FH30M-80S-0.4SHW(98) 数据手册
0.3 or 0.4 mm pitch, 3 mm above the board, Flip-Lock actuator,
Flexible Printed Circuit ZIF connectors
FH30 Series
Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Strong actuator construction
Enclosed shaft of the actuator
prevents it from dislocation
■Features
Simple FPC insertion
1. Strong actuator retention
Actuator will not be dislodged when operating under harsh
conditions.
2. Rotating Flip–Lock actuator
Rotating actuator permits easy insertion and retention of the
FPC.
Tactile sensation confirms complete FPC insertion and reliable
mechanical and electrical connection.
3. FPC position hold
Tabs on each side of the FPC assure correct placement and
hold in the connector prior to closing of the actuator.
FPC positioning tab
4. Accepts standard FPC thickness
0.3mm thick standard Flexible Printed Circuit (FPC) can be
used.
Lock
5. Easy solderability on the PC board
The soldering leads are on 0.6 mm or 0.8 mm pitch, exiting on
the front and back of the connector.
6. Board placement with automatic equipment
Flat upper surface and tape and reel packaging facilitate vacuum
pick-up and placement. Standard reel packaging contains 1000
connectors.
7. Conductive traces on the PCB can run under
the connector
No exposed contacts on the bottom of the connector.
8. Halogen-free*
* As defined by IEC61249-2-21
Br-900ppm maximum, Cl-900ppm maximum,
Cl + Br combined-1,500ppm maximum
2013.11w
1
FH30 Series●0.3 or 0.4mm pitch, 3mm above the board, Flip-Lock actuator, Flexible Printed Circuit ZIF connectors
■Product Specifications
Storage temperature range -10 to +50°C (Note 3)
0.3 mm pitch 0.4 mm pitch Operating temperature range -40 to +85°C (Note 2)
Ratings Current rating(Note 1)
Voltage rating
Recommended FPC
Relative humidity 90% max.
Thickness: 0.3±0.05, Gold plated contact pads
Item
1. Insulation resistance
500 Mø min.
Specification
2. Withstanding voltage
No flashover or insulation breakdown
Conditions
100 V DC
0.3 mm pitch: 90 Vrms AC / 1 minute
0.4mm pitch: 150 Vrms AC / 1 minute
150 mø max.
* Including FPC conductor resistance
Contact resistance: 150 mø max.
No damage, cracks, or parts dislocation
No electrical discontinuity of 1μs or longer
Insulation resistance: 50Mø min.
No deformation of components affecting
performance.
3. Contact resistance
4. Durability
Relative humidity 90% max. Storage humidity range
(No condensation)
Operating humidity range
0.15 A
0.3 A
30 Vrms AC 50 Vrms AC (No condensation)
5. Vibration
6. Shock
7. Humidity (Steady state)
8. Temperature cycle
9. Resistance to soldering heat
1 mA AC
20 cycles
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm
10 cycles in each of the 3 directions
Acceleration of 981m/s2, 6 ms duration,
sine half-wave, 3 cycles in each of the 3 axis
96 hours at 40°C and humidity of 90 to 95%
Temperature: -40°C ➝ +15°C to 35°C ➝ +85°C➝ +15°C to 35°C
Time:
-30 ➝ 2 to 3
➝ +30 ➝ +2 to 3
5 cycles
Reflow: At the recommended temperature profile
Manual soldering: 350°C for 5 seconds
Note1: When passing the current through all of the contacts, use 70% of the rated current.
Note2: Includes temperature rise caused by current flow.
Note3: The term "storage" refers to products stored for a long period prior to mounting and use.
The operating temperature and humidity range covers the non-conducting condition of connectors after installation on a
board.
■Materials
Part
Material
Finish
Insulator
LCP
Contacts
Phosphor bronze
Remarks
FH30 series Color:Gray
FH30M series Color:Beige
Gold plated
UL94V-0
■Ordering information
FH 30 M - 80S - 0.3 SHW (05)
1
2
3
4
5
6
7
q Series name
: FH
w Series No.
: 30
e Blank
: 0.3mm pitch
M
: 0.4 mm pitch
r Number of contacts
: FH30 series 60, 80, 90
t Contact pitch
: 0.3 mm, 0.4 mm
y Contact type
: SHW(SMT horizontal staggered mounting)
FH30M series 80, 96
u Plating specifications : (05)…Gold plated
(98)…Gold plated, 500 pieces/reel
2
■Dimensions
A
B
Q
C
R
(0.12)
9
R
(0.12)
D
4.85
4.2
Vacuum pick-up surface
3
6.55
0.8
0.8
(E: FPC insertion slot dimension)
Number of contacts indicator
Notes 1: The coplanarity of each terminal lead is within 0.1.
2: Packaged on tape and reel only. Check packaging specification.
3: Slight variations in color of the plastic compounds do not affect form ,fit or function of the connector.
4: After reflow, the terminal plating may change color, however this does not represent a quality issue.
All dimensions: mm
A
B
C
Q
R
FH30-60S-0.3SHW(05)
Part Number
580-0105-8-05
CL No.
Number of Contacts FPC contact pitch
60
0.3
21.9
17.7
17.4
17.4 18.35
D
E
0.3
0.6
FH30-80S-0.3SHW(05)
580-0100-4-05
80
0.3
27.9
23.7
23.4
23.4 24.35
0.3
0.6
FH30-90S-0.3SHW(05)
580-0106-0-05
90
0.3
30.9
26.7
26.4
26.4 27.35
0.3
0.6
FH30M-80S-0.4SHW(05)
580-0102-0-05
80
0.4
35.8
31.6
31.2
31.2 32.25
0.4
0.8
FH30M-96S-0.4SHW(05)
580-0103-2-05
96
0.4
42.2
38
37.6
37.6 38.65
0.4
0.8
Tape and reel packaging (1,000 pieces/reel, 500 pieces/reel).
Order by number of reels.
3
■Recommended PCB mounting ■Recommended FPC Dimensions
pattern and metal mask dimensions
0.3
B±0.05
R0
0.1±0.05
A
0.07±0.07
No(n-1)
(0.5)
C±0.05
.2
2.65±0.2
1.4±0.1
No.2
No (n)
Q±0.02
0.3±0.05
2
0.3
Mark side
R±0.05
0.3±0.07
0.3±0.03(Land)
F±0.05
D±0.05
G±0.1
H MIN
Recommended metal mask thickness: t=0.15
Detail A
0.3±0.07
B±0.03
0.25±0.03(Metal mask)
+0.04
-0.03
0.05 MIN
1.7±0.1
R±0.02
0±0.1
0.
2
R
(0.8)
(C
0.
5)
2.2±0.1
4.2±0.3
0.3±0.03(Land)
R±0.05
1.3±0.1
1.7±0.1
3.95±0.1
.2
3.2±0.3
Q±0.05
+0.04
-0.03
No.1
R0
J±0.1
Note 1 : Conductor width shall be 0.1±0.05 if FPC has plating bars.
All dimensions: mm
Part Number
CL No.
FH30-60S-0.3SHW(05)
580-0105-8-05
60
0.3
17.7 17.4 17.4 18.3 18.8 19.3 20.3 0.3
B
0.6
FH30-80S-0.3SHW(05)
580-0100-4-05
80
0.3
23.7 23.4 23.4 24.3 24.8 25.3 26.3 0.3
0.6
FH30-90S-0.3SHW(05)
580-0106-0-05
90
0.3
26.7 26.4 26.4 27.3 27.8 28.3 29.3 0.3
0.6
FH30M-80S-0.4SHW(05) 580-0102-0-05
80
0.4
31.6 31.2 31.2 32.2 32.7 33.2 34.2 0.4
0.8
FH30M-96S-0.4SHW(05) 580-0103-2-05
96
0.4
38
C
D
G
H
J
Material
Polyimide
R
0.8
Material Thickness
(μm)
1 mil thick
(25)
Cover adhesive
(25)
Surface treatment
0.2μm thick gold plated over 1 to
5μm thick nickel underplating
Copper foil
Cu
Base adhesive
Thermosetting adhesive
25
Base film
Polyimide
1 mil thick
25
Reinforcement material adhesive Thermosetting adhesive
30
Stiffener
Polyimide
3
1oz
35
7 mil thick
175
Total
2. Using Double-sided FPC
Q
37.6 37.6 38.6 39.1 39.6 40.6 0.4
■FH30 Series Recommended FPC Construction
1. Using Single-sided FPC
Material Name
Covering film layer
F
Material Name
Covering layer film
293
Material
Polyimide
Material Thickness
(μm)
1 mil thick
Cover adhesive
(25)
(25)
Surface treatment
Through-hole copper
Cu
Copper foil
Cu
Base adhesive
18
Base film
Polyimide
25
Base adhesive
Copper foil
Cu
Cover adhesive
25
Covering film layer
Polyimide
25
15
1/2oz
1 mil thick
1/2oz
1 mil thick
Stiffener
Polyimide
3
4 mil thick
Total
18
18
(18)
50
100
297
* To prevent release of the FPC due to it’s bending, use of the double-sided FPC with copper foil on the back side is NOT RECOMMENDED.
3. Precautions
1. This specification is a recommendation for the construction of the FH30 Series FPC (t=0.3 ± 0.05).
2. For details about the construction, please contact the FPC manufacturers.
4
■Packaging Specifications
●Embossed Carrier Tape Dimensions
●Reel Dimensions
(4.9)
1.75±0.1
2±0.15 12±0.1
Ø1
.5 +0
1
0.4±0.1
(T: INSIDE)
3)
M±0.1
K±0.3
L±0.1
(N)
(U: OUTSIDE)
Mounting section
Lead section (400mm min.)
1.7 +0.15
Top cover tape
Embossed carrier tape
No connector inserted
(10 pockets min.)
Unreeling direction
(10 pockets min.)
All dimensions: mm
CL No.
Number of Contacts
K
L
M
N
T
U
FH30-60S-0.3SHW(05)
580-0105-8-05
60
44
40.4
20.2
22.1
45.4
49.4
FH30-80S-0.3SHW(05)
580-0100-4-05
80
44
40.4
20.2
28.1
45.4
49.4
FH30-90S-0.3SHW(05)
580-0106-0-05
90
44
40.4
20.2
31.1
45.4
49.4
580-0102-0-05
80
56
52.4
26.2
36
57.4
61.4
580-0103-2-05
96
56
52.4
26.2
42.4
57.4
61.4
Part Number
Tape and reel packaging (1,000 pieces/reel).
■Temperature Profile
● Using Lead-free Solder Paste
MAX 250ç
250
230ç
Temperature(ç)
End section
1.35±0.1
(Ø80)
(Ø1
(Ø380)
4±0.1
200
HRS test condition
Solder method
:Reflow, IR/hot air
Environment
:Room air
Solder composition :Paste, 96.5%Sn/3.0%Ag/0.5%Cu
(Senju Metal Industry, Co., Ltd.'s Part
200ç
Number:M705-221CM5-32-10.5)
Test board
150
:Glass epoxy FH30:45∞80∞1.6mm thick
150ç
FH30M:70∞130∞1.6mm
thick
100
Land dimensions
:0.3mm∞1.7mm
Metal mask
:0.15mm thick
0.25mm∞1.7mm
50
25ç (60 sec.)
90 to 120 sec.
Preheating
Start
(30 sec.)
Soldering
The temperature profiles shown are based on the above
conditions.
In individual applications the actual temperature may
Time (Seconds)
vary,depending on solder paste type, volume / thickness and
board size / thickness. Consult your solder paste and
equipment manufacturer for specific recommendations.
5
■Operation and Precautions
q Install on the PC board with the actuator open.
e Actuator closing after the FPC is fully inserted.
Rotate the actuator down to a full stop, pushing it at
the center.
w FPC Insertion
Orient the FPC with the contact pads facing down.
Insert in the connector at an angle, assuring that the
positioning tabs are placed in the corresponding
positioning tab areas on both sides of the insulator
body.
Lower the FPC to a position parallel to the mounting
surface.
Verify the correct position by slightly pulling
horizontally on the FPC.
Positioning tab area (each side)
r Removing the FPC
Carefully rotate the actuator up, lifting it at the center.
Lift the FPC slightly to clear the positioning tabs and
withdraw it from the connector.
Positioning part
6
■Precautions
q Actuator operation
The actuator rotates at the center of it’s shaft, as
illustrated in the figure below.
w FPC Insertion and closing of the actuator.
Do not insert the FPC on an angle as illustrated in the
photograph below.
Rotation shaft
Be careful not to apply excessive force when
operating the actuator from the open position (before
the FPC has been inserted).
Exercise care not to touch the contacts with
fingernails or any other object.
Properly insert the FPC positioning tabs into the
corresponding areas on both sides of the insulator
body.
Incorrect FPC insertion
Correct FPC insertion
During the closing of the actuator do not pull up or
push on it directly down.
Do not grasp the actuator and pull on it (photograph
below).
e Make sure that the FPC does not rub against the
insertion slot or the contacts, as illustrated on the
figure below.
7
Closing of the actuator.
Rotate down pushing it at the center or evenly at
each end, as shown on the photographs below. Do
not push at one end only.
r Opening of the actuator
Rotate up, lifting it at the center or evenly at each end
of the actuator.
Do not lift at one end only.
t Forces to the FPC after insertion and closing of
the actuator.
Do not apply upward pull-force to the FPC close to the
connector.
If a need arise to route the FPC upward, assure that
it is NOT transferring any forces to the closed
actuator.
8
