Plastic-Encapsulate Diodes
BAV19WS - BAV21WS
Features
Fast Switching Speed
Surface Mount Package Ideally Suited for
Automatic Insertion
For General Purpose Switching Applications
High Conductance
Mechanical Data
Case: SOD-323, Molded Plastic
Case material - UL Flammability Rating
Classification 94V-0
Moisture Sensitivity: Level 1 per J-STD-020A
Terminals: Solderable per MIL-STD-202,
Method 208
Terminal Connections: Cathode Band, See
Page 2
BAV19WS Marking: A8 or T2 or T3
BAV20WS Marking: T2 or T3
BAV21WS Marking: T3
Weight: 0.004 grams (approx.)
SOT-323
Maximum Ratings @ TA = 25°C unless otherwise specified
Symbol
BAV19WS
BAV20WS
BAV21WS
Unit
Repetitive Peak Reverse Voltage
Characteristic
VRRM
120
200
250
V
Working Peak Reverse Voltage
DC Blocking Voltage
VRWM
VR
100
150
200
V
VR(RMS)
71
106
141
RMS Reverse Voltage
V
Forward Continuous Current (Note 1)
IFM
400
mA
Average Rectified Output Current (Note 1)
IO
200
mA
Non-Repetitive Peak Forward Surge Current @ t = 1.0ms
@ t = 1.0s
IFSM
2.5
0.5
A
IFRM
625
mA
Pd
200
mW
RqJA
625
°C/W
Tj , TSTG
-65 to +150
°C
Power Dissipation
Thermal Resistance Junction to Ambient Air (Note 1)
Operating and Storage Temperature Range
Electrical Characteristics @ TA = 25°C unless otherwise specified
Characteristic
Symbol
Min
Max
Unit
V(BR)R
120
200
250
¾
V
IR = 100mA
Forward Voltage (Note 2)
VFM
¾
1.0
1.25
V
IF = 100mA
IF = 200mA
Peak Reverse Current
@ Rated DC Blocking Voltage (Note 2)
IRM
¾
100
15
NA
mA
Tj = 25°C
Tj = 100°C
Total Capacitance
Ct
¾
5.0
pF
VR = 0, f = 1.0MHz
Reverse Recovery Time
trr
¾
50
ns
IF = IR = 30mA,
Irr = 0.1 x IR, RL = 100W
Reverse Breakdown Voltage (Note 2)
Note:
BAV19WS
BAV20WS
BAV21WS
Test Condition
1. Part mounted on FR-4 PC board with recommended pad layout, which can be found on our website at
http://www.diodes.com/datasheets/ap02001.pdf.
2. Short duration pulse test used to minimize self-heating effect.
GUANGDONG HOTTECH
INDUSTRIAL CO., LTD
Page:P2-P1
IF, INSTANTANEOUS FORWARD CURRENT (mA)
BAV19WS - BAV21WS
PD, POWER DISSIPATION (mW)
300
200
100
50
75
100
125
150
TA, AMBIENT TEMPERATURE (°C)
Fig. 1 Power Dissipation vs Ambient Temperature
1000
Tj = 25°C
100
10
1.0
0.1
0.01
2
VF, INSTANTANEOUS FORWARD VOLTAGE (V)
Fig. 2 Forward Characteristics
IR, LEAKAGE CURRENT (µA)
100
10
1
0.1
0.01
200
Tj, JUNCTION TEMPERATURE (°C)
Fig. 3 Leakage Current vs Junction Temperature
GUANGDONG HOTTECH
INDUSTRIAL CO., LTD
Page:P2-P2
很抱歉,暂时无法提供与“BAV21WS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.15840
- 200+0.05247
- 1500+0.03278
- 3000+0.02596
- 国内价格
- 1+0.09364
- 10+0.07442
- 30+0.06372
- 100+0.05735
- 500+0.05174
- 1000+0.04882
