RS1G14
RS1G14 Single Schmitt-Trigger Inverter
FEATURES
DESCRIPTION
Operating Voltage Range:1.65V to 5.5V
Low Power Consumption:1µA (Max)
Operating Temperature Range:
-40°C to +125°C
Input Accept Voltage to 5.5V
High Output Drive: ±24mA at VCC=3.0V
Ioff Supports Partial-Power-Down Mode
Operation
Micro SIZE PACKAGES: SOT23-5, SC70-5
APPLICATIONS
AC Receiver and
Home Theaters
Blu-ray Players and Home Theaters
Desktops or Notebook PCs
Digital Video Cameras (DVC)
Mobile Phones
Personal Navigation Device (GPS)
Portable Media Player
The RS1G14 Single Schmitt-trigger inverter is
designed for 1.65V to 5.5V VCC operation.
The RS1G14 device contains one inverter and
̅ . The device
performs the Boolean function Y= A
functions as an independent inverter with Schmitttrigger inputs, so the device has different input
threshold levels for positive-going (VT+) and negative
going (VT-) signals to provide hysteresis(ΔVT) which
makes the device tolerant to slow or noisy input
signals.
This device is fully specified for partial-power-down
applications using Ioff. The Ioff circuitry disables the
outputs, preventing damaging current backflow
through the device when it is powered down.
The RS1G14 is available in Green SOT23-5 and
SC70-5 packages. It operates over an ambient
temperature range of -40°C to +125°C.
Device Information
PART NUMBER
RS1G14
(1)
Functional Block Diagram
A
2
4
(1)
PACKAGE
BODY SIZE (NOM)
SOT23-5(5)
2.92mm×1.60mm
SC70-5(5)
2.10mm×1.25mm
For all available packages, see the orderable addendum at
the end of the data sheet.
FUNCTION TABLE
Y
INPUT
OUTPUT
A
Y
H
L
L
H
Y=A
H=High Voltage Level
L=Low Voltage Level
REV A.1
1 / 10
www.run-ic.com
RS1G14
Revision History
Note: Page numbers for previous revisions may different from page numbers in the current version.
Version
Change Date
A.1
2020/12/13
Change Item
initial version completed
2 / 10
www.run-ic.com
RS1G14
PIN CONFIGURATIONS
TOP VIEW
N.C.
1
A
2
GND
3
5
VCC
4
Y
SOT23-5/SOT353(SC70-5)
PIN DESCRIPTION
PIN
NAME
I/O TYPE
FUNCTION
1
N.C.
Not connected
2
A
I
Input
3
GND
P
Ground
4
Y
O
Output
5
VCC
P
Power Pin
3 / 10
www.run-ic.com
RS1G14
Specifications
Absolute Maximum Ratings (1)
over operating free-air temperature range (unless otherwise noted) (1)(2)
VCC
(1)
(2)
(3)
Supply voltage range
(2)
VI
Input voltage range
Vo
Voltage range applied to any output in the high-impedance or power-off state (2)
Vo
Voltage range applied to any output in the high or low
state (2)(3)
MIN
MAX
UNIT
-0.5
6.5
V
-0.5
6.5
V
-0.5
6.5
V
-0.5
VCC+0.5
V
IIK
Input clamp current
VI
很抱歉,暂时无法提供与“RS1G14XF5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+3.123823000+0.40441
- 6000+3.046856000+0.39444
- 9000+3.008309000+0.38945
- 15000+2.9655815000+0.38392
- 21000+2.9406221000+0.38069
- 30000+2.9166230000+0.37759
- 国内价格
- 5+0.54000
- 50+0.43200
- 150+0.38880
- 1500+0.30240
- 国内价格 香港价格
- 1+6.791571+0.87923
- 10+4.8489910+0.62775
- 25+4.3589725+0.56431
- 100+3.81948100+0.49447
- 250+3.56309250+0.46128
- 500+3.40843500+0.44125
- 1000+3.372461000+0.43660
