山东晶导微电子股份有限公司
Jingdao Microelectronics co.LTD
MM3Z2V0W THRU MM3Z75W
Silicon Planar Zener Diodes
PINNING
PIN
FEATURES
• Total power dissipation: Max. 300mW.
• Wide zener reverse voltage range 2.0V to 75V.
• Small plastic package suitable for surface mounted design.
• Tolerance approximately±5%
DESCRIPTION
1
Cathode
2
Anode
2
1
MECHANICAL DATA
▪Case: SOD-323W
▪Terminals: Solderable per MIL-STD-750, Method 2026
▪A pprox. Weight: 5.48mg / 0.00019oz
Top View
Simplified outline SOD-323W and symbol
Absolute Maximum Ratings And Characteristics (Ta = 25 °C)
Symbol
Value
Unit
Power Dissipation
P tot
300
mW
Forward Voltage at I F = 10 mA
VF
0.9
V
RθJA
417
°C/W
T j , T stg
-55 ~ +150
°C
Parameter
Typical thermal resistance juncting to ambient
Operating and Storage Temperature Range
(1)
Fig.1 Maximum Continuous Power Derating
0.6
Power Dissipation ( W )
0.5
0.4
0.3
0.2
0.1
0.0
25
50
75
100
125
T A , Temperature (°C)
2019.08
150
175
Transient Thermal Impedance( °C /W)
(1) Thermal resistance from junction to ambient at P.C.B. mounted with 2 .0" X 2.0" (5 X 5 cm) copper areas pads.
Fig.2 Typical Transient Thermal Impedance
2000
1000
100
10
0.01
0.1
1
10
100
t, Pulse Duration(sec)
SOD-323W-W-MM3Z2V0W~MM3Z75W-300mW
Page 1 of 3
山东晶导微电子股份有限公司
Characteristics at Ta = 25°C
Dynamic
Impedance
Zener Voltage Range (1)
Type
Marking
V ZT(at I ZT)
Min(V)
Reverse Current
I ZT
Z ZT(at I ZT)
IR
at V R
Max(μA)
(V)
Nom(V)
Max(V)
(mA)
Max (Ω)
MM3Z2V0W
B0
1.8
2.0
2.15
5
100
120
0.5
MM3Z2V2W
C0
2.08
2.2
2.33
5
100
120
0.7
MM3Z2V4W
1C
2.28
2.4
2.56
5
100
120
1
MM3Z2V7W
1D
2.5
2.7
2.9
5
110
120
1
MM3Z3V0W
1E
2.8
3.0
3.2
5
120
50
1
MM3Z3V3W
1F
3.1
3.3
3.5
5
130
MM3Z3V6W
1H
3.4
3.6
3.8
5
130
10
1
MM3Z3V9W
1J
3.7
3.9
4.1
5
130
5
1
MM3Z4V3W
1K
4
4.3
4.6
5
130
5
1
4.7
5
5
130
2
1
5.4
5
130
2
1.5
MM3Z4V7W
1M
4.4
MM3Z5V1W
1N
4.8
5.1
MM3Z5V6W
1P
5.2
5.6
6
5
80
1
2.5
MM3Z6V2W
1R
5.8
6.2
6.6
5
50
1
3
MM3Z6V8W
1X
6.4
6.8
7.2
5
30
0.5
3.5
MM3Z7V5W
1Y
7
7.5
7.9
5
30
0.5
4
MM3Z8V2W
1Z
7.7
8.2
8.7
5
30
0.5
5
MM3Z9V1W
2A
8.5
9.1
9.6
5
30
0.5
6
MM3Z10W
2B
9.4
10
10.6
5
30
0.1
7
MM3Z11W
2C
10.4
11
11.6
5
30
0.1
8
12.7
5
35
0.1
9
0.1
10
0.1
11
MM3Z12W
2D
11.4
12
MM3Z13W
2E
12.4
13
14.1
5
35
MM3Z15W
2F
13.8
15
15.6
5
40
MM3Z16W
2H
15.3
16
17.1
5
40
0.1
12
MM3Z18W
2J
16.8
18
19.1
5
45
0.1
13
MM3Z20W
2K
18.8
5
50
0.1
15
MM3Z22W
2M
20.8
22
23.3
5
55
0.1
17
MM3Z24W
2N
22.8
24
25.6
5
60
0.1
19
MM3Z27W
2P
25.1
27
28.9
2
70
0.1
21
MM3Z30W
2R
28
30
32
2
80
0.1
23
MM3Z33W
2X
31
33
35
2
80
0.1
25
0.1
27
MM3Z36W
2Y
34
36
38
2
90
MM3Z39W
2Z
37
39
41
2
100
0.1
30
MM3Z43W
3A
40
43
46
2
130
0.1
33
MM3Z47W
3B
44
47
50
2
150
0.1
36
MM3Z51W
3C
48
51
54
2
180
0.1
39
MM3Z56W
3D
52
56
60
2
200
0.1
43
MM3Z62W
3E
58
62
66
2
215
0.1
47
MM3Z68W
3F
64
68
72
2
240
0.1
52
MM3Z75W
3H
70
75
79
2
265
0.1
56
(1) V ZT is tested with pulses (20 ms)
2019.08
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-323W
E
E
D
b
A
C
A1
∠ALL ROUND
L1
E1
SOD-323W mechanical data
A
C
D
E
E1
b
L1
A1
max
1.1
0.15
1.4
1.8
2.75
0.4
0.45
0.2
min
0.8
0.08
1.2
1.4
2.55
0.25
0.2
max
43
5.9
55
70
108
16
16
min
32
3.1
47
55
100
9.8
7.9
UNIT
mm
9°
8
mil
The recommended mounting pad size
1.4
(55)
1.2
(47)
1.2
(47)
1.2
(47)
Unit: mm
(mil)
2019.08
Page 3 of 3
很抱歉,暂时无法提供与“MM3Z15W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.13868
- 500+0.11297
- 3000+0.09872
