1397
1397
    HEYCO
1397 数据手册
“Stay Connected” with Strain Relief Bushings ® Heyco Original Strain Relief Bushings ® Right Angle for Round Cables • Provides the same protection for your power supply cable as the straight-thru type AND... • Exits the cable flush against the panel, saving space and directing the cable parallel to the panel. • Overcomes space limitations and acts as a back or bottom bumper. • See page 4-38 for corresponding Mounting Hole Plugs which can be used to fill blank/unused Mounting Holes and thus allow for a single panel design for multiple applications. • Consult Heyco for other wire types and sizes. • See pages 4-27 & 4-28 for SR assembly tools. • For Double D Mounting Hole Punches, see page 4-30. NEW! WILL FIT THESE CABLES UL Type in. SV & SVT HPD SJ, SJO & SJT PANEL DIMENSIONS AWG/ Approximate Conductors Size mm. 18/2 .250 6,4 18/3 .265 6,7 18/2 .270 6,9 16/2 .290 7,4 18/2 .300 7,6 16/2 .325 8,3 18/3 .330 8,4 SJ 16/3 .330 8,4 SJ, SJO & SJT 16/2 18/3 16/3 .325 .330 .335 8,3 8,4 9,0 .500 12,7 .500- 12,7.515 13,1 .450 11,4 .100 DESC. PART DIMENSIONS Mounting C D Hole Plug HEAD BODY LENGTH LENGTH in. mm. in. mm. PART NO. 2,5 1374 1375 SR 15-1 .39 9,9 .69 17,5 2491 .500 12,7 .500- 12,7.515 13,1 .625 15,9 .550 14,0 .125 3,2 1320 1321 SR 10-2 .56 14,3 .97 24,6 2497 .625 15,9 .550 14,0 .125 3,2 1327 1328 SR 11-2 .56 14,3 .97 24,6 2497 .750 19,0 .660 16,8 .125 3,2 1397 1398 SR 17-2 .64 16,3 1.09 27,7 2503 22,2 .815 20,7 .125 3,2 1401 1402 SR 18-2 .84 21,4 1.36 34,5 2509 SJT 18/4 .360 9,1 SJT & SJTO 14/3 .370 9,4 SJ & ST 18/2 18/3 16/2 .390 .405 .405 9,9 10,3 10,3 16/3 .430 10,9 .750- 19,0.781 19,8 14/2 14/3 .530 .560 13,5 14,2 .875 S PART A B Finished NO. Mounting To Prevent Fit Panel Black White Hole Dia. Rotation Thickness* in. mm. in. mm. in. mm. Standard color black. Consult Heyco for other colors. *Maximum Panel Thickness. Part has additional clearance. Consult Heyco for your Custom Finished Fit Panel Thickness. B A MOUNTING HOLES C D Quick Specs 4-25 Material Certifications Flammability Rating Temperature Range Nylon 6/6 Recognized under the Component Program of Underwriters’ Laboratories File E15331 Certified by the Canadian Standards Association File 8919 94V-2 -.04°F (-18°C) to 221°F (105°C) 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com
很抱歉,暂时无法提供与“1397”相匹配的价格&库存,您可以联系我们找货
  • 1+7.181991+0.93332
