BZX84C9V1
BZX84C9V1
    SMC
    SOT23
    BZX84C9V1
BZX84C9V1 数据手册
BZX84C2V4-BZX84C51 Technical Data Data Sheet N0199, Rev. B BZX84C2V4-BZX84C51 ZENER DIODE Features Planar Die Construction 350mW Power Dissipation 2.4V- 51V Nominal Zener Voltage 5% Standard Vz Tolerance Designed for Surface Mount Application Plastic Material — UL Recognition Flammability Classification 94V-O “-A” is an AEC-Q101 qualified device This is a Halogen Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request       SOT-23 Schematic & Pin Configuration     Mechanical Characteristics     Case: SOT-23, Molded Plastic Terminals: Plated leads Solderable per MIL-STD-750, Method 2026 Mounting Position: Any Weight: 0.008g Maximum Ratings@TA=25°C unless otherwise specified Parameter Power Dissipation Typical Thermal Resistance, Junction to Ambient Operating Junction and Storage Temperature Range Symbol Value Units PD 350 mW RθJA 357 °C/W TJ,TSTG -55 to 150 °C  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  BZX84C2V4-BZX84C51 Technical Data Data Sheet N0199, Rev. B Electrical Characteristics @TA=25°C unless otherwise specified  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  BZX84C2V4-BZX84C51 Technical Data Data Sheet N0199, Rev. B Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  BZX84C2V4-BZX84C51 Technical Data Data Sheet N0199, Rev. B Ordering Information Device BZX84C2V4BZX84C51 Marking Diagram Package Shipping SOT-23 3000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. Z11 = Marking Code Note: If date code is before 2016 year, please contact with factory about marking. Mechanical Dimensions SOT-23 SYMBOL A A1 A2 b c D E E1 e e1 L L1 θ Millimeters MIN. MAX. 0.890 1.150 0.000 0.100 0.900 1.050 0.300 0.500 0.076 0.170 2.650 3.050 1.190 1.400 2.100 2.550 0.950 TYP. 1.780 2.050 0.550 REF. 0.300 0.500 0° 8°  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Inches MIN. MAX. 0.035 0.045 0.000 0.004 0.035 0.041 0.012 0.020 0.003 0.007 0.104 0.120 0.047 0.055 0.083 0.100 0.037 TYP. 0.070 0.081 0.022 REF. 0.012 0.020 0° 8° BZX84C2V4-BZX84C51 Technical Data Data Sheet N0199, Rev. B Carrier Tape Specification SOT-23 SYMBOL A B C d E F P P0 P1 W Min. 3.05 2.67 1.12 1.40 1.65 3.40 3.90 3.90 1.90 7.90 Millimeters Max. 3.25 2.87 1.32 1.60 1.85 3.60 4.10 4.10 2.10 8.30 DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
BZX84C9V1 价格&库存
很抱歉,暂时无法提供与“BZX84C9V1”相匹配的价格&库存,您可以联系我们找货
