CSP(6.0V)Series
FEATURES
● High power,high energy density
● Long cycle life,maintenance-free
● High Operating Voltage
● Lead terminals can be customized
● No Explosion Safety
APPLICATIONS
● Consumer electronics, Ride thru power support, Back up
power,Stand alone or augment existing,energy/power
sourceexisting.
OPERATING TEMPERATURE RANGE
● -40℃ to +65℃ @6.0V Balanced, 5.5V Unbalanced
● -40℃ to +85℃ @5.0V Balanced, 4.6V Unbalanced
GENERAL SPECIFICATIONS
Item
Performance
Storage temperature
-40°C to +65°C
Capacitance range
0.47F to 60F
Capacitance tolerance
-20%~+20% ; -10%~+30%
Rated voltage
6.0 V
Surge voltage
6.2 V
Temperature characteristics
Capacitance change: Within ±30% of initial measured value at +25°C
Internal resistance: Within ±200% of initial measured value at +25°C
High temperature load time
After 85°C 1000 hours (at:5.0V):
Capacitance change: ±30% of initial rated value
Internal resistance: Within 3 times of initial specified value
Projected cycle life
(From rated voltage to 1/2 rated
voltage at 25°C)
After 500,000 cycles:
Capacitance change: Within ±30 % of initial rated value
Internal resistance: Within 2 times of initial specified value
Humidity characteristic
Relative humidity: 90%~95% /Duration of testing:240 hrs /Temperature:40±2°C
Vibration resistance
Amplitude:1.5mm /Frequency:10~55Hz /Duration of testing:6 hrs
Shelf life
After 2 years at 25°C without load, the capacitor shall meet the specified endurance limits.
No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw
Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product,
please be sure to contact our sales offices or agents immediately.
Spec. Date:2021-07-05
CSP(6.0V)Series
DIMENSIONS
DB Type:
DA Type:
L±1.5mm
d±0.05mm
D±1.0mm
D±1.0mm
L±1.5mm
d±0.05mm
W±1.0mm
W±1.0mm
P±0.5mm
P±0.5mm
15mm min
15mm min
(-)Negative
4mm min
Cell Dia
4mm min
D
Ф8.0
Ф10.0
Ф12.5
Ф16.0
Ф18.0
W
8
10
12.5
16
18
16
32
60
P(mm)
DA Type
11.5
15.5
17.5
24.0
26.0
DC Type:
DB Type
5.0
5.5
7.5
8.5
10.5
(-)Negative
Фd
0.6
0.6
0.6
0.8
0.8
DZ Type:RADIAL BENT LEAD
D±1.0mm
L±1.5mm
D±1.0mm
L±1.5mm
3.0±0.5mm
d±0.05mm
d±0.05mm
W±1.0mm
P±0.5mm
P±0.5mm
W±1.0mm
15mm min
4mm min
B mm±0.5mm
(-)Negative
(-)Negative Polarity
Polarity
Cell Dia
Ф8.0
Ф10.0
Ф12.5
Ф16.0
Ф18.0
D
8
10
12.5
16
18
W
16
32
60
*for version with bent leads
P(mm)
DC Type
8
10
13
16
DZ Type
11.5
15.5
17.5
24.0
26.0
B(mm)
2.0
2.0
2.0
2.0
2.0
Фd
0.6
0.6
0.6
0.8
0.8
CSP(6.0V)Series
STANDARD PRODUCTS
Rated
Part Number
Voltage
(V)
Rated
Size
Cap (F) ФWxDxL
(mm)
Max.ESR
ESRAC
ESRDC
(1kHz/mΩ) (mΩ)
Maximum
Maximum
Endurance
Peak
Current(A)
Current(A)
Maximum
Leakage
Current
(72hrs/mA)
Power
Maximum
Energy
Density
Energy
Density
(W/Kg)
(W.h)
(Wh/kg)
CSP-6R0L474R-TWX
6.0
0.47
13*7*14
500
3000
0.47
0.98
0.006
864
0.0020
1.41
CSP-6R0L474R-TW
6.0
0.47
16*8*14
320
480
0.47
1.15
0.007
4286
0.0024
1.12
CSP-6R0L504R-TW
6.0
0.50
16*8*14
350
490
0.50
1.20
0.007
4290
0.0026
1.20
CSP-6R0L105R-TW
6.0
1.0
16*8*18
240
360
0.61
2.21
0.012
4762
0.0050
1.98
CSP-6R0L155R-TWX
6.0
1.5
16*8*18
260
320
0.59
2.84
0.013
3956
0.0075
2.68
CSP-6R0L155R-TW
6.0
1.5
16*8*22
200
300
0.74
3.10
0.014
4729
0.0075
2.46
CSP-6R0L255R-TWX
6.0
2.5
16*8*27
180
270
0.87
4.48
0.018
3907
0.0125
3.05
CSP-6R0L255R-TW
6.0
2.5
20*10*22
150
225
0.97
4.80
0.018
3810
0.0125
2.48
CSP-6R0L305R-TW
6.0
3.0
20*10*22
140
200
0.91
5.80
0.020
4198
0.0175
3.57
CSP-6R0L355R-TW
6.0
3.5
20*10*22
140
200
0.98
6.05
0.020
4198
0.0175
3.57
CSP-6R0L405R-TW
6.0
4.0
20*10*27
120
180
1.20
7.89
0.036
4156
0.0250
4.33
CSP-6R0L405R-TWX
6.0
4.0
25*13*22
120
180
1.20
7.89
0.036
4156
0.0250
4.33
CSP-6R0L505R-TWX
6.0
5.0
25*13*22
90
135
1.42
8.96
0.036
4118
0.0250
3.22
CSP-6R0L505R-TW
6.0
5.0
20*10*27
90
135
1.42
8.57
0.036
4118
0.0250
3.22
CSP-6R0L505R-TWQ
6.0
5.0
20*10*32
120
150
1.52
8.96
0.036
4235
0.0250
3.68
CSP-6R0L755R-TW
6.0
7.5
25*13*27
80
120
1.66
11.84
0.048
4453
0.0375
4.64
CSP-6R0L755R-TWQ
6.0
7.5
25*13*32
90
120
1.75
12.84
0.084
3600
0.0375
3.75
CSP-6R0L755R-TWX
6.0
7.5
25*13*22
80
150
1.35
10.59
0.030
3600
0.0375
4.69
CSP-6R0L106R-TW
6.0
10
25*13*32
70
105
1.93
14.63
0.066
4354
0.0500
5.29
CSP-6R0L106R-TWX
6.0
10
25*13*28
60
120
1.66
13.64
0.050
3428
0.0500
4.76
CSP-6R0L126R-TW
6.0
12.5 32*16*27
50
75
2.41
19.35
0.082
3516
0.0625
3.82
CSP-6R0156R-TW
6.0
15
32*16*32
40
60
2.92
23.68
0.090
3987
0.0750
4.15
CSP-6R0L256R-TW
6.0
25
36*18*42
32
48
3.96
34.09
0.126
3259
0.1250
4.53
CSP-6R0L306R-TW
6.0
30
36*18*42
30
45
4.09
38.30
0.145
3096
0.1500
4.84
CSP-6R0L506R-TW
6.0
50
36*18*62
26
39
5.30
50.85
0.288
2453
0.2500
5.54
CSP-6R0L606R-TW
6.0
60
36*18*62
24
28
5.51
56.96
0.260
2448
0.3000
6.12
Note: Adds passive balance. Balance options can be provided upon request. Customers can choose according to the application.
CSP(6.0V)Series
SAFETY RECOMMENDATIONS
WARNINGS
REGULATORY
• To Avoid Short Circuit, after usage or test, SuperCapacitors voltage needs
to discharge to ≤ 0.1V
• Do not Apply Overvoltage, Reverse Charge, Burn or Heat Higher than
150°C, explosion-proof valve may break open
• Do not Press, Damage or disassemble the SuperCapacitors, housing could
heat to high temperature causing Burns
• If you observe Overheating or Burning Smell from the capacitor
disconnect Power immediately, and do not touch
• MSDS
• RoHS Compliant
• Reach Compliant
TRANSPORTATION
Not subjected to US DOT or IATA regulations
UN3499,
很抱歉,暂时无法提供与“CSP-6R0L255R-TW”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+11.61432
- 10+9.88038
- 30+8.92620
- 224+6.74082
- 448+6.26886
- 896+6.04314
