SJN CONNECTOR
2.0mm pitch/Board-in Crimp style connectors
Specifications –––––––––––––––––––
2
5
6
9
T
BJS
1
4
8
U
3
7
U-
• Current rating: 3 A AC, DC (AWG #22)
• Voltage rating: 250 V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Insulation resistance: 1,000 MΩ min.
• Withstanding voltage: 800 VAC/minute
• Applicable wire: AWG #28 to #22
• Applicable PC board thickness: 1.2 to 1.6 mm
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
* Compliant with RoHS.
Side entry type board-in connector, with a
mounting height of only 2.8mm and a
thickness of 4.9mm.
Standards ––––––––––––––––––––––
• Housing lances
• Easy mounting onto printed circuit boards
Recognized E60389
PC board layout and Assembly layout
±0.05
4.9
φ0.9
2
5.45
2.8
3.5 min
2
±0.03
(0.5)
(1.7)
(0.7)
(2)
Note: 1. The above figure is the figure viewed from soldering side.
2. Tolerances are non-cumulative: ±0.05 mm for all centers.
3. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details.
1
SJN CONNECTOR
Contact
Applicable wire
AWG #
mm2
Model No.
0.95
SJN-001PT-0.9
SJN-002PT-0.9
Insulation O.D.(mm)
Q'ty /
reel
0.20∼0.33
24∼22
1.1∼1.4
15,000
0.08∼0.22
28∼24
0.9∼1.4
18,000
Material and Finish
(5.4)
Brass, tin-plated (reflow treatment)
RoHS compliance
Note: Contact JST if you require shielded wires, thin wires or other special
wires.
0.2
4
0.6
0.9
0.8
Contact
Crimping
machine Crimp applicator
SJN-001PT-0.9
AP-K2N
SJN-002PT-0.9
Applicator
Dies
Crimp applicator with dies
MKS-L
MK/SJN-001-09
APLMK SJN001-09
MKS-L
MK/SJN-002-09
APLMK SJN002-09
Housing
B
Circuits
Model No.
2
02P-SJN
03P-SJN
04P-SJN
06P-SJN
07P-SJN
08P-SJN
09P-SJN
10P-SJN
11P-SJN
3
A
4
2
2.8
6
7
8
4.9
2
7
8
9
JST
1
9
10
11
Dimensions (mm)
A
B
2.0
4.4
2,000
4.0
6.4
1,000
6.0
8.4
1,000
10.0
12.4
1,000
12.0
14.4
1,000
14.0
16.4
1,000
16.0
18.4
1,000
18.0
20.4
1,000
20.0
22.4
5,000
Materia
PA 66, UL94V-0, natural (white)
RoHS compliance
2
Q'ty/
bag
很抱歉,暂时无法提供与“08P-SJN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+0.707791000+0.09198
