CMCW2012F6R8KTT
承 认 书
SPECIFICATION FOR APPROVAL
CUSTOMER:
CUSTOMER P/N:
Cybermax P/N:
CMCW2012F6R8KTT
DRAWN NO.:
CM210225001C192
DATE:
21.02.25
REVISION NO. A
Signature:
APPROVED BY
Rev.01
CHECKED BY
DRAWN BY
黄
谢
申
21.02.25
21.02.25
21.02.25
大燕
焕飞
双凤
Page 1 of 9
www.cybermaxtech.com
CMCW2012F6R8KTT
Chang Item
DATE
Rev.01
Page 2 of 9
CMCW2012F6R8KTT
CUSTOMER:
CUSTOMER P/N:
Cybermax P/N:
DRAWN NO.:
CMCW2012F6R8KTT
CM210225001C192
PAGE:
REVISION:
DATE:
1/7
21.02.25
SHAPE & DIMENSION (UNIT:mm)
L
W
T
E
D
F
Marking Code:
PAD LAYOUT(MM):
Size:
2.29MAX
1.73MAX
1.52MAX
1.02Typ.
0.76Typ.
1.78Typ.
Color:
typeface:
ELECREICAL SCHEMATIC:
ELECREICAL SPECIFICATION
MEAS.
SPEC.
ITEM
CONDITIONS
TEST FREQ.
L
6.8
µH
Q
14
Typ
DCR
0.88
Ω
MAX
Isat
420
mA
MAX
7.9MHz/0.5V
△L/L≤30%
Irms
420
mA
MAX
7.9MHz/0.5V
△≦40℃
SRF
35
MHz
Typ
10%
7.9MHz/0.5V
Ta=25℃,Idc=0A
7.9MHz/0.5V
Ta=25℃
GENERAL SPECIFICATION
Electrical specifications :
Operation Temperature:
Storage Temperature:
Rev.01
at 25℃
-40~+125℃
-40~+125℃
Page 3 of 9
CMCW2012F6R8KTT
CUSTOMER:
CUSTOMER P/N:
Cybermax P/N:
DRAWN NO.:
CMCW2012F6R8KTT
CM210225001C192
PAGE:
REVISION:
DATE:
2/7
21.02.25
Reliability Test
No.
1
2
3
4
Item
Temperature Shock.
Humidity Resistance.
High Temperature
Resistance.
Low Temperature
Resistance.
Specification
Appearance: No damage.
Temperature: -25±2℃~+105±2℃ Kept for 30 minutes.
Inductance: within ±10% of
Transition time : 5 minutes.
initial.
100 Cycles.
Temperature: 40±2℃.
Relative Humidity: 90%.
initial.
Duration: 500 +4/-0 hours.
initial.
initial.
5
Vibration test.
initial.
Solderability Heat test. Inductance: within ±10% of
initial.
7
Solderability test.
Temperature: 105±2℃.
Duration: 1000 +4/-0 hours.
Temperature: -25±2℃.
Oscillation Frequency: 10Hz to 55Hz to 10Hz in 60 seconds
as a period. Total amplitude: 1.5mm.
Testing Time: a period of 2 hours in each 3 mutually
perpendicular directions (total of 6 hours).
6
Test Method
90% or more of electrode area
shall be coated by new solder.
Solder temperature: 260 +0/-5℃. Duration: 5 sec.
Allowed reflow time: 2 times.
Preheating: 160℃,60sec.
Solder temperature: 245±5℃.
Duration : 5 sec.
Flexure: 2mm.
8
Flexure Strength.
No visible mechanical damage. Pressurizing Speed: 0.5mm/sec.
Keep time: 30±1sec.
Force: 0.45Kg for 0603 series. Force: 0.9Kg for 0805
9
Terminal Strength.
No visible mechanical damage. series. Force: 1.8Kg for 1008 series above.
Keep time: 5 sec,X,Y directs.
Rev.01
Page 4 of 9
CMCW2012F6R8KTT
CUSTOMER:
CUSTOMER P/N:
Cybermax P/N:
DRAWN NO.:
Rev.01
CMCW2012F6R8KTT
CM210225001C192
Page 5 of 9
PAGE:
REVISION:
DATE:
3/7
21.02.25
CMCW2012F6R8KTT
CUSTOMER:
CUSTOMER P/N:
Cybermax P/N:
DRAWN NO.:
CMCW2012F6R8KTT
CM210225001C192
PAGE:
REVISION:
DATE:
4/7
21.02.25
B.O.M
项目名称
磁芯(DRUM CORE)
线材(WIRE)
胶水(GLUE)
Rev.01
型号及规格
MF401SWI2012C075-LS
P180G1
UW-523
Page 6 of 9
制造商
台湾佳叶/台湾光绅
益利素勒
贺盛
环保要求
RoHS
RoHS
RoHS
备注
主选
主选
灌封
CMCW2012F6R8KTT
CUSTOMER:
CUSTOMER P/N:
Cybermax P/N:
DRAWN NO.:
PAGE:
REVISION:
DATE:
CMCW2012F6R8KTT
CM210225001C192
5/7
21.02.25
TEST DATA FOR PREPRODUCTION SAMPLE
TEST RESOLUTION
MEAS.
L
D.C.R
ITEM
µH
Ω
6.8
0.88
SPEC.
DIMENSION (Unit:mm)
Q
长
宽
高
mm
mm
mm
2.29MAX
1.73MAX
1.52MAX
14
10%
MAX
TYP
7.9MHz/0.5V
At 25℃
7.9MHz/0.5V
1
6.83
0.650
15.0
2.16
1.52
1.22
2
6.79
0.650
15.0
2.14
1.50
1.20
3
6.78
0.650
14.0
2.14
1.50
1.21
4
6.77
0.660
14.0
2.16
1.51
1.22
5
6.82
0.670
15.0
2.15
1.52
1.22
6
6.84
0.650
14.0
2.16
1.52
1.21
7
6.86
0.660
15.0
2.14
1.51
1.20
8
6.86
0.670
14.0
2.15
1.51
1.22
9
6.81
0.670
15.0
2.16
1.50
1.21
10
6.83
0.650
18.0
2.15
1.51
1.20
AVG.
6.82
0.658
14.90
2.15
1.51
1.21
R
0.09
0.020
4.00
0.02
0.02
0.02
TEST
FREQ.
APPROVED BY
CHECKED BY
黄
21.02.25
大燕
Rev.01
Page 7 of 9
DRAWN BY
谢
21.02.25
申
21.02.25
焕飞
双凤
CMCW2012F6R8KTT
CUSTOMER:
CUSTOMER P/N:
Cybermax P/N:
DRAWN NO.:
CMCW2012F6R8KTT
CM210225001C192
PAGE:
REVISION:
DATE:
6/7
21.02.25
PACKAGING
Rev.01
Page 8 of 9
CMCW2012F6R8KTT
CUSTOMER:
CUSTOMER P/N:
Cybermax P/N:
DRAWN NO.:
PAGE:
REVISION:
DATE:
CMCW2012F6R8KTT
CM210225001C192
7/7
21.02.25
PACKAGING
1.1 外箱: 39*38*18.5 cm 一箱裝 8 內箱
1.2 內箱: 18.7*18.4*8.3 cm 一箱装 5 卷制品
1.3 外箱材質: A 三 A
1.4 內箱材質: A=A
1.5 每 5 卷制品用一只静电袋包裝
1.6 每一静电袋內放一只袋干燥剂
1.7 每一卷上面依标签样式的要求贴上标签明细
1.8 出货內外箱贴上该箱內实际內容明细
1.9 出货标签规格如下: 尺寸=长度:39mm
宽度:29mm
(如: 客戶有特殊要求時, 則依客戶要求實施.)
备注:如果捆包数量小于内箱捆包数量时就用内箱包装
Rev.01
Page 9 of 9
很抱歉,暂时无法提供与“CMCW2012F6R8KTT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.39593
- 100+0.31536
- 300+0.27508
- 2000+0.22238
- 4000+0.19818
- 10000+0.18620
