UMW
R
PC817
● 特点(Features):
1. 电流转换比(CTR: 最小. 50%工作条件 IF=5mA, VCE=5V)
Current Conversion Ratio (Min 50% Working Condition IF=5mA, VCE=5V)
2. 绝缘电压:(VISO=5,000Vrms) Insulation Voltage = 5,000Vrms
3. 响应时间 (tr: TYP. 4μs 工作条件 VCE=2V, IC=2mA, RL=100 Ω)
Response Time (tr: TYP. 4μs working condition VCE=2V, IC=2mA, RL=100 Ω)
4.UL approved: UL1577, file No. E492440
● 说明 (Instructions)
1. 817 系列光耦合器的组成是:由一个 GaAs 的发射管和一个 NPN 的晶体管组成
817 photocoupler consist of one piece of GaAs emitter and one piece of NPN
transistor
2. 817 的 BIN 脚宽是 2.54mm
BIN width of 817 is 2.54mm
● 应用范围 (Application Range)
1. 电脑. Computer
2. 器具的应用, 测量机. Instrumental application, measurement machine
3. 贮存器, 复印机, 自动售货机. Imbursement equipments, duplicating machine, automat
4. 家用电器, 如风扇等. Family-use electric equipments, such as fans, etc…
5. 信号传输系统. Signal transforming systems
● 最大绝对额定值
(常温=25℃) Max Absolute rated Value (Normal
Temperature=25℃)
参数 Parameter
顺向电流 Forward Current
逆向电压 Reverse Voltage
功消耗率 Consume Power
集极与射极电压
Collector and Emitter Voltage
射极与集极电压
输出 Output Emitter and Collector Voltage
集极电流 Collector Current
消耗功率 Consume Power
总功率消耗 Total Consume Power
*1 绝缘电压 Insulation Voltage
最大绝缘电压 Max Insulation Voltage
额 定 脉 冲 绝 缘 电 压 Rated Impulse Insulation
Voltage
工作温度 Working Temperature
存贮温度 Deposit Temperature
符号
Symbol
额定值 Rated Value
单位
Unit
IF
VR
P
50
6
70
mA
V
mW
VCEO
35
VECO
6
IC
PC
Ptot
Viso
VIOTM
50
150
200
5,000
6,000
mA
mW
mW
Vrms
V
VIORM
630
V
Topr
Tstg
-30 to + 100
-55 to + 125
Tsol
260
输入 Inout
V
*2 焊锡温度 Soldering Temperature
www.umw-ic.com
1
友台半导体有限公司
UMW
R
PC817
*1. 交流测试, 时间 1 分钟,湿度. =40~60% AC Test, 1 minute, humidity = 40~60%
如下是绝缘测试的方法. Insulation test method as below:
(1) 将产品的两端短路。 Short circuit both terminals of photocoupler
(2) 测试绝缘电压时无电流通过。No current when testing insulation voltage
(3) 测试时加正弦波形电压。Adding sine wave voltage when testing
*2. 锡焊时间为 10 秒 Soldering time is 10 seconds
● 光电特性(常温=25℃) Opto-electronic Characteristics
符号
Symbol
条件
Condition
最小
Min
顺向电压 Forward Current
VF
IF=20mA
1.2
1.4
V
逆向电流 Reverse Voltage
IR
VR=4V
10
μA
Ct
V=0, f=1KHz
30
250
pF
ICEO
VCE=20V, IF=0
100
nA
35
V
6
V
2.5
30
mA
50
600
0.1
0.2
V
Ω
参数 Parameter
输入 Input
集极电容
Collector Capacitance
集极至射极电流
Collector to emitter Current
输出 Output
集 极 与 射 极 衰 减 电 压
Collector
and
Emitter BVCEO
attenuation Voltage
射极与集极衰减电压
中.Mi 最 大 单位
dium Max Unit
IC=0.1mA
IF=0
IE=10μA
Emitter
and
Collector BVECO
Attenuation Voltage
集极电流
IF=0
Ic
Collector Current
IF=5mA
VCE=5V
*1 电流转换比
CTR
集 极 与 射 极 饱 和 电 压
Collector
and
Emitter VCE(sat)
Saturation Voltage
传输特性 Transforming 绝缘阻抗
Characteristics
Insulation Impedance
Riso
电容量 Capacotance
转换频率
Transforming Frequency
IF=20mA
IC= 1mA
DC500V
40~60%R.H.
5×1010 1×1011
Cf
V=0, f=1MHz
0.6
1
pF
fc
VCE=5V,
IC=2mA
80
kHz
RL=100Ω, -3dB
上升时间 Risetime
tr
VCE=2V,
IC=2mA
4
18
μs
下降时间 Descend Time
tf
RL=100Ω
3
18
μs
* 电流转换比 Current Conversion Ratio = IC / IF × 100%
www.umw-ic.com
2
友台半导体有限公司
UMW
R
PC817
● 电流转换比的等级分类 Grades of Current conversion ratio
等级标示
最 小 . M i n ( %)
最 大 . M a x ( %)
L
50
100
A
80
160
B
130
260
C
200
400
D
300
600
50
600
Grade Sign
L or A or B or C or D
说 明 : 工作条件: IF=5mA, VCE=5V, Ta=25℃.
Note: Working condition: IF=5mA, VCE=5V, Ta=25℃.
● 外形尺寸 Outer Dimension
UMW
DIP
●注解: Note
*1. 公司英文名. Company name
*2. BIN 级. Bin
*3. 生产周期. Production period
www.umw-ic.com
3
友台半导体有限公司
UMW
R
PC817
SOP
●注解: Note
*2. BIN 级. Bin
www.umw-ic.com
4
友台半导体有限公司
UMW
R
PC817
● 特性曲线 Characteristics Curve
www.umw-ic.com
5
友台半导体有限公司
很抱歉,暂时无法提供与“PC817C-S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.27681
- 100+0.21730
- 300+0.18674
- 2000+0.14948
- 4000+0.14062
- 10000+0.13468
- 国内价格
- 10+0.25374
- 100+0.19919
- 400+0.17117
- 800+0.16860
- 2000+0.13702
- 国内价格
- 1+0.24852
- 50+0.14606
- 2000+0.13189
