HSS3402A
N-Ch 30V Fast Switching MOSFETs
Description
Product Summary
The HSS3402A is the high cell density trenched Nch MOSFETs, which provides excellent RDSON
and efficiency for most of the small power switching
and load switch applications.
The HSS3402A meet the RoHS and Green Product
requirement with full function reliability approved.
VDS
30
V
RDS(ON),typ
34
mΩ
ID
4
A
SOT23 Pin Configuration
Green Device Available
Super Low Gate Charge
Excellent Cdv/dt effect decline
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
30
V
VGS
Gate-Source Voltage
ID@TA=25℃
ID@TA=70℃
IDM
PD@TA=25℃
±12
V
Continuous Drain Current, VGS @
4.5V1
4
A
4.5V1
3.5
A
Current2
16
A
Dissipation3
0.8
W
Pulsed Drain
Total Power
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-ambient
RθJC
Junction-Case1
www.hs-semi.cn
Thermal Resistance
1
Typ.
Max.
Unit
145
℃/W
78
℃/W
1
HSS3402A
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
30
V
Reference to 25℃ , ID=1mA
0.029
V/℃
34
45
VGS=10V , ID=4A
RDS(ON)
VGS(th)
Static Drain-Source On-Resistance2
Gate Threshold Voltage
VGS=4.5V , ID=3.5A
39
50
VGS=2.5V , ID=3A
50
65
0.5
1
1.6
V
-2.82
mV/℃
VDS=24V , VGS=0V , TJ=25℃
1
VDS=24V , VGS=0V , TJ=55℃
5
VGS=VDS , ID =250uA
m
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±12V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=3A
33
S
Qg
Total Gate Charge (4.5V)
4.6
0.98
VDS=15V , VGS=4.5V , ID=3A
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
1.8
Turn-On Delay Time
3.2
Td(on)
uA
nC
Rise Time
VDD=15V , VGS=10V , RG=3.3
1.9
Turn-Off Delay Time
ID=3A
17
Fall Time
2.6
Ciss
Input Capacitance
234
Coss
Output Capacitance
36
Crss
Reverse Transfer Capacitance
18
Min.
Typ.
Max.
Unit
4
A
16
A
1.2
V
Tr
Td(off)
Tf
VDS=15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
ISM
VSD
Parameter
Continuous Source
Pulsed Source
Current1,4
Current2,4
Diode Forward Voltage
2
Conditions
VG=VD=0V , Force Current
VGS=0V , IS=1A , TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The power dissipation is limited by 150℃ junction temperature
4.The data is theoretically the same as I D and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
2
HSS3402A
Typical Characteristics
www.hs-semi.cn
3
HSS3402A
www.hs-semi.cn
4
HSS3402A
Ordering Information
Part Number
HSS3402A
www.hs-semi.cn
Package code
SOT-23
Packaging
3000/Tape&Reel
5
很抱歉,暂时无法提供与“HSS3402A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.13857
- 500+0.11232
- 3000+0.09040
- 6000+0.08165
- 24000+0.07398
- 51000+0.06988
