SLSS360
High Voltage Hall
Effect
Switch Sensor
1. Introduction
SLSS360 Hall-Effect bipolar sensor, employed with high voltage bipolar technology, has been designed
purposely for automotive and industrial applications, and operates with supply voltages from 3.8 V to 60 V in
temperature range from -40 °C up to 150 °C. SLSS360 is available in SMD-package SOT23 and in the leaded
version TO92S.
2. Features
– Operates from 3.8 V to 60 V supply voltage
– Overvoltage protection capability up to 80 V
– Highest ESD performance up to ±4kV
– Short-circuit protected open-drain output
– Wide temperature range from -40 °C to 150 °C
– Ideal sensor for applications in extreme automotive and industrial environments
– Tiny SOT23 package and TO92S package
3. Potential Applications
– Brushless DC motor commutation
– Speed measurement
– Revolution counting
– Angular position detection
– Proximity detection
4. Block Diagram
The circuit includes temperature compensated voltage regular, Hall plate, signal amplifier and hysteresis
comparator in single silicon chip. The regulated voltage provides the reference voltage for the hall plate. A
magnetic field perpendicular to the sensor surface generates a hall voltage, which is amplified and then sent to
a hysteresis comparator.
VSUP
Voltage
Regulator
RL
VREF
OUT
Hall
Plate
AMP
GND
www.slkormicro.com
1
SLSS360
5. Pin Description
GND
2
1
2
VSUP
GND
3
VOUT
1
3
VSUP
VOUT
TO92S
SOT23
6. Ordering information
Partnumber package
Packing
Ambient, TA
SLSS360-9
TO92S
Bulk, 1000 pieces/bag
-40℃ to 150℃
SLSS360-3
SOT23
Reel, 3000pieces/reel
-40℃ to 150℃
7. Pin assignment
SOT23-3LPin
TO92SPin
number
number
1
2
3
Name
Function
1
2
VSUP
GND
3
VOUT
Power supply
Ground
Open collector with a internal pull-up
resistor
8. Absolute Maximum Ratings
Parameters
Power supply Voltage
Output voltage
Output current sink
Operating ambient
temperature
Storage temperature
www.slkormicro.com
Symbol
VSUP
VOUT
Isink
Min
-0.5
-0.5
Max
80
80
40
Units
V
V
mA
Ta
-40
150
˚C
Tstg
-50
165
˚C
2
SLSS360
High Voltage Hall Effect Switch
Co.,Ltd
9. Electrical and magnetic characteristics(Ta=25˚C)
Symbol
Parameter
Electrical characteristics
VSUP
Supply voltage
ISUP
Ile
Supply current
Leakage current
Output saturation
voltage
Vsat
Test conditions
Min.
Typ.
Max.
3.8
Units
60
V
Off state
8
10
mA
uA
On state
0.4
V
4.8
Tr
Output rise time
Rload=1kohms
Cload=20pF
1
uS
Tf
Output fall time
Rload=1kohms
Cload=20pF
1.5
uS
RL
Built-in pull-up
resistor
Kohm
10
Magnetic characteristics
Bop
Operate point
Brp
Release point
Bhys
Hysteresis
Rload=1kohms
Cload=20pF
10
25
40
Gauss
-40
-25
-10
Gauss
50
Gauss
10.Magnetoelectric conversion characteristics
Apply a magnetic field greater than Bop on the seal side of TO92S package (near the South Pole), and the
output becomes low;Apply a magnetic field less than Brp (near the North Pole) and the output becomes
high.When the chip is first powered on, if the magnetic field is between the Bop and the Brp, the output
state is in an undefined state (high or low).The magnetic field polarity of the operating and releasing
points of SOT23-3L package is opposite to that of TO92S.See below.
Output Voltage
VOH
BHYS
VOL
Brp
VOUT=low
www.slkormicro.com
VOUT=high
Bop
TO92S output state
3
B
SLSS360
Alfa Electronics Co.,Ltd
Output Voltage
VOH
BHYS
VOL
Brp
VOUT=low
VOUT=high
Bop
SOT23-3L output state
11. Application Circuit
Typical application circuit (see Fig. below)
VSUP
RL
OUT
GND
An example of typical application circuit
For applications with disturbances on the supply line or radiated disturbances, a series resistor RV and two
capacitors CP and CL all placed close to the sensor are recommended (see Fig. below).
For example: RV =100 ohms, CP = 4.7 nF, and CL = 1 nF.
www.slkormicro.com
B
4
SLSS360
VSUP
RV
RL
OUT
CP
CL
GND
GND
Example of application circuit 2
12. Outline dimensions
symbol
Size (mm)
minimum
maximum
1.42
1.67
0.056
0.066
A1
0.66
0.86
0.026
0.034
b
0.35
0.56
0.014
0.022
0.55
0.016
0.022
0.51
0.014
0.02
0.154
0.165
3.27
0.117
0.129
3.28
0.114
0.129
C
D
D1
5
minimum
A
b1
www.slkormicro.com
maximum
Size (in inches)
0.4
0.36
3.9
2.97
4.2
E
2.9
e
1.270 TYP
e1
2.44
2.64
0.096
0.104
L
13.5
15.5
0.531
0.61
x
2.025TYP
0.080TYP
y
1.545TYP
0.061TYP
z
0.500TYP
0.020TYP
θ
45˚TYP
0.050 TYP
45˚TYP
SLSS360
SLSS360 package outline
Size (mm)
symbol
Min.
Max.
Min.
Max.
A
1.05
1.25
0.041
0.049
A1
A2
1.05
1.15
0.041
0.045
b
0.3
0.5
0.012
0.02
c
0. 100
0.2
0.004
0.008
D
2.82
3.02
0.111
0.119
E
1.5
1.7
0.059
0.067
E1
2.65
2.95
0.104
0.116
e
6
0.950 TYP
0.037 TYP
e1
1.8
2
0.071
0.079
L
0.3
0.6
0.012
0.024
x
1.460TYP
0.057TYP
y
0.800TYP
0.032TYP
z
0.600TYP
0.024TYP
θ
www.slkormicro.com
Size (inches)
0˚
8˚
0˚
8˚
很抱歉,暂时无法提供与“SLSS360-3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.29935
- 50+1.02719
- 150+0.91055
- 500+0.76508
- 3000+0.70028
- 6000+0.66140
