RS256M16ZADD-75DT
RS256M16ZADD-75DT
    RAYSON(晶存)
    RS256M16ZADD-75DT
RS256M16ZADD-75DT 数据手册
RS256M16ZADD-75DT DDR4 SDRAM RS256M16ZADD-75DT– 32 Meg x 16 x 8 Banks RS512M8ZADD-75DT– 64 Meg x 8 x 8 Banks Features • • • • • • • • • • • • • • • • • • • • • • • • • • • • • VDD = VDDQ = 1.2V ±60mV VPP = 2.5V, –125mV/+250mV On-die, internal, adjustable VREFDQ generation 1.2V pseudo open-drain I/O TC of 0°C to 95°C – 64ms, 8192-cycle refresh at 0°C to 85°C – 32ms at 85°C to 95°C TC of 0°C to 95°C 16 internal banks (x4, x8): 4 groups of 4 banks each 8 internal banks (x16): 2 groups of 4 banks each 8n-bit prefetch architecture Programmable data strobe preambles Data strobe preamble training Command/Address latency (CAL) Multipurpose register READ and WRITE capability Write and read leveling Self refresh mode Low-power auto self refresh (LPASR) Temperature controlled refresh (TCR) Fine granularity refresh Self refresh abort Maximum power saving Output driver calibration Nominal, park, and dynamic on-die termination (ODT) Data bus inversion (DBI) for data bus Command/Address (CA) parity Databus write cyclic redundancy check (CRC) Per-DRAM addressability Connectivity test (x16) Post package repair (PPR) and soft post package repair (sPPR) modes JEDEC JESD-79-4 compliant Options • RaysonMemory • Configuration – 1 Gig x 4 – 512 Meg x 8 – 256 Meg x 16 • Product Code – DDR4 • Density – 4 Gigabyte • Voltage/Refresh – 1.5V/8k refresh • FBGA package (Pb-free) - x4, x8 – 78-ball (7.5mm x 11mm) – 78-ball (8mm x 12mm) – 78-ball (9mm x 10.5mm) – 78-ball (9mm x 11.5mm) – 78-ball (9mm x 13.2mm) • FBGA package (Pb-free) - x16 – 96-ball (9mm x 14mm), rev A – 96-ball (9mm x 14mm), rev B – 96-ball (7.5mm x 13.5mm) – rev E, F • Timing - cycle time – 0.750ns @ CL = 18 (DDR4-2666) – 0.833ns @ CL = 16 (DDR4-2400) – 0.833ns @ CL = 17 (DDR4-2400) – 0.937ns @ CL = 15 (DDR4-2133) – 0.937ns @ CL = 16 (DDR4-2133) – 0.937ns @ CL = 16 (DDR4-2133) – 0.937ns @ CL = 16 (DDR4-2133) • Operating temperature – Commercial (0° TC 95°C) 1 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM Features Table 1: Key Timing Parameters Speed Grade Data Rate (MT/s) Target tRCD-tRP-CL -075E1, 2, 3, 4 -083E1, 2, 3, 4 -0831, 2, 3, 4 -093F1, 2, 3 -093E1, 2 -0931, 2 -107E1 2666 2400 2400 2133 2133 2133 1866 18-18-18 16-16-16 17-17-17 14-14-14 15-15-15 16-16-16 13-13-13 Notes: 1. 2. 3. 4. t RCD (ns) 13.5 13.32 14.16 13.13 14.06 15 13.92 t RP (ns) CL (ns) 13.5 13.32 14.16 13.13 14.06 15 13.92 13.5 13.32 14.16 13.13 14.06 15 13.92 Backward compatible to 1600, CL = 11 (-125E). Backward compatible to 1866, CL = 13 (-107E). Backward compatible to 2133, CL = 15 (-2133). Backward compatible to 2133, CL = 14 (-2133). Table 2: Addressing Parameter Number of bank groups Bank group address Bank count per group Bank address in bank group Row addressing Column addressing Page size1 1 Gig × 4 512 Meg × 8 256 Meg × 16 4 BG[1:0] 4 BA[1:0] 64K (A[15:0]) 1K (A[9:0]) 512B / 1KB2 4 BG[1:0] 4 BA[1:0] 32K (A[15:0]) 1K (A[9:0]) 1KB 2 BG0 4 BA[1:0] 32K (A[14:0]) 1K (A[9:0]) 2KB Notes: 1. Page size is per bank, calculated as follows: Page size = 2COLBITS x ORG/8, where COLBIT = the number of column address bits and ORG = the number of DQ bits. 2. Die revision dependent. Ordering Information RS 256 M 16 ZA 00DD - 75 D T RS:Rayson Depth Width 256 16 T:Try pack-Tray D:1.2V Design ID:ZA 75:2666Mbps 83:2400Mbps DF:96ball(7.5*13mm) 2 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM Table of Contents Table of Contents Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General Notes and Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .14 Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .14 General Notes. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .14 Definitions of the Device-Pin Signal Level . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .15 Definitions of the Bus Signal Level . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .15 Ball Assignments . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .16 Ball Descriptions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .18 Package Dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .21 State Diagram. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .23 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .25 RESET and Initialization Procedure . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .26 Power-Up and Initialization Sequence . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .26 RESET Initialization with Stable Power Sequence . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .29 Uncontrolled Power-Down Sequence . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .30 Programming Mode Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .30 Mode Register 0 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .33 Burst, Length, Type, and Order . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .34 CAS Latency . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .35 Test Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .35 Write Recovery(WR)/READ-to-PRECHARGE. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .36 DLL RESET . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .36 Mode Register 1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .37 DLL Enable/DLL Disable . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .38 Output Driver Impedance Control . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .38 ODT R TT(NOM) Values . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .39 Additive Latency . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .39 Write Leveling . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .39 Output Disable . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .39 Termination Data Strobe . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .39 Mode Register 2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .41 CAS WRITE Latency . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .42 Low-Power Auto Self Refresh. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .42 Dynamic ODT . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .43 Write Cyclic Redundancy Check Data Bus . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .43 Target Row Refresh Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .43 Mode Register 3 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .44 Multipurpose Register. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .45 WRITE Command Latency When CRC/DM is Enabled . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .45 Fine Granularity Refresh Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .46 Temperature Sensor Status . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .46 Per-DRAM Addressability. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .46 Gear-Down Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .46 Mode Register 4 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .47 Post Package Repair Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .48 Soft Post Package Repair Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .48 WRITE Preamble . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .48 READ Preamble . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .49 READ Preamble Training . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .49 Temperature-Controlled Refresh . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .49 Command Address Latency . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .49 3 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM Table of Contents Internal VREF Monitor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .49 Maximum Power Savings Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .49 Mode Register 5 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .50 Data Bus Inversion. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .51 Data Mask . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .51 CA Parity Persistent Error Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .52 ODT Input Buffer for Power-Down . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .52 CA Parity Error Status . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .52 CRC Error Status . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .52 CA Parity Latency Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .52 Mode Register 6 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .53 t CCD_L Programming . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .54 VREFDQ Calibration Enable. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .54 VREFDQ Calibration Range . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .54 V REFDQ Calibration Value . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .54 Truth Tables . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .55 NOP Command . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .58 DESELECT Command . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .58 DLL-Off Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .58 DLL-On/Off Switching Procedures . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .60 DLL Switch Sequence from DLL-On to DLL-Off . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .60 DLL-Off to DLL-On Procedure . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .61 Input Clock Frequency Change . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .62 Write Leveling . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .64 DRAM Setting for Write Leveling and DRAM TERMINATION Function in that Mode. . . . . . . . . . . . . . . . . . . . . . . .65 Procedure Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .66 Write-Leveling Mode Exit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .67 Command Address Latency . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .69 Low-Power Auto Self Refresh Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .73 Manual Self Refresh Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .73 Multipurpose Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .75 MPR Reads . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .76 MPR Readout Format . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .78 MPR Readout Serial Format. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .78 MPR Readout Parallel Format . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .79 MPR Readout Staggered Format . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .80 MPR READ Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .81 MPR Writes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .83 MPR WRITE Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .83 MPR REFRESH Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .85 Gear-Down Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .87 Maximum Power-Saving Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .90 Maximum Power-Saving Mode Entry . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .90 Maximum Power-Saving Mode Entry in PDA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .91 CKE Transition During Maximum Power-Saving Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .91 Maximum Power-Saving Mode Exit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .92 Command/Address Parity. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .93 Per-DRAM Addressability . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .101 VREFDQ Calibration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .103 VREFDQ Range and Levels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .104 VREFDQ Step Size . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .104 VREFDQ Increment and Decrement Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .105 VREFDQ Target Settings. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .109 4 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM Table of Contents Connectivity Test Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .110 Pin Mapping . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .110 Minimum Terms Definition for Logic Equations . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .111 Logic Equations for a x4 Device, When Supported . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .111 Logic Equations for a x8 Device, When Supported . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .111 Logic Equations for a x16 Device . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .112 CT Input Timing Requirements . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .112 Post Package Repair and Soft Post Package Repair . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .114 Post Package Repair . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .114 PPR Row Repair . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .114 PPR Row Repair - Entry . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .114 PR Row Repair – WRA Initiated (REF Commands Allowed). . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .115 PPR Row Repair – WR Initiated (REF Commands NOT Allowed) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .116 sPPR Row Repair. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .118 PPR/sPPR Support Identifier . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .119 Target Row Refresh Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .120 ACTIVATE command . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .121 PRECHARGE Command . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .122 REFRESH Command . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .122 Temperature-Controlled Refresh Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .124 TCR Mode – Normal Temperature Range. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .124 TCR Mode – Extended Temperature Range . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .124 Fine Granularity Refresh Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .126 Mode Register and Command Truth Table . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .126 t REFI and tRFC Parameters . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .126 Changing Refresh Rate . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .129 Usage with TCR Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .129 Self Refresh Entry and Exit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .129 SELF REFRESH Operation. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .131 Self Refresh Abort . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .133 Self Refresh Exit with NOP Command . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .134 Power-Down Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .136 Power-Down Clarifications – Case 1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .141 Power-Down Entry, Exit Timing with CAL . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .142 ODT Input Buffer Disable Mode for Power-Down . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .145 CRC Write Data Feature. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .147 CRC Write Data . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .147 WRITE CRC DATA Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .147 DBI_n and CRC Both Enabled . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .148 DM_n and CRC Both Enabled . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .148 DM_n and DBI_n Conflict During Writes with CRC Enabled. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .148 CRC and Write Preamble Restrictions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .148 CRC Simultaneous Operation Restrictions. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .148 CRC Polynomial . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .148 CRC Combinatorial Logic Equations . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .149 Burst Ordering for BL8 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .150 CRC Data Bit Mapping . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .150 CRC Enabled With BC4 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .151 CRC with BC4 Data Bit Mapping. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .151 CRC Equations for x8 Device in BC4 Mode with A2 = 0 and A2 = 1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .153 CRC Error Handling . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .155 CRC Write Data Flow Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .156 Data Bus Inversion . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .157 5 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM Table of Contents DBI During a WRITE Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .157 DBI During a READ Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .158 Data Mask . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .159 Programmable Preamble Modes and DQS Postambles . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .160 WRITE Preamble Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .160 READ Preamble Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .163 READ Preamble Training . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .163 WRITE Postamble. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .164 READ Postamble. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .164 Bank Access Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .166 READ Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .170 Read Timing Definitions. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .170 Read Timing – Clock-to-Data Strobe Relationship . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .171 Read Timing – Data Strobe-to-Data Relationship. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .172 t LZ(DQS), tLZ(DQ), tHZ(DQS), and tHZ(DQ) Calculations . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .173 t RPRE Calculation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .175 t RPST Calculation. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .176 READ Burst Operation. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .177 READ Operation Followed by Another READ Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .179 READ Operation Followed by WRITE Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .184 READ Operation Followed by PRECHARGE Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .190 READ Operation with Read Data Bus Inversion (DBI) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .193 READ Operation with Command/Address Parity (CA Parity) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .194 READ Followed by WRITE with CRC Enabled . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .195 READ Operation with Command/Address Latency (CAL) Enabled . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .196 WRITE Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .198 Write Timing Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .198 Write Timing – Clock-to-Data Strobe Relationship . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .198 Write Timing – Data Strobe-to-Data Relationship . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .199 WRITE Burst Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .203 WRITE Operation Followed by Another WRITE Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .205 WRITE Operation Followed by READ Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .210 WRITE Operation Followed by PRECHARGE Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .213 WRITE Operation with WRITE DBI Enabled . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .216 WRITE Operation with CA Parity Enabled . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .217 WRITE Operation with Write CRC Enabled . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .218 Write Timing Violations . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .222 Motivation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .222 Data Setup and Hold Violations . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .222 Strobe-to-Strobe and Strobe-to-Clock Violations. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .222 ZQ CALIBRATION Commands. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .223 On-Die Termination . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .225 ODT Mode Register and ODT State Table . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .225 ODT Read Disable State Table. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .226 Synchronous ODT Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .227 ODT Latency and Posted ODT . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .227 Timing Parameters. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .227 ODT During Reads . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .229 Dynamic ODT . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .230 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .230 Asynchronous ODT Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .233 Electrical Specifications. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .234 Absolute Ratings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .234 6 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM Table of Contents DRAM Component Operating Temperature Range . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .234 Electrical Characteristics – AC and DC Operating Conditions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .235 Supply Operating Conditions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .235 Leakages . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .235 VREFCA Supply . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .236 VREFDQ Supply and Calibration Ranges. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .236 VREFDQ Ranges . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .237 7 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM List of Figures List of Figures Figure 1: Figure 2: Figure 3: Figure 4: Figure 5: Figure 6: Figure 7: Figure 8: Figure 9: Figure 10: Figure 11: Figure 12: Figure 13: Figure 14: Figure 15: Figure 16: Figure 17: Figure 18: Figure 19: Figure 20: Figure 21: Figure 22: Figure 23: Figure 24: Figure 25: Figure 26: Figure 27: Figure 28: Figure 29: Figure 30: Figure 31: Figure 32: Figure 33: Figure 34: Figure 35: Figure 36: Figure 37: Figure 38: Figure 39: Figure 40: Figure 41: Figure 42: Figure 43: Figure 44: Figure 45: Figure 46: Figure 47: Figure 48: Figure 49: Figure 50: Figure 51: Figure 52: Figure 53: Figure 54: Figure 55: Figure 56: 78-Ball – x4, x8 Ball Assignments. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .16 96-Ball FBGA – x16 Ball Assignments . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .17 78-Ball FBGA – x4, x8; “RAF” . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .21 96-Ball FBGA – x16; “REF“. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .22 Simplified State Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .23 RESET and initialization Sequence at Power-On Ramping. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .28 RESET Procedure at Power Stable Ramping . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .29 t MRD Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .31 tMOD Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .31 DLL-Off Mode Read Timing Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .59 DLL Switch Sequence from DLL-On to DLL-Off . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .61 DLL Switch Sequence from DLL-Off to DLL-On . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .62 Write-Leveling Concept, Example 1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .64 Write-Leveling Concept, Example 2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .65 Write-Leveling Sequence (DQS Capturing CK LOW at T1 and CK HIGH at T2) . . . . . . . . . . . . . . . . . . . .67 Write-Leveling Exit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .68 CAL Timing Definition. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .69 CAL Timing Example (Consecutive CS_n = LOW) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .69 CAL Enable Timing – tMOD_CAL . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .70 t MOD_CAL, MRS to Valid Command Timing with CAL Enabled. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .70 CAL Enabling MRS to Next MRS Command, tMRD_CAL. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .71 t MRD_CAL, Mode Register Cycle Time with CAL Enabled . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .71 Consecutive READ BL8, CAL3, 1tCK Preamable, Different Bank Group. . . . . . . . . . . . . . . . . . . . . . . . . . .72 Consecutive READ BL8, CAL4, 1tCK Preamable, Different Bank Group. . . . . . . . . . . . . . . . . . . . . . . . . . .72 Auto Self Refresh Ranges. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .74 MPR Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .75 MPR READ Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .81 MPR Back-to-Back READ Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .82 MPR READ-to-WRITE Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .82 MPR WRITE and WRITE-to-READ Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .84 MPR Bank-to-Back WRITE Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .84 REFRESH Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .85 READ-to-REFRESH Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .85 WRITE-to-REFRESH Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .86 Clock Mode Change from 1/2 Rate to 1/4 Rate (Initialization) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .88 Clock Mode Change After Exiting Self Refresh . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .88 Comparison Between Gear-Down Disable and Gear-Down Enable. . . . . . . . . . . . . . . . . . . . . . . . . . . . . .89 Maximum Power-Saving Mode Entry . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .90 Maximum Power-Saving Mode Entry with PDA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .91 Maintaining Maximum Power-Saving Mode with CKE Transition . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .91 Maximum Power-Saving Mode Exit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .92 Command/Address Parity Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .93 Command/Address Parity During Normal Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .95 Persistent CA Parity Error Checking Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .96 CA Parity Error Checking – SRE Attempt . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .96 CA Parity Error Checking – SRX Attempt . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .97 CA Parity Error Checking – PDE/PDX . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .97 Parity Entry Timing Example – tMRD_PAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .98 Parity Entry Timing Example – tMOD_PAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .98 Parity Exit Timing Example – tMRD_PAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .98 Parity Exit Timing Example – tMOD_PAR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .99 CA Parity Flow Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .100 PDA Operation Enabled, BL8 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .102 PDA Operation Enabled, BC4. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .102 MRS PDA Exit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .102 VREFDQ Voltage Range . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .103 8 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM List of Figures Figure 57: Example of VREF Set Tolerance and Step Size. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 58: VREFDQ Timing Diagram for VREF,time Parameter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 59: VREFDQ Training Mode Entry and Exit Timing Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 60: VREF Step: Single Step Size Increment Case . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 61: VREF Step: Single Step Size Decrement Case. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 62: VREF Full Step: From VREF,min to VREF,maxCase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 63: VREF Full Step: From VREF,max to VREF,minCase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 64: VREFDQ Equivalent Circuit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 65: Connectivity Test Mode Entry . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 66: PPR WRA – Entry . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 67: PPR WRA – Repair and Exit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 68: PPR WR – Entry . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 69: PPR WR – Repair and Exit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 70: sPPR – Entry, Repair, and Exit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 71: tRRD Timing. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 72: tFAW Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 73: REFRESH Command Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 74: Postponing REFRESH Commands (Example) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 75: Pulling In REFRESH Commands (Example) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 76: TCR Mode Example1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 77: 4Gb with Fine Granularity Refresh Mode Example. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 78: OFT REFRESH Command Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 79: Self Refresh Entry/Exit Timing. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 80: Self Refresh Entry/Exit Timing with CAL Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 81: Self Refresh Abort . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 82: Self Refresh Exit with NOP Command . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 83: Active Power-Down Entry and Exit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 84: Power-Down Entry After Read and Read with Auto Precharge . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 85: Power-Down Entry After Write and Write with Auto Precharge. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 86: Power-Down Entry After Write . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 87: Precharge Power-Down Entry and Exit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 88: REFRESH Command to Power-Down Entry. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 89: Active Command to Power-Down Entry . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 90: PRECHARGE/PRECHARGE ALL Command to Power-Down Entry . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 91: MRS Command to Power-Down Entry . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 92: Power-Down Entry/Exit Clarifications – Case 1. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 93: Active Power-Down Entry and Exit Timing with CAL. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 94: REFRESH Command to Power-Down Entry with CAL . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 95: ODT Power-Down Entry with ODT Buffer Disable Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 96: ODT Power-Down Exit with ODT Buffer Disable Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 97: CRC Write Data Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 98: CRC Error Reporting . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 99: tCK vs. 2tCK WRITE Preamble Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 100:tCK vs. 2tCK WRITE Preamble Mode, tCCD = 4 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 101:1tCK vs. 2tCK WRITE Preamble Mode, tCCD = 5 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 102:1tCK vs. 2tCK WRITE Preamble Mode, tCCD = 6 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 103:1tCK vs. 2tCK READ Preamble Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 104:READ Preamble Training . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 105:WRITE Postamble . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 106:READ Postamble . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 107:Bank Group x4/x8 Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 108:READ Burst tCCD_S and tCCD_L Examples . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 109:Write Burst tCCD_S and tCCD_L Examples . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 110:tRRD Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Figure 111:tWTR_S Timing (WRITE-to-READ, Different Bank Group, CRC and DM Disabled) . . . . . . . . . . . . . . Figure 112:tWTR_L Timing (WRITE-to-READ, Same Bank Group, CRC and DM Disabled) . . . . . . . . . . . . . . . . . Figure 113:Read Timing Definition . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 105 106 107 107 108 108 108 109 113 116 116 117 117 119 121 121 123 123 123 125 128 129 132 133 134 135 137 138 138 139 139 140 140 141 141 142 143 144 145 146 147 155 160 161 162 162 163 164 164 165 166 167 168 168 169 169 171 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM List of Figures Figure 114:Clock-to-Data Strobe Relationship . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 172 Figure 115:Data Strobe-to-Data Relationship . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 173 Figure 116:tLZ and tHZ Method for Calculating Transitions and Endpoints . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 174 Figure 117:tRPRE Method for Calculating Transitions and Endpoints. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 175 Figure 118:tRPST Method for Calculating Transitions and Endpoints . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 176 Figure 119:READ Burst Operation, RL = 11 (AL = 0, CL = 11, BL8) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 177 Figure 120:READ Burst Operation, RL = 21 (AL = 10, CL = 11, BL8). . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 178 Figure 121:Consecutive READ (BL8) with 1tCK Preamble in Different Bank Group . . . . . . . . . . . . . . . . . . . . . . . . 179 Figure 122:Consecutive READ (BL8) with 2tCK Preamble in Different Bank Group . . . . . . . . . . . . . . . . . . . . . . . . 179 Figure 123:Nonconsecutive READ (BL8) with 1tCK Preamble in Same or Different Bank Group . . . . . . . . . . . . 180 Figure 124:Nonconsecutive READ (BL8) with 2tCK Preamble in Same or Different Bank Group . . . . . . . . . . . . 180 Figure 125:READ (BC4) to READ (BC4) with 1tCK Preamble in Different Bank Group. . . . . . . . . . . . . . . . . . . . . . 181 Figure 126:READ (BC4) to READ (BC4) with 2tCK Preamble in Different Bank Group. . . . . . . . . . . . . . . . . . . . . . 181 Figure 127:READ (BL8) to READ (BC4) OTF with 1tCK Preamble in Different Bank Group . . . . . . . . . . . . . . . . . 182 Figure 128:READ (BL8) to READ (BC4) OTF with 2tCK Preamble in Different Bank Group . . . . . . . . . . . . . . . . . 182 Figure 129:READ (BC4) to READ (BL8) OTF with 1tCK Preamble in Different Bank Group . . . . . . . . . . . . . . . . . 183 Figure 130:READ (BC4) to READ (BL8) OTF with 2tCK Preamble in Different Bank Group . . . . . . . . . . . . . . . . . 183 Figure 131:READ (BL8) to WRITE (BL8) with 1tCK Preamble in Same or Different Bank Group . . . . . . . . . . . . . 184 Figure 132:READ (BL8) to WRITE (BL8) with 2tCK Preamble in Same or Different Bank Group . . . . . . . . . . . . . 184 Figure 133:READ (BC4) OTF to WRITE (BC4) OTF with 1tCK Preamble in Same or Different Bank Group. . . . 185 Figure 134:READ (BC4) OTF to WRITE (BC4) OTF with 2tCK Preamble in Same or Different Bank Group. . . . 186 Figure 135:READ (BC4) Fixed to WRITE (BC4) Fixed with 1tCK Preamble in Same or Different Bank Group. . 186 Figure 136:READ (BC4) Fixed to WRITE (BC4) Fixed with 2tCK Preamble in Same or Different Bank Group. . 187 Figure 137:READ (BC4) to WRITE (BL8) OTF with 1tCK Preamble in Same or Different Bank Group . . . . . . . . 187 Figure 138:READ (BC4) to WRITE (BL8) OTF with 2tCK Preamble in Same or Different Bank Group . . . . . . . . 188 Figure 139:READ (BL8) to WRITE (BC4) OTF with 1tCK Preamble in Same or Different Bank Group . . . . . . . . 189 Figure 140:READ (BL8) to WRITE (BC4) OTF with 2tCK Preamble in Same or Different Bank Group . . . . . . . . 189 Figure 141:READ to PRECHARGE with 1tCK Preamble . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 190 Figure 142:READ to PRECHARGE with 2tCK Preamble . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 191 Figure 143:READ to PRECHARGE with Additive Latency and 1tCK Preamble . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 191 Figure 144:READ with Auto Precharge and 1tCK Preamble . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 192 Figure 145:READ with Auto Precharge, Additive Latency, and 1tCK Preamble . . . . . . . . . . . . . . . . . . . . . . . . . . . . 192 Figure 146:Consecutive READ (BL8) with 1tCK Preamble and DBI in Different Bank Group . . . . . . . . . . . . . . . . 193 Figure 147:Consecutive READ (BL8) with 1tCK Preamble and CA Parity in Different Bank Group . . . . . . . . . . . 194 Figure 148:READ (BL8) to WRITE (BL8) with 1tCK Preamble and CA Parity in Same or Different Bank Group 194 Figure 149:READ (BL8) to WRITE (BL8 or BC4: OTF) with 1tCK Preamble and Write CRC in Same or Different Bank Group . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 195 Figure 150:READ (BC4: Fixed) to WRITE (BC4: Fixed) with 1tCK Preamble and Write CRC in Same or Different Bank Group . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 196 Figure 151:Consecutive READ (BL8) with CAL (3tCK) and 1tCK Preamble in Different Bank Group . . . . . . . . . 196 Figure 152:Consecutive READ (BL8) with CAL (4tCK) and 1tCK Preamble in Different Bank Group . . . . . . . . . 197 Figure 153:Write Timing Definition . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 199 Figure 154:Rx Compliance Mask. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 200 Figure 155:VCENT_DQ VREFDQ Voltage Variation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 200 Figure 156:Rx Mask DQ-to-DQS Timings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 201 Figure 157:Rx Mask DQ-to-DQS DRAM-Based Timings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 202 Figure 158:Example of Data Input Requirements Without Training . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 203 Figure 159:WRITE Burst Operation, WL = 9 (AL = 0, CWL = 9, BL8) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 204 Figure 160:WRITE Burst Operation, WL = 19 (AL = 10, CWL = 9, BL8) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 204 Figure 161:Consecutive WRITE (BL8) with 1tCK Preamble in Different Bank Group . . . . . . . . . . . . . . . . . . . . . . . 205 Figure 162:Consecutive WRITE (BL8) with 2tCK Preamble in Different Bank Group . . . . . . . . . . . . . . . . . . . . . . . 205 Figure 163:Nonconsecutive WRITE (BL8) with 1tCK Preamble in Same or Different Bank Group . . . . . . . . . . . 206 Figure 164:Nonconsecutive WRITE (BL8) with 2tCK Preamble in Same or Different Bank Group . . . . . . . . . . . 207 Figure 165:WRITE (BC4) OTF to WRITE (BC4) OTF with 1tCK Preamble in Different Bank Group. . . . . . . . . . . 207 Figure 166:WRITE (BC4) OTF to WRITE (BC4) OTF with 2tCK Preamble in Different Bank Group. . . . . . . . . . . 208 Figure 167:WRITE (BC4) Fixed to WRITE (BC4) Fixed with 1tCK Preamble in Different Bank Group. . . . . . . . . 209 Figure 168:WRITE (BL8) to WRITE (BC4) OTF with 1tCK Preamble in Different Bank Group . . . . . . . . . . . . . . . 209 10 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM List of Figures Figure 169:WRITE (BC4) OTF to WRITE (BL8) with 1tCK Preamble in Different Bank Group . . . . . . . . . . . . . . . 210 Figure 170:WRITE (BL8) to READ (BL8) with 1tCK Preamble in Different Bank Group . . . . . . . . . . . . . . . . . . . . . .210 Figure 171:WRITE (BL8) to READ (BL8) with 1tCK Preamble in Same Bank Group . . . . . . . . . . . . . . . . . . . . . . . . .211 Figure 172:WRITE (BC4) OTF to READ (BC4) OTF with 1tCK Preamble in Different Bank Group. . . . . . . . . . . . .211 Figure 173:WRITE (BC4) OTF to READ (BC4) OTF with 1tCK Preamble in Same Bank Group . . . . . . . . . . . . . . . .212 Figure 174:WRITE (BC4) Fixed to READ (BC4) Fixed with 1tCK Preamble in Different Bank Group. . . . . . . . . . .212 Figure 175:WRITE (BC4) Fixed to READ (BC4) Fixed with 1tCK Preamble in Same Bank Group . . . . . . . . . . . . . .213 Figure 176:WRITE (BL8/BC4-OTF) to PRECHARGE with 1tCK Preamble . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .214 Figure 177:WRITE (BC4-Fixed) to PRECHARGE with 1tCK Preamble . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .214 Figure 178:WRITE (BL8/BC4-OTF) to Auto PRECHARGE with 1tCK Preamble . . . . . . . . . . . . . . . . . . . . . . . . . . . . .215 Figure 179:WRITE (BC4-Fixed) to Auto PRECHARGE with 1tCK Preamble. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .215 Figure 180:WRITE (BL8/BC4-OTF) with 1tCK Preamble and DBI . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .216 Figure 181:WRITE (BC4-Fixed) with 1tCK Preamble and DBI . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .216 Figure 182:Consecutive Write (BL8) with 1tCK Preamble and CA Parity in Different Bank Group . . . . . . . . . . . .217 Figure 183:Consecutive WRITE (BL8/BC4-OTF) with 1tCK Preamble and Write CRC in Same or Different Bank Group . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .218 Figure 184:Consecutive WRITE (BC4-Fixed) with 1tCK Preamble and Write CRC in Same or Different Bank Group . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .219 Figure 185:Nonconsecutive WRITE (BL8/BC4-OTF) with 1tCK Preamble and Write CRC in Same or Different Bank Group . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .219 Figure 186:Nonconsecutive WRITE (BL8/BC4-OTF) with 2tCK Preamble and Write CRC in Same or Different Bank Group . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .220 Figure 187:WRITE (BL8/BC4-OTF/Fixed) with 1tCK Preamble and Write CRC in Same or Different Bank Group .. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 221 Figure 188:ZQ Calibration Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .224 Figure 189:Functional Representation of ODT . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .225 Figure 190:Synchronous ODT Timing with BL8 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .228 Figure 191:Synchronous ODT with BC4 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .228 Figure 192:ODT During Reads. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .229 Figure 193:Dynamic ODT (1tCK Preamble; CL = 14, CWL = 11, BL = 8, AL = 0, CRC Disabled). . . . . . . . . . . . . . . .231 Figure 194:Dynamic ODT Overlapped with RTT(NOM) (CL = 14, CWL = 11, BL = 8, AL = 0, CRC Disabled). . . . . .232 Figure 195:Asynchronous ODT Timings with DLL Off. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .233 Figure 196:VREFDQ Voltage Range . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .236 11 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM List of Tables List of Tables Table 1: Table 2: Table 3: Table 4: Table 5: Table 6: Table 7: Table 8: Table 9: Table 10: Table 11: Table 12: Table 13: Table 14: Table 15: Table 16: Table 17: Table 18: Table 19: Table 20: Table 21: Table 22: Table 23: Table 24: Table 25: Table 26: Table 27: Table 28: Table 29: Table 30: Table 31: Table 32: Table 33: Table 34: Table 35: Table 36: Table 37: Table 38: Table 39: Table 40: Table 41: Table 42: Table 43: Table 44: Table 45: Table 46: Table 47: Table 48: Table 49: Table 50: Table 51: Key Timing Parameters . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Addressing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Ball Descriptions. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .18 State Diagram Command Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .24 Address Pin Mapping. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .33 MR0 Register Definition . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .33 Burst Type and Burst Order . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .35 Address Pin Mapping. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .37 MR1 Register Definition . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .37 Addictive Latency (AL) Settings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .39 TDQS Function Matrix. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .40 Address Pin Mapping. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .41 MR2 Register Definition . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .41 Address Pin Mapping. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .44 MR3 Register Definition . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .44 Address Pin Mapping. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .47 MR4 Register Definition . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .47 Address Pin Mapping. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .50 MR5 Register Definition . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .50 Address Pin Mapping. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .53 MR5 Register Definition . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .53 Truth Table – Command . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .55 Truth Table – CKE. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .57 MR Settings for Leveling Procedures . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .65 DRAM TERMINATION Function in Leveling Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .66 Auto Self Refresh Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .73 MR3 Setting for the MPR Access Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .75 DRAM Address to MPR UI Translation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .76 MPR Page and MPRx Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .76 MPR Readout Serial Format . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .78 MPR Readout – Parallel Format. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .79 MPR Readout Staggered Format, x4 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .80 MPR Readout Staggered Format, x4 – Consecutive READs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .80 MPR Readout Staggered Format, x8 and x16 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .80 Mode Register setting for CA Parity . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .95 Timing Parameter. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .101 VREFDQ Range and Levels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .104 VREFDQ Settings (VDDQ = 1.2V) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .109 Connectivity Mode Pin Description and Switching Levels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .110 PPR MR0 Guard Key Settings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .115 DDR4 PPR Timing Parameters. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .118 DDR4 sPPR Timing Parameters. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .119 DDR4 Repair Mode Support Identifier . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .119 MAC Encoding of MPR Page 3 MPR3 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .120 Normal tREFI Refresh (TCR Disabled) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .124 Normal tREFI Refresh (TCR Enabled) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .125 MRS Definition . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .126 REFRESH Command Truth table . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .126 t REFI and tRFC Parameters. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .127 Power-Down Entry Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .136 CRC Error Detection Coverage . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .148 12 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM List of Tables Table 52: Table 53: Table 54: Table 55: Table 56: Table 57: Table 58: Table 59: Table 60: Table 61: Table 62: Table 63: Table 64: Table 65: Table 66: Table 67: Table 68: Table 69: Table 70: Table 71: Table 72: Table 73: Table 74: Table 75: Table 76: Table 77: Table 78: Table 79: CRC Data Mapping for x4 Devices, BL8 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .150 CRC Data Mapping for x8 Devices, BL8 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .150 CRC Data Mapping for x16 Devices, BL8. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .150 CRC Data Mapping for x4 Devices, BC4. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .151 CRC Data Mapping for x8 Devices, BC4. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .152 CRC Data Mapping for x16 Devices, BC4 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .152 DBI vs. DM vs. TDQS Function Matrix. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .157 DBI Write, DQ Frame Format (x8). . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .157 DBI Write, DQ Frame Format (x16) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .157 DBI Read, DQ Frame Format (x8) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .158 DBI Read, DQ Frame Format (x16) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .158 DM vs. TDQS vs. DBI Function Matrix. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .159 Data Mask, DQ Frame Format (x8) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .159 Data Mask, DQ Frame Format (x16) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .159 CWL Selection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .161 DDR4 Bank Group Timings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .167 Termination State Table . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .226 Read Termination Disable Window . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .226 ODT Latency at DDR4-1600/-1866/-2133/-2666/-3200. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .227 Dynamic ODT Latencies and Timing (1tCK Preamble Mode and CRC Disabled) . . . . . . . . . . . . . . . . .230 Dynamic ODT Latencies and Timing with Preamble Mode and CRC Mode Matrix . . . . . . . . . . . . . . .231 Absolute Maximum Ratings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .234 Temperature Range . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .234 Recommended Supply Operating Conditions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .235 VDD Slew Rate . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .235 Leakages . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .235 VREFDQ Specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .236 VREFDQ Range and Levels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .237 13 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM General Notes and Description General Notes and Description Description The DDR4 SDRAM is a high-speed dynamic random-access memory internally configured as an eight-bank DRAM for the x16 configuration and as a 16-bank DRAM for the x4 and x8 configurations. The DDR4 SDRAM uses an 8n-prefetch architecture to achieve high-speed operation. The 8n-prefetch architecture is combined with an interface designed to transfer two data words per clock cycle at the I/O pins. A single READ or WRITE operation for the DDR4 SDRAM consists of a single 8n-bit wide, four-clock data transfer at the internal DRAM core and two corresponding n-bit wide, one-half-clock-cycle data transfers at the I/O pins. General Notes • The functionality and the timing specifications discussed in this data sheet are for the DLL enable mode of operation (normal operation), unless specifically stated otherwise. • Throughout the data sheet, the various figures and text refer to DQs as “DQ.” The DQ term is to be interpreted as any and all DQ collectively, unless specifically stated otherwise. • The terms “_t” and “_c” are used to represent the true and complement of a differential signal pair. These terms replace the previously used notation of “#” and/or overbar characters. For example, differential data strobe pair DQS, DQS# is now referred to as DQS_t, DQS_c. • The term “_n” is used to represent a signal that is active LOW and replaces the previously used “#” and/or overbar characters. For example: CS# is now referred to as CS_n. • The terms “DQS” and “CK” found throughout the data sheet are to be interpreted as DQS_t, DQS_c and CK_t, CK_c respectively, unless specifically stated otherwise. • Complete functionality may be described throughout the entire document; any page or diagram may have been simplified to convey a topic and may not be inclusive of all requirements. • Any specific requirement takes precedence over a general statement. • Any functionality not specifically stated here within is considered undefined, illegal, and not supported, and can result in unknown operation. • Addressing is denoted as BG[n] for bank group, BA[n] for bank address, and A[n] for row/col address. • The NOP command is not allowed, except when exiting maximum power savings mode or when entering gear-down mode, and only a DES command should be used. • Not all features described within this document may be available on the Rev. A (first) version. • Not all specifications listed are finalized industry standards; best conservative estimates have been provided when an industry standard has not been finalized. • Although it is implied throughout the specification, the DRAM must be used after VDD has reached the stable power-on level and is achieved by toggling CKE at least once every 8192 × tREFI. In the event CKE is fixed HIGH, toggling CS_n at least once every 8192 × tREFI is acceptable. • Not all features designated in the data sheet may be supported by earlier die revisions due to late definition by JEDEC. 14 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM Definitions of the Device-Pin Signal Level Definitions of the Device-Pin Signal Level • • • • HIGH: A device pin is driving the logic 1 state. LOW: A device pin is driving the logic 0 state. High-Z: A device pin is tri-state. ODT: A device pin terminates with the ODT setting, which could be terminating or tristate depending on the mode register setting. Definitions of the Bus Signal Level • HIGH: One device on the bus is HIGH, and all other devices on the bus are either ODT or High-Z. The voltage level on the bus is nominally VDDQ. • LOW: One device on the bus is LOW, and all other devices on the bus are either ODT or High-Z. The voltage level on the bus is nominally VOL(DC) if ODT was enabled, or VSSQ if High-Z. • High-Z: All devices on the bus are High-Z. The voltage level on the bus is undefined as the bus is floating. • ODT: At least one device on the bus is ODT, and all others are High-Z. The voltage level on the bus is nominally VDDQ. 15 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM Ball Assignments Ball Assignments Figure 1: 78-Ball – x4, x8 Ball Assignments 1 2 3 VDD VSSQ NF, NF/ TDQS_c 4 5 6 7 8 9 NF, NF/DM_n/ DBI_n/TDQS_t VSSQ VSS A A B B VPP VDDQ DQS_c DQ1 VDDQ ZQ C C VDDQ DQ0 DQS_t VSS VDD VDDQ D D VSSQ DQ4/NC DQ2 DQ3 DQ5/NC VSSQ VSS VDDQ DQ6/NC DQ7/NC VDDQ VSS CK_c VDD E E F F VDD C2/ODT1 ODT CK_t VSS C0/CKE1 CKE CS_n G G C1/CS1_n RFU/TEN H H VDD CAS_n/ A15 WE_n/A14ACT_n RAS_n/A16 VSS J J VREFCA BG0 A10/AP A12/BC_n BG1 VDD K K VSS BA0 A4 A3 BA1 VSS RESET_n A6 A0 A1 A5 ALERT_n VDD A8 A2 A9 A7 VPP VSS A11 PAR A17/NC A13 VDD L L M M N N Notes: 1. See Ball descriptions. 2. A comma “,” separates the configuration; a slash “/” defines a selectable function. For example: Ball A7 = NF, NF/DM_n/DBI_n/TDQS_t where NF applies to the x4 configuration only. NF/DM_n/DBI_n/TDQS_t applies to the x8 configuration only and is selectable between NF, DM_n, DBI_n, or TDQS_t via MRS. 3. Address bits (including bank groups) are density- and configuration-dependent (see Addressing). 4. G9 may be RFU and not assigned as TEN on some die revisions as TEN is not required on 4Gb x4 and x8 offerings. 16 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM Ball Assignments Figure 2: 96-Ball FBGA – x16 Ball Assignments 1 2 3 4 5 6 7 8 9 A A VDDQ VSSQ DQ8 UDQS_c VSSQ VDDQ B B VPP VSS VDD UDQS_t DQ9 VDD C C VDDQ DQ12 DQ10 DQ11 DQ13 VSSQ D D VDD VSSQ VSS NF/UDM_n/ UDBI_n DQ14 DQ15 VSSQ NF/LDM_n/ LDBI_n VSSQ VDDQ E E VSSQ VSS F F VSSQ VDDQ LDQS_c DQ1 VDDQ ZQ VDDQ DQ0 LDQS_t VDD VSS VDDQ G G H H VSSQ DQ4 DQ2 DQ3 DQ5 VSSQ J J VDD VDDQ DQ6 DQ7 VDDQ VDD K K VSS CKE CK_t ODT CK_c VSS L L VDD WE_n/A14 ACT_n CS_n RAS_n/A16 VDD M M VREFCA BG0 A10/AP VSS BA0 A4 A12/BC_n CAS-n/A15 VSS N N A3 BA1 TEN P P RESET_n A6 A0 A1 A5 ALERT_n R R VDD A8 A2 A9 A7 VPP T T VSS A11 PAR NC A13 VDD Notes: 1. See Ball Descriptions. 2. A slash “/” defines a selectable function. For example: Ball E7 = NF/LDM_n. If data mask is enabled via the MRS, ball E7 = LDM_n. If data mask is disabled in the MRS, E7 = NF (no function). 3. Address bits (including bank groups) are density- and configuration-dependent (see Addressing). 17 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM Ball Descriptions Ball Descriptions The pin description table below is a comprehensive list of all possible pins for DDR4 devices. All pins listed may not be supported on the device defined in this data sheet. See the Ball Assignments section to review all pins used on this device. Table 3: Ball Descriptions Symbol Type Description A[17:0] Input A10/AP Input A12/BC_n Input ACT_n Input BA[1:0] Input BG[1:0] Input C0/CKE1, C1/CS1_n, C2/ODT1 Input CK_t, CK_c CKE Input Address inputs: Provide the row address for ACTIVATE commands and the column address for READ/WRITE commands to select one location out of the memory array in the respective bank. (A10/AP, A12/BC_n, WE_n/A14, CAS_n/A15, RAS_n/A16 have additional functions, see individual entries in this table.) The address inputs also provide the op-code during the MODE REGISTER SET command. A16 is used on some 8Gb and 16Gb parts, and A17 is only used on some 16Gb parts Auto precharge: A10 is sampled during READ and WRITE commands to determine whether auto precharge should be performed to the accessed bank after a READ or WRITE operation. (HIGH = auto precharge; LOW = no auto precharge.) A10 is sampled during a PRECHARGE command to determine whether the PRECHARGE applies to one bank (A10 LOW) or all banks (A10 HIGH). If only one bank is to be precharged, the bank is selected by the bank group and bank addresses. Burst chop: A12/BC_n is sampled during READ and WRITE commands to determine if burst chop (on-the-fly) will be performed. (HIGH = no burst chop; LOW = burst chopped). See the Command Truth Table. Command input: ACT_n indicates an ACTIVATE command. When ACT_n (along with CS_n) is LOW, the input pins RAS_n/A16, CAS_n/A15, and WE_n/A14 are treated as row address inputs for the ACTIVATE command. When ACT_n is HIGH (along with CS_n LOW), the input pins RAS_n/ A16, CAS_n/A15, and WE_n/A14 are treated as normal commands that use the RAS_n, CAS_n, and WE_n signals. See the Command Truth Table. Bank address inputs: Define the bank (within a bank group) to which an ACTIVATE, READ, WRITE, or PRECHARGE command is being applied. Also determines which mode register is to be accessed during a MODE REGISTER SET command. Bank group address inputs: Define the bank group to which a REFRESH, ACTIVATE, READ, WRITE, or PRECHARGE command is being applied. Also determines which mode register is to be accessed during a MODE REGISTER SET command. BG[1:0] are used in the x4 and x8 configurations. BG1 is not used in the x16 configuration. Stack address inputs: These inputs are used only when devices are stacked; that is, they are used in 2H, 4H, and 8H stacks for x4 and x8 configurations (these pins are not used in the x16 configuration). DDR4 will support a traditional DDP package, which uses these three signals for control of the second die (CS1_n, CKE1, ODT1). DDR4 is not expected to support a traditional QDP package. For all other stack configurations, such as a 4H or 8H, it is assumed to be a single-load (master/slave) type of configuration where C0, C1, and C2 are used as chip ID selects in conjunction with a single CS_n, CKE, and ODT signal. Clock: Differential clock inputs. All address, command, and control input signals are sampled on the crossing of the positive edge of CK_t and the negative edge of CK_c. Clock enable: CKE HIGH activates and CKE LOW deactivates the internal clock signals, device input buffers, and output drivers. Taking CKE LOW provides PRECHARGE POWERDOWN and SELF REFRESH operations (all banks idle), or active power-down (row active in any bank). CKE is asynchronous for self refresh exit. After VREFCA has become stable during the power-on and initialization sequence, it must be maintained during all operations (including SELF REFRESH). CKE must be maintained HIGH throughout read and write accesses. Input buffers (excluding CK_t, CK_c, ODT, RESET_n, and CKE) are disabled during power-down. Input buffers (excluding CKE and RESET_n) are disabled during self refresh. Input 18 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM Ball Descriptions Table 3: Ball Descriptions Symbol Type Description CS_n Input DM_n, UDM_n LDM_n Input ODT Input PAR Input RAS_n/A16, CAS_n/A15, WE_n/A14 RESET_n Input Chip select: All commands are masked when CS_n is registered HIGH. CS_n provides for external rank selection on systems with multiple ranks. CS_n is considered part of the command code. Input data mask: DM_n is an input mask signal for write data. Input data is masked when DM is sampled LOW coincident with that input data during a write access. DM is sampled on both edges of DQS. DM is not supported on x4 configurations. The UDM_n and LDM_n pins are used in the x16 configuration: UDM_n is associated with DQ[15:8]; LDM_n is associated with DQ[7:0]. The DM, DBI, and TDQS functions are enabled by mode register settings. See the Data Mask section. On-die termination: ODT (registered HIGH) enables termination resistance internal to the DDR4 SDRAM. When enabled, ODT (RTT) is applied only to each DQ, DQS_t, DQS_c, DM_n/ DBI_n/TDQS_t, and TDQS_c signal for the x4 and x8 configurations (when the TDQS function is enabled via mode register). For the x16 configuration, RTT is applied to each DQ, DQSU_t, DQSU_c, DQSL_t, DQSL_c, UDM_n, and LDM_n signal. The ODT pin will be ignored if the mode registers are programmed to disable RTT. Parity for command and address: This function can be enabled or disabled via the mode register. When enabled, the parity signal covers all command and address inputs, including ACT_n, RAS_n/A16, CAS_n/A15, WE_n/A14, A[17:0], A10/AP, A12/BC_n, BA[1:0], and BG[1:0] with C0, C1, and C2 on 3DS only devices. Control pins NOT covered by the parity signal are CS_n, CKE, and ODT. Unused address pins that are density- and configuration-specific should be treated internally as 0s by the DRAM parity logic. Command and address inputs will have parity check performed when commands are latched via the rising edge of CK_t and when CS_n is LOW. Command inputs: RAS_n/A16, CAS_n/A15, and WE_n/A14 (along with CS_n and ACT_n) define the command and/or address being entered. See the ACT_n description in this table. Input TEN Input DQ I/O DBI_n, UDBI_n, LDBI_n I/O DQS_t, DQS_c, DQSU_t, DQSU_c, DQSL_t, DQSL_c I/O Active LOW asynchronous reset: Reset is active when RESET_n is LOW, and inactive when RESET_n is HIGH. RESET_n must be HIGH during normal operation. RESET_n is a CMOS railto-rail signal with DC HIGH and LOW at 80% and 20% of VDD (960 mV for DC HIGH and 240 mV for DC LOW). Connectivity test mode: TEN is active when HIGH and inactive when LOW. TEN must be LOW during normal operation. TEN is a CMOS rail-to-rail signal with DC HIGH and LOW at 80% and 20% of VDD (960mV for DC HIGH and 240mV for DC LOW). Data input/output: Bidirectional data bus. DQ represents DQ[3:0], DQ[7:0], and DQ[15:0] for the x4, x8, and x16 configurations, respectively. If write CRC is enabled via mode register, the write CRC code is added at the end of data burst. Any one or all of DQ0, DQ1, DQ2, and DQ3 may be used to monitor the internal V REF level during test via mode register setting MR[4] A[4] = HIGH, training times change when enabled. During this mode, the RTT value should be set to High-Z. This measurement is for verification purposes and is NOT an external voltage supply pin. DBI input/output: Data bus inversion. DBI_n is an input/output signal used for data bus inversion in the x8 configuration. UDBI_n and LDBI_n are used in the x16 configuration; UDBI_n is associated with DQ[15:8], and LDBI_n is associated with DQ[7:0]. The DBI feature is not supported on the x4 configuration. DBI can be configured for both READ (output) and WRITE (input) operations depending on the mode register settings. The DM, DBI, and TDQS functions are enabled by mode register settings. See the Data Bus Inversion section. Data strobe: Output with READ data, input with WRITE data. Edge-aligned with READ data, centered-aligned with WRITE data. For the x16, DQSL corresponds to the data on DQ[7:0]; DQSU corresponds to the data on DQ[15:8]. For the x4 and x8 configurations, DQS corresponds to the data on DQ[3:0] and DQ[7:0], respectively. DDR4 SDRAM supports a differential data strobe only and does not support a single-ended data strobe. 19 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM Ball Descriptions Table 3: Ball Descriptions Symbol Type ALERT_n Output TDQS_t, TDQS_c VDD VDDQ VPP VREFCA VSS VSSQ ZQ RFU NC NF Description Alert output: This signal allows the DRAM to indicate to the system's memory controller that a specific alert or event has occurred. Alerts will include the command/address parity error and the CRC data error when either of these functions is enabled in the mode register. Output Termination data strobe: TDQS_t and TDQS_c are used by x8 DRAMs only. When enabled via the mode register, the DRAM will enable the same RTT termination resistance on TDQS_t and TDQS_c that is applied to DQS_t and DQS_c. When the TDQS function is disabled via the mode register, the DM/TDQS_t pin will provide the DATA MASK (DM) function, and the TDQS_c pin is not used. The TDQS function must be disabled in the mode register for both the x4 and x16 configurations. The DM function is supported only in x8 and x16 configurations. Supply Power supply: 1.2V ±0.060V. Supply DQ power supply: 1.2V ±0.060V. Supply DRAM activating power supply: 2.5V –0.125V/+0.250V. Supply Reference voltage for control, command, and address pins. Supply Ground. Supply DQ ground. Reference Reference ball for ZQ calibration: This ball is tied to an external 24 resistor (RZQ), which is tied to VSSQ. – Reserved for future use. – No connect: No internal electrical connection is present. – No function: May have internal connection present but has no function. 20 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM Package Dimensions Package Dimensions Figure 3: 78-Ball FBGA – x4, x8; “SAF” 0.155 Seating plane A 0.12 A 1.8 CTR nonconductive overmold 78X Ø0.47 Dimensions apply to solder balls postreflow on Ø0.42 SMD ball pads. Ball A1 ID (covered by SR) 9 8 7 Ball A1 ID 3 2 1 A B C D E F G H J K L M N 11 ±0.1 9.6 CTR 0.8 TYP 1.1 ±0.1 0.8 TYP 6.4 CTR 0.34 ±0.05 7.5 ±0.1 Notes: 1. All dimensions are in millimeters. 2. Solder ball material: SAC302 (Pb-free 96.5%, Sn, 3% Ag, 0.2% Cu). 21 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM Package Dimensions Figure 4: 78-Ball FBGA – x4, x8; “WEF”  3EATINGPLANE !  ! #42 NONCONDUCTIVE OVERMOLD 8Œ $IMENSIONSAPPLY TOSOLDERBALLSPOST REFLOWONŒ3-$ BALLPADS "ALL!)$ COVEREDBY32    "ALL!)$    ! " # $ % & ' ( * + , . ¢ #42 490 ¢ 490 #42 ¢ ¢ Notes: 1. All dimensions are in millimeters. 2. Solder ball material: SAC302 (Pb-free 96.5%, Sn, 3% Ag, 0.2% Cu). 22 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM Package Dimensions Figure 5: 78-Ball FBGA – x4, x8; “RHF” 0.155 Seating plane A 78X Ø0.45 Dimensions apply to solder balls postreflow on Ø0.35 SMD ball pads. 0.12 A 1.8 CTR Nonconductive overmold Ball A1 ID (covered by SR) 9 8 7 3 2 Ball A1 ID 1 A B C D E F 10.5 ±0.1 G 9.6 CTR H J K L M N 0.8 TYP 0.8 TYP 1.1 ±0.1 6.4 CTR 0.25 MIN 9 ±0.1 Notes: 1. All dimensions are in millimeters. 2. Solder ball material: SAC302 (Pb-free 96.5% Sn, 3% Ag, 0.2% Cu). 23 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM Package Dimensions Figure 6: 78-Ball FBGA – x4, x8; “GKF” 0.155 Seating plane 1.8 CTR Nonconductive overmold 78X Ø0.45 Dimensions apply to solder balls post-reflow on Ø0.35 SMD ball pads. A 0.12 A Ball A1 ID 9 8 7 Ball A1 ID 3 2 1 A B C D E F G H 11.5 ±0.1 9.6 CTR J K L M N 0.8 TYP 0.8 TYP 1.1 ±0.1 6.4 CTR 0.25 MIN 9 ±0.1 Notes: 1. All dimensions are in millimeters. 2. Solder ball material: SAC305 (Pb-free 96.5% Sn, 3% Ag, 0.5% Cu). 24 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM Package Dimensions Figure 7: 78-Ball FBGA – x4, x8; “PMF” 0.155 Seating plane A 0.12 A 1.8 CTR Nonconductive overmold 78X Ø0.47 Dimensions apply to solder balls post-reflow on Ø0.42 SMD ball pads. Ball A1 ID (covered by SR) 9 8 7 Ball A1 ID 3 2 1 A B C D E F G H J K L M N 13.2 ±0.1 9.6 CTR 0.8 TYP 1.1 ±0.1 0.8 TYP 6.4 CTR 0.28 MIN 9 ±0.1 Notes: 1. All dimensions are in millimeters. 2. Solder ball material: SAC305 (Pb-free 96.5% Sn, 3% Ag, 0.5% Cu). 25 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM Package Dimensions Figure 8: 96-Ball FBGA – x16; “HAF“ 0.155 Seating plane 0.12 A 1.8 CTR Nonconductive overmold A 96X Ø0.45 Dimensions apply to solder balls post-reflow on Ø0.35 SMD ball pads. Ball A1 ID Ball A1 ID 9 8 7 3 2 1 A B C D E F G H 12 CTR J 14 ±0.1 K L M N P R 0.8 TYP T 0.8 TYP 1.1 ±0.1 6.4 CTR 0.25 MIN 9 ±0.1 Notes: 1. All dimensions are in millimeters. 2. Solder ball material: SAC305 (Pb-free 96.5% Sn, 3% Ag, 0.5% Cu). 26 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM Package Dimensions Figure 9: 96-Ball FBGA – x16; “GEF“ 0.155 Seating plane A 0.12 A 1.8 CTR Nonconductive overmold 96X Ø0.47 Dimensions apply to solder balls postreflow on Ø0.42 SMD ball pads. Ball A1 ID (covered by SR) 9 8 7 Ball A1 ID 3 2 1 A B C D E F G H J K L M N P R T 14 ±0.1 12 CTR 0.8 TYP 1.1 ±0.1 0.8 TYP 6.4 CTR 0.29 MIN 9 ±0.1 Notes: 1. All dimensions are in millimeters. 2. Solder ball material: SAC302 (Pb-free 96.5% Sn, 3% Ag, 0.3% Cu). 27 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM Package Dimensions Figure 10: 96-Ball FBGA – x16; “DD“  3EATINGPLANE !  ! #42 .ONCONDUCTIVE OVERMOLD 8Œ $IMENSIONSAPPLY TOSOLDERBALLSPOST REFLOWONŒ 3-$BALLPADS "ALL!)$ COVEREDBY32    "ALL!)$    ! " # $ % & ' ( * + , . 0 2 4 ¢ #42 490 ¢ 490 #42 ¢ ¢ Notes: 1. All dimensions are in millimeters. 2. Solder ball material: SAC302 (Pb-free 96.5% Sn, 3% Ag, 0.2% Cu) 28 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM State Diagram State Diagram This simplified state diagram provides an overview of the possible state transitions and the commands to control them. Situations involving more than one bank, the enabling or disabling of on-die termination, and some other events are not captured in full detail. Figure 11: Simplified State Diagram IVREFDQ, RTT, and so on MPSM From any state RESET SRX* = SRX with NOP SRX* CKE_L MRS Power applied Power-On RESET MRS SRX* Reset procedure MRS, MPR, write leveling, VREFDQ training PDA mode Initialization TEN = 1 MRS MRS ZQCL SRX MRS SRE MRS Connectivity test TEN = 0 ZQ calibration Self refresh ZQCL,ZQCS REF Idle Refreshing RESET PDE ACT CKE_L CKE_L PDX Active powerdown Precharge powerdown Activating PDX PDE Bank active WRITE WRITE READ WRITE A READ Writing READ READ A WRITE Reading READ A WRITE A WRITE A READ A PRE, PREA Writing PRE, PREA PRE, PREA Precharging Reading Automatic sequence Command sequence 29 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM State Diagram Table 4: State Diagram Command Definitions Command Description ACT MPR MRS PDE PDX PRE PREA READ READ A REF RESET SRE SRX TEN WRITE WRITE A ZQCL ZQCS Active Multipurpose register Mode register set Enter power-down Exit power-down Precharge Precharge all RD, RDS4, RDS8 RDA, RDAS4, RDAS8 Refresh, fine granularity refresh Start reset procedure Self refresh entry Self refresh exit Boundary scan mode enable WR, WRS4, WRS8 with/without CRC WRA, WRAS4, WRAS8 with/without CRC ZQ calibration long ZQ calibration short Note: 1. See the Command Truth Table for more details. 30 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM Functional Description Functional Description The DDR4 SDRAM is a high-speed dynamic random-access memory internally configured as sixteen banks (4 bank groups with 4 banks for each bank group) for x4/x8 devices, and as eight banks for each bank group (2 bank groups with 4 banks each) for x16 devices. The device uses double data rate (DDR) architecture to achieve high-speed operation. DDR4 architecture is essentially an 8n-prefetch architecture with an interface designed to transfer two data words per clock cycle at the I/O pins. A single read or write access for a device module effectively consists of a single 8n-bit-wide, four-clock-cycledata transfer at the internal DRAM core and eight corresponding n-bit-wide, one-halfclock-cycle data transfers at the I/O pins. Read and write accesses to the device are burst-oriented. Accesses start at a selected location and continue for a burst length of eight or a chopped burst of four in a programmed sequence. Operation begins with the registration of an ACTIVE command, which is then followed by a READ or WRITE command. The address bits registered coincident with the ACTIVE command are used to select the bank and row to be accessed (BG[1:0] select the bank group for x4/x8, and BG0 selects the bank group for x16; BA[1:0] select the bank, and A[17:0] select the row. See the Addressing section for more details). The address bits registered coincident with the READ or WRITE command are used to select the starting column location for the burst operation, determine if the auto PRECHARGE command is to be issued (via A10), and select BC4 or BL8 mode on-the-fly (OTF) (via A12) if enabled in the mode register. Prior to normal operation, the device must be powered up and initialized in a predefined manner. The following sections provide detailed information covering device reset and initialization, register definition, command descriptions, and device operation. NOTE: The use of the NOP command is allowed only when exiting maximum power saving mode or when entering gear-down mode. 31 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM RESET and Initialization Procedure RESET and Initialization Procedure To ensure proper device function, the power-up and reset initialization default values for the following mode register (MR) settings are defined as: • • • • • Gear-down mode (MR3 A[3]): 0 = 1/2 rate Per-DRAM addressability (MR3 A[4]): 0 = disable Maximum power-saving mode (MR4 A[1]): 0 = disable CS to command/address latency (MR4 A[8:6]): 000 = disable CA parity latency mode (MR5 A[2:0]): 000 = disable Power-Up and Initialization Sequence The following sequence is required for power-up and initialization: 1. Apply power (RESET_n is to be maintained below 0.2 × VDD; all other inputs may be undefined). RESET_n needs to be maintained for minimum tPW_RESET_L with stable power. CKE is pulled LOW anytime before RESET_n is being de-asserted (minimum time of 10ns). The power voltage ramp time between 300mV to VDD,min must be no greater than 200ms, and, during the ramp, VDD must be greater than or equal to VDDQ and (VDD - VDDQ) < 0.3V. VPP must ramp at the same time or earlier than VDD, and VPP must be equal to or higher than VDD at all times. After VDD has ramped and reached the stable level, the initialization sequence must be started within 64ms. During power-up, either of the following conditions may exist and must be met: • Condition A: – Apply VPP without any slope reversal before or at the same time as VDD and VDDQ. – VDD and VDDQ are driven from a single-power converter output and apply VDD/ VDDQ without any slope reversal before or at the same time as VTT and VREFCA. – The voltage levels on all balls other than VDD, VDDQ, VSS, and VSSQ must be less than or equal to VDDQ and VDD on one side and must be greater than or equal to VSSQ and VSS on the other side. – V TT is limited to 0.76V MAX when the power ramp is complete. – VREFCA tracks VDD/2. • Condition B: – Apply VPP without any slope reversal before or at the same time as VDD. – Apply VDD without any slope reversal before or at the same time as VDDQ. – Apply VDDQ without any slope reversal before or at the same time as VTT and VREFCA. – The voltage levels on all pins other than VPP, VDD, VDDQ, VSS, and VSSQ must be less than or equal to VDDQ and VDD on one side and must be larger than or equal to VSSQ and VSS on the other side. 2. After RESET_n is de-asserted, wait for another 500µs until CKE becomes active. During this time, the device will start internal state initialization; this will be done independently of external clocks. A reasonable attempt was made in the design to power up with the following default MR settings: gear-down mode (MR3 A[3]): 0 = 1/2 rate; per-DRAM addressability (MR3 A[4]): 0 = disable; maximum power-down (MR4 A[1]): 0 = disable; CS to command/address latency (MR4 A[8:6]): 000 = disable; CA parity latency mode (MR5 A[2:0]): 000 = disable. However, it should be assumed that at power up the MR settings are undefined and should be programmed as shown below. 3. Clocks (CK_t, CK_c) need to be started and stabilized for at least 10ns or 5 tCK (whichever is larger) before CKE goes active. Because CKE is a synchronous signal, the corresponding setup time to clock (tIS) must be met. Also, a DESELECT command must be 32 Preliminary 4Gb: x4, x8, x16 DDR4 SDRAM RESET and Initialization Procedure 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. registered (with tIS setup time to clock) at clock edge Td. After the CKE is registered HIGH after RESET, CKE needs to be continuously registered HIGH until the initialization sequence is finished, including expiration of tDLLK and tZQ INIT. The device keeps its ODT in High-Z state as long as RESET_n is asserted. Further, the SDRAM keeps its ODT in High-Z state after RESET_n de-assertion until CKE is registered HIGH. The ODT input signal may be in an undefined state until tIS before CKE is registered HIGH. When CKE is registered HIGH, the ODT input signal may be statically held either LOW or HIGH. If RTT(NOM) is to be enabled in MR1, the ODT input signal must be statically held LOW. In all cases, the ODT input signal remains static until the power-up initialization sequence is finished, including the expiration of tDLLK and tZQ INIT. After CKE is registered HIGH, wait a minimum of RESET CKE EXIT time, tXPR, before issuing the first MRS command to load mode register (tXPR = MAX (tXS; 5 x tCK). Issue MRS command to load MR3 with all application settings, wait tMRD. Issue MRS command to load MR6 with all application settings, wait tMRD. Issue MRS command to load MR5 with all application settings, wait tMRD. Issue MRS command to load MR4 with all application settings, wait tMRD. Issue MRS command to load MR2 with all application settings, wait tMRD. Issue MRS command to load MR1 with all application settings, wait tMRD. Issue MRS command to load MR0 with all application settings, wait tMRD. Issue a ZQCL command to start ZQ calibration. Wait for tDLLK and tZQINIT to complete. The device will be ready for normal operation. 33
RS256M16ZADD-75DT 价格&库存
很抱歉,暂时无法提供与“RS256M16ZADD-75DT”相匹配的价格&库存,您可以联系我们找货
