LPW5206B5F
LPW5206B5F
    LPSEMI(微源)
    SOT23-5
    LPW5206B5F
LPW5206B5F 数据手册
Preliminary Datasheet LPW5206 USB Power Loading Switch General Description Features The LPW5206 is an integrated power switch for  160mΩ Low RDS(ON), High-side N-MOSFET self-powered and bus-powered Universal Series Bus  Guaranteed 600mA Continuous Current (USB) applications. A built-in charge pump is used to  2.5V to 6V Input Voltage  Low Quiescent Current:16μA  Soft Start Function quiescent current (16μA) and small package (SOT23-5)  Built-In Short-Circuit Protection is particularly suitable in battery-powered portable  Built-In Thermal Protection equipment.  RoHS Compliant and 100% Lead(Pb)-Free drive the N-Channel MOSFET that is free of parasitic body diode to eliminate any reversed current flow across the switch when it is powered off. Its low Several protection functions include soft start to limit inrush current during plug-in, current limiting at 600mA to meet USB power requirement, and thermal Typical Application Circuit shutdown to protect damage under over current conditions. VIN LPW5206 5 Cin 10uF Order Information LPW5206 □ □ 4 VIN EN VOUT VOUT GND NC 1 3 Cout 10uF 2 □ F: Pb-Free Package Type B5: SOT23-5 Marking Information Device Marking Package LPW5206B5F LPS SOT23-5 Applications 4WYWX Y: Year code. W: Weeks code. X: Series number code.  Power Switch  USB Device  Battery Charger Circuits LPW5206-09 Shipping Feb.-2014 Email: marketing@lowpowersemi.com www.lowpowersemi.com Page 1 of 4 Preliminary Datasheet LPW5206 Functional Pin Description Package Type Pin Configurations Top View VOUT 1 GND 2 NC 3 5 VIN 4 EN SOT23-5 Pin Description Pin Name Description 1 VOUT Output to system pin. 2 GND Ground. 3 NC No connector. 4 EN Device Enable (active High). 5 VIN Input pin. Function Block Diagram LPW5206-09 Feb.-2014 Email: marketing@lowpowersemi.com www.lowpowersemi.com Page 2 of 4 Preliminary Datasheet LPW5206 Absolute Maximum Ratings Note 1  Input Voltage to GND --------------------------------------------------------------------------------------------------- 6.5V  Output Voltage to GND ------------------------------------------------------------------------------------------------ 6.5V  Other pin to GND ---------------------------------------------------------------------------------------------------------- 6V  Maximum Junction Temperature --------------------------------------------------------------------------------- 150°C  Operating Ambient Temperature Range (TA) -------------------------------------------------------- -40℃ to 85°C  Maximum Soldering Temperature (at leads, 10 sec) ------------------------------------------------------- Note 1. 260°C Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Thermal Information  Maximum Power Dissipation (PD) -------------------------------------------------------------------------------- 0.45W  Thermal Resistance (θJA) ---------------------------------------------------------------------------------------- 250℃/W ESD Susceptibility  HBM(Human Body Mode) --------------------------------------------------------------------------------------------- 2KV  MM(Machine Mode) --------------------------------------------------------------------------------------------------- 200V Electrical Characteristics (Over recommended operating conditions unless specified otherwise) VIN=5.0V, EN=High, TA=25℃ ) Symbol Parameter VIN Input Voltage IOUT Output Current Limited 600 mA RDS(ON) Output N-MOSFET RDS(ON) 160 mΩ IQ Quiescent Current VIN=3V ISHDN Shutdown Current VEN=GND VEN(L) Enable Threshold Low VEN(H) Enable Threshold High IEN Input High Current LPW5206-09 Feb.-2014 Condition Min Typ 2.5 16 1.4 VIN=VEN=5.0V Email: marketing@lowpowersemi.com Max Units 6 V 28 µA 1 µA 0.4 V V 5 www.lowpowersemi.com µA Page 3 of 4 Preliminary Datasheet LPW5206 Packaging Information SOT23-5 LPW5206-09 Feb.-2014 Email: marketing@lowpowersemi.com www.lowpowersemi.com Page 4 of 4
LPW5206B5F 价格&库存
很抱歉,暂时无法提供与“LPW5206B5F”相匹配的价格&库存,您可以联系我们找货
