SMD1812-075
SMD1812-075
    JKSEMI(金开盛)
SMD1812-075 数据手册
JSMD 1812 Series Surface Mount PTC Devices Performance Specification Maximum V max Model Imax Resistance I hold I trip Pd @25°C @25°C Typ. Curren t Tim e R i min R1max Time To Trip (V dc) (A) (A) (A) (W) (A) (Sec) () () JSMD1812-010 30.0 100 0.10 0.30 0.8 0.5 1.50 0.750 15.000 JSMD1812-010/60 60.0 100 0.10 0.30 0.8 0.5 1.50 0.750 15.000 JSMD1812-014 60.0 100 0.14 0.34 0.8 1.5 0.15 0.650 6.000 JSMD1812-020 30.0 100 0.20 0.40 0.8 8.0 0.02 0.350 5.000 JSMD1812-020/60 60.0 100 0.20 0.40 0.8 8.0 0.02 0.350 5.000 JSMD1812-030 30.0 100 0.30 0.60 0.8 8.0 0.10 0.250 3.000 JSMD1812-035 30.0 100 0.35 0.70 0.8 8.0 0.10 0.350 1.800 JSMD1812-035/60 60.0 100 0.35 0.70 0.8 8.0 0.10 0.350 2.000 JSMD1812-050 16.0 100 0.50 1.00 0.8 8.0 0.15 0.150 1.000 JSMD1812-050/30 30.0 100 0.50 1.00 0.8 8.0 0.15 0.150 1.000 JSMD1812-050/60 60.0 100 0.50 1.00 0.8 8.0 0.15 0.150 1.000 JSMD1812-075 16.0 100 0.75 1.50 0.8 8.0 0.20 0.090 0.450 JSMD1812-075/24 24.0 100 0.75 1.50 0.8 8.0 0.20 0.090 0.450 JSMD1812-075/33 33.0 100 0.75 1.50 0.8 8.0 0.20 0.090 0.450 JSMD1812-110 8.0 100 1.10 2.20 0.8 8.0 0.30 0.050 0.250 JSMD1812-110/12 12.0 100 1.10 2.20 0.8 8.0 0.30 0.050 0.250 JSMD1812-110/16 16.0 100 1.10 2.20 0.8 8.0 0.30 0.050 0.250 JSMD1812-110/24 24.0 100 1.10 2.20 0.8 8.0 0.30 0.050 0.250 JSMD1812-110/33 33.0 100 1.10 2.20 0.8 8.0 0.30 0.050 0.250 JSMD1812-125 8.0 100 1.25 2.50 0.8 8.0 0.40 0.050 0.140 JSMD1812-125/12 12.0 100 1.25 2.50 0.8 8.0 0.40 0.050 0.140 JSMD1812-125/16 16.0 100 1.25 2.50 0.8 8.0 0.40 0.050 0.140 JSMD1812-150 8.0 100 1.50 3.00 0.8 8.0 0.50 0.040 0.160 JSMD1812-150/12 12.0 100 1.50 3.00 0.8 8.0 0.50 0.040 0.160 JSMD1812-150/16 16.0 100 1.50 3.00 0.8 8.0 0.50 0.040 0.160 JSMD1812-150/24 24.0 100 1.50 3.00 0.8 8.0 0.50 0.040 0.160 JSMD1812-160 8.0 100 1.60 2.80 0.8 8.0 1.00 0.030 0.130 JSMD1812-160/12 12.0 100 1.60 2.80 0.8 8.0 1.00 0.030 0.130 JSMD1812-160/16 16.0 100 1.60 2.80 0.8 8.0 1.00 0.030 0.130 JSMD1812-200 8.0 100 2.00 4.00 0.8 8.0 2.00 0.020 0.100 JSMD1812-200/12 12.0 100 2.00 4.00 0.8 8.0 2.00 0.020 0.100 JSMD1812-200/16 16.0 100 2.00 4.00 0.8 8.0 2.00 0.020 0.100 http:// www.jksemi.com 2016-12-01 版次: c JSMD 1812 Series Surface Mount PTC Devices JSMD1812-250 8.0 100 2.50 5.00 0.8 8.0 5.00 0.015 0.075 JSMD1812-250/12 12.0 100 2.50 5.00 0.8 8.0 5.00 0.015 0.075 JSMD1812-250/16 16.0 100 2.50 5.00 0.8 8.0 5.00 0.015 0.075 JSMD1812-260 8.0 100 2.60 5.00 0.8 8.0 2.50 0.015 0.050 JSMD1812-260/12 12.0 100 2.60 5.00 0.8 8.0 2.50 0.015 0.050 JSMD1812-260/16 16.0 100 2.60 5.00 0.8 8.0 2.50 0.015 0.050 JSMD1812-300 6.0 100 3.00 5.00 0.8 8.0 4.00 0.012 0.040 JSMD1812-300/8 8.0 100 3.00 5.00 0.8 8.0 4.00 0.012 0.040 V max = Maximum operating voltage device can withstand without damage at rated current (Imax). I max = Maximum fault current device can withstand without damage at rated voltage (Vmax). I hold = Hold Current. Maximum current device will not trip in 25°C still air. I trip = Trip Current. Minimum current at which the device will always trip in 25°C still air. Pd = Power dissipation when device is in the tripped state in 25°C still air environment at rated voltage. Ri min/max = Minimum/Maximum device resistance prior to tripping at25°C. R1max = Maximum device resistance is measured one hour post reflow. CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame. Environmental Specifications Test Conditions Resistance change Passive aging +85°C, 1000 hrs. ±5% typical Humidity aging +85°C, 85% R.H. , 168 hours ±5% typical Thermal shock +85°C to -40°C, 20 times ±33% typical Resistance to solvent MIL-STD-202,Method 215 No change Vibration MIL-STD-202,Method 201 No change Ambient operating conditions : - 40 °C to +85 °C Maximum surface temperature of the device in the tripped state is 125 °C Agency Approval and Environmental Complianc Agency File Number UL EN217453 2002/95/EC TUV pending EN14582 http:// www.jksemi.com Regulation Standard 2016-12-01 版次: c JSMD 1812 Series Surface Mount PTC Devices Thermal Derading Chart Recommended Hold Current(A) at Ambient Temperature(°C) Ambient Operation Temperature Model -40°C -20°C 0°C 25°C 40°C 50°C 60°C 70°C 85°C JSMD1812-010 0.16 0.14 0.12 0.10 0.08 0.07 0.06 0.05 0.03 JSMD1812-014 0.23 0.19 0.17 0.14 0.12 0.10 0.09 0.08 0.06 JSMD1812-020 0.29 0.26 0.23 0.20 0.17 0.15 0.14 0.12 0.10 JSMD1812-030 0.44 0.39 0.35 0.30 0.26 0.23 0.21 0.18 0.15 JSMD1812-035 0.50 0.45 0.40 0.35 0.30 0.26 0.24 0.20 0.16 JSMD1812-050 0.59 0.57 0.55 0.50 0.45 0.43 0.35 0.30 0.23 JSMD1812-075 1.10 0.99 0.87 0.75 0.63 0.57 0.49 0.45 0.35 JSMD1812-110 1.60 1.45 1.28 1.10 0.92 0.83 0.71 0.66 0.52 JSMD1812-125 2.00 1.75 1.52 1.25 1.00 0.95 0.90 0.75 0.53 JSMD1812-150 2.30 2.05 1.77 1.50 1.23 1.09 0.95 0.82 0.61 JSMD1812-160 2.10 1.96 1.88 1.60 1.26 1.12 0.98 0.84 0.63 JSMD1812-200 2.88 2.61 2.25 2.00 1.80 1.66 1.45 1.09 0.80 JSMD1812-250 3.27 3.04 2.88 2.50 2.21 2.07 1.92 1.78 1.57 JSMD1812-260 3.90 3.42 2.96 2.60 2.33 2.07 1.94 1.35 1.00 JSMD1812-300 4.15 3.76 3.46 3.00 2.55 2.28 2.01 1.61 1.33 Thermal Derating Curve Derating Curves for JSMD1812 Series 160 140 120 100 80 60 40 20 0 -40 -20 0 20 40 60 80 Temperature (°C) Average Time-Current Curve Average Time-Current Curve http:// www.jksemi.com 2016-12-01 版次: c JSMD 1812 Series Surface Mount PTC Devices Soldering Parameters TP 20~40 S TP 260 Critical Zone Ramp-up TL to TP TL 217 tL 60~150 s Tsmax 200 Tsmin Ramp-down 150 ts Preheat 60~180 s 25 t 25°C to peak Time Profile Feature Pb-Free Assembly Average Ramp-Up Rate(Ts max to T p) 3℃/second mac. Preheat -Temperature Min(Ts min) 150℃ -Temperature Max(Ts max) 200℃ -Time(Ts min to Ts max) 60~180 seconds Time maintained above: -Temperature(TL) 217℃ -Time(tL) 60~150 seconds Peak Temperature(Tp) 260℃ Ramp-Down Rate 6℃/second max. Time 25℃ to Peak Temperature 8 minutes max Storage Condition 0℃~35℃,≤70%RH Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free Recommended maximum paste thickness is 0.25mm Devices can be cleaned using standard industry methods and solvents. Note 1:All temperature refer to topside of the package, measured on the package body surface. Note 2: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements. Physical Dimensions(mm.) http:// www.jksemi.com 2016-12-01 版次: c JSMD 1812 Series Surface Mount PTC Devices Model A B Min. Max. JSMD1812-010 4.37 4.73 JSMD1812-010/60 4.37 JSMD1812-014 Min. C D E Min. Min. Max. Min. Max. 3.07 3.41 0.50 1.00 0.30 0.25 4.73 3.07 3.41 0.50 1.00 0.30 0.25 4.37 4.73 3.07 3.41 0.50 1.30 0.30 0.25 JSMD1812-020 4.37 4.73 3.07 3.41 0.50 1.30 0.30 0.25 JSMD1812-020/60 4.37 4.73 3.07 3.41 0.50 1.00 0.30 0.25 JSMD1812-030 4.37 4.73 3.07 3.41 0.50 1.30 0.30 0.25 JSMD1812-035 4.37 4.73 3.07 3.41 0.65 1.15 0.30 0.25 JSMD1812-035/60 4.37 4.73 3.07 3.41 1.00 1.50 0.30 0.25 JSMD1812-050 4.37 4.73 3.07 3.41 0.40 0.90 0.30 0.25 JSMD1812-050/30 4.37 4.73 3.07 3.41 0.40 0.90 0.30 0.25 JSMD1812-050/60 4.37 4.73 3.07 3.41 1.10 1.80 0.30 0.25 JSMD1812-075 4.37 4.73 3.07 3.41 0.40 0.90 0.30 0.25 JSMD1812-075/24 4.37 4.73 3.07 3.41 0.60 1.30 0.30 0.25 JSMD1812-075/33 4.37 4.73 3.07 3.41 0.60 1.30 0.30 0.25 JSMD1812-110 4.37 4.73 3.07 3.41 0.40 0.90 0.30 0.25 JSMD1812-110/12 4.37 4.73 3.07 3.41 0.40 0.90 0.30 0.25 JSMD1812-110/16 4.37 4.73 3.07 3.41 0.60 1.30 0.30 0.25 JSMD1812-110/24 4.37 4.73 3.07 3.41 0.60 1.30 0.30 0.25 JSMD1812-110/33 4.37 4.73 3.07 3.41 1.10 1.80 0.30 0.25 JSMD1812-125 4.37 4.73 3.07 3.41 0.60 1.30 0.30 0.25 JSMD1812-125/12 4.37 4.73 3.07 3.41 0.60 1.30 0.30 0.25 JSMD1812-125/16 4.37 4.73 3.07 3.41 0.65 1.15 0.30 0.25 JSMD1812-150 4.37 4.73 3.07 3.41 0.40 0.90 0.30 0.25 JSMD1812-150/12 4.37 4.73 3.07 3.41 0.35 0.85 0.30 0.25 JSMD1812-150/16 4.37 4.73 3.07 3.41 0.60 1.30 0.30 0.25 JSMD1812-150/24 4.37 4.73 3.07 3.41 0.40 1.20 0.30 0.25 JSMD1812-160 4.37 4.73 3.07 3.41 0.40 0.90 0.30 0.25 JSMD1812-160/12 4.37 4.73 3.07 3.41 0.35 0.85 0.30 0.25 JSMD1812-160/16 4.37 4.73 3.07 3.41 1.10 1.80 0.30 0.25 JSMD1812-200 4.37 4.73 3.07 3.41 0.60 1.30 0.30 0.25 JSMD1812-200/12 4.37 4.73 3.07 3.41 0.65 1.15 0.30 0.25 JSMD1812-200/16 4.37 4.73 3.07 3.41 1.10 1.80 0.30 0.25 JSMD1812-250 4.37 4.73 3.07 3.41 0.35 0.85 0.30 0.25 JSMD1812-250/12 4.37 4.73 3.07 3.41 0.65 1.15 0.30 0.25 JSMD1812-250/16 4.37 4.73 3.07 3.41 1.00 1.50 0.30 0.25 JSMD1812-260 4.37 4.73 3.07 3.41 0.50 1.30 0.30 0.25 JSMD1812-260/12 4.37 4.73 3.07 3.41 0.65 1.15 0.30 0.25 JSMD1812-260/16 4.37 4.73 3.07 3.41 1.00 1.50 0.30 0.25 JSMD1812-300 4.37 4.73 3.07 3.41 0.50 1.30 0.30 0.25 JSMD1812-300/8 4.37 4.73 3.07 3.41 1.00 1.50 0.30 0.25 Termination Pad Characteristics Terminal pad materials:Tin-plated Nickel-Copper Terminal pad solder ability:Meets EIA specification RS186-9E and ANSI/J-STD-002 Category 3. http:// www.jksemi.com 2016-12-01 版次: c JSMD 1812 Series Surface Mount PTC Devices Recommended Pad Layout (mm.) 1.78 士 0.1 3.2 士 0.1 1.78 士 0.1 3.2 士 0.1 Packaging Quantity Part Number Quantity JSMD 035/60.050/60.110/33.150/24.250/16.260/16.300.300/8 JSMD 010.010/60.014.020.020/60.030.035.075/33.110/24.125.1 6.150.16.160/16.200/12.200/16.250/12.260/12 1,000 pcs/reel 1,500 pcs/reel The others 2,000 pcs/reel Tape & reel packaging per EIA481-1 Tape And Reel Specifications (mm) Governing Specifications EIA 481-1 W 12 ± 0.3 P0 4.0 ± 0.10 P1 8.0 ± 0.10 P2 2.0 ± 0.05 A0 3.5 ± 0.10 B0 5.1 ± 0.10 B1max. 5.9 D0 1.50 + 0.1, -0 F 5.5 ± 0.05 E1 1.75 ± 0.10 E2min. 10.25 T 0.6 T1max. 0.1 K0 0.9 ± 0.1 Leader min. 390 Trailer min. 160 EIA Tape Component Dimensions P0 Embossment D T P2 E1 Cover F B W B0 K0 E2 T P1 EIA Reel Dimensions W2(measured at hub) A N(hub dia.) Reel Dimensions A max. 178 N min. 60 W1 12.4 ± 0.5 W2 18.4 Cover tape W1(measured at hub) Carrier tape Embossed cavity Storage And Handling ‧ ‧ Storage conditions:35°C max, 70% R.H. Devices may not meet specified performance if storage conditions are exceeded. http:// www.jksemi.com 2016-12-01 版次: c JSMD 1812 Series Surface Mount PTC Devices Part Number System J SMD1812-口口口 / 口口 Special voltage Rating(Optional) Holding Current Rating Device Dimensions: Length/width(Unit:1/100 inch) Size 4532 mm / 1812 inch JKSEMI Cross Reference Cross Reference JKSEMI TYCO/Raychem Littelfuse Bourns / Polytronics / Multifuse® EVERFUSE® SEA-LAND JSMD1812-010 miniSMDC010F 1812L010 MF-MSMF010 SMD1812P010TF mSMD010 JSMD1812-010/60 - 1812L010/60 - SMD1812P010TF/60 mSMD010-60V JSMD1812-014 miniSMDC014F 1812L014 MF-MSMF014 SMD1812P014TF mSMD014 JSMD1812-020 miniSMDC020F 1812L020 MF-MSMF020 SMD1812P020TF mSMD020 JSMD1812-020/60 - 1812L020/60 MF-MSMF020/60 - mSMD020-60V JSMD1812-030 miniSMDC030F - MF-MSMF030 - mSMD030 JSMD1812-035 - - - - - JSMD1812-035/60 - - - SMD1812P035TF/60 - JSMD1812-050 miniSMDC050F 1812L050 MF-MSMF050 SMD1812P050TF mSMD050 JSMD1812-050/30 - 1812L050/30 MF-MSMF050/30X SMD1812P050TF/30 - JSMD1812-050/60 - 1812L050/60 - SMD1812P050TF/60 mSMD050-60V JSMD1812-075 miniSMDC075F 1812L075 MF-MSMF075 SMD1812P075TF mSMD075 JSMD1812-075/24 miniSMDC075F/24 1812L075/24 MF-MSMF075/24 SMD1812P075TF/24 mSMD075-24V JSMD1812-075/33 miniSMDC075F/33 1812L075/33 MF-MSMF075/33X SMD1812P075TF/33 mSMD075-33V JSMD1812-110 - 1812L110 MF-MSMF110 SMD1812P110TF mSMD110 JSMD1812-110/12 - 1812L110 - - - JSMD1812-110/16 miniSMDC110F/16 1812L110/16 MF-MSMF110/16 SMD1812P110TF/16 mSMD110-16V JSMD1812-110/24 miniSMDC110F/24 1812L110/24 MF-MSMF110/24X SMD1812P110TF/24 mSMD110-24V JSMD1812-110/33 - 1812L110/33 - SMD1812P110TF/33 mSMD110-33V JSMD1812-125 miniSMDC125F - MF-MSMF125 - mSMD125 JSMD1812-125/12 - - - - - JSMD1812-125/16 miniSMDC125F/16 1812L125/16 - SMD1812P125TF/16 - JSMD1812-260 miniSMDC260F 1812L260 - - mSMD260 JSMD1812-260/12 miniSMDC260F/12 1812L260/12 - - - JSMD1812-260/16 miniSMDC260F/16 1812L260/16 MF-MSMF260 SMD1812P260TFT - JSMD1812-300 miniSMDC300F 1812L300 - SMD1812P300TFT mSMD300 JSMD1812-300/8 - - - - - http:// www.jksemi.com 2016-12-01 版次: c JSMD 1812 Series Surface Mount PTC Devices “Raychem” is a registered trademark of Tyco Electronics. “Littelfuse” is a registered trademark of Littelfuse “Multifuse” is a registered trademark of bourns,Inc. “EVERFUSE” is a registered trademark of Polytronics Technology Corp. “SEA-LAND” is a registered trademark of Sea-Land electronic corp. Website: http://www.jksemi.com For additional information, please contact your local Sales Representative. ©Copyright 2016, jksemi is a registered trademark of jksemi All rights arereserved http:// www.jksemi.com 2016-12-01 版次: c
SMD1812-075 价格&库存
很抱歉,暂时无法提供与“SMD1812-075”相匹配的价格&库存,您可以联系我们找货
