KH-2PH90-2X2P-L10.5
KH-2PH90-2X2P-L10.5
    KINGHELM(金航标)
    弯插,P=2mm
    排针 间距:2mm 2x2P 弯插
KH-2PH90-2X2P-L10.5 数据手册
SPECIFICATIONS Current Rating: 1.5 Amps Insulation Resistance:1000MΩ Min Contact Resistance: 20mΩ Max Withstanding Voltage: AC 500V Operation Temperature:-40°to+105° Contact Material: Brass Standard: PBT Insrlator Material: Polyester(UL 94V-0) Contact Plating: Gold Flash Max.Processing Temp: 200°C for30-60seconds (220°C for5seconds) RECOMMEND P.C.B LAYOUT PCB TOLERANCE:±0.05 (TOP VIEW) (1) (2) (3) (4) (5) (6) (7) (8) (9) Pin Spacing:200=2.0mm Product Name:PH=Pin Header No.of Rows:1=Single Row; 2=Dual Row No.of Pins Per Row:1~40 Insulator Material Height: 15=1.5mm; 20=2.0mm Connector Type:S=Straight; R=Right; Angle M=SMT Contact Material Length: 87=8.7mm 105=10.5mm No.of Insulator Material: 1=1PCS; 2=2PCS; 3=3PCS Contact Plating: SN=Tin;G0=Gold Flash;S0=Gold Flash/Tin;AU08=Au 0.8u" (10)Insulator Material Option: A=BK-PBT;B=BK-PA6T;C=BK-PA46;D=KB-LCP;S=Special 0755-83044319 KH-2PH90-2X2P-L10.5 UNLESS OTHEWIXE SPECIFIED TOLERANCE X :±0.3 X.X :±0.2 X.XX:±0.1 X° :±5° X.X° :±1° X.XX°:±0.5° CHECKED: LI BEI LIN 12/03/07 DRAWM NAME: SIZE REV A4 A CHECKED: No. of DIM.A WWW.BDS666.COM 深圳市金航标电子有限公司 2.0PH 2xnPin H2.0 90 ° L10.5/14.5 SCALE PROUCT NO. UNIT PROJECT / / APPROVED: PAGE 1/1 / / DIM.B No. of DIM.A DIM.B No. of DIM.A DIM.B No. of DIM.A DIM.B
KH-2PH90-2X2P-L10.5 价格&库存
很抱歉,暂时无法提供与“KH-2PH90-2X2P-L10.5”相匹配的价格&库存,您可以联系我们找货
KH-2PH90-2X2P-L10.5
  • 10+0.33912
  • 100+0.27173
  • 500+0.22065
  • 1000+0.19538
  • 5000+0.17518
  • 10000+0.16503
库存:10
