SK82B THRU SK820B
Reverse Voltage - 20 to 200 Volts
Forward Current - 8.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
DO-214AA/SMB
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
Built-in strain relief,ideal for automated placement
0.155(3.94)
0.130(3.30)
0.086 (2.20)
0.071 (1.80)
0.185(4.70)
0.160(4.06)
High forward surge current capability
High temperature soldering guaranteed:
0.012(0.305)
0.006(0.152)
250 °C/10 seconds at terminals
0.096(2.44)
0.084(2.13)
Mechanical Data
0.060(1.52)
0.030(0.76)
Ca se : JEDEC DO-214AA/SMB molded plastic body
Termina ls : Solderable per MIL-STD-750,Method 2026
Polarity : Color band denotes cathode end Moun ting
Pos ition : Any
Weigh t : 0.0034 ounce, 0.1grams
0.008(0.203)MAX.
0.220(5.59)
0.200(5.08)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
VRRM
VRMS
VDC
I(AV)
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
Maximum instantaneous forward voltage at 8.0A
VF
Maximum DC reverse current at rated
DCblocking voltage
TA=25℃
TA=100℃
Typical junction capacitance (1)
Typical thermal resistance
(2)
Operating junction temperature range
Storage temperature range
MDD
MDD
MDD
MDD
MDD
MDD
MDD
SK82B SK84B SK86B SK810B SK812B SK815B SK820B
60
100
120
150
200
V
14
40
42
60
70
100
84
120
105
150
140
200
V
V
0.45
0.55
TJ
TSTG
8.0
A
150
A
0.70
0.85
1.0
50
IR
CJ
RθJA
UNITS
mA
700
400
V
pF
50
℃/W
-55 to +125
-55 to +150
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 2.0x2.0”(5.0x5.0cm) copper pad areas
http://www.microdiode.com
Rev:2024A2
Page :1
SK82B THRU SK820B
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
Average Forward Current (A)
14
12
10
8
6
4
2
Single phase half-wave 60 Hz
50
75
100
125
150
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
10 4
10 1
T J =25°C
10 0
60
100
80
Percent of Rated Peak Reverse Voltage(%)
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
T J =25°C
Junction Capacitance (pF)
1
SK82B
SK84B
SK86B
SK810B~SS820B
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
500
100
SK82BF/SK84BF
SK86B/SK820B
1
0.1
100
10
Instaneous Forward Voltage (V)
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
175
150
125
100
75
50
25
1000
1.8
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
Number of Cycles at 60Hz
100
Transient Thermal Impedance( °C / W)
Instaneous Forward Current (A)
T J =75°C
10 2
Case Temperature (°C)
Peak Forward Surage Current (A)
T J =100°C
10 3
200
100
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
The curve above is for reference only.
Rev:2024A2
Page :2
SK82B THRU SK820B
Packing information
unit:mm
P0
Item
P1
Symbol
Tolerance
SMA
A
B
C
d
D
D1
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
2.80
5.33
2.36
1.50
330.00
50.00
178.00
62.00
13.00
1.75
5.50
4.00
4.00
2.00
0.28
12.00
18.00
D1
d
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
E
W1
F
B
A
W
P
D2
T
C
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
BOX
(pcs)
INNER
BOX
(mm)
REEL
DIA,
(mm)
SMB
13"
3,000
4.0
6,000
190*190*41
330
CARTON
SIZE
(mm)
365*365*360
CARTON
(pcs)
48,000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Symbol
A
Unit (mm)
1.68
Unit (inch)
0.066
B
1.52
0.060
C
3.93
0.154
D
2.41
0.095
E
5.45
0.215
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“SK84B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.75287
- 50+0.60394
- 150+0.52942
- 500+0.47358
- 3000+0.37930
- 6000+0.35694
