XL CONNECTOR
5.0mm pitch/Disconnectable Crimp style connectors
Specifications –––––––––––––––––––
JS
T
• Current rating: 10A AC, DC (Refer to the table below.)
• Voltage rating: 150V AC, DC
• Temperature range: -25˚C to +90˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/7m Ω max.
After environmental testing/10m Ω max.
• Insulation resistance:
1,000M Ω min.
• Withstanding voltage: 1,500V AC/minute
• Applicable wire: AWG #26 to #16
• Applicable PC board thickness: 1.6mm
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Note:
The rated current varies depending on the number of circuits and the size of the
wire to be connected by crimping.
Current unit:A
Wire size(AWG)
Circuits
#16
10
9
9
6
6
5
2
3
4
8
12
16
The reliable XL connectors have been
developed by utilizing the technology of
JST's field proven VH and SM connectors.
The XL connectors are being used in
electric appliances, vending machines,
and office automation equipment.
#18
6
5
5
4
4
3
#20
5
4
4
3
3
2
#22
4
3
3
3
3
2
#24
3
3
3
2
2
1
#26
3
2
2
2
2
1
Note:
Do not branch in parallel current which exceeds the rated current per circuit
listed below. (Example: more than 10A in the case of a 2-circuit connector using
AWG #16 wires.) If branched in parallel, current imbalance or other problems
may develop.
Standards ––––––––––––––––––––––
• Reliable housing construction
• Easy contact insertion
• Box-shaped contact
• Two kinds of connections
Recognized E60389
1 Certified LR20812
2 R75150
Locking header PC board layout (viewed from soldering side) and Assembly layout
3.0 min
17.7
φ1.5 ±0.05
20.1
5.8 ±0.05
(6.6)
5.0 ±0.05
Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers.
2. Hole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details.
Shrouded header PC board layout (viewed from component side)
[HDS type]
Side entry type
φ1.5±0.05
5.8±0.05
5.0±0.05
5.0±0.05
5.0±0.05
φ1.5±0.05
5.8±0.05
[HDS type]
Top entry type
1
XL CONNECTOR
[HDB type]
Top entry type
5.0±0.05
(3 circuits)
2-φ1.5±0.05
5.0±0.05
4.8±0.05
(2 circuits) φ2.5
3-φ1.5±0.05
6.6±0.05
5.8±0.05
φ2.5±0.05
4-φ1.5±0.05
10.3±0.1
5.8±0.05
φ2.5±0.05
(6 circuits)
(4 circuits)
(4 circuits)
6-φ1.5±0.05
4-φ1.5±0.05
5.0±0.05
6.6±0.05
2-φ1.5±0.05
±0.05
5.0±0.05
φ2.5±0.05
5.0±0.05
φ2.5±0.05
3.0±0.05
(2 circuits)
[HDB type]
Side entry type
φ2.5±0.05
5.8±0.05
10.3±0.1
5.8±0.05
6.6±0.05
5.8±0.05
Contact
Applicable wire
mm2
AWG #
Model No.
SXF-01T-P0.7
12.0
SXF-41T-P0.7
Insulation O.D. Q't y /
reel
(mm)
0.13∼0.5
26∼20
1.3∼2.7
0.5 ∼1.25
20∼16
1.9∼3.1
0.3×2∼0.5×2
22×2∼20×2
1.7×2∼2.0×2
3,000
4.0
Material and Finish
Phosphor bronze, tin-plated (reflow treatment)
3.35
Applicator
Dies
Crimp applicator with dies
MKS-L
MK/SXF-01-07
APLMK SXF01-07
Crimping
machine Crimp applicator
Contact
AP-K2N
SXF-01T-P0.7
RoHS compliance
Note: Contact JST for brass products.
3.0
Contact
SXF-41T-P0.7
Applicator
Dies
MKS-L
MK/SXF-41-07
APLMK SXF41-07
Crimping
AP-K2N
Housing
(3 circuits)
2.55
4.35
5.8
10.9
(4 to 16 circuits)
B
11.8
16.2
3.9
3.9
6.5
Circuits
2
3
4
8
12
16
5.0
Dimensions (mm)
A
B
Model No.
XLP-02V
XLP-03V
XLP-04V
XLP-08V
XLP-12V
XLP-16V
Q'ty /
bag
500
500
5.0
11.2
500
15.0
21.2
500
25.0
31.2
200
35.0
41.2
200
Material
2
5.1
10.0
PA 66, UL94V-0, natural (white)
RoHS compliance
18.7
18.7
18.7
4.3
17.7
12.35
5.5
5.5
3.9
17.7
12.35
5.5
(2 circuits)
6.2
5.0
2.55
5.8
A
4.35
10.9
As the color identification,
the following alphabet shall be put in the underlined part.
For availability, delivery and minimum order quantity, contact JST.
ex.
XLP-02V-oo(blank)…natural (white)
K…black R…red E…blue Y…yellow
XL CONNECTOR
Locking header
1.85
Circuits
15.4
0.64
B02P-XL
B04P-XL
B08P-XL
B12P-XL
B16P-XL
2
4
8
14.6
3.4
8.0
14.6
17.8
Dimensions (mm)
A
B
Model No.
12
16
Q'ty /
box
5.0
250
5.0
10.0
200
15.0
20.0
100
25.0
30.0
50
35.0
40.0
50
Material and Finish
5.0
6.62
5.8
Post: Brass, copper-undercoated, tin-plated (reflow treatment)
Wafer: PA 66, UL94V-0, natural (white)
A
B
RoHS compliance This product displays (LF)(SN) on a label.
ex.
B02P-XL-oo(blank)…natural (white) K…black R…red E…blue Y…yellow
Shrouded header
Top entry type
Circuits
2
(2 circuits)
(3 circuits)
3
4
6
1
Model No.
Top entry type
Side entry type
S02P-XL-HDB
B02P-XL-HDB
B03P-XL-HDB
S04P-XL-HDB
B04P-XL-HDB
B06P-XL-HDB
Q'ty / box
Top entry type Side entry type
200
100
200
200
100
100
Material and Finish
3
16.4
13.8
8.0
14.6
14.6
7.9
2
1
2
3.0
3.0
ex.
6.6
0.64
φ3.2
1.2
4.8
5.0
5.8
(4 circuits)
(6 circuits)
1
2
1
3
3
4
4
6
17.9
13.8
13.8
3.0
3.0
14.6
14.6
12.9
φ3.2
1.2
φ3.2
0.64
3.0
B02P-XL-HDB-oo-, S02P-XL-HDB-oo-,
M…green H…gray N…brown D…orange
L…lemon yellow
6.6
5.0
0.64
1.2
2.0
6.6
5.0
5.8
0.64
5.8
1.2
1.2
7.9
(4 circuits)
24.0
φ2.4
5.8
2
3
4
φ3.2
14.5
3.2
3.2
0.64
1
2
3.2
14.5
15.3
1
15.3
24.0
3.2
(2 circuits)
3.95 5.0
12.9
Side entry type
0.64
φ2.4
φ3.2
5.8
3
XL CONNECTOR
Shrouded header
Circuits
Top entry type
2
4
8
12
8
5.8
5
16
14.6
3.0
7.9
200
12.9
200
15.0
22.9
100
40
25.0
32.9
50
30
35.0
42.9
40
ex.
5.0
5.0
B
A
3.15
Dimensions (mm)
Q'ty
A
B Top/bag Side/box
Material and Finish
0.64
4
13.8
1
Model No.
Top entry type
Side entry type
B02P-XL-HDS
B04P-XL-HDS
S08P-XL-HDS
B08P-XL-HDS
S12P-XL-HDS
B12P-XL-HDS
S16P-XL-HDS
B16P-XL-HDS
B08P-XL-HDS-oo-, S08P-XL-HDS-oo-,
1.2
3.2
15.3
Side entry type
5.0
0.64
1.2
5.8
24.0
B
A
Contact position location numbers
1
JST
4
8
16
7
15
6
12
6
14
5
11
5
13
4
10
4
12
2
JST
2
4
8
3
7
3
9
3
11
JST
1
JST
JST
JST
3
2
4
2
6
2
8
2
10
1
3
1
5
1
7
1
9
很抱歉,暂时无法提供与“SXF-01T-P0.7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+0.258663000+0.03357
- 6000+0.249966000+0.03244
- 21000+0.2377621000+0.03085
- 国内价格
- 100+0.22907
- 1000+0.17777
- 3000+0.14256
- 国内价格 香港价格
- 1+0.380591+0.04938
- 500+0.33922500+0.04402
- 1000+0.289581000+0.03758
- 4000+0.256494000+0.03328
- 5000+0.256495000+0.03328
- 10000+0.2482110000+0.03221
- 30000+0.2482130000+0.03221
- 国内价格
- 100+0.25660
- 1000+0.19920
- 3000+0.15970
