ESP32-WROVER-E(8MB)
ESP32-WROVER-E(8MB)
    ESPRESSIF(乐鑫)
    SMD-38P,18x31.4x3.3mm
    ESP32-WROVER-E(8MB)
ESP32-WROVER-E(8MB) 数据手册
ESP32­WROVER­E & ESP32­WROVER­IE Datasheet Version 1.6 Espressif Systems Copyright © 2022 www.espressif.com About This Document This document provides the specifications for the ESP32-WROVER-E and ESP32-WROVER-IE modules. Document Updates Please always refer to the latest version on https://www.espressif.com/en/support/download/documents. Revision History For revision history of this document, please refer to the last page. Documentation Change Notification Espressif provides email notifications to keep customers updated on changes to technical documentation. Please subscribe at www.espressif.com/en/subscribe. Note that you need to update your subscription to receive notifications of new products you are not currently subscribed to. Certification Download certificates for Espressif products from www.espressif.com/en/certificates. Contents 1 Overview 1 2 Block Diagram 3 3 Pin Definitions 5 3.1 Pin Layout 5 3.2 Pin Description 5 3.3 Strapping Pins 7 4 Functional Description 9 4.1 CPU and Internal Memory 9 4.2 External Flash and SRAM 9 4.3 Crystal Oscillators 9 4.4 RTC and Low-Power Management 9 5 Peripherals and Sensors 11 6 Electrical Characteristics 12 6.1 Absolute Maximum Ratings 12 6.2 Recommended Operating Conditions 12 6.3 DC Characteristics (3.3 V, 25 °C) 12 6.4 Wi-Fi Radio 13 6.5 Bluetooth LE Radio 14 6.5.1 Receiver 14 6.5.2 Transmitter 14 7 Schematics 15 8 Peripheral Schematics 17 9 Physical Dimensions 18 10 Recommended PCB Land Pattern 19 11 Dimensions of External Antenna Connector 20 12 Product Handling 21 12.1 Storage Conditions 21 12.2 Electrostatic Discharge (ESD) 21 12.3 Reflow Profile 21 12.4 Ultrasonic Vibration 22 13 Related Documentation and Resources 23 Revision History 24 List of Tables 1 ESP32-WROVER-E Series Comparison 1 2 ESP32-WROVER-IE Series Comparison 1 3 ESP32-WROVER-E & ESP32-WROVER-IE Specifications 2 4 Pin Definitions 6 5 Strapping Pins 7 6 Description of ESP32 Power-up and Reset Timing Parameters 8 7 Absolute Maximum Ratings 12 8 Recommended Operating Conditions 12 9 DC Characteristics (3.3 V, 25 °C) 12 10 Wi-Fi Radio Characteristics 13 11 Receiver Characteristics – Bluetooth LE 14 12 Transmitter Characteristics – Bluetooth LE 14 List of Figures 1 ESP32-WROVER-E Block Diagram (with ESP32-D0WD-V3 embedded) 3 2 ESP32-WROVER-E Block Diagram (with ESP32-D0WDR2-V3 embedded) 3 3 ESP32-WROVER-IE Block Diagram (with ESP32-D0WD-V3 embedded) 4 4 ESP32-WROVER-IE Block Diagram (with ESP32-D0WDR2-V3 embedded) 4 5 Pin Layout (Top View) 5 6 ESP32 Power-up and Reset Timing 8 7 Schematics of ESP32-WROVER-E 15 8 Schematics of ESP32-WROVER-IE 16 9 Peripheral Schematics 17 10 Physical Dimensions 18 11 Recommended PCB Land Pattern 19 12 Dimensions of External Antenna Connector 20 13 Reflow Profile 21 1 Overview 1 Overview ESP32-WROVER-E and ESP32-WROVER-IE are two powerful, generic Wi-Fi + Bluetooth + Bluetooth LE MCU modules that target a wide variety of applications, ranging from low-power sensor networks to the most demanding tasks, such as voice encoding, music streaming and MP3 decoding. ESP32-WROVER-E comes with a PCB antenna, and ESP32-WROVER-IE with a connector for an external antenna. The information in this datasheet is applicable to both modules. The Series Comparison for the two modules is as follows: Table 1: ESP32­WROVER­E Series Comparison1 Ordering Code Ambient Temp.2 Size3 (°C) (mm) Flash PSRAM ESP32-WROVER-E-N4R8 4 MB (Quad SPI) 8 MB (Quad SPI) –40 ~ 85 ESP32-WROVER-E-N8R8 8 MB (Quad SPI) 8 MB (Quad SPI) –40 ~ 85 ESP32-WROVER-E-N16R8 16 MB (Quad SPI) 8 MB (Quad SPI) –40 ~ 85 4 –40 ~ 85 ESP32-WROVER-E-N4R2 4 MB (Quad SPI) 2 MB (Quad SPI) ESP32-WROVER-E-N8R2 8 MB (Quad SPI) 2 MB (Quad SPI)4 –40 ~ 85 ESP32-WROVER-E-N16R2 16 MB (Quad SPI) 2 MB (Quad SPI)4 –40 ~ 85 1 18.0 x 31.4 x 3.3 This table shares the same notes presented in the table 2 below. Table 2: ESP32­WROVER­IE Series Comparison Ordering Code Ambient Temp.2 Size3 (°C) (mm) Flash PSRAM ESP32-WROVER-IE-N4R8 4 MB (Quad SPI) 8 MB (Quad SPI) –40 ~ 85 ESP32-WROVER-IE-N8R8 8 MB (Quad SPI) 8 MB (Quad SPI) –40 ~ 85 ESP32-WROVER-IE-N16R8 16 MB (Quad SPI) 8 MB (Quad SPI) –40 ~ 85 4 –40 ~ 85 ESP32-WROVER-IE-N4R2 4 MB (Quad SPI) 2 MB (Quad SPI) ESP32-WROVER-IE-N8R2 8 MB (Quad SPI) 2 MB (Quad SPI)4 –40 ~ 85 4 –40 ~ 85 ESP32-WROVER-IE-N16R2 2 16 MB (Quad SPI) 2 MB (Quad SPI) 18.0 x 31.4 x 3.3 Ambient temperature specifies the recommended temperature range of the environment immediately outside the Espressif module. 3 For details, refer to Section 10 Physical Dimensions. 4 This module uses PSRAM integrated in the chip’s package. At the core of the module is the ESP32-D0WD-V3 chip or ESP32-D0WDR2-V3 chip*. The chip embedded is designed to be scalable and adaptive. There are two CPU cores that can be individually controlled, and the CPU clock frequency is adjustable from 80 MHz to 240 MHz. The chip also has a low-power coprocessor that can be used instead of the CPU to save power while performing tasks that do not require much computing power, such as monitoring of peripherals. ESP32 integrates a rich set of peripherals, ranging from capacitive touch sensors, Hall sensors, SD card interface, Ethernet, high-speed SPI, UART, I2S and I2C. Espressif Systems 1 ESP32-WROVER-E & ESP32-WROVER-IE Datasheet v1.6 Submit Documentation Feedback 1 Overview Note: * For details on the part numbers of the ESP32 family of chips, please refer to the document ESP32 Datasheet. The integration of Bluetooth® , Bluetooth LE and Wi-Fi ensures that a wide range of applications can be targeted, and that the module is all-around: using Wi-Fi allows a large physical range and direct connection to the Internet through a Wi-Fi router, while using Bluetooth allows the user to conveniently connect to the phone or broadcast low energy beacons for its detection. The sleep current of the ESP32 chip is less than 5 µA, making it suitable for battery powered and wearable electronics applications. The module supports a data rate of up to 150 Mbps, and 20 dBm output power at the antenna to ensure the widest physical range. As such the module does offer industry-leading specifications and the best performance for electronic integration, range, power consumption, and connectivity. The operating system chosen for ESP32 is freeRTOS with LwIP; TLS 1.2 with hardware acceleration is built in as well. Secure (encrypted) over the air (OTA) upgrade is also supported, so that users can upgrade their products even after their release, at minimum cost and effort. Table 3 provides the specifications of the two modules. Table 3: ESP32­WROVER­E & ESP32­WROVER­IE Specifications Categories Items Certification RF certification Test Reliablity Specifications See certificates for ESP32-WROVER-E and ESP32-WROVER-IE HTOL/HTSL/uHAST/TCT/ESD 802.11 b/g/n (802.11n up to 150 Mbps) Wi-Fi Protocols A-MPDU and A-MSDU aggregation and 0.4 µs guard interval support Frequency range 2412 ~ 2484 MHz Protocols Bluetooth v4.2 BR/EDR and Bluetooth LE specification NZIF receiver with –97 dBm sensitivity Bluetooth Radio Class-1, class-2 and class-3 transmitter AFH Audio CVSD and SBC SD card, UART, SPI, SDIO, I2C, LED PWM, Motor PWM, I2S, IR, pulse counter, GPIO, capacitive touch sen- Module interfaces sor, ADC, DAC, Two-Wire Automotive Interface (TWAI® ), compatible with ISO11898-1 (CAN Specification 2.0) Hardware On-chip sensor Hall sensor Integrated crystal 40 MHz crystal Integrated SPI flash See Table 1 and Table 2 Integrated PSRAM See Table 1 and Table 2 Operating voltage/Power supply 3.0 V ~ 3.6 V Minimum current delivered by power supply Espressif Systems 500 mA Package size (18.00±0.15) mm × (31.40±0.15) mm × (3.30±0.15) mm Moisture sensitivity level (MSL) Level 3 2 ESP32-WROVER-E & ESP32-WROVER-IE Datasheet v1.6 Submit Documentation Feedback Q Q 2 Block Diagram 2 Block Diagram ESP32-WROVER-IE 40 MHz Crystal 40 MHz Crystal 3V3 3V3 ESP32-WROVER-E Antenna Antenna RF Matching RF Matching GPIOs ESP32-D0WD-V3 QSPI PSRAM VDD_SDIO SPICS0 FLASH_CLK QSPI SPIDI SPIDO SPIWP SPIHD VDD_SDIO SPICS1 FLASHPSRAM_CLK SIO0 SIO1 SIO2 SIO3 GPIOs QSPI PSRAM EN ESP32-D0WDR2-V3 SPICS SPICLK SPIDI SPIDO SPIHD SPIWP VDD_SDIO EN QSPI FLASH Figure 1: ESP32­WROVER­E Block Diagram (with ESP32­D0WD­V3 embedded) ESP32-WROVER-E 40 MHz Crystal 3V3 Antenna RF Matching EN ESP32-D0WDR2-V3 GPIOs QSPI PSRAM SPICS SPICLK SPIDI SPIDO SPIHD SPIWP VDD_SDIO nna SIO3 SPIHD QSPI FLASH Figure 2: ESP32­WROVER­E Block Diagram (with ESP32­D0WDR2­V3 embedded) Espressif Systems 3 ESP32-WROVER-E & ESP32-WROVER-IE Datasheet v1.6 Submit Documentation Feedback ESP32-WROVER-IE 40 MHz Crystal 3V3 Antenna 3V3 RF Matching ESP32-D0WD-V3 VDD_SDIO SPICS0 FLASH_CLK SPIDI SPIDO SPIWP SPIHD VDD_SDIO SPICS1 PSRAM_CLK SIO0 SIO1 SIO2 SIO3 GPIOs QSPI PSRAM QSPI FLASH EN Figure 3: ESP32­WROVER­IE Block Diagram (with ESP32­D0WD­V3 embedded) ESP32-WROVER-IE 40 MHz Crystal 40 MHz Crystal 3V3 3V3 ESP32-WROVER-E Antenna Antenna RF Matching RF Matching GPIOs ESP32-D0WD-V3 QSPI PSRAM VDD_SDIO SPICS0 FLASH_CLK QSPI SPIDI SPIDO SPIWP SPIHD VDD_SDIO SPICS1 PSRAM_CLK FLASH SIO0 SIO1 SIO2 SIO3 GPIOs QSPI PSRAM EN ESP32-D0WDR2-V3 SPICS SPICLK SPIDI SPIDO SPIHD SPIWP VDD_SDIO EN QSPI FLASH Figure 4: ESP32­WROVER­IE Block Diagram (with ESP32­D0WDR2­V3 embedded) ESP32-WROVER-E 40 MHz Crystal 3V3 Antenna RF Matching EN ESP32-D0WDR2-V3 GPIOs QSPI PSRAM SPICS SPICLK SPIDI SPIDO SPIHD SPIWP VDD_SDIO ntenna 2 Block Diagram QSPI FLASH Espressif Systems 4 ESP32-WROVER-E & ESP32-WROVER-IE Datasheet v1.6 Submit Documentation Feedback 3V3 3 Pin Definitions 3 Pin Definitions 3.1 Pin Layout Keepout Zone 1 GND GND 38 2 3V3 IO23 37 3 EN IO22 36 4 SENSOR_VP TXD0 35 5 SENSOR_VN RXD0 34 6 IO34 IO21 33 7 IO35 NC 32 GND GND GND GND Pin 39 GND GND GND GND GND 8 IO32 IO19 31 9 IO33 IO18 30 10 IO25 IO5 29 11 IO26 NC 28 12 IO27 NC 27 13 IO14 IO4 26 14 IO12 IO0 25 15 GND IO2 24 16 IO13 IO15 23 17 NC NC 22 18 NC NC 21 19 NC NC 20 Figure 5: Pin Layout (Top View) 3.2 Pin Description The module has 38 pins. See pin definitions in Table 4. Espressif Systems 5 ESP32-WROVER-E & ESP32-WROVER-IE Datasheet v1.6 Submit Documentation Feedback 3 Pin Definitions Table 4: Pin Definitions Name No. Type Function GND 1 P Ground 3V3 2 P Power supply EN 3 I Module-enable signal. Active high. SENSOR_VP 4 I GPIO36, ADC1_CH0, RTC_GPIO0 SENSOR_VN 5 I GPIO39, ADC1_CH3, RTC_GPIO3 IO34 6 I GPIO34, ADC1_CH6, RTC_GPIO4 IO35 7 I GPIO35, ADC1_CH7, RTC_GPIO5 IO32 8 I/O IO33 9 I/O IO25 10 I/O GPIO25, DAC_1, ADC2_CH8, RTC_GPIO6, EMAC_RXD0 IO26 11 I/O GPIO26, DAC_2, ADC2_CH9, RTC_GPIO7, EMAC_RXD1 IO27 12 I/O GPIO27, ADC2_CH7, TOUCH7, RTC_GPIO17, EMAC_RX_DV IO14 13 I/O IO12 14 I/O GND 15 P IO13 16 I/O NC * 17 - - NC * 18 - - NC * 19 - - NC * 20 - - NC * 21 - - NC * 22 - - IO15 23 - IO2 24 I/O IO0 25 I/O IO4 26 I/O NC 27 - - NC 28 - - IO5 29 I/O GPIO5, VSPICS0, HS1_DATA6, EMAC_RX_CLK IO18 30 I/O GPIO18, VSPICLK, HS1_DATA7 IO19 31 I/O GPIO19, VSPIQ, U0CTS, EMAC_TXD0 NC 32 - - IO21 33 I/O GPIO21, VSPIHD, EMAC_TX_EN Espressif Systems GPIO32, XTAL_32K_P (32.768 kHz crystal oscillator input), ADC1_CH4, TOUCH9, RTC_GPIO9 GPIO33, XTAL_32K_N (32.768 kHz crystal oscillator output), ADC1_CH5, TOUCH8, RTC_GPIO8 GPIO14, ADC2_CH6, TOUCH6, RTC_GPIO16, MTMS, HSPICLK, HS2_CLK, SD_CLK, EMAC_TXD2 GPIO12, ADC2_CH5, TOUCH5, RTC_GPIO15, MTDI, HSPIQ, HS2_DATA2, SD_DATA2, EMAC_TXD3 Ground GPIO13, ADC2_CH4, TOUCH4, RTC_GPIO14, MTCK, HSPID, HS2_DATA3, SD_DATA3, EMAC_RX_ER GPIO15, ADC2_CH3, TOUCH3, MTDO, HSPICS0, RTC_GPIO13, HS2_CMD, SD_CMD, EMAC_RXD3 GPIO2, ADC2_CH2, TOUCH2, RTC_GPIO12, HSPIWP, HS2_DATA0, SD_DATA0 GPIO0, ADC2_CH1, TOUCH1, RTC_GPIO11, CLK_OUT1, EMAC_TX_CLK GPIO4, ADC2_CH0, TOUCH0, RTC_GPIO10, HSPIHD, HS2_DATA1, SD_DATA1, EMAC_TX_ER 6 ESP32-WROVER-E & ESP32-WROVER-IE Datasheet v1.6 Submit Documentation Feedback 3 Pin Definitions Name No. Type Function RXD0 34 I/O GPIO3, U0RXD, CLK_OUT2 TXD0 35 I/O GPIO1, U0TXD, CLK_OUT3, EMAC_RXD2 IO22 36 I/O GPIO22, VSPIWP, U0RTS, EMAC_TXD1 IO23 37 I/O GPIO23, VSPID, HS1_STROBE GND 38 P Ground Notice: * Pins GPIO6 to GPIO11 on the ESP32-D0WD-V3/ESP32-D0WDR2-V3 chip are connected to the SPI flash integrated on the module and are not led out. 3.3 Strapping Pins ESP32 has five strapping pins, which can be seen in Chapter 7 Schematics: • MTDI • GPIO0 • GPIO2 • MTDO • GPIO5 Software can read the values of these five bits from register ”GPIO_STRAPPING”. During the chip’s system reset release (power-on-reset, RTC watchdog reset and brownout reset), the latches of the strapping pins sample the voltage level as strapping bits of ”0” or ”1”, and hold these bits until the chip is powered down or shut down. The strapping bits configure the device’s boot mode, the operating voltage of VDD_SDIO and other initial system settings. Each strapping pin is connected to its internal pull-up/pull-down during the chip reset. Consequently, if a strapping pin is unconnected or the connected external circuit is high-impedance, the internal weak pull-up/pull-down will determine the default input level of the strapping pins. To change the strapping bit values, users can apply the external pull-down/pull-up resistances, or use the host MCU’s GPIOs to control the voltage level of these pins when powering on ESP32. After reset release, the strapping pins work as normal-function pins. Refer to Table 5 for a detailed boot-mode configuration by strapping pins. Table 5: Strapping Pins Voltage of Internal LDO (VDD_SDIO) Pin MTDI Default 3.3 V 1.8 V Pull-down 0 1 Booting Mode Pin Default SPI Boot Download Boot GPIO0 Pull-up 1 0 GPIO2 Pull-down Don’t-care 0 Espressif Systems 7 ESP32-WROVER-E & ESP32-WROVER-IE Datasheet v1.6 Submit Documentation Feedback 3 Pin Definitions Enabling/Disabling Debugging Log Print over U0TXD During Booting Pin Default U0TXD Active U0TXD Silent MTDO Pull-up 1 0 Timing of SDIO Slave FE Sampling FE Sampling RE Sampling RE Sampling Pin Default FE Output RE Output FE Output RE Output MTDO Pull-up 0 0 1 1 GPIO5 Pull-up 0 1 0 1 Note: • FE: falling-edge, RE: rising-edge. • Firmware can configure register bits to change the settings of ”Voltage of Internal LDO (VDD_SDIO)” and ”Timing of SDIO Slave” after booting. • Internal pull-up resistor (R9) for MTDI is not populated in the module, as the flash and SRAM in the module only support a power voltage of 3.3 V (output by VDD_SDIO). The illustration below shows the ESP32 power-up and reset timing. Details about the parameters are listed in Table 6. t0 t1 VDD3P3_RTC Min VDD VIL_nRST CHIP_PU Figure 6: ESP32 Power­up and Reset Timing Table 6: Description of ESP32 Power­up and Reset Timing Parameters Parameters t0 t1 Espressif Systems Description Time between the 3.3 V rails being brought up and CHIP_PU being activated Duration of CHIP_PU signal level < VIL_nRST (refer to its value in Table 9 DC Characteristics) to reset the chip 8 Min. Unit 50 µs 50 µs ESP32-WROVER-E & ESP32-WROVER-IE Datasheet v1.6 Submit Documentation Feedback 4 Functional Description 4 Functional Description This chapter describes the modules and functions integrated in ESP32-WROVER-E and ESP32-WROVER-IE. 4.1 CPU and Internal Memory ESP32-D0WD-V3 (ESP32-D0WDR2-V3) contains two low-power Xtensa® 32-bit LX6 microprocessors. The internal memory includes: • 448 KB of ROM for booting and core functions. • 520 KB of on-chip SRAM for data and instructions. • 8 KB of SRAM in RTC, which is called RTC FAST Memory and can be used for data storage; it is accessed by the main CPU during RTC Boot from the Deep-sleep mode. • 8 KB of SRAM in RTC, which is called RTC SLOW Memory and can be accessed by the co-processor during the Deep-sleep mode. • 1 Kbit of eFuse: 256 bits are used for the system (MAC address and chip configuration) and the remaining 768 bits are reserved for customer applications, including flash-encryption and chip-ID. 4.2 External Flash and SRAM ESP32 supports multiple external QSPI flash and SRAM chips. More details can be found in Chapter SPI in the ESP32 Technical Reference Manual. ESP32 also supports hardware encryption/decryption based on AES to protect developers’ programs and data in flash. ESP32 can access the external QSPI flash and SRAM through high-speed caches. • The external flash can be mapped into CPU instruction memory space and read-only memory space simultaneously. – When external flash is mapped into CPU instruction memory space, up to 11 MB + 248 KB can be mapped at a time. Note that if more than 3 MB + 248 KB are mapped, cache performance will be reduced due to speculative reads by the CPU. – When external flash is mapped into read-only data memory space, up to 4 MB can be mapped at a time. 8-bit, 16-bit and 32-bit reads are supported. • External SRAM can be mapped into CPU data memory space. Up to 4 MB can be mapped at a time. 8-bit, 16-bit and 32-bit reads and writes are supported. 4.3 Crystal Oscillators The module uses a 40-MHz crystal oscillator. 4.4 RTC and Low­Power Management With the use of advanced power-management technologies, ESP32 can switch between different power modes. Espressif Systems 9 ESP32-WROVER-E & ESP32-WROVER-IE Datasheet v1.6 Submit Documentation Feedback 4 Functional Description For details on ESP32’s power consumption in different power modes, please refer to section ”RTC and Low-Power Management” in ESP32 Datasheet. Espressif Systems 10 ESP32-WROVER-E & ESP32-WROVER-IE Datasheet v1.6 Submit Documentation Feedback 5 Peripherals and Sensors 5 Peripherals and Sensors Please refer to Section Peripherals and Sensors in ESP32 Datasheet. Note: External connections can be made to any GPIO except for GPIOs in the range 6-11, 16, or 17. GPIOs 6-11 are connected to the module’s integrated SPI flash. GPIOs 16 and 17 are connected to the module’s integrated PSRAM. For details, please see Section 7 Schematics. Espressif Systems 11 ESP32-WROVER-E & ESP32-WROVER-IE Datasheet v1.6 Submit Documentation Feedback 6 Electrical Characteristics 6 Electrical Characteristics 6.1 Absolute Maximum Ratings Stresses beyond the absolute maximum ratings listed in the table below may cause permanent damage to the device. These are stress ratings only, and do not refer to the functional operation of the device that should follow the recommended operating conditions. Table 7: Absolute Maximum Ratings Symbol Parameter VDD33 Power supply voltage Ioutput 1 Min Max –0.3 3.6 - 1,100 –40 105 Cumulative IO output current Tstore Storage temperature Unit V mA °C 1. The module worked properly after a 24-hour test in ambient temperature at 25 °C, and the IOs in three domains (VDD3P3_RTC, VDD3P3_CPU, VDD_SDIO) output high logic level to ground. Please note that pins occupied by flash and/or PSRAM in the VDD_SDIO power domain were excluded from the test. 2. Please see Appendix IO_MUX in ESP32 Datasheet for IO’s power domain. 6.2 Recommended Operating Conditions Table 8: Recommended Operating Conditions Symbol Parameter Min Typical Max Unit VDD33 Power supply voltage 3.0 3.3 3.6 V IV DD Current delivered by external power supply 0.5 - - A T Operating temperature –40 - 85 °C 6.3 DC Characteristics (3.3 V, 25 °C) Table 9: DC Characteristics (3.3 V, 25 °C) Symbol CIN VIH Parameter Min Typ Pin capacitance - 2 High-level input voltage 1 0.75×VDD Max 1 Unit pF - VDD +0.3 V 1 V VIL Low-level input voltage –0.3 - IIH High-level input current - - 50 nA IIL Low-level input current - - 50 nA VOH High-level output voltage 0.8×VDD1 - - V VOL Low-level output voltage - - 0.1×VDD1 V Espressif Systems 12 0.25×VDD ESP32-WROVER-E & ESP32-WROVER-IE Datasheet v1.6 Submit Documentation Feedback 6 Electrical Characteristics Symbol Parameter VDD3P3_CPU High-level source current power domain 1, 1 (VDD = 3.3 V, VDD3P3_RTC VOH >= 2.64 V, IOH 2 power domain 1, output drive strength set 2 VDD_SDIO power to the maximum) domain 1, 3 Min Typ Max Unit - 40 - mA - 40 - mA - 20 - mA - 28 - mA Low-level sink current (VDD1 = 3.3 V, VOL = 0.495 V, IOL output drive strength set to the maximum) RP U Resistance of internal pull-up resistor - 45 - kΩ RP D Resistance of internal pull-down resistor - 45 - kΩ - - 0.6 VIL_nRST Low-level input voltage of CHIP_PU to power off the chip V Notes: 1. Please see Appendix IO_MUX in ESP32 Datasheet for IO’s power domain. VDD is the I/O voltage for a particular power domain of pins. 2. For VDD3P3_CPU and VDD3P3_RTC power domain, per-pin current sourced in the same domain is gradually reduced from around 40 mA to around 29 mA, VOH >=2.64 V, as the number of current-source pins increases. 3. Pins occupied by flash and/or PSRAM in the VDD_SDIO power domain were excluded from the test. 6.4 Wi­Fi Radio Table 10: Wi­Fi Radio Characteristics Parameter Condition Operating frequency range Output impedance note2 TX power note3 Sensitivity Adjacent channel rejection Espressif Systems note1 Min Typical Max Unit - 2412 - 2484 MHz - - * - 12 13 14 dBm 18.5 19.5 20.5 dBm 11b, 1 Mbps - –97 - dBm 11b, 11 Mbps - –88 - dBm 11g, 6 Mbps - –92 - dBm 11g, 54 Mbps - –75 - dBm 11n, HT20, MCS0 - –92 - dBm 11n, HT20, MCS7 - –72 - dBm 11n, HT40, MCS0 - –89 - dBm 11n, HT40, MCS7 - –69 - dBm 11g, 6 Mbps - 27 - dB 11g, 54 Mbps - 13 - dB 11n, HT20, MCS0 - 27 - dB 11n, HT20, MCS7 - 12 - dB 11n, MCS7 11b mode 13 Ω ESP32-WROVER-E & ESP32-WROVER-IE Datasheet v1.6 Submit Documentation Feedback 6 Electrical Characteristics Notes: 1. Device should operate in the frequency range allocated by regional regulatory authorities. Target operating frequency range is configurable by software. 2. For the modules that use external antennas, the output impedance is 50 Ω. For other modules without external antennas, users do not need to concern about the output impedance. 3. Target TX power is configurable based on device or certification requirements. 6.5 Bluetooth LE Radio 6.5.1 Receiver Table 11: Receiver Characteristics – Bluetooth LE Parameter Conditions Min Typ Max Unit Sensitivity @30.8% PER - –94 –93 –92 dBm Maximum received signal @30.8% PER - 0 - - dBm Co-channel C/I - - +10 - dB F = F0 + 1 MHz - –5 - dB F = F0 – 1 MHz - –5 - dB F = F0 + 2 MHz - –25 - dB F = F0 – 2 MHz - –35 - dB F = F0 + 3 MHz - –25 - dB F = F0 – 3 MHz - –45 - dB 30 MHz ~ 2000 MHz –10 - - dBm 2000 MHz ~ 2400 MHz –27 - - dBm 2500 MHz ~ 3000 MHz –27 - - dBm 3000 MHz ~ 12.5 GHz –10 - - dBm - –36 - - dBm Unit Adjacent channel selectivity C/I Out-of-band blocking performance Intermodulation 6.5.2 Transmitter Table 12: Transmitter Characteristics – Bluetooth LE Parameter Conditions Min Typ Max RF transmit power - - 0 - dBm Gain control step - - 3 - dBm RF power control range - –12 - +9 dBm F = F0 ± 2 MHz - –52 - dBm F = F0 ± 3 MHz - –58 - dBm F = F0 ± > 3 MHz - –60 - dBm ∆ f 1avg - - - 265 kHz ∆ f 2max - 247 - - kHz ∆ f 2avg /∆ f 1avg - - +0.92 - - ICFT - - –10 - kHz Drift rate - - 0.7 - kHz/50 µs Drift - - 2 - kHz Adjacent channel transmit power Espressif Systems 14 ESP32-WROVER-E & ESP32-WROVER-IE Datasheet v1.6 Submit Documentation Feedback 5 4 3 2 1 This is the reference design of the module. GND The values of C1 and C2 vary with the selection of the crystal. GND The value of R2 varies with the actual PCB board. 1 1uF C2 TBD GND 0 GND 3 GND TBD C20 100pF VDD33 U1 2 C3 D C1 XIN VDD33 GND XOUT 4 GND C9 GND 0.1uF PCB ANTENNA GND 2.0nH(0.1nH) C13 C11 C10 C21 10uF 1uF 0.1uF NC 40MHz(±10ppm) GPIO21 U0TXD U0RXD GPIO22 R3 499 3.3nF/6.3V(10%) GND J39 IPEX(NC) VDD33 GND CAP1 CAP2 VDDA XTAL_P XTAL_N VDDA GPIO21 U0TXD U0RXD GPIO22 49 0(NC) GND 3 2 C5 10nF/6.3V(10%) GND GND ANT2 R14 20K(5%) D1 C4 VDD33 ESD 0.1uF 1 2 ANT1 R15 RF_ANT L4 0 PCB_ANT C15 C14 TBD TBD GND C LNA_IN TBD GND GND The values of C15, L4 and C14 vary with the actual PCB board. SENSOR_VP SENSOR_VN EN GPIO34 GPIO35 GPIO32 GPIO33 GPIO25 NC: No component. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 VDDA LNA_IN VDD3P3 VDD3P3 SENSOR_VP SENSOR_CAPP SENSOR_CAPN SENSOR_VN CHIP_PU VDET_1 VDET_2 32K_XP 32K_XN GPIO25 SCK/CLK R12 15 16 17 18 19 20 21 22 23 24 FLASH_CLK 0 38 37 36 35 34 33 32 31 30 29 28 27 26 25 ESP32-D0WD-V3 ESP32-D0WDR2-V3 GPIO19 GPIO23 GPIO18 GPIO5 SDI/SD1 SDO/SD0 SCK/CLK SCS/CMD SWP/SD3 SHD/SD2 GPIO17 GPIO16 R4 C24 VDD_SDIO 2K(NC) 1uF VDD33 GND 0(NC) GPIO17 R13 SRAM_CLK 0 GND R9 C19 GPIO13 GPIO15 GPIO2 GPIO0 GPIO4 10K(NC) GPIO26 GPIO27 GPIO14 GPIO12 VDD33 R11 0.1uF GND Flash and PSRAM VDD_SDIO SHD/SD2 7 CLK /HOLD FLASH B GND VDD_SDIO R10 8 /CS GND 1 FLASH_CLK 6 VCC U3 SCS/CMD VDD_SDIO DI DO /WP 5 SDI/SD1 2 SDO/SD0 3 SWP/SD3 10K U4 1 2 3 4 GPIO16 SDO/SD0 SWP/SD3 4 ESP32-WROVER-E & ESP32-WROVER-IE Datasheet v1.6 U2 GPIO19 VDD3P3_CPU GPIO23 GPIO18 GPIO5 SD_DATA_1 SD_DATA_0 SD_CLK SD_CMD SD_DATA_3 SD_DATA_2 GPIO17 VDD_SDIO GPIO16 GPIO26 GPIO27 MTMS MTDI VDD3P3_RTC MTCK MTDO GPIO2 GPIO0 GPIO4 GND ANT1 15 Submit Documentation Feedback GND 1 R1 C6 48 47 46 45 44 43 42 41 40 39 L5 GND GND R2 VDD33 CS# VDD SO/SIO1 SIO3 SIO2 SCLK VSS SI/SIO0 8 7 6 5 SHD/SD2 SRAM_CLK SDI/SD1 PSRAM GND GND Pin.1 GND Pin.2 3V3 Pin.3 EN Pin.4 SENSOR_VP Pin.5 SENSOR_VN Pin.6 IO34 Pin.7 IO35 Pin.8 IO32 Pin.9 IO33 Pin.10 IO25 Pin.11 IO26 Pin.12 IO27 Pin.13 IO14 Pin.14 IO12 Pin.15 GND Pin.16 IO13 Pin.17 NC Pin.18 NC Pin.19 NC When ESP32-D0WDR2-V3 is used, U4 will be NC. Figure 7: Schematics of ESP32­WROVER­E GND GND GPIO23 VDD33 EN GPIO22 SENSOR_VP U0TXD SENSOR_VN U0RXD GPIO34 GPIO21 GPIO35 EPAD GPIO32 GPIO19 GPIO33 GPIO18 GPIO25 GPIO5 GPIO26 GPIO27 GPIO14 GPIO4 GPIO12 GPIO0 GPIO2 GND GPIO13 GPIO15 ESP32-WROVER-E(pin-out) Pin.38 GND Pin.37 IO23 Pin.36 IO22 Pin.35 U0TXD Pin.34 U0RXD Pin.33 IO21 Pin.32 NC Pin.31 IO19 Pin.30 IO18 Pin.29 IO5 Pin.28 NC Pin.27 NC Pin.26 IO4 Pin.25 IO0 Pin.24 IO2 Pin.23 IO15 Pin.22 NC Pin.21 NC Pin.20 NC 7 Schematics Espressif Systems 7 Schematics 5 4 3 2 1 7 Schematics GND The value of R2 varies with the actual PCB board. 1 1uF GND 3 GND C20 100pF VDD33 TBD C2 TBD 2 C3 D C1 U1 XIN VDD33 GND XOUT 4 GND GND 0 Espressif Systems GND The values of C1 and C2 vary with the selection of the crystal. C9 GND 0.1uF PCB ANTENNA GND 2.0nH(0.1nH) C13 C11 C10 C21 10uF 1uF 0.1uF NC R3 GPIO21 U0TXD U0RXD GPIO22 499 3.3nF/6.3V(10%) GND GND GND 40MHz(±10ppm) C6 C5 10nF/6.3V(10%) J39 IPEX VDD33 GND CAP1 CAP2 VDDA XTAL_P XTAL_N VDDA GPIO21 U0TXD U0RXD GPIO22 0 GND 3 2 ANT2 R14 20K(5%) 49 GND 1 R1 48 47 46 45 44 43 42 41 40 39 L5 GND GND R2 VDD33 D1 C4 VDD33 ESD 0.1uF 1 2 ANT1 R15 0(NC) RF_ANT L4 PCB_ANT C14 TBD GND GND The values of C15, L4 and C14 vary with the actual PCB board. SENSOR_VP SENSOR_VN EN GPIO34 GPIO35 GPIO32 GPIO33 GPIO25 NC: No component. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 VDDA LNA_IN VDD3P3 VDD3P3 SENSOR_VP SENSOR_CAPP SENSOR_CAPN SENSOR_VN CHIP_PU VDET_1 VDET_2 32K_XP 32K_XN GPIO25 SCK/CLK R12 15 16 17 18 19 20 21 22 23 24 U2 16 FLASH_CLK 0 GPIO19 VDD3P3_CPU GPIO23 GPIO18 GPIO5 SD_DATA_1 SD_DATA_0 SD_CLK SD_CMD SD_DATA_3 SD_DATA_2 GPIO17 VDD_SDIO GPIO16 38 37 36 35 34 33 32 31 30 29 28 27 26 25 ESP32-D0WD-V3 ESP32-D0WDR2-V3 GPIO19 GPIO23 GPIO18 GPIO5 SDI/SD1 SDO/SD0 SCK/CLK SCS/CMD SWP/SD3 SHD/SD2 GPIO17 GPIO16 R4 C24 VDD_SDIO 2K(NC) 1uF VDD33 GND 0(NC) GPIO17 R13 SRAM_CLK 0 GND R9 C19 GPIO13 GPIO15 GPIO2 GPIO0 GPIO4 10K(NC) GPIO26 GPIO27 GPIO14 GPIO12 VDD33 R11 0.1uF GND Flash and PSRAM VDD_SDIO SHD/SD2 7 CLK /HOLD FLASH B GND VDD_SDIO R10 8 /CS GND 1 FLASH_CLK 6 VCC U3 SCS/CMD VDD_SDIO DI DO /WP 5 SDI/SD1 2 SDO/SD0 3 SWP/SD3 10K U4 1 2 3 4 GPIO16 SDO/SD0 SWP/SD3 4 ESP32-WROVER-E & ESP32-WROVER-IE Datasheet v1.6 Submit Documentation Feedback C15 TBD GND C LNA_IN TBD GPIO26 GPIO27 MTMS MTDI VDD3P3_RTC MTCK MTDO GPIO2 GPIO0 GPIO4 GND ANT1 CS# VDD SO/SIO1 SIO3 SIO2 SCLK VSS SI/SIO0 8 7 6 5 SHD/SD2 SRAM_CLK SDI/SD1 PSRAM GND GND Pin.1 GND Pin.2 3V3 Pin.3 EN Pin.4 SENSOR_VP Pin.5 SENSOR_VN Pin.6 IO34 Pin.7 IO35 Pin.8 IO32 Pin.9 IO33 Pin.10 IO25 Pin.11 IO26 Pin.12 IO27 Pin.13 IO14 Pin.14 IO12 Pin.15 GND Pin.16 IO13 Pin.17 NC Pin.18 NC Pin.19 NC When ESP32-D0WDR2-V3 is used, U4 will be NC. Figure 8: Schematics of ESP32­WROVER­IE A GND GND GPIO23 VDD33 EN GPIO22 SENSOR_VP U0TXD SENSOR_VN U0RXD GPIO34 GPIO21 GPIO35 EPAD GPIO32 GPIO19 GPIO33 GPIO18 GPIO25 GPIO5 GPIO26 GPIO27 GPIO14 GPIO4 GPIO12 GPIO0 GPIO2 GND GPIO13 GPIO15 ESP32-WROVER-IE(pin-out) Pin.38 GND Pin.37 IO23 Pin.36 IO22 Pin.35 U0TXD Pin.34 U0RXD Pin.33 IO21 Pin.32 NC Pin.31 IO19 Pin.30 IO18 Pin.29 IO5 Pin.28 NC Pin.27 NC Pin.26 IO4 Pin.25 IO0 Pin.24 IO2 Pin.23 IO15 Pin.22 NC Pin.21 NC Pin.20 NC 8 Peripheral Schematics 8 Peripheral Schematics This is the typical application circuit of the module connected with peripheral components (for example, power supply, antenna, reset button, JTAG interface, and UART interface). U1 C2 R1 22uF 0.1uF TBD EN SENSOR_VP SENSOR_VN IO34 IO35 IO32 IO33 IO25 IO26 IO27 IO14 IO12 C3 TBD GND IO13 GND P_GND GND3 IO23 IO22 TXD0 RXD0 IO21 NC IO19 IO18 IO5 NC NC IO4 IO0 IO2 IO15 NC NC NC GND1 3V3 EN SENSOR_VP SENSOR_VN IO34 IO35 IO32 IO33 IO25 IO26 IO27 IO14 IO12 GND2 IO13 NC NC NC 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 22 21 20 GND IO19 IO18 IO5 ESP32-WROVER-E/ESP32-WROVER-IE 1 2 3 4 1 2 3 4 UART GND GND JP2 Boot Option SW1 JP3 TMS TDI TCK TDO JP1 1 2 3 4 IO4 IO0 IO2 IO15 GND IO14 IO12 IO13 IO15 VDD33 IO23 IO22 TXD0 RXD0 IO21 1 2 C1 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 1 2 VDD33 R2 1 2 3 4 C4 JTAG 0R EN 0.1uF GND IO12 should be kept low when the module is powered on. Figure 9: Peripheral Schematics Note: • Soldering Pad 39 to the Ground of the base board is not necessary for a satisfactory thermal performance. If users do want to solder it, they need to ensure that the correct quantity of soldering paste is applied. • To ensure the power supply to the ESP32 chip during power-up, it is advised to add an RC delay circuit at the EN pin. The recommended setting for the RC delay circuit is usually R = 10 kΩ and C = 1 µF. However, specific parameters should be adjusted based on the power-up timing of the module and the power-up and reset sequence timing of the chip. For ESP32’s power-up and reset sequence timing diagram, please refer to Section Power Scheme in ESP32 Datasheet. 4 Espressif Systems 3 17 ESP32-WROVER-E & ESP32-WROVER-IE Datasheet v1.6 Submit Documentation Feedback 2 9 Physical Dimensions Espressif Systems 9 Physical Dimensions Unit: mm 18.00±0.15 3.30±0.15 0.85 0.1 0.50 15.84 0.90 10.50 0.57 1.10 0.85 Top View Side View Figure 10: Physical Dimensions Bottom View 16.16 0.50 23.05 24.09 3.70 3.72 0.90 3.70 10.45 1.27 ESP32-WROVER-E & ESP32-WROVER-IE Datasheet v1.6 31.40±0.15 6.22 0.90 6.22 0.45 18 Submit Documentation Feedback 0.80 2.25 10 Recommended PCB Land Pattern 10 Recommended PCB Land Pattern Unit: mm Via for thermal pad Copper 6.22 18.00 Antenna Area 38x1.50 3.70 0.90 0.50 0.50 0.90 3.70 16.16 1.27 1.10 7.50 38 22.86 31.40 38x0.90 1 20 19 0.50 Figure 11: Recommended PCB Land Pattern Espressif Systems 19 ESP32-WROVER-E & ESP32-WROVER-IE Datasheet v1.6 Submit Documentation Feedback 11 Dimensions of External Antenna Connector 11 Dimensions of External Antenna Connector Unit: mm Figure 12: Dimensions of External Antenna Connector Espressif Systems 20 ESP32-WROVER-E & ESP32-WROVER-IE Datasheet v1.6 Submit Documentation Feedback 12 Product Handling 12 Product Handling 12.1 Storage Conditions The products sealed in moisture barrier bags (MBB) should be stored in a non-condensing atmospheric environment of < 40 °C and 90%RH. The module is rated at the moisture sensitivity level (MSL) of 3. After unpacking, the module must be soldered within 168 hours with the factory conditions 25 ± 5 °C and 60 %RH. If the above conditions are not met, the module needs to be baked. 12.2 Electrostatic Discharge (ESD) • Human body model (HBM): ±2000 V • Charged-device model (CDM): ±500 V 12.3 Reflow Profile Temperature (℃) Solder the module in a single reflow. Peak Temp. 235 ~ 250 ℃ 250 Preheating zone 150 ~ 200 ℃ 60 ~ 120 s 217 200 Reflow zone 217 ℃ 60 ~ 90 s Cooling zone –1 ~ –5 ℃/s Soldering time > 30 s Ramp-up zone 1 ~ 3 ℃/s 100 50 25 Time (sec.) 0 0 50 100 150 200 250 Ramp-up zone — Temp.: 25 ~ 150 ℃ Time: 60 ~ 90 s Ramp-up rate: 1 ~ 3 ℃/s Preheating zone — Temp.: 150 ~ 200 ℃ Time: 60 ~ 120 s Reflow zone — Temp.: >217 ℃ 60 ~ 90 s; Peak Temp.: 235 ~ 250 ℃ Time: 30 ~ 70 s Cooling zone — Peak Temp. ~ 180 ℃ Ramp-down rate: –1 ~ –5 ℃/s Solder — Sn-Ag-Cu (SAC305) lead-free solder alloy Figure 13: Reflow Profile Espressif Systems 21 ESP32-WROVER-E & ESP32-WROVER-IE Datasheet v1.6 Submit Documentation Feedback 12 Product Handling 12.4 Ultrasonic Vibration Avoid exposing Espressif modules to vibration from ultrasonic equipment, such as ultrasonic welders or ultrasonic cleaners. This vibration may induce resonance in the in-module crystal and lead to its malfunction or even failure. As a consequence, the module may stop working or its performance may deteriorate. Espressif Systems 22 ESP32-WROVER-E & ESP32-WROVER-IE Datasheet v1.6 Submit Documentation Feedback 13 Related Documentation and Resources 13 Related Documentation and Resources Related Documentation • ESP32 Series Datasheet – Specifications of the ESP32 hardware. • ESP32 Technical Reference Manual – Detailed information on how to use the ESP32 memory and peripherals. • ESP32 Hardware Design Guidelines – Guidelines on how to integrate the ESP32 into your hardware product. • ESP32 ECO and Workarounds for Bugs – Correction of ESP32 design errors. • Certificates https://espressif.com/en/support/documents/certificates • ESP32 Product/Process Change Notifications (PCN) https://espressif.com/en/support/documents/pcns • ESP32 Advisories – Information on security, bugs, compatibility, component reliability. https://espressif.com/en/support/documents/advisories • Documentation Updates and Update Notification Subscription https://espressif.com/en/support/download/documents Developer Zone • ESP-IDF Programming Guide for ESP32 – Extensive documentation for the ESP-IDF development framework. • ESP-IDF and other development frameworks on GitHub. https://github.com/espressif • ESP32 BBS Forum – Engineer-to-Engineer (E2E) Community for Espressif products where you can post questions, share knowledge, explore ideas, and help solve problems with fellow engineers. https://esp32.com/ • The ESP Journal – Best Practices, Articles, and Notes from Espressif folks. https://blog.espressif.com/ • See the tabs SDKs and Demos, Apps, Tools, AT Firmware. https://espressif.com/en/support/download/sdks-demos Products • ESP32 Series SoCs – Browse through all ESP32 SoCs. https://espressif.com/en/products/socs?id=ESP32 • ESP32 Series Modules – Browse through all ESP32-based modules. https://espressif.com/en/products/modules?id=ESP32 • ESP32 Series DevKits – Browse through all ESP32-based devkits. https://espressif.com/en/products/devkits?id=ESP32 • ESP Product Selector – Find an Espressif hardware product suitable for your needs by comparing or applying filters. https://products.espressif.com/#/product-selector?language=en Contact Us • See the tabs Sales Questions, Technical Enquiries, Circuit Schematic & PCB Design Review, Get Samples (Online stores), Become Our Supplier, Comments & Suggestions. https://espressif.com/en/contact-us/sales-questions Espressif Systems 23 ESP32-WROVER-E & ESP32-WROVER-IE Datasheet v1.6 Submit Documentation Feedback Revision History Revision History Date Version Release notes Added module variants embedded with ESP32-D0WDR2-V3 chip Added Table 1: ESP32-WROVER-E Series Comparison and Table 2: ESP32- 2022-07-20 v1.6 WROVER-IE Series Comparison Added Figure 6 and Table 6 in Section 3.3: Strapping Pins Updated Section 13: Related Documentation and Resources Replaced Espressif Product Ordering Information with ESP Product Selector Updated the description of TWAI in Table 3 2022-02-22 v1.5 Added a link to RF certificates in Table 3 Updated Ordering Information Table Updated Table 7 Fixed typos 2021-02-09 V1.4 Updated Figure 10: Physical Dimensions Updated Figure 11: Recommended PCB Land Pattern Updated the trade mark from TWAI™ to TWAI® 2021-02-02 V1.3 Modified the note below Figure 13: Reflow Profile Deleted Reset Circuit and Discharge Circuit for VDD33 Rail in Section 8: Peripheral Schematics Updated Figure 3.1: Pin Layout 2020-11-02 V1.2 Added a note to EPAD in Section 10: Recommended PCB Land Pattern Updated the note to RC delay circuit in Section 8: Peripheral Schematics Updated the following figures: • Figure 1: ESP32-WROVER-E Block Diagram (with ESP32-D0WD-V3 embed- 2020-06-11 V1.1 ded) • Figure 2: ESP32-WROVER-E Block Diagram (with ESP32-D0WDR2-V3 embedded) 2020-05-22 V1.0 Espressif Systems Official release 24 ESP32-WROVER-E & ESP32-WROVER-IE Datasheet v1.6 Submit Documentation Feedback Disclaimer and Copyright Notice Information in this document, including URL references, is subject to change without notice. ALL THIRD PARTY’S INFORMATION IN THIS DOCUMENT IS PROVIDED AS IS WITH NO WARRANTIES TO ITS AUTHENTICITY AND ACCURACY. NO WARRANTY IS PROVIDED TO THIS DOCUMENT FOR ITS MERCHANTABILITY, NONINFRINGEMENT, FITNESS FOR ANY PARTICULAR PURPOSE, NOR DOES ANY WARRANTY OTHERWISE ARISING OUT OF ANY PROPOSAL, SPECIFICATION OR SAMPLE. All liability, including liability for infringement of any proprietary rights, relating to use of information in this document is disclaimed. No licenses express or implied, by estoppel or otherwise, to any intellectual property rights are granted herein. The Wi-Fi Alliance Member logo is a trademark of the Wi-Fi Alliance. The Bluetooth logo is a registered trademark of Bluetooth SIG. www.espressif.com All trade names, trademarks and registered trademarks mentioned in this document are property of their respective owners, and are hereby acknowledged. Copyright © 2022 Espressif Systems (Shanghai) Co., Ltd. All rights reserved.
ESP32-WROVER-E(8MB) 价格&库存
很抱歉,暂时无法提供与“ESP32-WROVER-E(8MB)”相匹配的价格&库存,您可以联系我们找货
