B4012AP422-003
B4012AP422-003
    GOERTEK(歌尔)
    DIP-2_D4X1.2MM_TM
B4012AP422-003 数据手册
Specification of Electret Condenser Microphone (RoHS Compliance&Halogen-Free) Customer Name : Foster Customer Model : 557570 GoerTek Model : B4012AP422-003 GoerTek DESIGN Arthur Apr.17 2012 CHECK Dave Apr.17 2012 STANDARD Aimee Apr.17 2012 APPROVAL Worden Apr.17 2012 10644 ISO/TS16949:2002 013 013 2551 2728 ISO14001:2004 ISO9001:2000 Version :1.0 CUSTOMER APPROVAL Tel : + 86 536 8525155 Fax : + 86 536 8525000 E- Mail : goertek@goertek.com Website: http://www.goertek.com Address: No.268 Dongfang Road, High-Tech Industry Development District, Weifang, Shandong, P.R.C. have sound, will travel page 1/10 Restricted 1 Security warning 1.1 1.2 The information contained in this document is the exclusive property of GoerTek Inc. and should not be disclosed to any third party without the written consent of GoerTek Inc. This product and all of it's part are ROHS Compliance and observe halogen free and Sb 2O3 free. 2 Publication history Version Modified P/O No. Date Description Design Approval 1.0 / 2012.04.17 New Design Arthur Worden have sound, will travel page 2/10 Contents 1 Test Condition 4 2 Electrical Characteristics 4 3 Frequency Response Curve and Limits 4 4 Measurement Circuit 5 5 Test setup Drawing 5 6 Mechanical Characteristics 6 6.1 Appearance Drawing 6 6.2 Weight 6 7 Soldering 7.1 Jig for soldering 7 7 7.2 Cautions 7 8 Reliability Test 8 8.1 Vibration Test 8 8.2 Drop Test 8 8.3 High Temperature Test 8 8.4 Low Temperature Test 8 8.5 Humidity Test 8 8.6 Soldering Heat Shock 8 8.7 Temperature Shock Test 8 8.8 ESD Shock Test 8 9 Packing 9 9.1 Packing Specification 9 9.2 Packing Explain 10 10 Stock and Transportation 10 10.1 Stock 10 10.2 Transportation 10 10.3 Storage Temperature Range 10 10.4 Operating Temperature Range 10 11 Output Inspection standard 10 have sound, will travel page 3/10 PRODUCT SPECIFICATIONS Type : Model: Electret Condenser Microphone B4012AP422-003 1 Test Condition (Vs=2.1V , R L=2.21kΩ, L=50cm) Standard Conditions (Re. IEC 60268-4) Temperature Environment Conditions +15 ℃~+35℃ 25 %RH~75%RH 86kPa ~106kPa Judgement Conditions +20℃±2 ℃ 60 %RH ~70%RH 86kPa ~106kPa Air pressure Humidity 2 Electrical Characteristics Symbol Test Conditions Min Typ Max Unit S f=1kHz, Pin=1Pa -44 -42 -40 dB 0dB=1V/Pa Output Impedance Zout f=1kHz, Pin=1Pa 2.2k Ω Directivity D(θ) Omnidirectional Item Sensitivity Current Consumption I S/N Ratio S/N(A) Decreasing Voltage Characteristic Operating Voltage Range S dB Vs=2.1V , RL=2.21kΩ f=1kHz, Pin=1Pa 100 260 µA 58 A-Weighted Curve dB f=1kHz, Pin=1Pa Vs=2.0-- 1.5V Vs 1.1 Input SPL 3 dB 10 V 120 dB 3 Frequency Response Curve and Limits Frequency Response Relative Response (dB) +15 +10 +5 +3 +3 +8 +8 -3 -3 +8 +3 +3 0 -5 -10 -6 -3 -3 -3 -8 -15 -20 100 200 500 1k 1.1k Frequency (Hz) have sound, will travel 3k 5k 10k page 4/10 4 Measurement Circuit Term.1 FET RL=2.21K Vs + 2.1V + 390 Ω OUTPUT C=1µF 10 nF Term.2 GND Circuit of the microphone 5 Test Setup Drawing Power Amplifier Free-field 1/2" Microphone Audio Analyzer 50cm Speaker MIC Input Output Power&Load Remote Control Turn Table Anechoic Room have sound, will travel page 5/10 6 Mechanical Characteristics 6.1 Appearance Drawing (Unit: mm) Ø3.5±0.1 Filter 1.5±0.1 1.2±0.1 Ø4.0±0.1 0.15±0.05 2-Ø0.3±0.05 1.4±0.1 0.45±0.1 Term1.Output 03 Term2.Ground 6.2 Weight Less than 0.2g. have sound, will travel page 6/10 7 Soldering 7.1 Jig for soldering (Unit: mm) Jig for soldering Copper or aluminum or its alloys MIC insert hole Shape of the individual hole 7.2 Cautions 7.2.1 We use antistatic welding machine which can control soldering temperature automatically during soldering process. 7.2.2 The temperature of the high-frequency electric welding machine is set at 310 ℃ and welding time less than 2 seconds. 7.2.3 ECM should be fixed on the soldering jig which has higher heat radiation effects during soldering process. 7.2.4 ECM may be destroyed by static electricity easily, so the measures for eliminating static electricity should be executed. 7.2.5 Don't do the X-ray inspection on ECM after being assembled on the main board. 7.2.6 Don't do the cleaning process with any kind of volatile solvent (Acetone, TCE, alcohol, etc.,), water, or detergent. Any dust or particle got into ECM can reduce the sensitivity of the microphone. 7.2.7 Process conditions may affect the acoustic characteristics. 7.2.8 Wave soldering conditions may affect the acoustic characteristics. have sound, will travel page 7/10 8 Reliability Test 8.1 Vibration Test 8.2 Drop Test To be no interference in operation after vibrations,10Hz to 55 Hz for 1 minute full amplitude 1.52mm,for 2 hours at three axises in state of standard packing,sensitivity to be within ±3dB from initial sensitivity. (The measurement to be done after 2 hours of conditioning at +15 ℃~+35℃, R.H 25% ~75%) To be no interference in operation after dropped to concrete floor 6 time from 1 meter height in state of Outer packing,sensitivity to be within ±3dB from initial sensitivity. (The measurement to be done after 2 hours of conditioning at +15 ℃~+35℃, R.H 25% ~75%) 8.3 After exposure at +85°C for 200 hours, sensitivity to be within ±3dB from initial sensitivity. High Temperature (The measurement to be done after 2 hours of conditioning at +15 ℃~+35℃, R.H 25%~75%) Test 8.4 Low After exposure at -40°C for 200 hours, sensitivity to be within ±3dB from initial sensitivity. Temperature (The measurement to be done after 2 hours of conditioning at +15 ℃~+35℃, R.H 25%~75%) Test 8.5 Humidity Test After exposure at +50℃ and 95% relative humidity for 120 hours,sensitivity to be within ±3dB from initial sensitivity. (The measurement to be done after 2 hours of conditioning at +15 ℃~+35℃, R.H 25% ~75%) 8.6 After exposure at -25℃ for 30 minutes, at 20℃ for 10 minutes, at+70℃ for 30 minutes,at Temperature 20℃ for 10 minutes,5 cycles,sensitivity to be within ±3dB from initial sensitivity. (The measurement to be done after 2 hours of conditioning at +15 ℃~+35℃, R.H 25% ~75%) Cycle Test 8.7 After exposure at -25℃ for 60 minutes, at+70℃ for 60 minutes(change time 20 seconds), Temperature 32 cycles,sensitivity to be within ±3dB from initial sensitivity. Shock Test (The measurement to be done after 2 hours of conditioning at +15 ℃~+35℃, R.H 25% ~75%) 8.8 ESD Shock Test The microphone under test must be discharged between each ESD exposure without ground. (contact:±8kV,air:±15kV) There is no interference in operation after 10 times exposure. have sound, will travel page 8/10 9 Packing 9.1 Packing Specification Drawing(Unit: mm) Qty(pcs.) Material Marking 57 100 Plastic Lid 60 67 100 Plastic Tray Packing 70 60 Middle Box 0 14 20×100 Paper Particular for Customer's P.O 30×2000 Paper Particular for Customer's P.O 45 0 45 Outer Box 180 230 have sound, will travel page 9/10 9.2 Packing explain The Middle Box labeling Customer packaging requirement 10 Stock and Transportation 10.1 Keep ECM in warehouse with less than 75% humidity and without sudden temperature change, acid air, any other harmful air or strong magnetic field. 10.2 The ECM with normal pack can be transported by ordinary conveyances.Please protect products against moist, shock, sunburn and pressure during transportation. 10.3 Storage Temperature Range :-25 ℃~+70 ℃ 10.4 Operating Temperature Range :-25 ℃~+70 ℃ 11 Output Inspection standard Output inspection standard is excuted according to 《ISO2859-1:1999 》. have sound, will travel page 10/10
B4012AP422-003 价格&库存
很抱歉,暂时无法提供与“B4012AP422-003”相匹配的价格&库存,您可以联系我们找货
