CSRT2512FTR100-UP
CSRT2512FTR100-UP
    SEI
    CSRT2512FTR100-UP
CSRT2512FTR100-UP 数据手册
CSRT Series Stackpole Electronics, Inc. Thin Film Current Sensing Resistor Resistive Product Solutions Features: • • • • • • • • • • • • 0201 to 2512 (standard terminations) and 0612 to 1225 (wide terminations) available Low resistance, TCR and inductance Excellent long-term stability High precision current sensing High power capability “-UP” High power version Non-standard resistance values available AEC-Q200 qualified (all sizes except 0201) 100% RoHS compliant and lead free without exemption Halogen free REACH compliant For anti-sulfur CSRT, see CSRT-AS Series – Anti-sulfur Metal Film Low Resistance Chip Resistor Applications: • • • • • • Consumer electronics Computer Telecom Measuring instrument Industrial / Power supply Battery management system Electrical Specifications Type/Code Power Rating (W) @ 70ºC Max Rated Current (A) Max Overload (A) CSRT0201 0.2 2 4.47 CSRT0402 0.25 2.24 5 CSRT0603 0.4 2.83 6.32 CSRT0805 0.5 3.58 8 0.5 7.07 15.81 1 5.06 11.32 CSRT1210 1 5.06 11.32 CSRT2010 CSRT2512 1.5 3 3.87 5.48 8.66 12.25 CSRT1206 TCR (ppm/ºC) ± 100 ± 50 ± 100 ± 50 ± 100 ± 50 ± 150 ± 100 ± 50 ± 200 ± 150 ± 100 ± 50 ± 150 ± 100 ± 50 ± 50 ± 50 Ohmic Range (Ω) and Tolerance 0.5% 1% 2% 5% 0.05 - 0.098 0.1 - 10 0.05 - 0.098 0.1 - 10 0.05 - 0.098 0.1 - 10 0.039 - 0.049 0.05 - 0.098 0.1 - 10 0.01 - 0.038 0.039 - 0.049 0.05 - 0.098 0.1 - 10 0.039 - 0.049 0.05 - 0.098 0.1 - 10 0.1 - 10 0.1 - 10 Electrical Specifications – High Power Type/Code CSRT2512_-UP Power Rating (W) @ 70ºC 3.5 Max Rated Current Max Overload TCR (ppm/ºC) (A) (A) 8.37 18.71 ± 50 Rev Date: 3/28/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 1 Ohmic Range (Ω) and Tolerance 0.5% 1% 2% 5% 0.05 - 50 www.seielect.com marketing@seielect.com/ CSRT Series Stackpole Electronics, Inc. Thin Film Current Sensing Resistor Resistive Product Solutions Electrical Specifications – Wide Termination Type/Code Power Rating (W) @ 70ºC Max Rated Current (A) Max Overload (A) CSRT0612 1 10 22.36 CSRT1020 2 14.14 31.62 CSRT1225 3 17.32 38.73 TCR (ppm/ºC) ± 150 ± 100 ± 150 ± 100 ± 150 ± 100 0.5% 0.1 - 2 0.1 - 2 0.1 - 2 Ohmic Range (Ω) and Tolerance 1% 2% 5% 0.01 - 0.019 0.02 - 2 0.01 - 0.019 0.02 - 2 0.01 - 0.019 0.02 - 2 Mechanical Specifications Type/Code CSRT0201 CSRT0402 CSRT0603 CSRT0805 CSRT1206 (0.039 Ω - 10 Ω) CSRT1210 CSRT2010 CSRT2512 (-UP) Type/Code CSRT1206 (0.01 Ω - 0.038 Ω) L Body Length 0.024 ± 0.001 0.60 ± 0.03 0.039 ± 0.004 1.00 ± 0.10 0.063 ± 0.004 1.60 ± 0.10 0.079 ± 0.004 2.00 ± 0.10 0.122 ± 0.004 3.10 ± 0.10 0.122 ± 0.004 3.10 ± 0.10 0.197 ± 0.008 5.00 ± 0.20 0.248 ± 0.008 6.30 ± 0.20 W Body Width 0.012 ± 0.001 0.30 ± 0.03 0.020 ± 0.002 0.50 ± 0.05 0.031 ± 0.004 0.80 ± 0.10 0.049 ± 0.004 1.25 ± 0.10 0.063 ± 0.004 1.60 ± 0.10 0.098 ± 0.006 2.50 ± 0.15 0.098 ± 0.006 2.50 ± 0.15 0.126 ± 0.008 3.20 ± 0.20 H Body Height 0.010 ± 0.002 0.26 ± 0.05 0.014 ± 0.002 0.35 ± 0.05 0.018 ± 0.004 0.45 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 0.028 ± 0.006 0.70 ± 0.15 I1 Top Termination 0.006 ± 0.002 0.15 ± 0.05 0.008 ± 0.004 0.20 ± 0.10 0.010 ± 0.006 0.25 ± 0.15 0.014 ± 0.008 0.35 ± 0.20 0.016 ± 0.008 0.40 ± 0.20 0.020 ± 0.008 0.50 ± 0.20 0.024 ± 0.010 0.60 ± 0.25 0.026 ± 0.010 0.65 ± 0.25 I2 Bottom Termination 0.006 ± 0.002 0.15 ± 0.05 0.010 ± 0.004 0.25 ± 0.10 0.012 ± 0.006 0.30 ± 0.15 0.016 ± 0.008 0.40 ± 0.20 0.018 ± 0.008 0.45 ± 0.20 0.020 ± 0.008 0.50 ± 0.20 0.024 ± 0.010 0.60 ± 0.25 0.026 ± 0.010 0.65 ± 0.25 L Body Length 0.130 ± 0.008 3.30 ± 0.20 W Body Width 0.067 ± 0.008 1.70 ± 0.20 H Body Height 0.026 ± 0.008 0.65 ± 0.20 I1 Top Termination 0.008 ± 0.006 0.20 ± 0.15 I2 Unit Bottom Termination 0.027 ± 0.008 inches 0.68 ± 0.20 mm Rev Date: 3/28/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com/ CSRT Series Stackpole Electronics, Inc. Thin Film Current Sensing Resistor Resistive Product Solutions Mechanical Specifications – Wide Termination Type/Code CSRT0612 CSRT1020 CSRT1225 L Body Length 0.063 ± 0.006 1.60 ± 0.15 0.098 ± 0.006 2.50 ± 0.15 0.126 ± 0.008 3.20 ± 0.20 W Body Width 0.126 ± 0.008 3.20 ± 0.20 0.197 ± 0.006 5.00 ± 0.15 0.248 ± 0.008 6.30 ± 0.20 H Body Height 0.022 ± 0.006 0.55 ± 0.15 0.022 ± 0.006 0.55 ± 0.15 0.022 ± 0.006 0.55 ± 0.15 I1 Top Termination 0.012 ± 0.008 0.30 ± 0.20 0.016 ± 0.008 0.40 ± 0.20 0.024 ± 0.010 0.60 ± 0.25 I2 Unit Bottom Termination 0.020 ± 0.008 inches 0.50 ± 0.20 mm 0.020 ± 0.008 inches 0.50 ± 0.20 mm 0.031 ± 0.010 inches 0.80 ± 0.25 mm Performance Characteristics Test Item Test Method Test Condition Test Limits Temperature Coefficient of Resistance (TCR) JIS C-5201-1 4.8 IEC-60115-1 4.8 TCR +125°C, 25°C is the reference temperature Refer to Electrical Specifications table Short Time Overload JIS C-5201-1 4.13 IEC-60115-1 4.13 Standard Power: 5 times rated power whichever is less for 5 seconds High Power and wide terminal type: 5 times rated power whichever is less for 5 seconds ± (1% + 0.001Ω) Insulation Resistance JIS C-5201-1 4.8 IEC-60115-1 4.8 100 VDC for 1 minute ≥ 10GΩ 0805, 0612 and above applied 500 VAC, 1 minute 0201, 0402, 0603 applied 300 VAC, 1 minute Central part pressurizing force: 10 N, 10 seconds No short or burned on the appearance No breakage. >95% coverage - no visual damage ± (1% + 0.001Ω) No visual damage >95% coverage - no visual damage ± (1% + 0.001Ω) No visual damage Dielectric Withstanding Voltage Core Body Strength JIS C-5201-1 4.7 JIS C-5201-1 4.15 JIS C-5201-1 4.17 Solderability IEC-60115-1 4.17 Resistance to Soldering JIS C-5201-1 4.18 Heat IEC-60115-1 4.18 JIS C5201-1 4.18 Leaching IEC-60068-2-58 8.2.1 Rapid Change of JIS C-5201-1 4.19 Temperature IEC-60115-1 4.19 Damp Heat with Load Biased Humidity Load Life (Endurance) High Temperature Exposure JIS C-5201-1 4.24 IEC-60115-1 4.24 MIL-STD-202 Method 103 JIS C-5201-1 4.25 IEC-60115-1 4.25.1 JIS C-5201-1 4.25 IEC 60068-2-2 Resistance to Solvent JIS C-5201-1 clause 4.29 Terminal Strength JIS C-5201-1 4.32 AEC Q200-006 245ºC ± 5°C for 3 ± 0.5 seconds 260ºC ± 5°C for 10 seconds 260ºC ± 5°C for 30 seconds -55°C to +155°C, 300 cycles 40ºC ± 2°C, 90 ~ 95% R.H., rated power or max. working current whichever is less for 1000 hours with 1.5 hours "ON" and 0.5 hours "OFF" 1000 hours; 85°C/85% RH, 10% of operating power. Measurement at 24 ± 4 hours after test conclusion. 70ºC ± 2°C, rated power or max. working current whichever is less for 1000 hours with 1.5 hours "ON" and 0.5 hours "OFF" At +155ºC ± 5°C for 1000 + 48/- 0 hours all sizes, except 2512-UP At +170ºC ± 5°C for 1000 + 48/- 0 hours for 2512-UP The tested resistor be immersed into isopropyl alcohol of 20°C ~ 25°C for 60 seconds. Then the resistor is left in room for 48 hours Pressurizing force for 10 seconds. 0201, 0402, 0603: 8 N; 0805, 0612 and above: 17.7N Rev Date: 3/28/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 ± (1% + 0.001Ω) ± (0.5% + 0.05Ω) ± (1% + 0.001Ω) ± (1% + 0.001Ω) ± (1% + 0.001Ω) No visual damage No breakage www.seielect.com marketing@seielect.com/ CSRT Series Stackpole Electronics, Inc. Thin Film Current Sensing Resistor Resistive Product Solutions Performance Characteristics (cont.) Test Item Test Method Test Condition Bending once for 5 seconds. D: 0201, 0402, 0603, 0805 = 5 mm Bending Strength 1206, 1210, 0612 = 3 mm 2010, 2512, 1020, 1225 = 2 mm Operating temperature range is -55°C to +155°C for all sizes except 2512-UP Operating temperature range for 2512-UP is -55°C to +170°C JIS C-5201-1 4.33 IEC-60115-1 4.33 Test Limits ± (1% + 0.001Ω) No visual damage Power Derating Curve: Soldering Profiles Rev Date: 3/28/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com/ CSRT Series Stackpole Electronics, Inc. Thin Film Current Sensing Resistor Resistive Product Solutions Recommended Pad Layout Type/Code CSRT0201 CSRT0402 CSRT0603 CSRT0805 CSRT1206 (0.01 Ω - 0.038 Ω) CSRT1206 (0.039 Ω - 10 Ω) CSRT1210 CSRT2010 CSRT2512 (-UP) CSRT0612 CSRT1020 CSRT1225 a b c Unit 0.010 0.25 0.020 0.50 0.031 0.80 0.051 1.30 0.047 1.20 0.087 2.20 0.079 2.00 0.150 3.80 0.193 4.90 0.020 0.50 0.039 1.00 0.047 1.20 0.033 0.85 0.063 1.60 0.094 2.40 0.114 2.90 0.189 4.80 0.165 4.20 0.173 4.40 0.260 6.60 0.319 8.10 0.102 2.60 0.159 4.05 0.205 5.20 0.014 0.35 0.028 0.70 0.039 1.00 0.057 1.45 0.072 1.84 0.071 1.80 0.106 2.70 0.106 2.70 0.134 3.40 0.126 3.20 0.217 5.50 0.276 7.00 inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm Reel Specifications Type/Code A B C D W M Unit 0.079 ± 0.020 2.00 ± 0.50 0.531 ± 0.039 13.50 ± 1.00 0.827 ± 0.039 21.00 ± 1.00 2.362 ± 0.039 60.00 ± 1.00 0.453 ± 0.079 11.50 ± 2.00 7.008 ± 0.079 178.00 ± 2.00 inches mm CSRT0201 CSRT0402 CSRT0603 CSRT0805 Rev Date: 3/28/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com/ CSRT Series Stackpole Electronics, Inc. Thin Film Current Sensing Resistor Resistive Product Solutions Reel Specifications (cont.) Type/Code A B C D W CSRT1206 CSRT1210 CSRT2010 CSRT2512 (-UP) 0.079 ± 0.020 2.00 ± 0.50 0.531 ± 0.039 13.50 ± 1.00 0.827 ± 0.039 21.00 ± 1.00 2.362 ± 0.039 60.00 ± 1.00 CSRT0612 CSRT1020 CSRT1225 0.453 11.50 0.453 11.50 0.630 16.00 0.630 16.00 0.453 11.50 0.630 16.00 0.630 16.00 ± ± ± ± ± ± ± ± ± ± ± ± ± ± 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 M Unit 7.008 ± 0.079 178.00 ± 2.00 inches mm inches mm inches mm inches mm inches mm inches mm inches mm Packaging Specifications - Paper Tape Type/Code CSRT0201 CSRT0402 CSRT0603 CSRT0805 CSRT1206 CSRT1210 CSRT0612 A 0.018 0.45 0.028 0.70 0.041 1.05 0.061 1.55 0.075 1.90 0.112 2.85 0.112 2.85 Type/Code ± ± ± ± ± ± ± ± ± ± ± ± ± ± G B 0.004 0.10 0.004 0.10 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.030 0.75 0.047 1.20 0.071 1.80 0.091 2.30 0.120 3.05 0.120 3.05 0.120 3.05 ± ± ± ± ± ± ± ± ± ± ± ± ± ± H W 0.004 0.10 0.004 0.10 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.315 ± 0.008 8.00 ± 0.20 CSRT0402 CSRT0603 0.157 ± 0.004 4.00 ± 0.10 0.079 ± 0.002 2.00 ± 0.05 CSRT1206 CSRT1210 CSRT0612 Rev Date: 3/28/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 6 ± ± ± ± ± ± ± ± ± ± ± ± ± ± 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 F 0.069 ± 0.004 1.75 ± 0.10 0.138 ± 0.002 3.50 ± 0.05 P D T 0.014 0.35 0.018 0.45 0.024 0.60 0.030 0.75 0.030 0.75 0.030 0.75 0.030 0.75 CSRT0201 CSRT0805 E 0.079 2.00 0.079 2.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± ± ± ± ± ± ± 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.059 +0.004/-0 1.50 +0.10/-0 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com/ CSRT Series Stackpole Electronics, Inc. Thin Film Current Sensing Resistor Resistive Product Solutions Packaging Specifications - Embossed Tape Type/Code CSRT2010 CSRT2512 (-UP) CSRT1020 CSRT1225 A 0.110 2.80 0.134 3.40 0.110 2.80 0.134 3.40 Type/Code ± ± ± ± ± ± ± ± H B 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.220 5.60 0.264 6.70 0.220 5.60 0.264 6.70 ± ± ± ± ± ± ± ± T W 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 E F G Unit 0.472 ± 0.004 12.00 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.217 ± 0.002 5.50 ± 0.05 0.157 ± 0.004 4.00 ± 0.10 T1 P D D1 0.033 ± 0.006 0.85 ± 0.15 0.157 ± 0.004 4.00 ± 0.10 0.059 +0.004/-0 1.50 +0.10/-0 inches mm inches mm inches mm inches mm Unit CSRT2010 CSRT2512 (-UP) CSRT1020 0.079 ± 0.002 2.00 ± 0.05 0.009 ± 0.004 0.23 ± 0.10 0.059 ± 0.004 inches 1.50 ± 0.10 mm CSRT1225 RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description CSRT Thin Film Current Sensing Resistor Package / Standard Termination Series RoHS Type Compliant SMD Rev Date: 3/28/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. YES 7 Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) 100% Matte Sn over Ni Always Always www.seielect.com marketing@seielect.com/ CSRT Series Stackpole Electronics, Inc. Thin Film Current Sensing Resistor Resistive Product Solutions “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 C S R T 2 5 1 2 F T 1 R 0 0 - U P Product Series Thin Film CSRT Current Sensing Size Code W 0201 0.2 0402 0.25 0603 0.4 0805 0.5 0.5 1206 1 1210 1 2010 1.5 2512 3 2512 (-UP) 3.5 0612 1 1020 2 1225 3 Tolerance Code Tol D 0.5% F 1% G 2% J 5% Packaging Size Quantity 0201, 0402 10000 Paper Tape 0603, 0805, 1206 5000 1210, 0612 2010, 2512 Embossed 4000 1020, 1225 Code Description Rev Date: 3/28/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. T 8 Resistance Value Four characters with the multiplier used as the decimal holder. "L" used as multiplier of Special Code Description blank Standard -UP High Power -3 10 for any value under 0.1 ohm. 0.01 ohm = 10L0 0.098 ohm = 98L0 10 ohm = 10R0 www.seielect.com marketing@seielect.com/
CSRT2512FTR100-UP 价格&库存
很抱歉,暂时无法提供与“CSRT2512FTR100-UP”相匹配的价格&库存,您可以联系我们找货
CSRT2512FTR100-UP
  • 4000+2.177684000+0.28304
  • 12000+2.0500712000+0.26645
库存:4128
CSRT2512FTR100-UP
  • 1+4.053861+0.52688
  • 10+3.4052410+0.44258
  • 50+2.9853550+0.38801
  • 100+2.82394100+0.36703
  • 500+2.49733500+0.32458
库存:4128
