SB5150
SB5150
    PINGWEI(平伟)
    DO-27(DO-201AD)
SB5150 数据手册
00 S B 5 20 THRU S B 52 5200 5 . 0AMP. SCHOTTKY BARRIER RECTIFIERS DO-27/DO-201AD FEATURE .High current capability, .Low forward voltage drop .Low power loss, high efficiency .High surge capability .High temperature soldering guaranteed 260°C /1 0sec/0.375" lead length at 5 lbs tension 0.96(24.4) MIN. .220(5.6) .187(5.0) + .375(9.5) .335(8.5) MECHANICAL DATA .Terminal: Plated axial leads solderable per MIL-STD 202E, method 208C .Case: Molded with UL-94 Class V-0 recognized Flame Retardant Epoxy .Polarity: color band denotes cathode .Mounting position: any DIA. - 0.96(24.4) MIN. .051(1.3) .043(1.1) DIA. Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (single-phase, half-wave, 60HZ, resistive or inductive load rating at 25°C, unless otherwise stated) Type Number Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC blocking Voltage Maximum Average Forward Rectified Current 3/8" lead length at TL =90°C Peak Forward Surge Current SYM BOL SB 520 SB 530 SB 540 SB 550 SB 560 SB 580 SB SB SB SB units 590 5100 5150 5200 VRRM VRMS VDC 20 30 40 50 60 80 90 100 150 200 V 14 21 28 35 42 56 63 70 105 140 V 20 30 40 50 60 80 90 100 150 200 V IF(AV) 5.0 A IFSM 150 A 8.3ms singlehalf sine-wave superimposed on rated load(JEDEC method) Maximum Forward Voltage at 5.0A DC Maximum DC Reverse Current@TA=25°C at rated DC blocking voltage @ TA =100°C Typical Junction Capacitance(Note1) Typical Thermal Resistance(Note2) Storage Temperature Operating Junction Temperature VF IR CJ R(JA) TSTG 0.55 0.70 0.85 0.95 V 0.5 0.1 mA 5.0 3.0 mA 500 112 pF TJ 40 °C /W -55 to +150 °C -55 to +150 °C Note: 1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc 2. Thermal Resistance from Junction to Ambient at 0.5" lead length, vertical P.C. Board Mounted - 1 - 5200)) RATING AND CHARACTERISTIC CURVES (SB520 THRU SB5200 FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 2.5 Single Phase Half Wave 60Hz Resistive or inductive Load 0 0 50 100 150 V V40 5 10 0V -20 0V V 0 -10 0V 15 8 TJ=25℃ Pulse Width=300μs 1% Duty Cycle 1 .1 200 V 0 -6 0V 20 5.0 INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) 100 0.8 .5 .2 1.1 1.4 INSTANEOUS FORWARD VOLTAGE,(V) AMBIENT TEMPERTURE,(℃) FIG.4-TYPICAL REVERSE CHARACTERISTICS FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT 200 8.3ms Single Half Sine-Wave (JEDEC Method) 150 INSTANEOUS REVERSE CURRENT,(mA) PEAK FORWARD SURGE CURRENT,(A) 10 100 50 0 0 10 1.0 TJ=25℃ .1 .01 100 0 20 40 60 80 100 120 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) NUMBER OF CYCLES AT 60Hz - 2 - 140
SB5150 价格&库存
很抱歉,暂时无法提供与“SB5150”相匹配的价格&库存,您可以联系我们找货
