ASX00021
ASX00021
    ARDUINO
    ASX00021
ASX00021 数据手册
Arduino® Vision Shield Product Datasheet SKU (Ethernet): ASX00021 SKU (LoRa): ASX00026 Description: The Arduino Portenta Vision Shield is an addon board providing machine vision capabilities and additional connectivity to the Portenta family of Arduino boards, designed to meet the needs of industrial automations. The Portenta Vision Shield connects via a high density connector to the Portenta H7 with minimal hardware and software setup. Target areas: Industry, surveillance Features Note: This board needs the Arduino Portenta H7 to function ■ Himax HM-01B0 camera module Ultra Low Power Image Sensor designed ■ for Always-on vision devices and applications High sensitivity 3.6μ BrightSenseTM pixel ■ technology window, vertical flip and horizontal mirror ■ readout Programmable black level calibration ■ target, frame size, frame rate, exposure, analog gain (up to 8x) and digital gain (up to 4x) Automatic exposure and gain control loop ■ with support for 50Hz / 60Hz flicker avoidance Motion Detection circuit with ■ programmable ROI and detection threshold with digital output to serve as an interrupt 1 / 17 ■ ■ ■ ■ ■ ■ Supported resolutions QQVGA (160x120) at 15, 30, 60 and 120 FPS QVGA (320x240) at 15, 30 and 60 FPS Power Arduino -> Basics and click on helloworld.py. Click on the green square underneath the connection button to run. 4.5 Online resources Now that you have gone through the basics of what you can do with the board you can explore the endless possibilities it provides by checking exciting projects on ProjectHub [6], the Arduino Library Reference [7] and the online store [8] where you will be able to complement your board with sensors, actuators and more. 4.6 Board Recovery All Arduino boards have a built-in bootloader which allows flashing the board via USB. In case a sketch locks up the processor and the board is not reachable anymore via USB it is possible to enter bootloader mode by double-tapping the reset button right after power up. 8 / 17 Arduino Vision Shield Rev 1 - 03/03/2021 5. Connector Pinouts 5.1 JTAG Pin Function Type Description 1 2 3,5,9 4 6 10 7,11,12,13, 14,15,17,1 8,19,20 VDDIO SWD GND SCK SWO RESET NC Power I/O Power Output I/O Input Not Connected Positive Reference voltage for debug interface Single Wire Debug Data Negative reference voltage for debug interface Single Wire Debug Clock Single Wire Debug Trace CPU Reset 9 / 17 Arduino Vision Shield Rev 1 - 03/03/2021 5.2 High Density Connector 10 / 17 Arduino Vision Shield Rev 1 - 03/03/2021 6. Mechanical Information 6.1 Board Outline 6.2 Mounting holes 11 / 17 Arduino Vision Shield Rev 1 - 03/03/2021 6.3 Connector and component positions 12 / 17 Arduino Vision Shield Rev 1 - 03/03/2021 6.4 Mounting Instructions 13 / 17 Arduino Vision Shield Rev 1 - 03/03/2021 7. Certifications 7.1 Declaration of Conformity CE/RED DoC (EU) We declare under our sole responsibility that the products above are in conformity with the essential requirements of the following EU Directives and therefore qualify for free movement within markets comprising the European Union (EU) and European Economic Area (EEA). ROHS 2 Directive 2011/65/EU Conforms to: EN50581:2012 Directive 2014/35/EU. (LVD) Conforms to: EN 60950-1:2006/A11:2009/A1:2010/A12:2011/AC:2011 Directive 2004/40/EC & 2008/46/EC & 2013/35/EU, EMF Conforms to: EN 62311:2008 7.2 Declaration of Conformity to EU RoHS & REACH 191 11/26/2018 Arduino boards are in compliance with Directive 2011/65/EU of the European Parliament and Directive 2015/863/EU of the Council of 4 June 2015 on the restriction of the use of certain hazardous substances in electrical and electronic equipment. Substance Maximum Limit (ppm) Lead (Pb) Cadmium (Cd) Mercury (Hg) Hexavalent Chromium (Cr6+) Poly Brominated Biphenyls (PBB) Poly Brominated Diphenyl ethers (PBDE) Bis(2-Ethylhexyl} phthalate (DEHP) Benzyl butyl phthalate (BBP) Dibutyl phthalate (DBP) Diisobutyl phthalate (DIBP) Exemptions : No exemptions are claimed. 1000 100 1000 1000 1000 1000 1000 1000 1000 1000 Arduino Boards are fully compliant with the related requirements of European Union Regulation (EC) 1907 /2006 concerning the Registration, Evaluation, Authorization and Restriction of Chemicals (REACH). We declare none of the SVHCs (https://echa.europa.eu/web/guest/candidate-list-table), the Candidate List of Substances of Very High Concern for authorization currently released by ECHA, is present in all products (and also package) in quantities totaling in a concentration equal or above 0.1%. To the best of our knowledge, we also declare that our products do not contain any of the substances listed on the "Authorization List" (Annex XIV of the REACH regulations) and Substances of Very High Concern (SVHC) in any significant amounts as specified by the Annex XVII of Candidate list published by ECHA (European Chemical Agency) 1907 /2006/EC. 7.3 Conflict Minerals Declaration As a global supplier of electronic and electrical components, Arduino is aware of our obligations with regards to laws and regulations regarding Conflict Minerals, specifically the Dodd-Frank Wall Street Reform and Consumer Protection Act, Section 1502. Arduino does not directly source or process conflict minerals such as Tin, Tantalum, Tungsten, or Gold. Conflict minerals are contained in our products in the form of solder, or as a 14 / 17 Arduino Vision Shield Rev 1 - 03/03/2021 component in metal alloys. As part of our reasonable due diligence Arduino has contacted component suppliers within our supply chain to verify their continued compliance with the regulations. Based on the information received thus far we declare that our products contain Conflict Minerals sourced from conflict-free areas. 15 / 17 Arduino Vision Shield Rev 1 - 03/03/2021 8. Reference Documentation Ref 1. Arduino IDE (Desktop) Link https://www.arduino.cc/en/Main/Software 2. Arduino IDE (Cloud) https://create.arduino.cc/editor 3. Cloud IDE Getting Started https://create.arduino.cc/projecthub/Arduino_Genuino/getting-started-with-ard uino-web-editor-4b3e4a 4. Forum http://forum.arduino.cc/ 5. OpenMV IDE https://openmv.io/pages/download 6. ProjectHub https://create.arduino.cc/projecthub?by=part&part_id=11332&sort=trending 7. Library Reference https://www.arduino.cc/reference/en/ 8. Arduino Store https://store.arduino.cc/ 16 / 17 Arduino Vision Shield Rev 1 - 03/03/2021 9. Revision History Date Revision Changes 03/03/2021 1 First Release 17 / 17 Arduino Vision Shield Rev 1 - 03/03/2021
ASX00021
物料型号: - 以太网版:SKU (Ethernet): ASX00021 - LoRa 版:SKU (LoRa): ASX00026
器件简介: - 该板需要 Arduino Portenta H7 才能工作。 - 包含 Himax HM-01B0 摄像头模块,专为始终开启的视觉设备和应用设计,具有超低功耗图像传感器。 - 支持运动检测电路,具有可编程 ROI(感兴趣区域)和检测阈值。
引脚分配: - JTAG 引脚:包括 VDDIO、SWD、GND、SCK、SWO、RESET 等。 - 高密度连接器引脚:包括 CAMD7、SWCK、CAMD6、BOOT_SOURCE、SNDIO、POWER_ON_REQ、CAMD4、COINCELL、V-SDCAR、CAMD3、CAMD2、DHIC、D6、SDCD3、SDCD2、SDCD1、SDCDO、CAM CLK、12SDI、CAM HS、SDCCHD、I2SWS、GNO、2.8V、VSYS、UART2TX、UART2RX、UART3 TX、UART3 RX、CAN1 RX、CAN1 TX、GND、VIN、I2C1S0645、SPI1CS、I2C1SDA、SPI1CK、SPI1MOSI、UART1 CTS、UART1 RTS、UART1 RX、UART1 TX、GPIO、VCC/+3V3、ETH L2、ETHL1、DSI CK-、PWM7、PMM2、DSI CK+、PAM8、PMM3、DSI DO-、PWM9、PMM4、DSI DO+、PAM10、PMM5、DSID1-、GND、VCC/+3V3、ETH B-、DSI D1+、ADC VREF-、ADC A4、ADCVREF+、ADC AG、ETHB+、ADC A5、ETH A、ADC A6、ETHA+、ADC A7、ADC A3。
参数特性: - 摄像头模块:Himax HM-01B0,分辨率 324x324,最大 60FPS。 - 功耗:<1.1mW(QQVGA 分辨率 30FPS),<2mW(QVGA 分辨率 30FPS)。 - 麦克风:MP34DT06JTR MEMS PDM 数字麦克风,具有 122.5 dBSPL 的 AOP 和 64 dB 的信噪比。
功能详解: - 支持多种分辨率和帧率。 - 具有自动曝光和增益控制循环,支持 50Hz/60Hz 闪烁避免。 - 提供以太网和 LoRa 两种连接选项,分别适用于有线网络和长距离低带宽操作。
应用信息: - 适用于工业生产、预测性维护和监控等场景。 - 支持机器学习和物联网应用。
封装信息: - 包括板子的拓扑图、摄像头模块、数字麦克风、Micro SD 卡槽、以太网(仅限 ASX00021)、LoRa 模块(仅限 ASX00026)和电源信息。
ASX00021 价格&库存
很抱歉,暂时无法提供与“ASX00021”相匹配的价格&库存,您可以联系我们找货
ASX00021
  • 1+458.822221+59.23011
库存:62
ASX00021
  • 1+502.43640
  • 10+488.76303
  • 25+481.19217
库存:57
ASX00021
库存:115
ASX00021
    • 1+657.536171+84.88241
    • 5+485.728515+62.70348
    库存:9
