3811-60052
3811-60052
    AMPHENOLSVMICROWAVE(安费诺MAO)
3811-60052 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING 01 PRELIMINARY DATE APPROVED 10/17 DAL 4X .086 2.18 SMPS INTERFACE RP .131 3.33 .130 3.30 .230 5.84 .181 4.60 .180 4.57 .026 0.65 4X .044 1.12 4X .009 0.23 .470 11.94 .048 1.21 MATERIAL: .086 2.18 BODY & SHROUDS: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1; OR ASTM A582 TYPE 303, COND. A CONTACTS: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATORS: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B .015 0.38 .0045±.0010 0.11±0.03 4X .110±.002 2.79±0.05 .045 1.14 .420±.004 10.67±0.10 NOTES: 1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE CONTACT US AT applications@svmicro.com FINISH: BODY, SHROUDS, & CONTACTS: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: PERFORMANCE: N/A PROPRIETARY IMPEDANCE: FREQ. RANGE: 50 OHMS DC TO 65.0 GHz. THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV PART NUMBER COUPLING STYLE 3811-60051 FULL DETENT 3811-60052 SMOOTH BORE UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: JDT 10/03/17 CHECKED: APPROVED: DAL 10/03/17 DAL 10/03/17 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMPS MALE 4-PORT EDGE LAUNCH SIZE CAGE CODE DWG. NO. B 95077 SCALE: 14:1 3811-60051-60052 SHEET 1 OF 1
3811-60052 价格&库存
很抱歉,暂时无法提供与“3811-60052”相匹配的价格&库存,您可以联系我们找货
