KY8023S6
KY8023S6
    KEYSEMI(旷岳)
    SOT23-6L
    KY8023S6
KY8023S6 数据手册
KY8023 400mA Bi-Direction Relay Driver GENERAL DESCRIPTION FEATURES KY8023 is a bi-direction relay driver circuit, used to ⚫ Input voltage : 5V~40V control the magnetic latching relay, with large output ⚫ Recommended supply voltage with relay load capability, ultra-low power consumption. It can be : 5V~30V widely used in smart meters and other pulses, level ⚫ ISS<1μA (high impedance state) control applications. ⚫ Input high level threshold : 1.3V ⚫ Typical driving current : 400mA ⚫ Rdson=7Ω (VIN=12V, PMOSFET+NMOSFET) KY8023 can provide 400mA typical driving current, which will different according to the relay coil resistance. Maximum : 800mA (VIN≤15V) The maximum driving current can reach 800mA when Rdson=5Ω (VIN=30V, PMOSFET+NMOSFET) the supply voltage is equal to or below 15V. The input ⚫ Fly-wheel diode forward voltage : 1.3V(IS=1A) high level threshold VTH is 1.3V. ⚫ Environment temperature : -40 ~ +85℃ ⚫ SOT23-6L and SOP-8 packages KY8023 is available in SOT23-6L and SOP-8 packages. APPLICATIONS ⚫ Smart meter TYPICAL APPLICATION CIRCUIT L AC V+ 220V AC AC N L + AC V+ AC V- 220V AC V- N BRIDGE 1 BRIDGE 6 3 B 1 8 2 KY8023 7 3 6 4 5 RS 2 KY8023 5 A A 4 B Relay Relay PIN ASSIGNMENT OB B GND VIN A OA SOT23-6L KY8023 Rev 1.0 + OA VIN NC B A NC GND OB SOP-8 KEYSEMI Proprietary Information Unauthorized Photocopy and Duplication Prohibited © 2019 KEYSEMI All Rights Reserved RS KY8023 400mA Bi-Direction Relay Driver ORDER INFORMATION PART NO PACAKGE TEMPERATURE TAPE & REEL KY8023S6 KY8023P8 SOT23-6L SOP-8 -40 ~ +85℃ -40 ~ +85℃ 3000/REEL 2500/REEL 5 4 3 1 SOT23-6L 2 XX 3 2 6 8 4 5 6 XXXX XYMXXX NXYWV 1 7 MARKING DESCRIPTION Part number Internal code Version code Serial number Y:Year M:Month Bonding wire material SOP-8 “N”: product code “X”: Package factory “Y”: Wafer foundry vendor. “W”: The week of manufacturing. “A” stands for week 1, “Z” stands for week 26, “a” stands for week 27, “z” stands for week 52. “V”: Product version code. PIN DESCRIPTION PIN NO SYMBOL DESCRIPTTION 1 OA Output A 2 NC Not connected KY8023S6 KY8023P8 4 3 3 A Input A 2 4 GND Ground 1 5 OB Output B 6 NC Not connected 6 7 B Input B 5 8 VIN Supply input voltage ABSOLUTE MAXIMUM RATINGS (Note) SYMBOL ITEMS VALUE UNIT -0.3~40 V VIN Input Voltage TJ Junction Temperature 150 ℃ Ta Ambient Temperature -40~125 ℃ θja θjc KY8023 Rev 1.0 Package thermal resistance SOT23-6L 190 SOP-8 128 SOT23-6L 110 SOP-8 45 KEYSEMI CORPORATION ℃/W Page 2 KY8023 400mA Bi-Direction Relay Driver TSTG ℃ Storage Temperature -55 to 150 TSOLDER Package Lead Soldering Temperature 260℃, 10s HBM ESD Susceptibility, Human Body Mode 3000 V MM ESD Susceptibility, Machine Mode 300 V Latch-up 500 mA LU Note: Exceed these limits to damage to the device. Exposure to absolute maximum rating conditions may affect device reliability. RECOMMANDED OPERATING RANGE SYMBOL ITEMS VIN VIN Supply Voltage TOPT Operating Temperature VALUE UNIT 5~30 V -40 to +85 ℃ ELECTRICAL CHARACTERISTICS The following specifications apply for VIN=12V TA=25℃, unless specified otherwise. SYMBOL ITEMS VIN Input Voltage IQ Quiescent Current Rdson CONDITIONS MIN TYP 5 MAX UNIT 30 V VA=3V or VB=3V 200 250 VA=5V or VB=5V 450 550 VIN=12V,RL=75Ω 8 10 VIN=30V,RL=75Ω 5.5 10 VIN=12V,RL=40Ω 7 10 VIN=30V,RL=40Ω 5 10 µA Switch Rdson Ω VTH ON Input High Voltage 1.3 V RIN Equivalent Input Resistor 115 KΩ VSD Fly-Wheel Diode Forward Voltage IS=1A ISS Shut-down Current VA=VB=0,VIN=40V TR Rise Time VIN=12V,RL=80Ω 50 ns Turn ON Delay Time VIN=12V,RL=80Ω 50 ns Fall Time VIN=12V,RL=80Ω 40 ns Turn OFF Delay Time VIN=12V,RL=80Ω 0.8 µs TD(ON) TF TD(OFF) 1.3 1.5 V 1 µA LOGIC FUNCTION TABLE Input A Input B Output OA Output OB RELAY RESPONSE 1 0 1 0 ON 0 1 0 1 OFF 0 0 High-impedance High-impedance Hold 1 1 High-impedance High-impedance Hold KY8023 Rev 1.0 KEYSEMI CORPORATION Page 3 KY8023 400mA Bi-Direction Relay Driver SIMPLIFIED BLOCK DIAGRAM VIN B Input Protection A Combinational Logic VIN OA Output Driver VIN OB Output Protection GND DETAILED DESCRIPTION Pulse triggering If input is driven by square pulse, connect the inputs to the pulse source directly. Relay will operate as logic table stated (VIN should be less than the power supply voltage, Rs is current-limiting resistor, it can be ignored in the voltage is below 20V, i.e. Rs=0). The recommended pulse width=100ms. The length of the intervals should be longer than 100ms. These intervals include: intervals between forward drive pulse and next backward drive pulse, intervals between forward drive pulse and next forward drive pulse, intervals between backward drive pulse and next forward drive pulse, intervals between backward drive pulse and next backward drive pulse. Backward drive/CLOSE Forward drive/OPEN Input A Input B interval Pulse width =100ms Pulse width =100ms Forward drive/OPEN Input A Input B KY8023 Rev 1.0 interval Forward drive/OPEN interval interval Pulse width Pulse width =100ms =100ms KEYSEMI CORPORATION Page 4 KY8023 400mA Bi-Direction Relay Driver L AC V+ AC V- 220V AC N + BRIDGE 1 A B 6 2 KY8023 5 3 RS 4 Relay Pulse triggering application diagram Relay free-wheel Relay from ON to OFF, the energy stored in the relay inductor released by the chip’s internal body diode and the relay inductor. Until the end of the release of this energy, relay proceeding to the next operation. KY8023 Rev 1.0 KEYSEMI CORPORATION Page 5 KY8023 400mA Bi-Direction Relay Driver PACKAGE OUTLINE Package SOT23-6L Devices per reel 3000Pcs Unit mm Package Dimension: Ɵ D 0.2 E E1 L b e c A1 Symbol A2 A e1 Dimensions In Millimeters Min. Typ. Max. A 1.050 - 1.250 A1 0.000 - 0.100 A2 1.050 - 1.150 b 0.300 0.400 0.500 c 0.100 - 0.200 D 2.820 2.900 3.020 E 1.500 1.600 1.700 E1 2.650 2.800 2.950 e 0.950 Typ. e1 1.800 1.900 2.000 L 0.300 - 0.600 θ 0° - 8° KY8023 Rev 1.0 KEYSEMI CORPORATION Page 6 KY8023 400mA Bi-Direction Relay Driver PACKAGE OUTLINE Package SOP-8 Devices per reel 2500Pcs Unit mm Package Dimension: θ3 θ1 h A A2 R1 R L2 h A3 B B A1 θ L 0.10 θ4 θ2 (L1) D c1 c E E1 b b1 INDEX e Symbol BASE METAL SECTION B-B 0.25 M b Dimension (mm) MIN NOM MAX A - - 1.77 A1 0.08 0.18 A2 1.2 A3 Symbol Dimension (mm) MIN NOM MAX D 4.7 4.9 5.1 0.28 E 5.8 6 6.2 1.4 1.6 E1 3.7 3.9 4.1 0.55 0.65 0.75 e b 0.39 - 0.48 L b1 0.38 0.41 0.43 L1 c 0.21 - 0.26  KY8023 Rev 1.0 KEYSEMI CORPORATION 1.27BSC 0.5 0.65 0.8 1.05BSC 0 - 8° Page 7 KY8023 400mA Bi-Direction Relay Driver Revision History Version No. Date Description Rev 1.0 2019-03-20 Initial preliminary release KY8023 Rev 1.0 KEYSEMI CORPORATION Page 8
KY8023S6 价格&库存
很抱歉,暂时无法提供与“KY8023S6”相匹配的价格&库存,您可以联系我们找货
