19S104-40ML5
19S104-40ML5
    ROSENBERGER
    SMP
19S104-40ML5 数据手册
Technical Data Sheet RF_35/09.14/6.2 Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG SMP Straight Plug PCB Limited Detent 19S104-40ML5 All dimensions are in mm; tolerances according to ISO 2768 m-H Interface According to MIL-STD-348 Documents PCB layout Tape & reel packaging B 126 VG24.01M00 Material and plating Connector parts Center contact Outer contact Dielectric Material Brass Brass LCP Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Plating AuroDur®, gold plated AuroDur®, gold plated Tel. : +49 8684 18-0 Email : info@rosenberger.de Page 1/2 Technical Data Sheet SMP Straight Plug PCB Limited Detent 19S104-40ML5 Electrical data 50  DC to 26.5 GHz  26 dB, DC to 6 GHz  20 dB, 6 to 12 GHz  0.05 x f(GHz) dB, DC to 12 GHz  5 G  6.0 m  2.0 m 500 V rms 335 V rms 1.2A DC max. RF_35/09.14/6.2 Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG Impedance Frequency Return loss Insertion loss Insulation resistance Center contact resistance Outer contact resistance Test voltage Working voltage Contact Current - VSWR in application depends decisive on PCB layout - Mechanical data  500 7N Mating cycles Center contact captivation Engagement force - limited detent Disengagement force - limited detent 45 N max. 9 N min. Environmental data Temperature range Thermal shock Vibration Shock Moisture resistance Max. soldering temperature RoHS -65°C to +155°C MIL-STD-202, Method 107, Condition B MIL-STD-202, Method 204, Condition B MIL-STD-202, Method 213, Condition A MIL-STD-202, Method 106 IEC 61760-1, +260°C for 10 sec. compliant Tooling N/A Suitable cables N/A Weight Weight 0.29 g/pce While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our products, we reserve the right to make changes judged to be necessary. For the installation of the electrotechnical equipment, particular electrotechnical expertise is required. Draft Date Approved Date Rev. Engineering change number Name Date Inge Mühlauer 17.08.04 Chr. Janßen 27.10.20 h00 20-1927 S. Huber-Siegl 27.10.20 Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Tel. : +49 8684 18-0 Email : info@rosenberger.de Page 2/2
19S104-40ML5 价格&库存
很抱歉,暂时无法提供与“19S104-40ML5”相匹配的价格&库存,您可以联系我们找货
