5.82.000.000/0710
5.82.000.000/0710
    RAFI
    KEYCAPRS76,OPAQUE,1MOD,LGTBEIGE
5.82.000.000/0710 数据手册
RS 76 full-travel keyswitches General data The RS 76 full-travel keyswitches are designed for configuring keyboards. They offer very comfortable operation with an overall height of 15.5 / 15.9 mm and a key travel of 4 mm. The modular system with a grid of 3/4“ = 19.05 mm enables you to design any key block you may want. Mechanical contact system RS 76 M A gold alloy is used as the contact material and provides high contact reliability, low contact resistance and short bouncing time. Solid-state contact system RS 76 C The solid-state switch in Hall-IC technology ensures bounce-free and wear-free switching and a long operating life. Function: When pressing the keys, a permanent magnet changes its position relative to the Hall-IC and thereby generates an output signal. Their use is especially recommended in hostile environments and for heavy duty applications. Content RS 76 M full-travel keyswitch, non-illuminated RS 76 M keyswitch, non-illuminated RS 76 M keyswitch with diode, non-illuminated RS 76 M keyswitch, illuminated RS 76 M keyswitch, illuminated, momentary RS 76 M keyswitch, illuminated, latching RS 76 MX keyswitch, fully illuminated RS 76 C keyswitch, non-illuminated RS 76 C keyswitch, non-illuminated RS 76 C keyswitch, illuminated RS 76 C keyswitch, illuminated, momentary RS 76 C keyswitch, illuminated, latching Keycaps for RS 76, non-illuminated Keycap for RS 76, opaque Keycap for RS 76, opaque, with nail protection Keycap for RS 76 with legend insert Keycaps for RS 76, illuminated Keycap for RS 76 with light bar Keycap for RS 76, illuminated, with legend insert Keycap for RS 76, illuminated, with nail protection and legend insert Keycap for RS 76, illuminated, with legend insert Keycap, fully illuminated, for RS 76 MX Keycaps for RS 76, with legend, two-shot moulded/keycap sets Keycap set for RS 76, symbols A-Z Keycap set for RS 76, symbols 0-9 RS 76 accessories Cover for RS 76 IP40 4 - 126 4 - 127 4 - 127 4 - 128 4 - 129 4 - 129 4 - 130 4 - 132 4 - 133 4 - 134 4 - 135 4 - 135 4 - 136 4 - 136 4 - 137 4 - 137 4 - 138 4 - 138 4 - 139 4 - 139 4 - 140 4 - 140 4 - 142 4 - 142 4 - 143 4 - 144 4 - 144 PCB Keyswitches 4 - 119 Stock items are marked by bold printed order numbers. 4 RS 76 RS 76 full-travel keyswitches The Rafi full-travel keyswitches RS 76 are modular systems for designing individual key blocks and keyboards in the 3/4 inch (= 19.05 mm) grid. Definitions Momentary keyswitches Momentary keyswitches return to their initial position after being pressed (momentary action). Latching keyswitches Latching keyswitches lock when actuated and are returned to their initial position when pressed again (push-push action). Keycap materials Keycap without legend insert: ABS Keycap with legend insert: – Keycap body: ABS – Lens: PC Keycap, n-module A 2-module keycap f. ex. has the twofold length of a 1-module keycap. Contact principle There are two contact principles: – Mechanical (M): Cross contact (RS 76 M) Bridge contact (RS 76 M, illuminated) – Contactless (C): Based on Hall-IC (RS 76 C) Soldering The soldering temperature should not exceed 250 °C, the soldering time not be longer tahn 3 seconds. All RS 76 C-keyswitches can be soldered in solder bathes. The assembled PCB should be cleaned only by using brushing machines from the soldering side ot the PCB. The cleaning agend should not exceed the component side ot the PCB. All keyswitches can be flow-soldered, provided that an acid fluxer is used and that the whole unit is cleaned afterwards in de-ionised water. Cleaning Keyswitches should not be washed in freon or similar substances as a lubricant is used, otherwise the operating life of the keyswitches will be reduced. If complete keyboards are to be cleaned by dipping, it must be remembered that they keyboard may only be dipped in the dipping solution as far as the component side of the PCB. Legending of keycaps Keycaps can be legended by different methods: 4 Two-shot moulding Using this method the symbol is separately manufactured from a plastic and then the appropriate keycap form is moulded round it. Advantage: The character becomes a integrated part of the keycap, thus eliminating abrasion. All Rafi keycap sets with standard legending are manufatured by this method. Customer specific two-shot moulded keycaps on request. Printing Keycaps can be printed with a two-component ink on request. The abrasin of this kind of legending is high. This method of legending is suitable for average volumes. Engraving In this labour intensive process the keycaps are engraved with the required symbol, then inlaid with ink. Only used for small volumes. Laser-printing This method of legending can be recommended when complete keyboards are required in different keyboard layouts for which Rafi will develop the respective software. The keyboards can then be legended within a short time. This method of legending ist particularly recommended for average to large volumes. Legend inserts In the case of keycaps with replaceable legend inserts it is possible to print or engrave the legend inserts. As these insets are protected by the lens, there can be no abrasion here either. RS 76 4 - 120 PCB Keyswitches RS 76 full-travel keyswitches Design No. Description 1.1 Keyswitch RS 76 C 1.2 Keyswitch RS 76 C with LED 1.3 Keyswitch RS 76 M 1.4 Keyswitch R 76 M with LED 2 Keycap, 1- resp. multi-module 3 Keycap with nail protection, 1- resp. multi-module 5 Keycap, illuminated 6 Keycap, illuminated 7 Keycap, illuminated 8 LED 9 Spacer for LED (for RS 76 C only) 10.1 Plunger for mult-moduel keycaps* 10.2 Sleeve for multi-moduel keycaps* 10.3 Metal lever for multi-module keycaps* 10.4 Bearing bracket for multi-module keycaps* 11 Covers 4 * These parts are included as a complete packet in the delivery of keycaps ≥ 2-module. RS 76 PCB Keyswitches 4 - 121 RS 76 full-travel keyswitches Hole Pattern PCB RS 76 M/RS 76 C The hole patterns apply to the horizontal position of the keycaps only. Should they be in a vertical position, the momentary keyswitch must be mounted accordingly, i.e. rotated by 90°. For 1 – 13/4-module keycaps (view on component side) Momentary keyswitch, non-illuminated Momentary keyswitch, illuminated RS 76 M RS 76 C 4 For 2-, 3- and 8-module keycaps (view on component side) RS 76 M/C Hole diam. 2 Nor through-plating • 4 holes for bearing bracket diam. 1.1 No through-plating Keycap RS 76 4 - 122 L1 mm L2 mm 2-module 25.40 22.86 3-module 30.48 24.13 5-module 68.58 68.58 Metal bow touches the surface of PCB, in this area no conductor tracks on component side Important note: In the case of 2-, 3- and 8-module keycaps, additional holes must be provided for the accessories. In the case of keycaps < 2-module, neither accessories nor holes are required. PCB Keyswitches RS 76 full-travel keyswitches Specific Technical Data RS 76 C Output pulse diagram Dynamic characteristics (max.) Tw = 25 °C Tw = 50 °C Tw = 70 °C Turn-on delay time tPHL 3 µs 7 µs 10 µs Turn-off delay time tPHL 4 µs 5 µs 6 µs Fall/rise time tPHL 2 µs 2,5 µs 3 µs tPHL 1 µs 1,5 µs 2,5 µs 4 Static with Enable Input RS 76 PCB Keyswitches 4 - 123 RS 76 full-travel keyswitches Examples for Application RS 76 C Driving of logic components Indication of logical states Driving of a PNP transistor Use as static key with open collector output. Output transistor (NPN) is conductive when actuated. 4 RS 76 Use in keyboards 4 - 124 PCB Keyswitches RS 76 full-travel keyswitches RS 76 M full-travel keyswitch, non-illuminated Technical data General information Recommended key grid Mechanical design Contact function Mounting Terminals 4 19.05 mm Contact system Contact arrangement Contact materials Illumination momentary soldering solder terminals, tin-plated cross contact 1 NO Au alloy no Mechanical characteristics Operating force max. Operating travel Switching travel Robustness min. see order block 4 mm 1.5 - 2.8 mm 100 N Electrical characteristics Rated voltage min. Rated voltage max. Rated current min. Rated current max. Rated power max. Contact resistance when new max. Contact resistance acc. to life max. Insulation resistance ESD strength max. Bouncing time max. Other specifications Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. (product) Storage temperature max. (rail) Resistance to constant environment Resistance at variable environment Operating life min. Degree of protection Flammability of materials -25 °C +70 °C -40 °C +80 °C +50 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 107 IP40 UL 94 HB 2 V (with Diode 3 V) 42 V 0.01 mA 100 mA 1W 100 mΩ (without Diode) 3 Ω (without Diode) 109 Ω 8 kV 5 ms Accessories RS 76 M full-travel keyswitch, non-illuminated Description RS 76 Photo Order no. Page Keycap for RS 76 with legend insert 5.04.665.222/5520 4 - 137 Keycap for RS 76, opaque, with nail protection 5.80.000.000/0710 4 - 137 Keycap for RS 76, opaque 5.82.000.000/0152 4 - 136 4 - 126 Stock items are marked by bold printed order numbers. PCB Keyswitches RS 76 full-travel keyswitches RS 76 M keyswitch, non-illuminated Contact function Illumination Contact arrangement Contact materials Operating travel Operating force max. Order no. complete momentary no 1 NO Au alloy 4 mm 0.9 N 3.13.002.502/0000 momentary no 1 NO Au alloy 4 mm 1.4 N 3.13.002.512/0000 Technical data see page 4 - 126 For accessories, refer to RS 76 special accessories. For keycaps, see keycaps for RS 76. RS 76 M keyswitch with diode, non-illuminated Contact function Illumination Contact arrangement Contact materials Operating travel Operating force max. Order no. complete momentary no 1 NO Au alloy 4 mm 0.9 N 3.13.005.001/0000 momentary no 1 NO Au alloy 4 mm 1.4 N 3.13.005.011/0000 4 Technical data see page 4 - 126 For accessories, refer to RS 76 special accessories. For keycaps, see keycaps for RS 76. RS 76 PCB Keyswitches Stock items are marked by bold printed order numbers. 4 - 127 RS 76 full-travel keyswitches RS 76 M keyswitch, illuminated Pict.: RS 76M, for spot illumination RS 76MX, for full illumination RS 76MX, keyboard fully illuminated Technical data General information Recommended key grid Mechanical design Contact function Mounting Terminals 4 Contact system Contact arrangement Contact materials Illumination see order block soldering solder terminals, tin-plated bridge contact 1 NO Au alloy see order block Mechanical characteristics Operating force max. Operating travel Switching travel Robustness min. 1N 4 mm 1.5 - 2.8 mm 100 N Electrical characteristics Rated voltage min. Rated voltage max. Rated current min. Rated current max. Rated power max. Contact resistance when new max. Contact resistance acc. to life max. Insulation resistance ESD strength max. Bouncing time max. 19.05 mm Other specifications Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. (product) Storage temperature max. (rail) Resistance to constant environment Resistance at variable environment 2V 42 V 0.01 mA 100 mA 1W Operating life min. Degree of protection Flammability of materials 3Ω 109 Ω 8 kV 10 ms -25 °C +70 °C -40 °C +80 °C +50 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 107 momentary, 105 latching IP40 UL 94 HB 200 mΩ Accessories RS 76 M keyswitch, illuminated Description RS 76 Photo Order no. Page LED yellow, 3mm 1.90.690.103/0000 5 - 21 Cover for RS 76 IP40, 1-module, dark grey 5.04.520.174/0801 4 - 145 Keycap for RS 76, illuminated, with legend insert 5.04.665.522/5520 4 - 139 Keycap for RS 76, illuminated, with nail protection and legend insert 5.04.665.912/5520 4 - 139 Keycap for RS 76 with light bar 5.82.110.000/0710 4 - 138 4 - 128 Stock items are marked by bold printed order numbers. PCB Keyswitches RS 76 full-travel keyswitches RS 76 M keyswitch, illuminated, momentary Pict.: RS 76M, für Punktausleuchtung Contact function Contact system Illumination Recommended key grid Order no. complete momentary bridge contact spot illumination with 3 mm LED possible 19.05 mm 3.13.002.102/0000 Technical data see page 4 - 128 For accessories, refer to RS 76 special accessories. For keycaps, see keycaps for RS 76. RS 76 M keyswitch, illuminated, latching Contact function Contact system Illumination Recommended key grid Order no. complete latching bridge contact spot illumination with 3 mm LED possible 19.05 mm 3.13.002.022/0000 4 Technical data see page 4 - 128 For accessories, refer to RS 76 special accessories. For keycaps, see keycaps for RS 76. RS 76 PCB Keyswitches Stock items are marked by bold printed order numbers. 4 - 129 RS 76 full-travel keyswitches RS 76 MX keyswitch, fully illuminated Pict.: RS 76MX, full illumination RS 76M, keyboard fully illuminated Contact function Contact system Illumination Recommended key grid Order no. complete momentary bridge contact full illumination with 2 SMD LED possible 19.05 mm 3.13.002.922/0000 Technical data see page 4 - 128 Accessories: Keycap, fully illuminated, for RS 76 MX: 5.05.511.168/0209 Keycap, fully illuminated, for RS 76 MX: 5.05.511.168/0754 For accessories, refer to RS 76 special accessories. For keycaps, see keycaps for RS 76. The SMD LEDs are soldered on the back of the printed circuit board and shine through openings in the board and keyswitch housing. 4 RS 76 4 - 130 Stock items are marked by bold printed order numbers. PCB Keyswitches RS 76 full-travel keyswitches RS 76 C keyswitch, non-illuminated Technical data General information Recommended key grid Mechanical design Contact function Mounting Terminals Contact system Illumination Mechanical characteristics Switching travel off Operating force max. Operating travel Switching travel on Robustness min. 4 Electrical characteristics Operating voltage DC Supply current max. at UIL = 0 V Supply current max. at UIH = 5 V Input voltage (F) at UIL = 0 V Input voltage (F) at UIH = 2.4V Output load current (Q) max. Output residual current (Q) max. Output saturation 19.05 mm momentary soldering solder terminals, tin-plated contactless with Hall-IC no voltage (Q) max. bei 16 mA ESD strength max. Output switching times (Q) bei 25°C, tPHL Output switching times (Q) bei 25°C, tPLH Output switching times (Q) bei 25°C, tTHL Output switching times (Q) bei 25°C, tTLH Other specifications Reliability of Hall-IC’s at 25°C Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. (product) Storage temperature max. (rail) Resistance to constant environment 0.8 ... 2.4 mm see order block 4 mm 1.5 - 2.8 mm 100 N 4.75 ... 5.25 V 0.5 mA 5 mA Resistance at variable environment 0.4 V 5.25 V Operating life min.(mechanical) Degree of protection Flammability of materials 16 mA 10 µA 0.4 V 8 kV 3 µs 4 µs 1 µs 2 µs λ = 2.5 x 10-7 h-1 0 °C +70 °C -40 °C +80 °C +50 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 see order block IP40 UL 94 HB Accessories RS 76 C keyswitch, non-illuminated Description RS 76 Photo Order no. Page Keycap for RS 76 with legend insert 5.04.665.222/5520 4 - 137 Keycap for RS 76, opaque, with nail protection 5.80.000.000/0710 4 - 137 Keycap for RS 76, opaque 5.82.000.000/0152 4 - 136 4 - 132 Stock items are marked by bold printed order numbers. PCB Keyswitches RS 76 full-travel keyswitches RS 76 C keyswitch, non-illuminated Contact function Contact system Illumination Operating force max. Operating travel Order no. complete momentary contactless with Hall-IC contactless with Hall-IC no 0.7 N 4 mm 3.13.001.010/0000 no 1N 4 mm 3.13.001.210/0000 momentary Technical data see page 4 - 132 For accessories and keycaps, refer to RS 76. For applications, refer to the general description of RS 76. 4 RS 76 PCB Keyswitches Stock items are marked by bold printed order numbers. 4 - 133 RS 76 full-travel keyswitches RS 76 C keyswitch, illuminated Technical data General information Recommended key grid Mechanical design Contact function Mounting Terminals 4 19.05 mm Contact system Illumination LED colour see order block soldering solder terminals, tin-plated contactless with Hall-IC with LED see order block Mechanical characteristics Switching travel on Switching travel off Operating force max. Operating travel Robustness min. 1.5 - 2.8 mm 0.8 ... 2.4 mm 0.7 N 4 mm 100 N Electrical characteristics Number of LED Operating voltage DC Supply current max. at UIL = 0 V Supply current max. at UIH = 5 V Input voltage (F) at UIL = 0 V Input voltage (F) at UIH = 2.4V Output load current (Q) max. Output residual current (Q) max. Output saturation voltage (Q) max. bei 16 mA ESD strength max. Output switching times (Q) bei 25°C, tPHL Output switching times (Q) bei 25°C, tPLH Output switching times (Q) bei 25°C, tTHL Output switching times (Q) bei 25°C, tTLH Other specifications Reliability of Hall-IC’s at 25°C Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. (product) Storage temperature max. (rail) Resistance to constant environment see order block 4.75 ... 5.25 V 0.5 mA 5 mA Resistance at variable environment 0.4 V 5.25 V Operating life min. Degree of protection Flammability of materials 16 mA 0.4 V 8 kV 3 µs 4 µs 1 µs 2 µs λ = 2.5 x 10-7 h-1 0 °C +70 °C -40 °C +80 °C +50 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 see order block IP40 UL 94 HB 10 µA Accessories RS 76 C keyswitch, illuminated Description RS 76 Photo Order no. Page LED yellow, 3mm 1.90.690.103/0000 5 - 21 Cover for RS 76 IP40, 1-module, dark grey 5.04.520.174/0801 4 - 145 4 - 134 Stock items are marked by bold printed order numbers. PCB Keyswitches RS 76 full-travel keyswitches Accessories RS 76 C keyswitch, illuminated Description Photo Order no. Page Keycap for RS 76, illuminated, with legend insert 5.04.665.522/5520 4 - 139 Keycap for RS 76, illuminated, with nail protection and legend insert 5.04.665.912/5520 4 - 139 Keycap for RS 76 with light bar 5.82.110.000/0710 4 - 138 RS 76 C keyswitch, illuminated, momentary Contact function Contact system Illumination Operating force max. Operating travel Order no. complete momentary contactless with Hall-IC with LED 0.7 N 3.13.001.110/0000 4 mm Technical data see page 4 - 134 RS 76 C keyswitch, illuminated, latching 4 Contact function Contact system Illumination Operating force max. Operating travel Order no. complete latching contactless with Hall-IC with LED 0.7 N 3.13.001.130/0000 4 mm Technical data see page 4 - 134 RS 76 PCB Keyswitches Stock items are marked by bold printed order numbers. 4 - 135 RS 76 full-travel keyswitches Keycaps for RS 76, non-illuminated Keycap for RS 76, opaque 4 Size of keycap Illuminable Colour of keycap / legending Colour of lens / legend insert Order no. complete 1-module no light beige/- 5.82.000.000/0710 1-module no light grey/- 5.82.000.000/0242 1-module no dark grey/- 5.82.000.000/0801 1-module no charcoal grey/- 5.82.000.000/0152 Keycap sets available in two-shot moulded design. Other keycap sizes, e.g. 1.25-, 1.5-, 1.75-, 2-, 3-, 5- and 8-module versions available on request. RS 76 4 - 136 Stock items are marked by bold printed order numbers. PCB Keyswitches RS 76 full-travel keyswitches Keycap for RS 76, opaque, with nail protection Size of keycap Illuminable Colour of keycap / legending Colour of lens / legend insert Order no. complete 1-module no light beige/- 5.80.000.000/0710 1-module no light grey/- 5.80.000.000/0242 1-module no dark grey/- 5.80.000.000/0801 1-module no charcoal grey/- 5.80.000.000/0152 Keycap sets available in two-shot moulded design. Other keycap sizes, e.g. 1.25-, 1.5-, 1.75-, 2-, 3- and 8-module versions available on request. Keycap for RS 76 with legend insert 4 Size of keycap Illuminable Colour of keycap / legending Colour of lens / legend insert Order no. complete 1-module no light beige/- colourless/white 5.04.665.222/5520 1-module no dark grey/- colourless/white 5.04.665.228/5520 1-module no charcoal grey/- colourless/white 5.04.665.221/5520 1-module no light grey/- colourless/white 5.04.665.230/5520 Supplied as single parts: Mat lens, legend insert, keycap body. RS 76 PCB Keyswitches Stock items are marked by bold printed order numbers. 4 - 137 RS 76 full-travel keyswitches Keycaps for RS 76, illuminated Pict.: 1,5-module, light grey, green lens light beige Keycap for RS 76 with light bar Pict.: light beige 4 Size of keycap Illuminable Colour of keycap / legending Colour of lens / legend insert Order no. complete 1-module yes light beige/- 5.82.110.000/0710 1-module yes light grey/- 5.82.110.000/0242 1-module yes dark grey/- 5.82.110.000/0801 1-module yes charcoal grey/- 5.82.110.000/0152 RS 76 4 - 138 Stock items are marked by bold printed order numbers. PCB Keyswitches RS 76 full-travel keyswitches Keycap for RS 76, illuminated, with legend insert Pict.: 1,5-module, light grey, green lens Size of keycap Illuminable Colour of keycap / legending Colour of lens / legend insert Order no. complete 1-module yes light beige/- colourless/white 5.04.665.522/5520 1-module yes dark grey/- colourless/white 5.04.665.528/5520 1-module yes charcoal grey/- colourless/white 5.04.665.521/5520 1-module yes light grey/- colourless/white 5.04.665.530/5520 Supplied as single parts: Mat lens, legend insert, diffuser foil, keycap body. Other colours on request. Keycap for RS 76, illuminated, with nail protection and legend insert Pict.: light grey, yellow lens Size of keycap Illuminable Colour of keycap / legending Colour of lens / l egend insert Order no. complete 1-module yes light beige/- colourless/white 5.04.665.912/5520 1-module yes dark grey/- colourless/white 5.04.665.918/5520 1-module yes charcoal grey/- colourless/white 5.04.665.911/5520 1-module yes light grey/- colourless/white 5.04.665.920/5520 4 Supplied as single parts: Mat lens, legend insert, keycap body. Other colours on request. RS 76 PCB Keyswitches Stock items are marked by bold printed order numbers. 4 - 139 RS 76 full-travel keyswitches Keycap for RS 76, illuminated, with legend insert Pict.: red Size of keycap Illuminable Colour of keycap / legending Colour of lens / legend insert Order no. complete 1-module yes light beige/- colourless/white 5.04.665.162/5520 1-module yes dark grey/- colourless/white 5.04.665.168/5520 1-module yes charcoal grey/- colourless/white 5.04.665.161/5520 1-module yes light grey/- colourless/white 5.04.665.170/5520 Supplied as single parts: Mat lens, legend insert, diffuser foil, keycap body. Other colours on request. Keycap, fully illuminated, for RS 76 MX 4 Size of keycap Illuminable Colour of keycap / legending Colour of lens / legend insert Order no. complete 1-module yes white/- white translucent/- 5.05.511.168/0209 1-module yes light grey/- white translucent/- 5.05.511.168/0754 11/4-tlg yes white/- white translucent/- 5.05.511.169/0209 11/2-tlg yes white/- white translucent/- 5.05.511.170/0209 13/4-tlg yes white/- white translucent/- 5.05.511.171/0209 11/4-module with light conductor 5-module yes white/- white translucent/- 5.05.511.173/0209 yes light grey/- white translucent/- 5.00.888.171/0000 Laser-printed versions available on request. RS 76 4 - 140 Stock items are marked by bold printed order numbers. PCB Keyswitches RS 76 full-travel keyswitches Keycaps for RS 76, with legend, two-shot moulded/keycap sets Keycap set for RS 76, symbols A-Z opaque with nail protection, light beige/brown Size of keycap Form of lens Colour of keycap / legending Symbol Order no. complete 1-module light beige/brown A-Z 5.00.999.501/0000 dark grey/white A-Z 5.00.999.502/0000 charcoal grey/white A-Z 5.00.999.500/0000 light grey/black A-Z 5.00.999.824/0000 1-module keycap opaque with nail protection keycap opaque with nail protection keycap opaque with nail protection keycap opaque with nail protection keycap opaque light beige/brown A-Z 5.00.999.526/0000 1-module keycap opaque dark grey/white A-Z 5.00.999.527/0000 1-module keycap opaque charcoal grey/white A-Z 5.00.999.525/0000 1-module keycap opaque light grey/black A-Z 5.00.999.825/0000 1-module 1-module 4 1-module RS 76 4 - 142 Stock items are marked by bold printed order numbers. PCB Keyswitches RS 76 full-travel keyswitches Keycap set for RS 76, symbols 0-9 Pict.: opaque light beige / brown opaque with nail protection, charcoal grey/white Size of keycap Form of lens Colour of keycap / l egending Symbol Order no. complete 1-module light beige/brown 0-9 5.00.999.505/0000 dark grey/white 0-9 5.00.999.506/0000 charcoal grey/white 0-9 5.00.999.504/0000 light grey/black 0-9 5.00.999.826/0000 1-module keycap opaque with nail protection keycap opaque with nail protection keycap opaque with nail protection keycap opaque with nail protection keycap opaque light beige/brown 0-9 5.00.999.530/0000 1-module keycap opaque dark grey/white 0-9 5.00.999.531/0000 1-module keycap opaque charcoal grey/white 0-9 5.00.999.529/0000 1-module keycap opaque light grey/black 0-9 5.00.999.827/0000 1-module 1-module 1-module 4 RS 76 PCB Keyswitches Stock items are marked by bold printed order numbers. 4 - 143 RS 76 full-travel keyswitches RS 76 accessories Pict.: light beige dark grey Cover for RS 76 IP40 Pict.: light beige 4 RS 76 Short text Feature 1 Feature 2 Cover for RS 76 IP40, 1/4-module, black black 1 Cover for RS 76 IP40, 1/4-module, charcoal grey charcoal grey 1 Cover for RS 76 IP40, 1/4-module, light grey light grey 1 Cover for RS 76 IP40, 1/4-module, light beige light beige 1 Cover for RS 76 IP40, 1/4-module, light grey light grey 1 Cover for RS 76 IP40, 1/4-module, dark grey dark grey 1 Cover for RS 76 IP40, 1/2-module, black black 1 Cover for RS 76 IP40, 1/2-module, charcoal grey charcoal grey 1 Cover for RS 76 IP40, 1/2-module, light grey light grey 1 Cover for RS 76 IP40, 1/2-module, light beige light beige 1 Cover for RS 76 IP40, 1/2-module, light grey light grey 1 Cover for RS 76 IP40, 1/2-module, dark grey dark grey 1 Cover for RS 76 IP40, 3/4-module, black black 3 Cover for RS 76 IP40, 3/4-module, charcoal grey charcoal grey 3 Cover for RS 76 IP40, 3/4-module, light grey light grey 3 4 - 144 Stock items are marked by bold printed order numbers. Order no. /4-module 5.04.520.171/0103 /4-module 5.04.520.171/0152 /4-module 5.04.520.171/0242 /4-module 5.04.520.171/0710 /4-module 5.04.520.171/0754 /4-module 5.04.520.171/0801 /2-module 5.04.520.172/0103 /2-module 5.04.520.172/0152 /2-module 5.04.520.172/0242 /2-module 5.04.520.172/0710 /2-module 5.04.520.172/0754 /2-module 5.04.520.172/0801 /4-module 5.04.520.173/0103 /4-module 5.04.520.173/0152 /4-module 5.04.520.173/0242 PCB Keyswitches RS 76 full-travel keyswitches Short text Feature 1 Feature 2 Cover for RS 76 IP40, 3/4-module, light beige light beige 3 Cover for RS 76 IP40, 3/4-module, light grey light grey 3 Cover for RS 76 IP40, 3/4-module, dark grey dark grey Cover for RS 76 IP40, 1-module, black Order no. /4-module 5.04.520.173/0710 /4-module 5.04.520.173/0754 3 /4-module 5.04.520.173/0801 black 1-module 5.04.520.174/0103 Cover for RS 76 IP40, 1-module, charcoal grey charcoal grey 1-module 5.04.520.174/0152 Cover for RS 76 IP40, 1-module, light grey light grey 1-module 5.04.520.174/0242 Cover for RS 76 IP40, 1-module, light beige light beige 1-module 5.04.520.174/0710 Cover for RS 76 IP40, 1-module, light grey light grey 1-module 5.04.520.174/0754 Cover for RS 76 IP40, 1-module, dark grey dark grey 1-module 5.04.520.174/0801 4 RS 76 PCB Keyswitches Stock items are marked by bold printed order numbers. 4 - 145
5.82.000.000/0710 价格&库存
很抱歉,暂时无法提供与“5.82.000.000/0710”相匹配的价格&库存,您可以联系我们找货
