APSF6R3ETD821MF08S
APSF6R3ETD821MF08S
    NCC(贵弥功)
    AEC-D6.3X8MM_TM
    820UF ±20% 6.3V
APSF6R3ETD821MF08S 数据手册
CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS TM NPCAP Radial Lead PSF - Series PSF ・Super low ESR, high ripple current capability ・ESR 5mΩmax. (2 to 4Vdc) ・Longer life (20,000 hours at 105℃) ・Rated voltage range : 2 to 16Vdc ・Solvent resistant type (see PRECAUTIONS AND GUIDELINES) ・RoHS2 Compliant ・Halogen Free Lower ESR PSE ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current *Note -55 to +105℃ 2 to 16Vdc ±20%(M) Shall not exceed values shown in STANDARD RATINGS. (at 20℃, 120Hz) (at 20℃ after 2 minutes) Dissipation Factor (tanδ) Low Temperature Characteristics (Max.Impedance Ratio) Endurance 0.10 max. (at 20℃, 120Hz) Z(-25℃)/Z(+20℃)≦1.15 Z(-55℃)/Z(+20℃)≦1.25 (at 100kHz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 20,000 hours at 105℃. Appearance No significant damage Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦150% of the initial specified value ESR ≦150% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjecting them to DC voltage at 60℃, 90 to 95% RH for 1,000 hours. Appearance No significant damage Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦The initial specified value ESR 2 to 6.3Vdc : ≦The initial specified value : ≦150% of the initial specified value 16Vdc Leakage current ≦The initial specified value The capacitors shall be subjected to 1,000 cycles each consisting of charge with the surge voltage specified at 105℃ for 30 seconds through a protective resistor(R=1kΩ) and discharge for 5 minutes 30 seconds. Rated voltage (Vdc) 2.0 2.5 4.0 6.3 16 2.3 2.9 4.6 7.2 18 Surge voltage (Vdc) Bias Humidity Test Surge Voltage Test Appearance Capacitance change D.F. (tanδ) ESR No significant damage ≦±20% of the initial value ≦The initial specified value 2 to 6.3Vdc : ≦The initial specified value 16Vdc : ≦150% of the initial specified value Leakage current ≦The initial specified value 0.5% per 1,000 hours maximum (Confidence level 60% at 105℃) Failure Rate *Note : If any doubt arises, measure the leakage current after the following voltage treatment. Voltage treatment : DC rated voltage is applied to the capacitors for 120 minutes at 105℃. ◆DIMENSIONS [mm] Code : E Coated Case φD' φd F05, F08, H08 F±0.5 ● Terminal L' 15min. 4min. F±0.5 Coated Case φD' φd HB5, JB5 Size code F05 F08 H08 HB5 JB5 φD 6.3 8.0 10.0 φd 0.45 0.6 F 2.5 3.5 5.0 Note1 : L+1.2 max. for 6.3V820μF φD' φD+0.5max. L' L+1.0max. (Note1) L+1.5max. ◆MARKING EX) 2.5V560µF F 6D6 560 2.5V L' 15min. 4min. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS TM NPCAP Radial Lead PSFSeries - ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 A PS F 2 R 5 E AA 5 6 1 M F 0 8 S Supplement code Size code Capacitance tolerance code Capacitance code (ex. 560µF:561) Lead forming·Taping code Terminal code Voltage code (ex. 2.5V:2R5, 16V:160) Series code Category Please refer to "Product code guide (conductive polymer type)" ◆STANDARD RATINGS WV (Vdc) 2 2.5 4 6.3 16 Cap (µF) 1,000 330 470 560 820 1,200 1,600 470 560 820 100 270 270 330 470 470 Case size φD×L(mm) Leakage current (µA max./after 2min.) ESR (mΩ max./20℃, 100k to 300kHz) Rated ripple current (mArms/105℃, 100kHz) 6.3×8 6.3×8 6.3×8 6.3×8 6.3×8 6.3× 8 8×8 6.3× 8 6.3× 8 6.3×8 6.3× 5 8×8 8×11.5 8×8 8×11.5 10× 11.5 500 500 500 500 500 1,200 800 500 500 1,030 500 864 864 1,050 1,500 1,500 5 5 5 5 5 5 5 5 5 8 24 10 11 13 11 10 5,900 5,900 5,900 5,900 5,900 5,900 6,100 5,900 5,900 4,700 2,490 5,000 5,080 4,700 5,400 6,100 Part No. APSF2R0E□□102MF08S APSF2R5E□□331MF08S APSF2R5E□□471MF08S APSF2R5E□□561MF08S APSF2R5E□□821MF08S APSF2R5E□□122MF08S APSF2R5E□□162MH08S APSF4R0E□□471MF08S APSF4R0E□□561MF08S APSF6R3E□□821MF08S APSF160E□□101MF05S APSF160E□□271MH08S APSF160E□□271MHB5S APSF160E□□331MH08S APSF160E□□471MHB5S APSF160E□□471MJB5S □□ : Enter the appropriate lead forming or taping code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Frequency(Hz) Radial lead type 120 0.10 1k 0.35 10k 0.60 50k 0.80 100k to 500k 1.00 Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U
APSF6R3ETD821MF08S 价格&库存
很抱歉,暂时无法提供与“APSF6R3ETD821MF08S”相匹配的价格&库存,您可以联系我们找货
