SM5S Series
Surface Mount
Transient Voltage Suppressors
Working Voltage: 10 to 43 V
Peak Pulse Power: 3600 W
Features
Optimized glass passivated chip
TJ = 175 °C capability suitable for high
reliability and automotive requirement
3600 W peak pulse power capability with a
10/1000 μs waveform, repetitive rate (duty
cycle):0.01 %
Meet ISO 7637-2 5a/5b and ISO 16750 load
dump test (varied by test condition)
AEC-Q101 qualified
Low leakage current
Low forward voltage drop
Uni-directional polarity
Excellent clamping capability
Very fast response time
RoHS compliant
DO-218AB
Mechanical Data
Case: DO-218AB
Molding compound: UL94V-0 flammability
Polarity: Heatsink is anode
Maximum Ratings(TA=25℃ unless otherwise noted)
Parameter
(1)
Peak power dissipation with a 10/1000μs waveform
Peak power dissipation with a 10/10,000μs waveform
Symbol
PPP
Value
3600
Unit
W
PPP
2800
W
Peak pulse current with a 10/1000μs waveform
Power dissipation on infinite heatsink at TL = 25 °C
IPP
See Next Table
A
PD
5.0
W
Peak forward surge current 8.3 ms single half sine-wave
IFSM
500
A
TJ, TSTG
- 55 to +175
°C
(1)
Operating junction and storage temperature range
Note:
(1)Non-repetitive current pulse per Fig.2 and derated above TA= 25 °C per Fig.1
www.dowosemi.cn
P. 1
SM5S Series
AVERAGE
FORWARD
CURRENT, (A)
AMBIENT
TEMPERATURE
100
Tr=10μs
100
25
100
175
100
Peak Pulse Current , (% )
Peak Pulse Derating in Percentage of Peak
Power or Current, (%)
Ratings and Characteristics Curves (TA=25℃ unless otherwise noted)
50
25
Peak Value
(Ipp)
Half Value = Ipp
2
50
10/1000 μsec. Waveform
td
50
75
100
125
150
175
200
2
Time , (ms)
Ambient Temperature ,TA (℃)
Fig. 1 - Pulse Derating Curve
6.0
1
4
10
2800
1100
2.0
5
4.0
0.0
50
33
23
13
10
10000
5
Peak Power (W)
Steady State Power Dissipation, (W)
3
0.5
1
1.5
2
3
4
Fig. 2 - Pulse Waveform
8.0
TJ = 25 °C
Pulse Width (td) is defined as the
point where the peak current decays
to 50 % of Ipp
25
50
75
100
125
150
175
200
1000
10
5200
100
1900
10
100
Pulse Width ,td (ms)
Lead Temperature , TL (℃)
Fig. 4 - Peak Pulse Power Rating Curve
Fig. 3 - Steady State Power Derating Curve
Package Outline Dimensions (millimeters)
Recommended Mounting Pad Layout
3.3
3.0
3.5
11.0
9.5
www.dowosemi.cn
15.8
P. 2
SM5S Series
Surface Mount Tape and Reel Packaging
G
ZONE 1
N A
ZONE1
B
D
C
T
Dimensions in Millimeters (inches)
TAPE SIZE
A MAX.
24 mm (0.945)
330 ± 2.0 (13.0 ±
0.079)
178 ± 2.0 (7.0 ±
0.079)
B MIN.
C
13.5 ± 0.50
1.5 (0.059)
(0.53 ±
0.02)
D MIN.
N MIN.
G MAX.
T MAX.
20.2
(0.795)
50 (1.97)
26.4 (1.039)
30.4
(1.197)
Recommended Soldering Parameters
IR-Reflow Condition
Temp. min
150
Temp. max
200
Time(min to max) 60-180
Ramp up rate (150-200℃)
Reflow
sec
220
Peak Temp.
245
Time(Liq. to Peak)
60-150
sec
很抱歉,暂时无法提供与“SM5S26A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.75640
- 10+5.29200
- 30+5.06520
- 100+4.82760
- 750+4.53600
- 1500+4.46040
