LM317T
LM317T
    UMW(友台)
    TO-220-3
    线性稳压器及LDO 1.2~37V TO220-3L
LM317T 数据手册
UMW R UMW LM317 DESCRIPTION This monolithic integrated circuit is an adjustable 3-terminal positive voltage regulator designed to supply more than 1.5A of load current with an output voltage adjustable over a 1.2 to 37V. It employs internal current limiting , thermal shut-down and safe area compensation. TO-220-3L FEATURE  Internal thermal overload protection  Internal short circuit current limiting  Output transistor safe operating area compensation TO-252 1. Adj 2. Output 3. Input SOT-223 Internal Block Diagram Vin 3 Input + Protection Circuitry Voltage Reference Rlimit 2 Vo Output 1 Vadj www.umw-ic.com 1 友台半导体有限公司 UMW R UMW LM317 Absolute Maximum Rating s Symbol Parameter Value Unit VI-VO Input-Output Voltage Differential 40 V TLEAD Lead Temperature 230 ℃ TO-220 Power Dissipation PD Internally limited TO-252 2 SOT-223 1 TJ Operating Junction Temperature Range 0~125 Tstg Storage Temperature Range -55~125 Temperature Coefficient of Output Voltage ΔVO /ΔT W ℃ %/℃ ±0.02 ELECTRICAL CHARACTERISTICS (VO-VI=5V,IO=0.5A,0℃≤TJ≤+125℃ ,IMAX=1.5A,PDMAX=20W,unless otherwise specified) Parameter Line Regulation(note1) Load Regulation(note1) Adjustable Pin Current Symbol Test conditions Rline Rload TYP MAX TA=25℃ 3V≤VI-VO≤40V 0.01 0.04 3V≤VI-VO≤40V 0.02 0.07 TA=25℃ , 10mA≤ IO≤ IMAX VO< 5V VO ≥5V 10mA≤ IO≤ IMAX 18 0.4 25 0.5 VO
LM317T 价格&库存
很抱歉,暂时无法提供与“LM317T”相匹配的价格&库存,您可以联系我们找货
LM317T
    • 1+1.17320
    库存:462
    LM317T
    • 1+7.727361+0.96700
    • 10+5.5471410+0.69417
    • 50+4.6661450+0.58392
    • 100+4.39228100+0.54965
    • 250+4.10370250+0.51354
    • 500+3.92975500+0.49177
    • 1000+3.786581000+0.47385
    • 2500+3.635272500+0.45492
    • 5000+3.544105000+0.44351
    库存:997
    LM317T
    • 1+1.04060
    • 50+0.80080
    • 1000+0.73700
    库存:2336
    LM317T
    • 1+1.74840
    • 30+1.63180
    • 100+1.51530
    • 500+1.39870
    • 1000+1.28220
    • 2000+1.16560
    库存:297
    LM317T
    • 5+1.46005
    • 50+1.09269
    • 150+0.95361
    库存:297
