SCW2520F330KTT
SCW2520F330KTT
    SUNLTECH(顺磁)
    SMD,2.92x2.7x2.23mm
    33UH ±10%
SCW2520F330KTT 数据手册
SCW2520F330KTT SHAPE & DIMENSION (UNIT:mm) CODE DIMENSION L W T E F D 2.92MAX 2.70MAX 2.23MAX 1.02Typ. 2.54Typ. 1.27Typ. Marking Code: PAD LAYOUT(MM): Size: Color: typeface: ELECREICAL SCHEMATIC: ELECREICAL SPECIFICATION MEAS. SPEC. ITEM CONDITIONS TEST FREQ. L 33 Q 10 DCR 7.0 Ω Max Ta=25℃ 502BC Isat 200 mA Max △≦40℃ VR116+VR7210 SRF 12 MHz Min E5071C ENA µH ± 10% Min 2.50MHz/0.5V Ta=25℃,Idc=0A HP4286A 2.50MHz/0.5V HP4286A GENERAL SPECIFICATION Electrical specifications : at 25℃ Operation Temperature: -40~+125℃ Storage Temperature: -40~+125℃ Rev.01 P age 1 of 5 www. sunltech.com SCW2520F330KTT Reliability Test No. 1 2 3 4 Item Temperature Shock. Humidity Resistance. High Temperature Resistance. Low Temperature Resistance. Specification Appearance: No damage. Temperature: -25±2℃~+105±2℃ Kept for 30 minutes. Inductance: within ±10% of Transition time : 5 minutes. initial. 100 Cycles. Appearance: No damage. Temperature: 40±2℃. Inductance: within ±10% of Relative Humidity: 90%. initial. Duration: 500 +4/-0 hours. Appearance: No damage. Inductance: within ±10% of initial. Appearance: No damage. Inductance: within ±10% of initial. Appearance: No damage. 5 Vibration test. Inductance: within ±10% of initial. Solderability Heat test. Inductance: within ±10% of initial. 7 Solderability test. Temperature: 105±2℃. Duration: 1000 +4/-0 hours. Temperature: -25±2℃. Duration: 1000 +4/-0 hours. Oscillation Frequency: 10Hz to 55Hz to 10Hz in 60 seconds as a period. Total amplitude: 1.5mm. Testing Time: a period of 2 hours in each 3 mutually perpendicular directions (total of 6 hours). Appearance: No damage. 6 Test Method 90% or more of electrode area shall be coated by new solder. Solder temperature: 260 +0/-5℃. Duration: 5 sec. Allowed reflow time: 2 times. Preheating: 160℃,60sec. Solder temperature: 245±5℃. Duration : 5 sec. Flexure: 2mm. 8 Flexure Strength. No visible mechanical damage. Pressurizing Speed: 0.5mm/sec. Keep time: 30±1sec. Force: 0.45Kg for 0603 series. Force: 0.9Kg for 0805 9 Terminal Strength. No visible mechanical damage. series. Force: 1.8Kg for 1008 series above. Keep time: 5 sec,X,Y directs. Rev.01 P age 2 of 5 www. sunltech.com SCW2520F330KTT SOLDERING CONDITIONS Rev.01 P age 3 of 5 www. sunltech.com SCW2520F330KTT TEST DATA FOR PREPRODUCTION SAMPLE TEST RESOLUTION MEAS. L D.C.R ITEM uH Ω 33 7.0 SPEC. DIMENSION (Unit:mm) Q Max W T mm mm mm 2.92MAX 2.70Max 2.23Max 10 ± 10% L Min TEST 2.5MHz/ FREQ. 0.5V 1 32.95 5.97 13.0 2.83 2.44 2.04 2 33.11 5.96 12.0 2.83 2.45 2.03 3 32.99 5.98 13.0 2.82 2.44 2.05 4 33.10 5.99 14.0 2.83 2.43 2.04 5 33.13 5.97 14.0 2.81 2.43 2.03 6 33.12 5.96 14.0 2.83 2.44 2.04 7 33.16 5.97 13.0 2.81 2.43 2.05 8 33.16 5.97 13.0 2.82 2.44 2.05 9 32.96 5.97 12.0 2.82 2.43 2.04 10 32.89 5.99 13.0 2.82 2.45 2.05 AVG. 33.06 5.97 13.10 2.82 2.44 2.04 R 0.27 0.03 2.00 0.02 0.02 0.02 Rev.01 at 25℃ 2.5MHz/ 0.5V P age 4 of 5 www. sunltech.com SCW2520F330KTT PACKAGING PACKAGING QUANTITY Rev.01 2000PCS/RELL P age 5 of 5 www. sunltech.com
SCW2520F330KTT 价格&库存
很抱歉,暂时无法提供与“SCW2520F330KTT”相匹配的价格&库存,您可以联系我们找货
SCW2520F330KTT
    • 10+0.10211
    • 100+0.08483
    • 300+0.07619
    • 2000+0.06005
    • 4000+0.05487
    • 10000+0.05228
    库存:3673
