SIM4065-8-1-15-00-A
SIM4065-8-1-15-00-A
    GCT
    SMD
SIM4065-8-1-15-00-A 数据手册
PRODUCT SPECIFICATION Part Number Product Description Doc Number   SIM4065 A Rev Date 24/10/14 SIM Card Connector, Push Push Type, 8 Pin, SMT with Card Detect, 1.6mm Profile. Page 1  SIM4065 Approved AO Prepared Checked ST                         www.gct.co   VJ PRODUCT SPECIFICATION Part Number Product Description Doc Number   SIM4065 A Rev Date 24/10/14 SIM Card Connector, Push Push Type, 8 Pin, SMT with Card Detect, 1.6mm Profile. Page 2  SIM4065 Approved Prepared AO Checked ST VJ 1.0 SCOPE.   This specification covers performance, tests and quality requirements for the SIM Card Connector SIM 4065 (Push Push Type, 8-Pin, SMT, 1.6mm Profile).     2.0 PRODUCT NAME AND PART NUMBER. SIM Card Connector, 8 Pin, Push Push Type: SIM4065. 3.0 PRODUCT SHAPE, DIMENSIONS AND MATERIAL. Please refer to drawings. 4.0 RATINGS.                Current rating ………………………. 1.0 Amp DC Voltage rating ……………………… 50 Volts AC (RMS) Max. Operating Temperature Range …… -40°C to +85°C 5.0 TEST AND MEASUREMENT CONDITIONS. Product is designed to meet electrical, mechanical and environmental performance requirements specified in Paragraph 6.0. All tests are performed under the following conditions unless otherwise specified. Temperature ………………………… 15°C ~ +35°C Relative Humidity …………………… 45% ~ 75% R.H. 6.0 PERFORMANCE. Item Examination of Product Test Condition Requirement Visual, dimensional and functional inspection as per quality plan. www.gct.co Product shall meet requirements of product drawing and specification.   PRODUCT SPECIFICATION Part Number Product Description Doc Number   SIM4065 A Rev Date 24/10/14 SIM Card Connector, Push Push Type, 8 Pin, SMT with Card Detect, 1.6mm Profile. Page 3  SIM4065 Approved Prepared AO Checked ST 6.1 Electrical Performance. Item Test Condition Requirement Contact Resistance Measure and record contact resistance of mated connector using test current of 10mA max and 20 mV open circuit voltage in accordance with EIA-364-23A. Insulation Resistance Apply 500Volts DC between adjacent contacts of mated connectors for one minute in accordance with EIA-364-21C. Dielectric Strength Mate connectors and apply500 V AC for 1 minute between adjacent terminal or ground, in accordance with EIA-364-20B. Signal 100 mΩ max Switch 300 mΩ max 1000 MΩ minimum No creeping discharge or flash over. 6.2 Mechanical Performance. Item Test Condition Requirement Durability The connector should be mated and unmated for 5000 cycles at a rate of 10 cycles/ minute in accordance with EIARS-364-09A. Vibration Subject mated connectors to 10 to 55 to 10 Hz frequency span over 1 minute at a 1.52mm amplitude for a total of 15 minutes. Test to be conducted on 3 mutually perpendicular planes. In accordance with EIA-364-28. Mechanical Shock Apply DC and 1mA to all contacts and subject the part to a 294 m/s2 half sine wave acceleration for 11 ms. Three shocks to be applied in each of the X, Y and Z planes and in both directions. A total of 18 shocks and in accordance with EIA-364-27B. www.gct.co   No evidence of physical damage. Contact Resistance Signal≦100mΩ. Switch ≦300mΩ at end of test No evidence of physical damage Contact Resistance ≦100mΩ Current discontinuity≦ 1μs at end of test No evidence of physical damage Contact Resistance ≦100mΩ Current discontinuity≦ 1μs at end of test. VJ PRODUCT SPECIFICATION Part Number Product Description Doc Number   SIM4065 A Rev Date 24/10/14 SIM Card Connector, Push Push Type, 8 Pin, SMT with Card Detect, 1.6mm Profile. Page 4  SIM4065 Approved Prepared AO Checked ST VJ 6.3 Environmental Performance and Others. Item Test Condition Requirement No evidence of physical damage, discharge, flashes Contact Resistance Signal≦100mΩ. Switch ≦300mΩ at end of test Insulation Resistance ≧ 1000 MΩ Mate Connector and perform the following thermal cycle :- Thermal Shock -40+/-3℃for 30 minutes. +25℃ for 5 minutes. +85+/-2℃for 30 minutes. +25℃ for 5 minutes. Repeat for 5 cycles in accordance with EIA-364-32C. Humidity Test Salt Water Spray Temperature Life (High) Solderability Resistance to Reflow Soldering Heat. Mate connector and expose to temperature of 40±2 with 95% RH for 96 hours then place in ambient temperature for 1 to 2 hrs. In accordance with EIA-RS-364-31A. No evidence of physical damage, discharge, flashes Contact Resistance Signal≦100mΩ. Switch ≦300mΩ at end of test Insulation Resistance ≧ 1000 MΩ Subject mated connectors to 35±2 and 5±1% salt condition for 24 hours. Test in accordance with EIA-RS-364-26B. Contact Resistance Signal≦100mΩ. Switch ≦300mΩ at end of test No pin hole, corrosion on contact area Subject mated connectors to 85°C ±2°C for 250 hours in accordance with EIA364-17B. No evidence of physical damage Signal≦100mΩ. Switch ≦300mΩ at end of test Dip solders tails into molten solder, held at a temperature of 245±5°C for 5±0.5 second, in accordance with EA-364-52. 95% of immersed area must show no voids of pin holes. Mount connector, place in reflow oven and expose to the temperature profile shown in fig 1.0 No evidence of physical damage www.gct.co   PRODUCT SPECIFICATION Part Number Product Description Doc Number   SIM4065 A Rev Date 24/10/14 SIM Card Connector, Push Push Type, 8 Pin, SMT with Card Detect, 1.6mm Profile. Page 5  SIM4065 Approved Prepared AO Checked Fig. 1. Recommended Reflow Temp. Profile www.gct.co   ST VJ PRODUCT SPECIFICATION Part Number Product Description Doc Number   SIM4065 A Rev Date 24/10/14 SIM Card Connector, Push Push Type, 8 Pin, SMT with Card Detect, 1.6mm Profile. Page 6  SIM4065 Approved Prepared AO ST Checked 7.0 PRODUCT QUALIFICATION AND TEST SEQUENCE Test Item Group A B C D E F G Examination of Product 1,4 1,6 1,10 1,5 1,5 1,3 1,3 Contact Resistance 2,5 2,5 2,7 2,4 2,4 Insulation Resistance 3,8 Dielectric Strength 4,9 Durability 3 Vibration 4 3 Mechanical shock Thermal Shock 5 6 Humidity Salt Water Spray 3 Temperature Life(high) 3 Solderability 2 Resistance to Reflow Soldering Heat. Sample QTY. 2 5 5 5 5 5 5 5 The Number of Group is Test Sequence (Drop Test Sample QTY 1 C ) Notes: Numbers indicate sequence in which tests are performed. Precondition samples with 10 cycle’s durability. SAMPLE SELECTION Samples shall be prepared in accordance with applicable manufactures’ instructions and shall be randomly selected from current production. Test groups A,B,C,D,E,F &G shall consist of a minimum of five connectors. A minimum of 30 contacts shall be selected and identified. Unless otherwise specified, these contacts shall be used for all measurements.   www.gct.co   VJ
SIM4065-8-1-15-00-A 价格&库存
很抱歉,暂时无法提供与“SIM4065-8-1-15-00-A”相匹配的价格&库存,您可以联系我们找货
SIM4065-8-1-15-00-A
    SIM4065-8-1-15-00-A
      库存:4000
      SIM4065-8-1-15-00-A
        • 1+34.00920
        • 10+29.30040
        • 30+26.50320
        • 100+23.68440
        • 500+22.37760
        • 1000+21.78360
        SIM4065-8-1-15-00-A
        • 1+17.644951+2.29332
        • 10+14.9704710+1.94571
        • 25+14.0306225+1.82356
        • 50+13.3583250+1.73618
        • 100+12.72037100+1.65327
        • 250+11.92304250+1.54964
        • 500+11.35388500+1.47567
        库存:1699
        SIM4065-8-1-15-00-A
        • 1000+10.812031000+1.40524
        • 2000+10.296252000+1.33821
        • 3000+10.006083000+1.30049
        • 5000+9.652165000+1.25449
        • 7000+9.425967000+1.22509
        库存:1699
