A
SMBJ3.3A 数据手册
SMBJ3.3A 600W Transient Voltage Suppressor Rev.2 FEATURES:        Planar technology. Halogen-free and ROHS compliant. Stand-off voltage:3.3V. 600W peak pulse power capability at 10×1000μs waveform. Excellent clamping capability. Fast response time. SMB  Symbol ABSOLUTE MAXIMUM RATINGS (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Symbol Value Unit TSTG/TJ -55 to +150 ℃ PM(AV) 5.0 W PPP 600 W Storage operating junction temperature range Steady state power dissipation at TL=75℃ Peak pulse power dissipation on 10/1000μs waveform MARKING 1409 U03A : Device Marking Code 1409: In ninth week, 2014 U03A ELECTRICAL CHARACTERISTICS (TA=25℃) ① Part Number VR IR@VR VBR@IT IT VC@IPP IPP① CO② V μA V (min) mA V (max) A (max) pF(typ.) SMBJ3.3A 3.3 100 4.1 1 7.3 82.5 4100 Marking U03A Surge waveform: 10/1000μs ② CO is measured at: Vbias=0V,VRMS=1V,f=1MHz VR: Stand-off voltage -- Maximum voltage that can be applied VBR: Breakdown voltage VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP IR: Reverse leakage current - 1 / 4 - www.jksemi.com 600W /SMBJ3.3A ORDERING INFORMATION  RATINGS AND V‐I CHARACTERISTICS CURVES (TA=25ºC, unless otherwise noted) FIG.1:V- I curve characteristics (Uni-directional) IF FIG.2: Pulse waveform IPPM(%IRSM) 150 I tr=10μs 100 V C V BR V R tr = rise time to peak value td = decay time to half value Peak value V Half value I RV F IT 50 IPP 0 0 td 1.0 t(ms) 2.0 3.0 4.0 FIG.3: Pulse derating curve P PP derating in percentage(%) 100 80 60 40 20 0 0 25 50 T A (℃ ) 75 100 125 150 175 - 2 / 4 - www.jksemi.com 600W /SMBJ3.3A SOLDERING PARAMETERS Pb-Free assembly (see figure at right) Pre Heat -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquidus Temp (TL)to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow Reflow condition tp TP Critical Zone TL to TP Ramp-up TL -Temperature(TL)(Liquidus) +217℃ -Temperature(tL) 60-150 secs. tL TS(max) Temperature Reflow Condition Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃of actual Peak Temp (tp) 20-40secs. Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Ramp-down Preheat TS(min) 25 ts time to peak temperatue (t 25℃ to peak) Time PACKAGE MECHANICAL DATA  B Dimensions H F A C Ref. D K J L J G E Millimeters Min. Max. Min. Max. A 3.30 3.94 0.130 0.155 B 4.30 4.80 0.169 0.189 C 1.90 2.20 0.075 0.087 D 0.95 1.52 0.037 0.060 E 5.20 5.60 0.205 0.220 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.10 2.40 0.083 0.094 J 2.20 L - 3 / 4 - 0.087 2.60 K DO-214AA (SMB) Inches 2.30 0.102 0.091 www.jksemi.com 600W /SMBJ3.3A TAPE AND REEL SPECIFICATION‐SMB P0 P2 Cathode Ref. B0 W F E D0 A0 P1 Dimensions Millimeters Inches A0 3.76 ± 0.3 0.148 ± 0.012 B0 5.69± 0.3 0.224 ± 0.012 C 330.0 13.0 D0 1.55 ± 0.1 0.061 ± 0.004 E 1.75 ± 0.2 0.069 ± 0.008 E1 13.3 ± 0.3 0.524± 0.012 0.217 ± 0.008 F 5.5 ± 0.2 P0 4.00 ± 0.2 0.157 ± 0.008 P1 8.00 ± 0.2 0.3145 ± 0.008 P2 2.00 ± 0.2 0.079 ± 0.008 W 12.0± 0.2 0.472 ± 0.008 W1 15.7 ± 2.0 0.618 ± 0.079 OUTLINE UNIT WEIGHT (g/PCS) typ. REEL (PCS) PER CARTON (PCS) REEL DIAMETERS (mm) SMBJ3.3A 0.098 3,000 48,000 330 - 4 / 4 - www.jksemi.com
SMBJ3.3A 价格&库存
很抱歉,暂时无法提供与“SMBJ3.3A”相匹配的价格&库存,您可以联系我们找货
