ABPY00160808601Y00
ABPY00160808601Y00
    CHILISIN(奇力新)
    单路 0603磁珠 阻抗600Ω@100MHZ
ABPY00160808601Y00 数据手册
Automotive Chip Bead ABPY Series AEC-Q200 RoHS Compliant Halogen Free REACH Compliant ■ Part Numbering A Grade BPY Series Name 00 Control Code 100505 Dimensions Code (mm) 100505 1.0x0.5x0.5 160808 1.6x0.8x0.8 201209 2.0x1.25x0.9 321611 3.2x1.6x1.1 300 Impedance (Ω) 300 30 121 120 102 1000 Y 00 Tolerance Internal Code Y ±25% This specification applies to Multilayer Chip ferrite Bead for Automotive Electronics based on AEC-Q200 except for Power train and Safety. Automotive Chip Bead ABPY Series AEC-Q200 ABPY00100505 Type ■ Dimensions ■ Recommended Land Pattern unit:mm unit:mm ■ Electrical Characteristics Part No. ABPY00100505100Y00 ABPY00100505300Y00 ABPY00100505600Y00 ABPY00100505121Y00 ABPY00100505181Y00 ABPY00100505221Y00 ABPY00100505601Y00 ABPY00100505102Y00 Impedance Test Freq. (Ω) 10 30 60 120 180 220 600 1000 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV RDC Rated Current (Ω)Max. (mA)Max. 0.030 0.050 0.075 0.090 0.140 0.180 0.340 0.490 2000 1700 1500 1400 900 1100 700 500 Note: When ordering, please specify tolerance code. Tolerance: Y=±25% 1. Operating temperature range -40℃~125℃ 2. Rate Current:Applied the current to coils, the temperature rise shall not be more than 30℃ 3. Measure Equipment: Z: HP4291A RDC: HP4338B or CHEN HWA 502 Automotive Chip Bead ABPY Series AEC-Q200 ABPY00100505 Type ■ Characteristics Graph Z 8 6 X 4 R 2 0 1 10 100 100 Z IMPEDANCE(Ω) IMPEDANCE(Ω) IMPEDANCE(Ω) 12 120 50 45 40 35 30 25 20 15 10 5 0 14 10 ABPY00100505600Y00 ABPY00100505300Y00 ABPY00100505100Y00 16 X R 1 10 ABPY00100505121Y00 100 80 ` X R 1 10 100 300 Z 150 100 X 50 R 1 1000 100 1000 1200 700 1000 IMPEDANCE(Ω) 600 Z 500 400 300 200 X R 100 800 Z 600 400 200 R X 0 0 1 10 100 1000 FREQUENCY (MHz) RDC
ABPY00160808601Y00 价格&库存
很抱歉,暂时无法提供与“ABPY00160808601Y00”相匹配的价格&库存,您可以联系我们找货
ABPY00160808601Y00
    • 20+0.08241
    • 200+0.06750
    • 600+0.05919
    库存:1369
