XT25F16BDFIGT
XT25F16BDFIGT
    XTX(芯天下)
    DFN8_EP
    XT25F16BDFIGT
XT25F16BDFIGT 数据手册
3.3V QUAD IO Serial Flash XT25F16B XT25F16B Quad IO Serial NOR Flash Datasheet XTX Technology Inc. Tel: (86 755) 28229862 Fax: (86 755) 28229847 Web Site: http://www.xtxtech.com/ Technical Contact: fae@xtxtech.com * Information furnished is believed to be accurate and reliable. However, XTX Technology Inc. assumes no responsibility for the consequences of use of such information or for any infringement of patents of other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent rights of XTX Technology Inc. Specifications mentioned in this publication are subject to change without notice. This publication supersedes and replaces all information previously supplied. XTX Technology Inc. products are not authorized for use as critical components in life support devices or systems without express written approval of XTX Technology Inc. The XTX logo is a registered trademark of XTX Technology Inc. All other names are the property of their respective own. Rev 2.2 May/08/2021 Page 1 XT25F16B 3.3V QUAD IO Serial Flash Serial NOR Flash Memory 3.3V Multi I/O with 4KB, 32KB & 64KB Sector/Block Erase e     2048K-byte  256 bytes per programmable page Temperature Range & Moisture Sensitivity Level   Standard, Dual, Quad SPI  Standard SPI: SCLK, CS#, SI, SO, WP#, HOLD#  Dual SPI: SCLK, CS#, IO0, IO1, WP#, HOLD#  Quad SPI: SCLK, CS#, IO0, IO1, IO2, IO3  Sector of 4K-byte Block of 32/64k-byte Industrial Level Temperature. (-40℃ to +85℃), MSL3 Low Power Consumption  30mA maximum active current  1uA typical power down current Single Power Supply Voltage:  Flexible Architecture     16M -bit Serial Flash 2.7~3.6V  Minimum 100,000 Program/Erase Cycle  High Speed Clock Frequency Advanced security Features  120MHz for fast read with 30PF load   Dual I/O Data transfer up to 240Mbits/s  Quad I/O Data transfer up to 320Mbits/s 4*256-Byte Security Registers With OTP Lock  Support 128 bits Unique ID  Software/Hardware Write Protection  Program/Erase Speed  Write protect all/portion of memory via software  Page Program time: 0.5ms typical   Sector Erase time: 150ms typical Enable/Disable protection with WP# Pin   Block Erase time: 0.3/0.4s typical Top or Bottom, Sector or Block selection  Chip Erase time: 7s typical  Package Options  See 1.1 Available Ordering OPN  All Pb-free packages are compliant RoHS, Halogen-Free and REACH. Rev 2.2 May/08/2021 Page 2 3.3V QUAD IO Serial Flash XT25F16B CONTENTS 1. GENERAL DESCRIPTION ..............................................................................................................................................5 1.1. 1.2. 1.3. 1.4. AVAILABLE ORDERING OPN ............................................................................................................................................ 5 CONNECTION DIAGRAM .................................................................................................................................................. 5 PIN DESCRIPTION........................................................................................................................................................... 6 BLOCK DIAGRAM ........................................................................................................................................................... 7 2. MEMORY ORGANIZATION ..........................................................................................................................................8 3. DEVICE OPERATION ....................................................................................................................................................9 4. STATUS REGISTER ..................................................................................................................................................... 10 5. DATA PROTECTION ................................................................................................................................................... 12 6. COMMANDS DESCRIPTION ....................................................................................................................................... 14 6.1. 6.2. 6.3. 6.4. 6.5. 6.6. 6.7. 6.8. 6.9. 6.10. 6.11. 6.12. 6.13. 6.14. 6.15. 6.16. 6.17. 6.18. 6.19. 6.20. 6.21. 6.22. 6.23. 6.24. 6.25. 6.26. 6.27. 6.28. 6.29. 7. WRITE ENABLE (WREN) (06H) ..................................................................................................................................... 17 WRITE ENABLE FOR VOLATILE STATUS REGISTER (50H) ...................................................................................................... 17 WRITE DISABLE (WRDI) (04H) ..................................................................................................................................... 18 READ STATUS REGISTER (RDSR) (05H OR 35H) ............................................................................................................... 18 WRITE STATUS REGISTER (WRSR) (01H) ........................................................................................................................ 18 READ DATA BYTES (READ) (03H).................................................................................................................................. 19 READ DATA BYTES AT HIGHER SPEED (FAST READ) (0BH) .................................................................................................. 19 DUAL OUTPUT FAST READ (3BH) ................................................................................................................................... 20 QUAD OUTPUT FAST READ (6BH) .................................................................................................................................. 21 DUAL I/O FAST READ (BBH) ......................................................................................................................................... 21 QUAD I/O FAST READ (EBH) ........................................................................................................................................ 23 QUAD I/O WORD FAST READ (E7H) .............................................................................................................................. 24 PAGE PROGRAM (PP) (02H) ......................................................................................................................................... 25 QUAD PAGE PROGRAM (QPP) (32H) ............................................................................................................................. 25 SECTOR ERASE (SE) (20H) ............................................................................................................................................ 26 32KB BLOCK ERASE (BE) (52H) .................................................................................................................................... 27 64KB BLOCK ERASE (BE) (D8H).................................................................................................................................... 28 CHIP ERASE (CE) (60/C7H) .......................................................................................................................................... 28 DEEP POWER-DOWN (DP) (B9H) .................................................................................................................................. 29 RELEASE FROM DEEP POWER-DOWN AND READ DEVICE ID (RDI) (ABH) .............................................................................. 29 READ MANUFACTURE ID/ DEVICE ID (REMS) (90H) ........................................................................................................ 31 READ UNIQUE ID (RUID) (90H) .................................................................................................................................... 31 READ IDENTIFICATION (RDID) (9FH) .............................................................................................................................. 31 HIGH SPEED MODE(HSM)(A3H)................................................................................................................................... 32 CONTINUOUS READ MODE RESET (CRMR) (FFH)............................................................................................................. 33 ERASE SECURITY REGISTERS (44H) ................................................................................................................................. 33 PROGRAM SECURITY REGISTERS (42H) ............................................................................................................................ 34 READ SECURITY REGISTERS (48H) .................................................................................................................................. 35 ENABLE RESET (66H) AND RESET (99H) .......................................................................................................................... 36 ELECTRICAL CHARACTERISTICS.................................................................................................................................. 37 7.1. 7.2. 7.3. 7.4. 7.5. 7.6. 7.7. 7.8. POWER-ON TIMING ..................................................................................................................................................... 37 INITIAL DELIVERY STATE ................................................................................................................................................ 37 DATA RETENTION AND ENDURANCE ................................................................................................................................ 37 LATCH UP CHARACTERISTICS .......................................................................................................................................... 37 ABSOLUTE MAXIMUM RATINGS...................................................................................................................................... 38 CAPACITANCE MEASUREMENT CONDITION ....................................................................................................................... 38 DC CHARACTERISTICS ................................................................................................................................................... 39 AC CHARACTERISTICS ................................................................................................................................................... 40 8. ORDERING INFORMATION ........................................................................................................................................ 43 9. PACKAGE INFORMATION .......................................................................................................................................... 44 Rev 2.2 May/08/2021 Page 3 3.3V QUAD IO Serial Flash 9.1. 9.2. 9.3. 9.4. 9.5. 10. Rev 2.2 XT25F16B PACKAGE SOP8 150MIL ............................................................................................................................................. 44 PACKAGE SOP8 208MIL ............................................................................................................................................. 45 PACKAGE DFN8 (2X3X0.55) MM .................................................................................................................................. 46 PACKAGE DFN8(2X3X0.40) MM ................................................................................................................................... 47 PACKAGE WSON (6X5) MM ......................................................................................................................................... 48 REVISION HISTORY................................................................................................................................................ 49 May/08/2021 Page 4 XT25F16B 3.3V QUAD IO Serial Flash 1. GENERAL DESCRIPTION The XT25F16B (16M-bit) Serial flash supports the standard Serial Peripheral Interface (SPI), and supports the Dual/Quad SPI: Serial Clock, Chip Select, Serial Data I/O0 (SI), I/O1 (SO), I/O2 (WP#), and I/O3 (HOLD#). The Dual I/O data is transferred with speed of 240Mbits/s and the Quad I/O & Quad output data is transferred with speed of 320 Mbits/s. 1.1. Available Ordering OPN OPN Package Type Package Carrier XT25F16BSOIGU SO8 150mil Tube XT25F16BSOIGT SO8 150mil Tape & Reel XT25F16BSSIGU SO8 208mil Tube XT25F16BSSIGT SO8 208mil Tape & Reel XT25F16BDFIGT DFN8 2x3x0.55 mm Tape & Reel XT25F16BDTIGT DFN8 2x3x0.40 mm Tape & Reel XT25F16BWOIGA WSON 6*5 mm Tray 1.2. Connection Diagram CS# 1 8 VCC SO(IO1) 2 7 HOLD#(IO3) Top View WP#(IO2) 3 6 SCLK VSS 4 5 SI(IO0) 8-PIN SOP Rev 2.2 May/08/2021 Page 5 XT25F16B 3.3V QUAD IO Serial Flash 8 VCC CS# 1 7 HOLD#(IO3) SO(IO1) 2 Top View 6 SCLK WP#(IO2) 3 5 SI(IO0) VSS 4 8-PIN DFN/WSON 1.3. Pin Description Pin Name I/O Description CS# SO (IO1) I I/O Chip Select Input Data Output (Data Input Output 1) WP# (IO2) I/O Write Protect Input (Data Input Output 2) Ground VSS SI (IO0) I/O SCLK I HOLD# (IO3) I/O VCC Rev 2.2 Data Input (Data Input Output 0) Serial Clock Input Hold Input (Data Input Output 3) Power Supply May/08/2021 Page 6 XT25F16B 3.3V QUAD IO Serial Flash 1.4. Block Diagram Write Control Logic Status Register HOLD#(IO3) SCLK CS# SPI Command & Control Logic High Voltage Generators Page Address Latch/Counter Rev 2.2 Flash Memory Column Decode And 256-Byte Page Buffer SI(IO0) SO(IO1) Write Protect Logic And Row Decode WP#(IO2) Byte Address Latch/Counter May/08/2021 Page 7 XT25F16B 3.3V QUAD IO Serial Flash 2. MEMORY ORGANIZATION XT25F16B Each Device has Each block has Each sector has Each page has Remark 2M 64K/32K 4K 256 bytes 8K 256/128 16 - pages 512 16/8 - - sectors 32/64 - - - blocks XT25F16B 64K Bytes Block Sector Architecture Block 31 30 …… …… 2 1 0 Rev 2.2 Sector Address range 511 1FF000H 1FFFFFH …… …… …… 496 1F0000H 1F0FFFH 495 1EF000H 1EFFFFH …… …… …… 480 1E0000H 1E0FFFH …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… 47 02F000H 02FFFFH …… …… …… 32 020000H 020FFFH 31 01F000H 01FFFFH …… …… …… 16 010000H 010FFFH 15 00F000H 00FFFFH …… …… …… 0 000000H 000FFFH May/08/2021 Page 8 3.3V QUAD IO Serial Flash XT25F16B 3. DEVICE OPERATION SPI Mode Standard SPI The XT25F16B features a serial peripheral interface on 4 signals bus: Serial Clock (SCLK), Chip Select (CS#), Serial Data Input (SI) and Serial Data Output (SO). Both SPI bus mode 0 and 3 are supported. Input data is latched on the rising edge of SCLK and data shifts out on the falling edge of SCLK. Note: “WP#” & “HOLD#” pin require external pull-up. Dual SPI The XT25F16B supports Dual SPI operation when using the “Dual Output Fast Read” and “Dual I/O Fast Read” (3BH and BBH) commands. These commands allow data to be transferred to or from the device at two times the rate of the standard SPI. When using the Dual SPI command the SI and SO pins become bidirectional I/O pins: IO0 and IO1. Note: “WP#” & “HOLD#” pin require external pull-up. Quad SPI The XT25F16B supports Quad SPI operation when using the “Quad Output Fast Read”,” Quad I/O Fast Read”, “Quad I/O Word Fast Read” (6BH, EBH, E7H) commands. These commands allow data to be transferred to or from the device at four times the rate of the standard SPI. When using the Quad SPI command the SI and SO pins become bidirectional I/O pins: IO0 and IO1, and WP# and HOLD# pins become IO2 and IO3. Quad SPI commands require the non-volatile Quad Enable bit (QE) in Status Register to be set. Hold The HOLD# signal goes low to stop any serial communications with the device, but doesn’t stop the operation of write status register, programming, or erasing in progress. The operation of HOLD, need CS# keep low, and starts on falling edge of the HOLD# signal, with SCLK signal being low (if SCLK is not being low, HOLD operation will not start until SCLK being low). The HOLD condition ends on rising edge of HOLD# signal with SCLK being low (If SCLK is not being low, HOLD operation will not end until SCLK being low). The SO is high impedance, both SI and SCLK don’t care during the HOLD operation, if CS# drives high during HOLD operation, it will reset the internal logic of the device. To re-start communication with chip, the HOLD# must be at high and then CS# must be at low. Figure1. Hold Condition CS# SCLK HOLD# HOLD Rev 2.2 HOLD May/08/2021 Page 9 XT25F16B 3.3V QUAD IO Serial Flash 4. STATUS REGISTER S15 Reserved S14 CMP S13 Reserved S12 Reserved S11 Reserved S10 LB S9 QE S8 Reserved S7 SRP S6 BP4 S5 BP3 S4 BP2 S3 BP1 S2 BP0 S1 WEL S0 WIP The status and control bits of the Status Register are as follows: WIP bit. The Write In Progress (WIP) bit indicates whether the memory is busy in program/erase/write status register progress. When WIP bit sets to 1, means the device is busy in program/erase/write status register progress, when WIP bit sets 0, means the device is not in program/erase/write status register progress. WEL bit. The Write Enable Latch (WEL) bit indicates the status of the internal Write Enable Latch. When set to 1 the internal Write Enable Latch is set, when set to 0 the internal Write Enable Latch is reset and no Write Status Register, Program or Erase command is accepted. BP4, BP3, BP2, BP1, BP0 bits. The Block Protect (BP4, BP3, BP2, BP1, BP0) bits are non-volatile. They define the size of the area to be software protected against Program and Erase commands. These bits are written with the Write Status Register (WRSR) command. When the Block Protect (BP4, BP3, BP2, BP1, BP0) bits are set to 1, the relevant memory area (as defined in Table1) becomes protected against Page Program (PP), Sector Erase (SE) and Block Erase (BE) commands. The Block Protect (BP4, BP3, BP2, BP1, BP0) bits can be written provided that the Hardware Protected mode has not been set. The Chip Erase (CE) command is executed, if the Block Protect (BP4, BP3, BP2, BP1, BP0) bits are all 0. SRP bit. The Status Register Protect (SRP) bit is non-volatile Read/Write bits in the status register. The SRP bit controls the method of write protection: software protection, hardware protection, power supply lock-down or one time programmable protection. SRP1 WP# Status Register Description 0 X Software Protected The Status Register can be written to after a Write Enable command, WEL=1. (Default) 1 0 Hardware Protected WP#=0, the Status Register locked and can not be written to. 1 1 Hardware Unprotected WP#=1, the Status Register is unlocked and can be written to after a Write Enable command, WEL=1. QE bit. The Quad Enable (QE) bit is a non-volatile Read/Write bit in the Status Register that allows Quad operation. When the QE bit is set to 0 (Default) the WP# pin and HOLD# pin are enable. When the QE bit is set to 1, the Quad IO2 and IO3 pins are enabled. (The QE bit should never be set to 1 during standard SPI or Dual SPI operation if the WP# or HOLD# pins are tied directly to the power supply or ground). Rev 2.2 May/08/2021 Page 10 3.3V QUAD IO Serial Flash XT25F16B LB bit. The LB bit is a non-volatile One Time Program (OTP) bit in Status Register (S10) that provide the write protect control and status to the Security Registers. The default state of LB is 0, the security registers are unlocked. LB can be set to 1 using the Write Register instruction. LB is One Time Programmable, once it’s set to 1, the Security Registers will become read-only permanently. CMP bit. The CMP bit is a non-volatile Read/Write bit in the Status Register (S14). It is used in conjunction with the BP4-BP0 bits to provide more flexibility for the array protection. Please see the Status registers Memory Protection table for details. The default setting is CMP=0. Rev 2.2 May/08/2021 Page 11 XT25F16B 3.3V QUAD IO Serial Flash 5. DATA PROTECTION The XT25F16B provide the following data protection methods:  Write Enable (WREN) command: The WREN command is set the Write Enable Latch bit (WEL). The WEL bit will return to reset by the following situation:  Power-Up  Write Disable (WRDI)  Write Status Register (WRSR)  Page Program (PP)  Sector Erase (SE) / Block Erase (BE) / Chip Erase (CE)  Software Protection Mode: The Block Protect (BP4, BP3, BP2, BP1, BP0) bits define the section of the memory array that can be read but not change.  Hardware Protection Mode: WP# going low to protected the BP0~BP4 bits and SRP bit.  Deep Power-Down Mode: In Deep Power-Down Mode, all commands are ignored except the Release from Deep Power-Down Mode command. Table1.0 XT25F16B Protected area size (CMP=0) Status Register Content Memory Content BP4 BP3 BP2 BP1 BP0 Blocks Addresses Density Portion X X 0 0 0 NONE NONE NONE NONE 0 0 0 0 1 31 1F0000H-1FFFFFH 64KB Upper 1/32 0 0 0 1 0 30 to 31 1E0000H-1FFFFFH 128KB Upper 1/16 0 0 0 1 1 28 to 31 1C0000H-1FFFFFH 256KB Upper 1/8 0 0 1 0 0 24 to 31 180000H-1FFFFFH 512KB Upper 1/4 0 0 1 0 1 16 to 31 100000H-1FFFFFH 1M Upper 1/2 0 1 0 0 1 0 000000H-00FFFFH 64KB Lower 1/32 0 1 0 1 0 0 to 1 000000H-01FFFFH 128KB Lower 1/16 0 1 0 1 1 0 to 3 000000H-03FFFFH 256KB Lower 1/8 0 1 1 0 0 0 to 7 000000H-07FFFFH 512KB Lower 1/4 0 1 1 0 1 0 to 15 000000H-0FFFFFH 1M Lower 1/2 X X 1 1 X 0 to 31 000000H-1FFFFFH 2M ALL 1 0 0 0 1 31 1FF000H-1FFFFFH 4KB Top Block 1 0 0 1 0 31 1FE000H-1FFFFFH 8KB Top Block 1 0 0 1 1 31 1FC000H-1FFFFFH 16KB Top Block 1 0 1 0 X 31 1F8000H-1FFFFFH 32KB Top Block 1 1 0 0 1 0 000000H-000FFFH 4KB Bottom Block 1 1 0 1 0 0 000000H-001FFFH 8KB Bottom Block 1 1 0 1 1 0 000000H-003FFFH 16KB Bottom Block 1 1 1 0 X 0 000000H-007FFFH 32KB Bottom Block Rev 2.2 May/08/2021 Page 12 XT25F16B 3.3V QUAD IO Serial Flash Table1.1 XT25F16B Protected area size (CMP=1) Status Register Content Memory Content BP4 BP3 BP2 BP1 BP0 Blocks Addresses Density Portion X X 0 0 0 0 to 31 000000H-1FFFFFH 2M ALL 0 0 0 0 1 0 to 30 000000H-1EFFFFH 1984KB Lower 31/32 0 0 0 1 0 0 to 29 000000H-1DFFFFH 1920KB Lower 15/16 0 0 0 1 1 0 to 27 000000H-1BFFFFH 1792KB Lower 7/8 0 0 1 0 0 0 to 23 000000H-17FFFFH 1536KB Lower 3/4 0 0 1 0 1 0 to 15 000000H-0FFFFFH 1M Lower 1/2 0 1 0 0 1 1 to 31 010000H-1FFFFFH 1984KB Upper 31/32 0 1 0 1 0 2 to 31 020000H-1FFFFFH 1920KB Upper 15/16 0 1 0 1 1 4 to 31 040000H-1FFFFFH 1792KB Upper 7/8 0 1 1 0 0 8 to 31 080000H-1FFFFFH 1536KB Upper 3/4 0 1 1 0 1 16 to 31 100000H-1FFFFFH 1M Upper 1/2 X X 1 1 X NONE NONE NONE NONE 1 0 0 0 1 0 to 31 000000H-1FEFFFH 2044KB Lower 511/512 1 0 0 1 0 0 to 31 000000H-1FDFFFH 2040KB Lower 255/256 1 0 0 1 1 0 to 31 000000H-1FBFFFH 2032KB Lower 127/128 1 0 1 0 X 0 to 31 000000H-1F7FFFH 2016KB Lower 63/64 1 1 0 0 1 0 to 31 001000H-1FFFFFH 2044KB Upper 511/512 1 1 0 1 0 0 to 31 002000H-1FFFFFH 2040KB Upper 255/256 1 1 0 1 1 0 to 31 004000H-1FFFFFH 2032KB Upper 127/128 1 1 1 0 X 0 to 31 008000H-1FFFFFH 2016KB Upper 63/64 Rev 2.2 May/08/2021 Page 13 XT25F16B 3.3V QUAD IO Serial Flash 6. COMMANDS DESCRIPTION All commands, addresses and data are shifted in and out of the device, beginning with the most significant bit on the first rising edge of SCLK after CS# is driven low. Then, the one-byte command code must be shifted in to the device, most significant bit first on SI, each bit being latched on the rising edges of SCLK. See Table2, every command sequence starts with a one-byte command code. Depending on the command, this might be followed by address bytes, or by data bytes, or by both or none. CS# must be driven high after the last bit of the command sequence has been shifted in. For the command of Read, Fast Read, Read Status Register or Release from Deep Power-Down, and Read Device ID, the shifted-in command sequence is followed by a data-out sequence. CS# can be driven high after any bit of the data-out sequence is being shifted out. For the command of Page Program, Sector Erase, Block Erase, Chip Erase, Write Status Register, Write Enable, Write Disable or Deep Power-Down command, CS# must be driven high exactly at a byte boundary, otherwise the command is rejected, and is not executed. That is CS# must be driven high when the number of clock pulses after CS# being driven low is an exact multiple of eight. For Page Program, if at any time the input byte is not a full byte, nothing will happen and WEL will not be reset. Table 2. Commands Command Name Byte1 Byte2 Byte3 Byte4 Byte5 Byte6 n-Bytes Write Enable Write Enable for Volatile Status Register 06H Write Disable 04H Read Status Register-1 05H (S7-S0) (continuous) Read Status Register-2 35H (S15-S8) (continuous) Write Status Register 01H (S7-S0) (S15-S8) Read Data 03H A23-A16 A15-A8 A7-A0 (D7-D0) (Next byte) (continuous) Fast Read 0BH A23-A16 A15-A8 A7-A0 dummy (D7-D0) (continuous) Dual Output Fast Read 3BH A23-A16 A15-A8 A7-A0 dummy (D7-D0)(1) (continuous) 50H (continuous) A7-A0 Dual I/O Fast Read BBH A23-A8(2) M7-M0(2) (D7-D0)(1) (continuous) Quad Output Fast Read 6BH A23-A16 A15-A8 A7-A0 Dummy(5) (D7-D0)(3) (continuous) M7-M0(4) Dummy(6) (D7-D0)(3) (continuous) dummy (D7-D0)(3) (continuous) A23-A0 Quad I/O Fast Read EBH Quad I/O Word Fast M7-M0(4) A23-A0 Read E7H Continuous Read Reset FFH Page Program 02H A23-A16 A15-A8 A7-A0 (D7-D0) Quad Page Program 32H A23-A16 A15-A8 A7-A0 (D7-D0)(3) Sector Erase 20H A23-A16 A15-A8 A7-A0 Block Erase(32KB) 52H A23-A16 A15-A8 A7-A0 Block Erase(64KB) D8H A23-A16 A15-A8 A7-A0 Chip Erase C7/60H Deep Power-Down B9H Release From Deep Power-Down, And Read Device ID ABH Rev 2.2 (Next byte) dummy dummy May/08/2021 dummy (DID7-DID0) (continuous) Page 14 XT25F16B 3.3V QUAD IO Serial Flash Release From Deep Power-Down ABH Manufacturer/Device ID 90H dummy dummy 00H Read Unique ID 90H 00h 00h 00H High Speed Mode A3H dummy dummy dummy Read Identification 9FH Erase Security Register(8) 44H (MID7MID0) A23-A16 (JDID15JDID8) A15-A8 (JDID7JDID0) A7-A0 Program Security Register(8) 42H A23-A16 A15-A8 A7-A0 (D7-D0) (Next byte) Read Security Register(8) 48H A23-A16 A15-A8 A7-A0 dummy (D7-D0) Enable Reset 66H Reset 99H (MID7-MID0) (DID7-DID0) (continuous) Dummy (1) Dummy(2) Dummy ..(16) ; D0---D7 (continuous) NOTE: 1. Dual Output data IO0 = (D6, D4, D2, D0) IO1 = (D7, D5, D3, D1) 2. Dual Input Address IO0 = A22, A20, A18, A16, A14, A12, A10, A8,A6, A4, A2, A0, M6, M4, M2, M0 IO1 = A23, A21, A19, A17, A15, A13, A11, A9,A7, A5, A3, A1, M7, M5, M3, M1 3. Quad Output Data IO0 = (D4, D0, …..) IO1 = (D5, D1, …..) IO2 = (D6, D2, …..) IO3 = (D7, D3, …..) 4. Quad Input Address IO0 = A20, A16, A12, A8, A4, A0, M4, M0 IO1 = A21, A17, A13, A9, A5, A1, M5, M1 IO2 = A22, A18, A14, A10, A6, A2, M6, M2 IO3 = A23, A19, A15, A11, A7, A3, M7, M3 5. Quad I/O Fast Read Data IO0 = (x, x, x, x, D4, D0,…) IO1 = (x, x, x, x, D5, D1,…) IO2 = (x, x, x, x, D6, D2,…) IO3 = (x, x, x, x, D7, D3,…) 6. Quad I/O Word Fast Read Data IO0 = (x, x, D4, D0,…) IO1 = (x, x, D5, D1,…) Rev 2.2 May/08/2021 Page 15 XT25F16B 3.3V QUAD IO Serial Flash IO2 = (x, x, D6, D2,…) IO3 = (x, x, D7, D3,…) 7. Quad I/O Word Fast Read Data: the lowest address bit must be 0. 8. Security Registers Address: Security Register0: A23-A16=00H, A15-A8=00H, A7-A0= Byte Address; Security Register1: A23-A16=00H, A15-A8=01H, A7-A0= Byte Address; Security Register2: A23-A16=00H, A15-A8=02H, A7-A0= Byte Address; Security Register3: A23-A16=00H, A15-A8=03H, A7-A0= Byte Address. Table of ID Definitions: XT25F16B Operation Code M7-M0 ID15-ID8 9FH 0B 40 90H 0B 15 14 ABH Rev 2.2 ID7-ID0 14 May/08/2021 Page 16 3.3V QUAD IO Serial Flash XT25F16B 6.1. Write Enable (WREN) (06H) The Write Enable (WREN) command is for setting the Write Enable Latch (WEL) bit. The Write Enable Latch (WEL) bit must be set prior to every Page Program (PP), Sector Erase (SE), Block Erase (BE), Chip Erase (CE) and Write Status Register (WRSR) command. The Write Enable (WREN) command sequence: CS# goes low sending the Write Enable command CS# goes high. Figure2. Write Enable Sequence Diagram CS# 0 1 2 3 4 5 6 7 SCLK Command SI SO 06H High-Z 6.2. Write Enable for Volatile Status Register (50H) The non-volatile Status Register bits can also be written to as volatile bits. This gives more flexibility to change the system configuration and memory protection schemes quickly without waiting for the typical nonvolatile bit write cycles or affecting the endurance of the Status Register non-volatile bits. The Write Enable for Volatile Status Register command must be issued prior to a Write Status Register command and any other commands can't be inserted between them. Otherwise, Write Enable for Volatile Status Register will be cleared. The Write Enable for Volatile Status Register command will not set the Write Enable Latch bit, it is only valid for the Write Status Register command to change the volatile Status Register bit values. Figure3. Write Enable for Volatile Status Register Sequence Diagram CS# 0 1 2 3 4 5 6 7 SCLK Command SI SO Rev 2.2 50H High-Z May/08/2021 Page 17 XT25F16B 3.3V QUAD IO Serial Flash 6.3. Write Disable (WRDI) (04H) The Write Disable command is for resetting the Write Enable Latch (WEL) bit. The Write Disable command sequence: CS# goes lowsending the Write Disable command CS# goes high. The WEL bit is reset by following condition: Power-up and upon completion of the Write Status Register, Page Program, Sector Erase, Block Erase and Chip Erase commands. Figure 4. Write Disable Sequence Diagram CS# 0 1 2 3 4 5 6 7 SCLK Command SI 04H High-Z SO 6.4. Read Status Register (RDSR) (05H or 35H) The Read Status Register (RDSR) command is for reading the Status Register. The Status Register can be read at any time, even while a Program, Erase or Write Status Register cycle is in progress. When one of these cycles is in progress, it is recommended to check the Write In Progress (WIP) bit before sending a new command to the device. It is also possible to read the Status Register continuously. For command code “05H”, the SO will output Status Register bits S7~S0. The command code “35H”, the SO will output Status Register bits S15~S8. Figure 5. Read Status Register Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK Command SI 05H or 35H S7~S0 or S15~S8 out SO High-Z 7 6 5 4 3 2 1 MSB S7~S0 or S15~S8 out 0 7 6 5 4 3 2 1 0 7 MSB 6.5. Write Status Register (WRSR) (01H) The Write Status Register (WRSR) command allows new values to be written to the Status Register. Before it can be accepted, a Write Enable (WREN) command must previously have been executed. After the Write Enable (WREN) command has been decoded and executed, the device sets the Write Enable Latch (WEL). The Write Status Register (WRSR) command has no effect on S15, S1 and S0 of the Status Register. CS# must be driven high after the eighth or sixteen bit of the data byte has been latched in. If not, the Write Status Register (WRSR) command is not executed. If CS# is driven high after eighth bit of the data byte, the CMP and QE bit will be cleared to 0. As soon as CS# is driven high, the self-timed Write Status Register cycle (whose duration is tW) is initiated. While the Write Status Register cycle is in progress, the Status Register may still be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Write Status Register cycle, and is 0 when it is completed. When the cycle is completed, the Write Enable Latch (WEL) is reset. Rev 2.2 May/08/2021 Page 18 XT25F16B 3.3V QUAD IO Serial Flash The Write Status Register (WRSR) command allows the user to change the values of the Block Protect (BP4, BP3, BP2, BP1, BP0) bits, to define the size of the area that is to be treated as read-only, as defined in Table1. The Write Status Register (WRSR) command also allows the user to set or reset the Status Register Protect (SRP) bit in accordance with the Write Protect (WP#) signal. The Status Register Protect (SRP) bit and Write Protect (WP#) signal allow the device to be put in the Hardware Protected Mode. The Write Status Register (WRSR) command is not executed once the Hardware Protected Mode is entered. Figure 6. Write Status Register Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK Command SI Status Register in 7 6 5 4 3 2 1 01H MSB 0 15 14 13 12 11 10 9 8 MSB High-Z SO 6.6. Read Data Bytes (READ) (03H) The Read Data Bytes (READ) command is followed by a 3-byte address (A23-A0), each bit being latched-in during the rising edge of SCLK. Then the memory content, at that address, is shifted out on SO, each bit being shifted out, at a Max frequency fR, during the falling edge of SCLK. The first byte addressed can be at any location. The address is automatically incremented to the next higher address after each byte of data is shifted out. The whole memory can, therefore, be read with a single Read Data Bytes (READ) command. Any Read Data Bytes (READ) command, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. Figure 7. Read Data Bytes Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 SCLK Command SI 03H 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB SO Data Out1 High-Z MSB Data Out2 7 6 5 4 3 2 1 0 6.7. Read Data Bytes At Higher Speed (Fast Read) (0BH) The Read Data Bytes at Higher Speed (Fast Read) command is for fast reading data out. It is followed by a 3-byte address (A23-A0) and a dummy byte, each bit being latched-in during the rising edge of SCLK. Then the memory content, at that address, is shifted out on SO, each bit being shifted out, at a Max frequency fR, during the falling edge of SCLK. The first byte addressed can be at any location. The address is automatically incremented to the next higher address after each byte of data is shifted out. Rev 2.2 May/08/2021 Page 19 XT25F16B 3.3V QUAD IO Serial Flash Figure 8. Read Data Bytes at Higher Speed Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 24-bit address(A23:A0) 0BH 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 SCLK Dummy Byte SI 7 6 5 4 3 2 1 0 Data Out1 SO Data Out2 7 6 5 4 3 2 1 Data Out3 0 7 6 5 4 3 2 1 0 MSB MSB 6.8. Dual Output Fast Read (3BH) The Dual Output Fast Read command is followed by 3-byte address (A23-A0) and a dummy byte, each bit being latched in during the rising edge of SCLK, then the memory contents are shifted out 2-bit per clock cycle from SI and SO. The command sequence is shown in Figure 9. The first byte addressed can be at any location. The address is automatically incremented to the next address after each byte of data is shifted out. Figure 9. Dual Output Fast Read Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 3BH 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 SCLK Dummy Byte SI 6 4 2 0 6 4 2 Data Out1 SO Rev 2.2 0 6 4 2 0 6 4 2 Data Out2 7 5 3 1 7 5 3 MSB MSB May/08/2021 Data Out3 0 6 Data Out4 1 7 5 3 1 7 5 3 MSB MSB 1 7 Page 20 XT25F16B 3.3V QUAD IO Serial Flash 6.9. Quad Output Fast Read (6BH) The Quad Output Fast Read command is followed by 3-byte address (A23-A0) and a dummy byte, each bit being latched in during the rising edge of SCLK, then the memory contents are shifted out 4-bit per clock cycle from IO3, IO2, IO1 and IO0. The command sequence is shown in Figure 10. The first byte addressed can be at any location. The address is automatically incremented to the next address after each byte of data is shifted out. Figure 10. Quad Output Fast Read Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI(IO0) 24-bit address(A23:A0) 6BH 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO(IO1) High-Z WP#(IO2) High-Z HOLD#(IO3) CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 SCLK Dummy Byte SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 HOLD#(IO3) Byte1 Byte2 Byte3 Byte4 Byte5 Byte6 Byte7 Byte8 6.10. Dual I/O Fast Read (BBH) The Dual I/O Fast Read command is similar to the Dual Output Fast Read command but with the capability to input the 3-byte address (A23-0) and a “Continuous Read Mode” byte 2-bit per clock by SI and SO, each bit being latched in during the rising edge of SCLK, then the memory contents are shifted out 2-bit per clock cycle from SI and SO. The command sequence is shown in Figure 11. The first byte addressed can be at any location. The address is automatically incremented to the next address after each byte of data is shifted out. To ensure optimum performance the High Speed mode (HSM) command (A3H) must be executed once, prior to the Dual I/O Fast Read command. Dual I/O Fast Read with “Continuous Read Mode” The Dual I/O Fast Read command can further reduce command overhead through setting the “Continuous Read Mode” bits (M7- 0) after the input 3-byte address (A23-A0). If the “Continuous Read Mode” bits (M5- 4) =(1, 0), then the next Dual I/O Fast Read command (after CS# is raised and then lowered) does not require the BBH command code. The command sequence is shown in figure 11a. If the “Continuous Read Mode” bits (M5- 4) do not equal (1, 0), the next command requires the first BBH command code, thus returning to normal operation. A “Continuous Read Mode” Reset command can be used to reset (M5- 4) before issuing normal command. Rev 2.2 May/08/2021 Page 21 XT25F16B 3.3V QUAD IO Serial Flash Figure 11. Dual I/O Fast Read Sequence Diagram (M5-4≠(1, 0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Command SI(IO0) BBH SO(IO1) 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 A23-16 A15-8 A7-0 M7-0 CS# 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK SI(IO0) 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 SO(IO1) 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 Byte1 Byte2 Byte5 Byte4 Byte3 Byte6 Figure 11a. Dual I/O Fast Read Sequence Diagram (M5-4= (1, 0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK SI(IO0) 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 SO(IO1) 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 A23-16 A15-8 A7-0 M7-0 CS# 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 SCLK SI(IO0) 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 SO(IO1) 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 Byte1 Rev 2.2 Byte2 May/08/2021 Byte3 Byte4 Page 22 XT25F16B 3.3V QUAD IO Serial Flash 6.11. Quad I/O Fast Read (EBH) The Quad I/O Fast Read command is similar to the Dual I/O Fast Read command but with the capability to input the 3-byte address (A23-0) and a “Continuous Read Mode” byte and 4-dummy clock 4-bits per clock by IO0, IO1, IO3, IO4, each bit being latched in during the rising edge of SCLK, then the memory contents are shifted out 4-bit per clock cycle from IO0, IO1, IO2, IO3. The command sequence is shown in Figure 12. The first byte addressed can be at any location. The address is automatically incremented to the next address after each byte of data is shifted out. The Quad Enable bit (QE) of Status Register (S9) must be set to enable for the Quad I/O Fast read command. To ensure optimum performance the High Speed mode (HSM) command (A3H) must be executed once, prior to the Quad I/O Fast Read command. Quad I/O Fast Read with “Continuous Read Mode” The Quad I/O Fast Read command can further reduce command overhead through setting the “Continuous Read Mode” bits (M7-0) after the input 3-byte address (A23-A0). If the “Continuous Read Mode” bits (M5- 4) =(1, 0), then the next Quad I/O Fast Read command (after CS# is raised and then lowered) does not require the EBH command code. The command sequence is shown in Figure 12a. If the “Continuous Read Mode” (M5- 4) do not equal (1, 0), the next command requires the first EBH command code, thus returning to normal operation. A “Continuous Read Mode” Reset command can be used to reset (M5- 4) before issuing normal command. Figure 12. Quad I/O Fast Read Sequence Diagram (M5-4≠(1, 0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Command SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 7 3 7 3 7 3 7 3 7 3 7 3 7 EBH HOLD#(IO3) A23-16 A15-8 A7-0 M7-0 Dummy Byte1 Byte2 Figure 12a. Quad I/O Fast Read Sequence Diagram (M5-4= (1, 0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 HOLD#(IO3) 7 3 7 3 7 3 7 3 7 3 7 3 7 A23-16 A15-8 A7-0 M7-0 Rev 2.2 May/08/2021 Dummy Byte1 Byte2 Page 23 XT25F16B 3.3V QUAD IO Serial Flash 6.12. Quad I/O Word Fast Read (E7H) The Quad I/O Word Fast Read command is similar to the Quad I/O Fast Read command except that the lowest address bit (A0) must equal 0 and only 2-dummy clock. The command sequence is shown in followed Figure 13. The first byte addressed can be at any location. The address is automatically incremented to the next higher address after each byte of data is shifted out. The Quad Enable bit (QE) of Status Register (S9) must be set to enable for the Quad I/O Word Fast read command. Quad I/O Word Fast Read with “Continuous Read Mode” The Quad I/O Word Fast Read command can further reduce command overhead through setting the “Continuous Read Mode” bits (M7-0) after the input 3-byte address (A23-A0). If the “Continuous Read Mode” bits (M5- 4) =(1, 0), then the next Quad I/O Word Fast Read command (after CS# is raised and then lowered) does not require the E7H command code. The command sequence is shown in followed Figure 13a. If the “Continuous Read Mode” bits (M5- 4) do not equal (1, 0), the next command requires the first E7H command code, thus returning to normal operation. A “Continuous Read Mode” Reset command can be used to reset (M7-0) before issuing normal command. Figure 13. Quad I/O Word Fast Read Sequence Diagram (M5-4≠(1, 0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Command SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 HOLD#(IO3) 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 E7H A23-16 A15-8 A7-0 M7-0 Dummy Byte1 Byte2 Byte3 Figure13a. Quad I/O Word Fast Read Sequence Diagram (M5-4= (1, 0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 HOLD#(IO3) 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 A23-16 A15-8 A7-0 M7-0 Dummy Byte1 Byte1 Byte2 Rev 2.2 May/08/2021 Page 24 XT25F16B 3.3V QUAD IO Serial Flash 6.13. Page Program (PP) (02H) The Page Program (PP) command is for programming the memory. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before sending the Page Program command. The Page Program (PP) command is entered by driving CS# Low, followed by the command code, three address bytes and at least one data byte on SI. If the 8 least significant address bits (A7-A0) are not all zero, all transmitted data that goes beyond the end of the current page are programmed from the start address of the same page (from the address whose 8 least significant bits (A7-A0) are all zero). CS# must be driven low for the entire duration of the sequence. The Page Program command sequence: CS# goes low sending Page Program command 3-byte address on SI at least 1 byte data on SI CS# goes high. The command sequence is shown in Figure14. If more than 256 bytes are sent to the device, previously latched data are discarded and the last 256 data bytes are guaranteed to be programmed correctly within the same page. If less than 256 data bytes are sent to device, they are correctly programmed at the requested addresses without having any effects on the other bytes of the same page. CS# must be driven high after the eighth bit of the last data byte has been latched in; otherwise the Page Program (PP) command is not executed. As soon as CS# is driven high, the self-timed Page Program cycle (whose duration is tPP) is initiated. While the Page Program cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Page Program cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A Page Program (PP) command applied to a page which is protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) is not executed. Figure 14. Page Program Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 SCLK 24-bit address(A23:A0) Command SI 02H 23 22 21 20 19 Data Byte1 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 MSB 0 MSB 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 2072 2073 2074 2075 2076 2077 2078 2079 CS# SCLK Data Byte2 SI Data Byte3 Data Byte4 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 MSB MSB MSB Data Byte256 7 6 5 4 3 2 1 0 MSB 6.14. Quad Page Program (QPP) (32H) The Quad Page Program command is for programming the memory using four pins: IO0, IO1, IO2, and IO3. To use Quad Page Program the Quad enable in status register Bit9 must be set (QE=1). A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before sending the Page Program command. The Quad Page Program command is entered by driving CS# Low, followed by the command code (32H), three address bytes and at least one data byte on IO pins. The command sequence is shown in Figure 15. If more than 256 bytes are sent to the device, previously latched data are discarded and the last 256 data bytes are guaranteed to be programmed correctly within the same page. If less than 256 data bytes are sent to device, they are correctly programmed at the requested addresses without having any effects on the other bytes of the same page. CS# must be driven high after the Rev 2.2 May/08/2021 Page 25 XT25F16B 3.3V QUAD IO Serial Flash eighth bit of the last data byte has been latched in; otherwise the Quad Page Program command is not executed. As soon as CS# is driven high, the self-timed Quad Page Program cycle (whose duration is tPP) is initiated. While the Quad Page Program cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Quad Page Program cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A Quad Page Program command applied to a page which is protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) will not be executed. Figure 15. Quad Page Program Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 SCLK 24-bit address(A23:A0) Command SI 32H 23 22 21 20 19 7 6 5 4 3 2 1 0 4 0 4 0 4 0 4 0 SO(IO1) 5 1 5 1 5 1 5 1 WP#(IO2) 6 2 6 2 6 2 6 2 HOLD#(IO3) 7 3 7 3 7 3 7 3 MSB Byte1 Byte2 Byte3 Byte4 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 536 537 538 539 540 541 542 543 CS# SCLK SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 HOLD#(IO3) 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 Byte5 Byte6 Byte7 Byte8 Byte9 Byte10 Byte11 Byte12 Byte13 Byte14 Byte15 Byte16 Byte253 Byte254 Byte255 Byte256 6.15. Sector Erase (SE) (20H) The Sector Erase (SE) command is for erasing the all data of the chosen sector. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The Sector Erase (SE) command is entered by driving CS# low, followed by the command code, and 3-address byte on SI. Any address inside the sector is a valid address for the Sector Erase (SE) command. CS# must be driven low for the entire duration of the sequence. The Sector Erase command sequence: CS# goes low sending Sector Erase command 3-byte address on SICS# goes high. The command sequence is shown in Figure 16. CS# must be driven high after the eighth bit of the last address byte has been latched in; otherwise the Sector Erase (SE) command is not executed. As soon as Rev 2.2 May/08/2021 Page 26 XT25F16B 3.3V QUAD IO Serial Flash CS# is driven high, the self-timed Sector Erase cycle (whose duration is tSE) is initiated. While the Sector Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Sector Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A Sector Erase (SE) command applied to a sector which is protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bit (see Table1.0&1.1) will not be executed. Note: Power disruption during erase operation will cause incomplete erase and data corruption, thus recommend to perform a re-erase once power resume. Figure 16. Sector Erase Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 20H 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB 6.16. 32KB Block Erase (BE) (52H) The 32KB Block Erase (BE) command is for erasing the all data of the chosen block. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The 32KB Block Erase (BE) command is entered by driving CS# low, followed by the command code, and three address bytes on SI. Any address inside the block is a valid address for the 32KB Block Erase (BE) command. CS# must be driven low for the entire duration of the sequence. The 32KB Block Erase command sequence: CS# goes low sending 32KB Block Erase command 3-byte address on SI CS# goes high. The command sequence is shown in Figure17. CS# must be driven high after the eighth bit of the last address byte has been latched in; otherwise the 32KB Block Erase (BE) command is not executed. As soon as CS# is driven high, the self-timed Block Erase cycle (whose duration is tBE) is initiated. While the Block Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Block Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A 32KB Block Erase (BE) command applied to a block which is protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bits (see Table1.0 & 1.1) will not be executed. Note: Power disruption during erase operation will cause incomplete erase and data corruption, thus recommend to perform a re-erase once power resume. Figure 17. 32KB Block Erase Sequence Diagram CS 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 52H 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB Rev 2.2 May/08/2021 Page 27 XT25F16B 3.3V QUAD IO Serial Flash 6.17. 64KB Block Erase (BE) (D8H) The 64KB Block Erase (BE) command is for erasing the all data of the chosen block. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The 64KB Block Erase (BE) command is entered by driving CS# low, followed by the command code, and three address bytes on SI. Any address inside the block is a valid address for the 64KB Block Erase (BE) command. CS# must be driven low for the entire duration of the sequence. The 64KB Block Erase command sequence: CS# goes low Sending 64KB Block Erase command 3-byte address on SICS# goes high. The command sequence is shown in Figure 18. CS# must be driven high after the eighth bit of the last address byte has been latched in; otherwise the 64KB Block Erase (BE) command is not executed. As soon as CS# is driven high, the self-timed Block Erase cycle (whose duration is tBE) is initiated. While the Block Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Block Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A 64KB Block Erase (BE) command applied to a block which is protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bits (see Table1.0 & 1.1) will not be executed. Note: Power disruption during erase operation will cause incomplete erase and data corruption, thus recommend to perform a re-erase once power resume. Figure 18. 64KB Block Erase Sequence Diagram CS 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI D8H 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB 6.18. Chip Erase (CE) (60/C7H) The Chip Erase (CE) command is for erasing the all data of the chip. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit .The Chip Erase (CE) command is entered by driving CS# Low, followed by the command code on Serial Data Input (SI). CS# must be driven Low for the entire duration of the sequence. The Chip Erase command sequence: CS# goes lowsending Chip Erase commandCS# goes high. The command sequence is shown in Figure 19. CS# must be driven high after the eighth bit of the command code has been latched in, otherwise the Chip Erase command is not executed. As soon as CS# is driven high, the selftimed Chip Erase cycle (whose duration is tCE) is initiated. While the Chip Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Chip Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. The Chip Erase (CE) command is executed if the Block Protect bits are all 0 or all 1. The Chip Erase (CE) command is ignored if one or more sectors are protected. Note: Power disruption during erase operation will cause incomplete erase and data corruption, thus recommend to perform a re-erase once power resume. Figure 19. Chip Erase Sequence Diagram CS# 0 1 2 3 4 5 6 7 SCLK Command SI Rev 2.2 60H or C7H May/08/2021 Page 28 XT25F16B 3.3V QUAD IO Serial Flash 6.19. Deep Power-Down (DP) (B9H) Executing the Deep Power-Down (DP) command is the only way to put the device in the lowest consumption mode (the Deep Power-Down Mode). It can also be used as an extra software protection mechanism, while the device is not in active use, since in this mode, the device ignores all Write, Program and Erase commands. Driving CS# high deselects the device, and puts the device in the Standby Mode (if there is no internal cycle currently in progress). But this mode is not the Deep Power-Down Mode. The Deep Power-Down Mode can only be entered by executing the Deep Power-Down (DP) command. Once the device has entered the Deep PowerDown Mode, all commands are ignored except the Release from Deep Power-Down and Read Device ID (RDI) command. This releases the device from this mode. The Release from Deep Power-Down and Read Device ID (RDI) command also allows the Device ID of the device to be output on SO. The Deep Power-Down Mode automatically stops at Power-Down, and the device always Power-Up in the Standby Mode. The Deep Power-Down (DP) command is entered by driving CS# low, followed by the command code on SI. CS# must be driven low for the entire duration of the sequence. The Deep Power-Down command sequence: CS# goes lowsending Deep Power-Down commandCS# goes high. The command sequence is shown in Figure 20. CS# must be driven high after the eighth bit of the command code has been latched in; otherwise the Deep Power-Down (DP) command is not executed. As soon as CS# is driven high, it requires a delay of tDP before the supply current is reduced to ICC2 and the Deep PowerDown Mode is entered. Any Deep Power-Down (DP) command, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. Figure 20. Deep Power-Down Sequence Diagram CS# tDP 0 1 2 3 4 5 6 7 SCLK Command SI Stand-by mode Deep Power-down mode B9H 6.20. Release from Deep Power-Down and Read Device ID (RDI) (ABH) The Release from Power-Down and Read/Device ID command is a multi-purpose command. It can be used to release the device from the Power-Down state or obtain the devices electronic identification (ID) number. To release the device from the Power-Down state, the command is issued by driving the CS# pin low, shifting the instruction code “ABH” and driving CS# high as shown in Figure21. Release from Power-Down will take the time duration of tRES1 (See AC Characteristics) before the device will resume normal operation and other command are accepted. The CS# pin must remain high during the tRES1 time duration. When used only to obtain the Device ID while not in the Power-Down state, the command is initiated by driving the CS# pin low and shifting the instruction code “ABH” followed by 3-dummy byte. The Device ID bits are then shifted out on the falling edge of SCLK with most significant bit (MSB) first as shown in Figure21a. The Device ID value for the XT25F16B is listed in Manufacturer and Device Identification table. The Device ID can be read continuously. The command is completed by driving CS# high. When used to release the device from the Power-Down state and obtain the Device ID, the command is the same as previously described, and shown in Figure 21a, except that after CS# is driven high it must remain high for a time duration of tRES2 (See AC Characteristics). After this time duration the device will resume normal operation and other command will be accepted. If the Release from Power-Down/Device ID command is issued while an Erase, Program or Write cycle is in process (when WIP equal 1) the command is ignored and will not have any effect on the current cycle. Rev 2.2 May/08/2021 Page 29 XT25F16B 3.3V QUAD IO Serial Flash Figure 21. Release Power-Down Sequence Diagram CS tRES1 0 1 2 3 4 5 6 7 SCLK Command SI ABH Deep Power-down mode Stand-by mode Figure 21a. Release Power-Down/Read Device ID Sequence Diagram CS 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 SCLK Command SI ABH tRES2 3 Dummy Bytes 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB SO Device ID High-Z MSB 7 6 5 4 3 2 1 0 Stand-by Mode Rev 2.2 May/08/2021 Page 30 XT25F16B 3.3V QUAD IO Serial Flash 6.21. Read Manufacture ID/ Device ID (REMS) (90H) The Read Manufacturer/Device ID command is an alternative to the Release from Power-Down / Device ID command that provides both the JEDEC assigned Manufacturer ID and the specific Device ID. The command is initiated by driving the CS# pin low and shifting the command code “90H” followed by a 24-bit address (A23-A0) of 000000H. After which, the Manufacturer ID and the Device ID are shifted out on the falling edge of SCLK with most significant bit (MSB) first is shown in Figure 22. If the 24-bit address is initially set to 000001H, the Device ID will be read first. Figure 22. Read Manufacture ID/ Device ID Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 90H 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 SCLK SI Manufacturer ID SO 7 6 5 4 3 2 1 MSB Manufacturer ID Device ID 0 7 6 5 4 3 2 1 MSB 0 7 6 5 4 3 2 1 0 MSB 6.22. Read Unique ID (RUID) (90H) Please contact XTX FAE for detail. 6.23. Read Identification (RDID) (9FH) The Read Identification (RDID) command allows the 8-bit manufacturer identification to be read, followed by two bytes of device identification. The device identification indicates the memory type in the first byte, and the memory capacity of the device in the second byte. Any Read Identification (RDID) command while an Erase or Program cycle is in progress, is not decoded, and has no effect on the cycle that is in progress. The Read Identification (RDID) command should not be issued while the device is in Deep Power-Down Mode. The device is first selected by driving CS# to low. Then, the 8-bit command code for the command is shifted in. This is followed by the 24-bit device identification, stored in the memory, being shifted out on Serial Data Output, each bit being shifted out during the falling edge of Serial Clock. The command sequence is shown in Figure23. The Read Identification (RDID) command is terminated by driving CS# to high at any time during data output. When CS# is driven high, the device is put in the Standby Mode. Once in the Standby Mode, the device waits to be selected, so that it can receive, decode and execute commands. Rev 2.2 May/08/2021 Page 31 XT25F16B 3.3V QUAD IO Serial Flash Figure 23. Read Identification ID Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 SCLK Command SI 9FH Manufacturer ID High-Z SO 7 6 5 4 3 2 1 Memory Type JDID15-JDID8 0 7 6 5 4 3 2 1 Capacity JDID7-JDID0 0 7 6 5 4 3 2 1 0 High-Z MSB 6.24. High Speed Mode(HSM)(A3H) The High Speed Mode (HSM) command must be executed prior to Dual or Quad I/O commands when operating at high frequencies (see fR and fC1 in AC Electrical Characteristics). This command allows pre-charging of internal charge pumps so the voltages required for accessing the flash memory array are readily available. The command sequence: CS# goes low Sending A3H command Sending 3-dummy byte CS# goes high. See Figure24. After the HSM command is executed, the device will maintain a slightly higher standby current (ICC8) than standard SPI operation. The Release from Power-Down or HSM command (ABH) can be used to return to standard SPI standby current (ICC1). In addition, Write Enable command (06H) and Power-Down command (B9H) will also release the device from HSM mode back to standard SPI standby state. Figure 24. High Speed Mode Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI A3H tHSM 3 Dummy Bytes 23 22 21 20 19 MSB 7 6 5 4 3 2 1 0 High Speed Mode SO Rev 2.2 May/08/2021 Page 32 XT25F16B 3.3V QUAD IO Serial Flash 6.25. Continuous Read Mode Reset (CRMR) (FFH) The Dual/Quad I/O Fast Read operations, “Continuous Read Mode” bits (M7-0) are implemented to further reduce command overhead. By setting the (M7-0) to AXH, the next Dual/Quad I/O Fast Read operations do not require the BBH/EBH/E7H command code. Because the XT25F16B has no hardware reset pin, so if Continuous Read Mode bits are set to “AXH”, the XT25F16B will not recognize any standard SPI commands. So Continuous Read Mode Reset command will release the Continuous Read Mode from the “AXH” state and allow standard SPI command to be recognized. The command sequence is shown in Figure 25. Figure 25. Continuous Read Mode Reset Sequence Diagram CS# Mode Bit Reset for Quad/ Dual I/O 0 1 2 3 4 5 6 7 SCLK SI(IO0) FFH SO(IO1) Don’t care WP#(IO2) Don’t care HOLD#(IO3) Don’t care 6.26. Erase Security Registers (44H) The XT25F16B provides four 256-byte Security Registers which only erased all at once but able to program individually. These registers may be used by the system manufacturers to store security and other important information separately from the main memory array. The Erase Security Registers command is similar to Sector/Block Erase command. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The Erase Security Registers command sequence: CS# goes lowsending Erase Security Registers Command CS# goes high. The command sequence is shown in Figure 26. CS# must be driven high after the eighth bit of the command code has been latched in, otherwise the Erase Security Registers command is not executed. As soon as CS# is driven high, the self-timed Erase Security Registers cycle (whose duration is tSE) is initiated. While the Erase Security Registers cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Erase Security Registers cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. The Security Registers Lock Bit (LB) in the Status Register can be used to OTP protect the security registers. Once the LB bit is set to 1, the Security Registers will be permanently locked; the Erase Security Registers command will be ignored. Address A23-A16 A15-A10 A9-A0 Security Registers 00000000 000000 Don’t Care Rev 2.2 May/08/2021 Page 33 XT25F16B 3.3V QUAD IO Serial Flash Figure 26. Erase Security Registers command Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 24-bit address(A23:A0) 44H 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB 6.27. Program Security Registers (42H) The Program Security Registers command is similar to the Page Program command. It allows from 1 to 256 bytes Security Registers data to be programmed. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before sending the Program Security Registers command. The Program Security Registers command is entered by driving CS# Low, followed by the command code (42H), three address bytes and at least one data byte on SI. As soon as CS# is driven high, the self-timed Program Security Registers cycle (whose duration is tPP) is initiated. While the Program Security Registers cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Program Security Registers cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. If the Security Registers Lock Bit (LB) is set to 1, the Security Registers will be permanently locked. Program Security Registers command will be ignored. Address A23-A16 A15-A8 A7-A0 Security Registers 0 00H 00H Byte Address Security Registers 1 00H 01H Byte Address Security Registers 2 00H 02H Byte Address Security Registers 3 00H 03H Byte Address Figure 27. Program Security Registers command Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 SCLK 24-bit address(A23:A0) Command SI 42H 23 22 21 20 19 Data Byte1 7 6 5 4 3 2 1 MSB 0 7 6 5 4 3 2 1 0 MSB 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 2072 2073 2074 2075 2076 2077 2078 2079 CS# SCLK Data Byte2 SI 7 6 5 4 3 2 1 MSB Rev 2.2 Data Byte3 0 7 6 5 4 3 2 1 MSB Data Byte4 0 7 6 5 4 3 2 1 MSB May/08/2021 Data Byte256 0 7 6 5 4 3 2 1 0 MSB Page 34 XT25F16B 3.3V QUAD IO Serial Flash 6.28. Read Security Registers (48H) The Read Security Registers command is similar to Fast Read command. The command is followed by a 3byte address (A23-A0) and a dummy byte, each bit being latched-in during the rising edge of SCLK. Then the memory content, at that address, is shifted out on SO, each bit being shifted out, at a Max frequency fC, during the falling edge of SCLK. The first byte addressed can be at any location. The address is automatically incremented to the next address after each byte of data is shifted out. Once the A9-A0 address reaches the last byte of the register (Byte 3FFH), it will reset to 000H, the command is completed by driving CS# high. Address A23-A16 A15-A10 A9-A0 Security Registers 00000000 000000 Address Figure 28. Read Security Registers command Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 48H 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 SCLK Dummy Byte SI 7 6 5 4 3 2 1 0 Data Out1 SO 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 Data Out3 0 MSB MSB Rev 2.2 Data Out2 May/08/2021 Page 35 XT25F16B 3.3V QUAD IO Serial Flash 6.29. Enable Reset (66H) and Reset (99H) If the Reset command is accepted, any on-going internal operation will be terminated and the device will return to its default power-on state and lose all the current volatile settings, such as Volatile Status Register bits, Write Enable Latch status (WEL), Read Parameter setting (P7-P0), Continuous Read Mode bit setting(M7-M0) and Wrap Bit Setting (W6-W4). The “Reset (99H)” command sequence as follow: CS# goes low  Sending Enable Reset command  CS# goes high  CS# goes low  Sending Reset command  CS# goes high. Once the Reset command is accepted by the device, the device will take approximately tRST_R to reset. During this period, no command will be accepted. Data corruption may happen if there is an internal Erase or Program operation when Reset command sequence is accepted by the device. It is recommended to check the BUSY bit and the SUS bit in Status Register before issuing the Reset command sequence. Figure 29. Enable Reset and Reset command Sequence Diagram CS# 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 SCLK Command SI Rev 2.2 High-Z 66H Command 99H May/08/2021 Page 36 XT25F16B 3.3V QUAD IO Serial Flash 7. ELECTRICAL CHARACTERISTICS 7.1. Power-on Timing Vcc(max) Chip Selection is not allowed Vcc(min) tVSL Device is fully accessible VWI Time Power-Up Timing and Write Inhibit Threshold Symbol Parameter Min tVSL VCC(min) To CS# Low 1 VWI Write Inhibit Voltage 1.5 Max Unit ms 2.5 V 7.2. Initial Delivery State The device is delivered with the memory array erased: all bits are set to 1(each byte contains FFH).The Status Register contains 00H (all Status Register bits are 0). 7.3. Data Retention and Endurance Parameter Data Retention Time Erase/Program Endurance Typical Unit 20 Years 100K Cycles Min Max 7.4. Latch up Characteristics Parameter Input Voltage Respect To VSS On I/O Pins -1.0V VCC Current Rev 2.2 -100mA May/08/2021 VCC+1.0V 100mA Page 37 XT25F16B 3.3V QUAD IO Serial Flash 7.5. Absolute Maximum Ratings Parameter Value Unit Ambient Operating Temperature -40 to 85 ℃ Storage Temperature -65 to 150 ℃ Output Short Circuit Current 200 mA Applied Input/Output Voltage -0.5 to 4.0 V VCC -0.5 to 4.0 V 7.6. Capacitance Measurement Condition Symbol Parameter Min Typ Max Unit Conditions CIN Input Capacitance 6 pF VIN=0V COUT Output Capacitance 8 pF VOUT=0V CL Load Capacitance 30 Input Rise And Fall time pF 5 ns Input Pulse Voltage 0.1VCC to 0.8VCC V Input Timing Reference Voltage 0.2VCC to 0.7VCC .8 0.5VCC V Output Timing Reference Voltage V VCC Figure30. Input Test Waveform and Measurement Level Maximum Negative Overshoot Waveform 20ns 20ns VSS VSS-2.0V 20ns Maximum Positive Overshoot Waveform 20ns VCC+2.0V VCC 20ns Rev 2.2 May/08/2021 20ns Page 38 XT25F16B 3.3V QUAD IO Serial Flash 7.7. DC Characteristics (T=-40℃~85℃,VCC=2.7~3.6V) Symbol Parameter Test Condition Min. Typ Max. Unit ILI Input Leakage Current ±2 μA ILO Output Leakage Current ±2 μA CS#=VCC ICC1 Standby Current VIN=VCC or VSS CS#=VCC 1 5 μA ICC2 Deep Power-Down Current VIN=VCC or VSS 1 5 μA 15 20 mA 13 18 mA 7 10 mA CLK=0.1VCC/0.9VCC at 120MHz, Q=Open(*1 I/O) CLK=0.1VCC/0.9VCC at 80MHz, Q=Open(*1,*2,*4 ICC3 Operating Current(Read) I/O) CLK=0.1VCC/0.9VCC at 50MHZ,Q=Open(*1 I/O) ICC4 Operating Current(PP) CS#=VCC 30 mA ICC5 Operating Current(WRSR) CS#=VCC 30 mA ICC6 Operating Current(SE) CS#=VCC 30 mA ICC7 Operating Current(BE) CS#=VCC 30 mA ICC8 High Speed Current 800 uA VIL Input Low Voltage -0.5 0.2VCC V VIH Input High Voltage 0.7VCC VCC+0.4 V VOL Output Low Voltage IOL=1.6mA 0.4 V VOH Output High Voltage IOH=-100uA 600 VCC-0.2 V Note: 1. Typical values given for TA=25°C. 2. Value guaranteed by design and/or characterization, not 100% tested in production. Rev 2.2 May/08/2021 Page 39 XT25F16B 3.3V QUAD IO Serial Flash 7.8. AC Characteristics (T=-40℃~85℃,VCC=2.7~3.6V,CL=30pF) Symbol Parameter Min. Typ. Max. Unit fC Serial Clock Frequency For:Fast Read(0BH), Dual Output(3BH) 120 MHz fC1 Serial Clock Frequency For:Dual I/O(BBH), Quad I/O(EBH),Quad Output(6BH) (Dual I/O & Quad I/O With High Speed mode) 80 MHz fC2 Serial Clock Frequency For:Dual I/O(BBH), Quad I/O(EBH) (Dual I/O & Quad I/O Without High Speed mode) 80 MHz 80 MHz fR Serial Clock Frequency For: Read Data(03H), Read Identification ID(9FH), Read Manufacture ID (90H) tCLH Serial Clock High Time 45%PC ns tCLL Serial Clock Low Time 45%PC ns tCLCH Serial Clock Rise Time(Slew Rate) 0.2 V/ns tCHCL Serial Clock Fall Time(Slew Rate) 0.2 V/ns tSLCH CS# Active Setup Time 5 ns tCHSH CS# Active Hold Time 5 ns tSHCH CS# Not Active Setup Time 5 ns tCHSL CS# Not Active Hold Time 5 ns tSHSL CS# High Time (read/write) 20 ns tSHQZ Output Disable Time tCLQX Output Hold Time 1 ns tDVCH Data In Setup Time 2 ns tCHDX Data In Hold Time 2 ns tHLCH Hold# Low Setup Time(relative to Clock) 5 ns tHHCH Hold# High Setup Time(relative to Clock) 5 ns tCHHL Hold# High Hold Time(relative to Clock) 5 ns tCHHH Hold# Low Hold Time(relative to Clock) 5 ns tHLQZ Hold# Low To High-Z Output 6 ns tHHQX Hold# Low To Low-Z Output 6 ns tCLQV Clock Low To Output Valid 5.5 ns tWHSL Write Protect Setup Time Before CS# Low 20 ns tSHWL Write Protect Hold Time After CS# High 100 ns tDP CS# High To Deep Power-Down Mode 0.1 us tRES1 CS# High To Standby Mode Without Electronic Signature Read 0.1 us tRES2 CS# High To Standby Mode With Electronic Signature Read 0.1 us tHSM CS# High To High Speed mode 0.1 us tRST_R CS# High To Next Command After Reset (from read) 20 tRST_P CS# High To Next Command After Reset (from pro- 20 Rev 2.2 6 May/08/2021 ns Page 40 XT25F16B 3.3V QUAD IO Serial Flash gram) tRST_E CS# High To Next Command After Reset (from erase) 12 tW Write Status Register Cycle Time 60 3000 ms tPP Page Programming Time 0.5 0.7 ms tSE Sector Erase Time 150 4000 ms tBE Block Erase Time(32K Bytes/64K Bytes) 0.3/0.4 3/4 s tCE Chip Erase Time 7 20 s Note: 1. Typical values given for TA=25°C. 2. Value guaranteed by design and/or characterization, not 100% tested in production. Rev 2.2 May/08/2021 Page 41 XT25F16B 3.3V QUAD IO Serial Flash Figure 31. Serial Input Timing tSHSL CS# tCHSL tCHSH tSLCH tSHCH SCLK tDVCH SI tCHCL tCLCH tCHDX MSB LSB High-Z SO Figure 32. Output Timing CS# tCLH tSHQZ SCLK tCLQV tCLQX tCLL tCLQV tCLQX LSB SO SI Least significant address bit (LSB) in Figure 33. Hold Timing CS# tCHHL tHLCH tHHCH SCLK tHLQZ SO tCHHH tHHQX HOLD# SI do not care during HOLD operation Rev 2.2 May/08/2021 Page 42 XT25F16B 3.3V QUAD IO Serial Flash 8. ORDERING INFORMATION The ordering part number is formed by a valid combination of the following XT 25F 16B SO I G U Company Prefix XT = XTX Product Family 25F = 2.7~3.6V Serial Flash Memory with 4KB Uniform-Sector Product Density 16B = 16M bit Product Package SO = SOP8(150mil) SS = SOP8(208mil) DF = DFN8(2x3x0.55mm) DT = DFN8(2x3x0.40mm) WO = WSON 6x5 Temperature & Moisture Sensitivity Level I = Industrial Level Temp. (-40℃ to +85℃), MSL3 Green Code G = Green/Reach Package Product Carrier U = Tube; T = Tape & Reel; A = Tray Rev 2.2 May/08/2021 Page 43 XT25F16B 3.3V QUAD IO Serial Flash 9. PACKAGE INFORMATION 9.1. Package SOP8 150MIL e 8 b b1 5 c c1 With Plating Base Metal Detail “B” E1 E b “B” 4 Θ 1 L L1 Detail “A” “A” A2 A h A1 D SYMBOL A A1 A2 b b1 c c1 D E1 e E h L L1 θ Rev 2.2 c MIN — 0.10 1.30 0.39 0.38 0.20 0.19 4.80 3.80 5.80 0.25 0.50 0° MILLIMETER NOM MAX — 1.75 — 0.25 1.40 1.50 — 0.47 0.41 0.44 — 0.24 0.20 0.21 4.90 5.00 3.90 4.00 1.27BSC 6.00 6.20 — 0.50 — 0.80 1.05REF — 8° May/08/2021 Page 44 XT25F16B 3.3V QUAD IO Serial Flash 9.2. Package SOP8 208MIL b b1 E1 E c c1 With Plating Base Metal c D A3 e A2 A L 0.25 L1 b SYMBOL A A1 A2 A3 b b1 c c1 D E E1 e L L1 θ Rev 2.2 θ° GAGE PLANE SEATING PLANE A1 MIN 1.75 0.05 1.70 0.75 0.33 0.30 0.17 0.15 5.13 7.70 5.18 0.50 0° MILLIMETER NOM 1.95 0.15 1.80 0.80 — — — 0.20 5.23 7.90 5.28 1.27 BSC 0.65 1.31 REF — May/08/2021 MAX 2.15 0.25 1.90 0.85 0.51 0.48 0.25 0.23 5.33 8.10 5.38 0.80 8° Page 45 XT25F16B 3.3V QUAD IO Serial Flash 9.3. Package DFN8 (2x3x0.55) mm b e L L1 D h Pin 1 Corner 1 2 Nd EXPOSED THERMAL PAD ZONE BOTTOM VIEW c A1 A TOP VIEV h E E2 D2 SIDE VIEW SYMBOL A A1 b c D D2 e Nd E E2 L L1 h Rev 2.2 MIN 0.50 0 0.18 0.10 1.90 1.50 2.90 0.10 0.30 0.05 0.05 MILLIMETER NOM 0.55 0.02 0.25 0.15 2.00 1.60 0.50BSC 1.50BSC 3.00 0.20 0.35 0.10 0.15 May/08/2021 MAX 0.60 0.05 0.30 0.20 2.10 1.70 3.10 0.30 0.40 0.15 0.25 Page 46 XT25F16B 3.3V QUAD IO Serial Flash 9.4. Package DFN8(2x3x0.40) mm D e L1 b 8 8 L D2 E2 E h h EXPOSED THERMAL PAD ZONE PIN1 Laser Mark 1 b1 2 2 1 Nd SIDE VIEW TOP VIEW BOTTOM VIEW A c A1 SIDE VIEW SYMBOL A A1 b b1 c D D2 e Nd E E2 L L1 h Rev 2.2 MIN 0.35 0 0.20 1.90 1.50 2.90 0.10 0.40 0.05 0.10 MILLIMETER NOM — 0.02 0.25 0.18REF 0.127REF 2.00 1.60 0.50BSC 1.50BSC 3.00 0.20 0.45 0.10 0.15 May/08/2021 MAX 0.40 0.05 0.30 2.10 1.70 3.10 0.30 0.50 0.15 0.20 Page 47 XT25F16B 3.3V QUAD IO Serial Flash 9.5. Package WSON (6x5) mm A A1 L 1 8 8 1 h h b 2 E 2 Nd E2 e b1 c D2 EXPOSED THERMAL PAD ZONE D TOP VIEW SIDE VIEW BOTTOM VIEW SIDE VIEW SYMBOL MILLIMETER MIN NOM MAX A 0.70 0.75 0.80 A1 0.00 0.02 0.05 b 0.35 0.40 0.45 b1 Rev 2.2 0.25 REF c 0.18 0.20 0.25 D 5.90 6.00 6.10 Nd 3.81 BSC e 1.27 BSC E 4.90 5.00 5.10 D2 3.30 3.40 3.50 E2 3.90 4.00 4.10 L 0.55 0.60 0.65 h 0.30 0.35 0.40 May/08/2021 Page 48 3.3V QUAD IO Serial Flash XT25F16B 10. REVISION HISTORY Revision Description Date 0.0 Initial Release Jul 18, 2017 0.1 Revise SOP8 150/208mil & DFN8 package dimension drawing Aug 3, 2017 0.2 Revise error on page #3,5 & page #23 &24 Quad Read dummy cycle to 6. Aug 16, 2017 Add ICC3 (CLK=0.1VCC/0.9VCC at 50MHZ,Q=Open(*1 I/O)): 5mA typ; 0.3 Aug 22, 2017 0.4 Revise Data Retention table page #36 & add read ID max clock page #39, include package carrier for tray type. Dec 4, 2017 0.5 Include DFN8 4x3 package type and correct “9F” read ID timing diagram Mar 22, 2018 0.6 Revise connect diagram, cover page and include menu Apr 4, 2018 0.7 Revise to add industrial plus grade OPN and upgrade format & menu bookmark capability. Jul 26, 2018 0.8 Revise to modify format Aug 13,2018 0.9 Revise to change erase performance for tBE, tSE, tW & typical & max time and tCE max time at page #41. Aug 16,2018 1.0 Revise “FR” serial clock frequency for read ID (90H), remove company address. Add MSL information. Aug-30-2018 1.1 Revise to correct typo at page#8 memory organization; FC2 clock to 80MHZ page#40 and ICC1 & ICC2 current at page #39. Oct-16-2018 1.2 Add Package DFN8(2x3x0.55) mm Oct-19-2018 1.3 Revise to change advance security features from 3x256 to 4x256 byte page #2 and revise 42H command description security register table page #35 Nov-09-2018 1.4 Revise to include UID feature, update command table, remove erase/program suspend/resume command. Dec-13-2018 1.5 Revise to add note of external pull-up under single and dual mode, and add description about power disruption during erase operation Mar-14-2018 1.6 Updated AC Characteristics Aug-14-2019 1.7 Updated to change tCLQV in AC Characteristics from 6.5ns to 5.5ns based on simulation result Sep-3-2019 1.8 Updated AC Characteristics based on qual report Dec-19-2019 1.9 Deleted high temperature OPNs and package TSOP8, DFN 4X3, DFN 4X4 April-8-2020 2.0 Updated data protection and figure number, change the sequence of status register and data protection. Oct-10-2020 2.1 2.2 Rev 2.2 Modify Protected area size; Add Write Enable for Volatile Status Register (50H); Add Enable Reset (66H) and Reset (99H); Modify AC CHARACTERISTICS; Re-correct Quad read dummy cycle to 4. Update POD of SOP8 150MIL, DFN8(2x3x0.4)mm,WSON8(6x5)mm Update the connection diagram of 8-PIN SOP and 8-PIN DFN/WSON Adjust Vwl min from “-“ to “1.5”, Vwl max from “1.5“ to “2.5” May/08/2021 Apr-02-2021 May-08-2021 Page 49
XT25F16BDFIGT
物料型号:XT25F16B,这是芯天下技术股份有限公司生产的3.3V四IO串行闪存芯片。
器件简介:XT25F16B是一款16M位的串行闪存,支持标准SPI、双SPI和四SPI接口。它具有256字节的可编程页面,支持4KB、32KB和64KB的扇区/块擦除,具备灵活的架构和先进的安全特性。
引脚分配:文档中提供了详细的引脚描述和连接图,包括8引脚SOP和8引脚DFN/WSON两种封装方式。
参数特性: - 工作电压:2.7~3.6V - 工作温度范围:工业级温度范围(-40℃至+85℃) - 功耗:最大活跃电流30mA,典型掉电电流1uA - 编程/擦除周期:最少100,000次 - 时钟频率:高达120MHz,支持快速读取
功能详解:包括内存组织、设备操作、状态寄存器、数据保护、命令描述等。文档详细描述了各种操作模式和命令,如页编程、扇区擦除、块擦除和芯片擦除等。
应用信息:XT25F16B适用于需要高可靠性和数据保护的应用场景,例如工业控制、汽车电子和物联网设备。
封装信息:提供了多种封装选项,包括SOP8、DFN8和WSON等,所有无铅封装均符合RoHS、无卤素和REACH标准。
XT25F16BDFIGT 价格&库存
很抱歉,暂时无法提供与“XT25F16BDFIGT”相匹配的价格&库存,您可以联系我们找货
