SCGB-5
SCGB-5
    WAKEFIELD-VETTE
    SCGB-5
SCGB-5 数据手册
Grounding Bus Bars and Kits SCGB & SCGBK Series Wakefield Vette offers the SCGB/SCGBK series of standard off the shelf grounding busbar and kits for various applications. These are variations of UL Listed ground bar kits of different bar sizes, hole sizes, and lug configurations in addition to the many standard kits in stock. Wakefield-Vette can fully customize an order to serve any application, whether it be custom hole patterns for a unique lug shape, an irregular bar size, plating, etc. The mounting brackets that are used are stainless steel, which significantly increases the part’s useful life. The use of stainless steel also protects the brackets from corrosion. Part Number Configurator: SeriesSCGB- Ground Bar SCGB-XKT- Ground Bar Kit SCGB- Ground Bar Part Number1-12 FinishB-Bare T-Tin N-Nickel S-Silver SCGBKT- Ground Bar Kit Grounding Bus Bars and Kits Summary Of Standard Offerings w/ 6 taps Grounding Bus Bars and Kits * Note plating option is bare on these specifications. SCGB-1 • • • • • • • • • • • SCGB-1KT • • • • • • • • • • • • • • • • • • Weight: 1.61lb Length: 10" Width: 2" Thickness: .25" Edge: Square Edge - Deburred Shape: Rectangle Material: Copper Sheet/Plate C110 H02 (Half Hard) Temper Amps: Meets requirements for an ampacity range of 550 to 599, for 60 Hz current Plating: Tin, Nickel and Silver Available Part Type: Grounding bus bar UL Certification: UL GROUNDING and BONDING EQUIPMENT - USA KDER.E326023 Weight: 2.7lb Length: 10" Width: 2" Height: 4" Thickness: .25" Edge: Square Edge - Deburred Shape: Rectangle Material: Copper Sheet/Plate C110 H02 (Half Hard) Temper Plating: Tin, Nickel and Silver Available Part Type: Grounding bus bar Brand: Storm Power Components UL Certification: UL GROUNDING and BONDING EQUIPMENT - USA KDER.E326023; CANADA KDER7.E326023 Kit Includes: (1) Tin Plated Copper bar (SCGB-1) (2) UL Recognized Polyester Standoff Insulators (3) Stainless Steel Mounting Brackets (4) 3/8" Stainless Steel Bolts (5) 3/8" Stainless Steel Lock Washers Grounding Bus Bars and Kits * Note plating option is bare on these specifications. SCGB-2 SCGB-2KT • • • • • • • • • • Weight: 3.87lb Length: 24" Width: 2" Thickness: .25" Edge: Square Edge - Deburred Shape: Rectangle Material: Copper Sheet/Plate C110 H02 (Hard) Temper Plating: Tin, Nickel and Silver Available Part Type: Grounding bus bar UL Certification: UL GROUNDING and BONDING EQUIPMENT - USA KDER.E326023; ISO 9001-2008 • • • • • • • • Weight: 6lb Length: 24" Width: 2" Height: 4" Thickness: .25" Edge: Square Edge - Deburred Shape: Rectangle Material: Copper Sheet/Plate C110 H02 (Half Hard) Temper • Plating: Tin, Nickel and Silver Available • Part Type: Grounding bus bar • UL Certification: UL GROUNDING and BONDING EQUIPMENT - USA KDER.E326023; CANADA KDER7.E326023; ISO 9001-2015 Kit Includes: (1) Copper bar (SCGB-2) (2) UL Recognized Polyester Standoff Insulators (3) (2) Stainless Steel Mounting Brackets (4) (4) 3/8" Stainless Steel Bolts (5) (4) 3/8" Stainless Steel Lock Washers Grounding Bus Bars and Kits * Note plating option is bare on these specifications. SCGB-3 • • • • • • • • • • SCGB-3KT • • • • • • • • • • • • • • • • • Weight: 3.22lb Length: 10" Width: 4" Thickness: .25" Edge: Square Edge - Deburred Shape: Rectangle Material: Copper Sheet/Plate C110 H02 ( Half Hard) Temper Plating: Tin, Nickel and Silver Available Part Type: Grounding bus bar UL Certification: UL GROUNDING and BONDING EQUIPMENT - USA KDER.E326023 Weight: 4.48lb Length: 10" Width: 4" Height: 4" Thickness: .25" Edge: Square Edge - Deburred Shape: Rectangle Material: Copper Sheet/Plate C110 H02 (Hard) Temper Plating: Tin, Nickel and Silver Available Part Type: Grounding bus bar UL Certification: UL GROUNDING and BONDING EQUIPMENT - USA KDER.E326023; CANADA KDER7.E326023; ISO 9001-2008 Kit Includes: Copper bar (SCGB-3) UL Recognized Polyester Standoff Insulators Stainless Steel Mounting Brackets 3/8" Stainless Steel Bolts 3/8" Stainless Steel Lock Washers Grounding Bus Bars and Kits * Note plating option is bare on these specifications. SCGB-4 • • • • • • • • Weight: 3.22lb Length: 10" Width: 4" Height: 0.25" Thickness: .25" Edge: Square Edge - Deburred Shape: Rectangle Material: Copper Sheet/Plate C110 H02 (Half Hard) Temper • Plating: Tin, Nickel and Silver Available • Part Type: Grounding bus bar • UL Certification: UL GROUNDING and BONDING EQUIPMENT - USA KDER.E326023; ISO 9001-2008 SCGB-KT4 • • • • • • • • • • • • • • • • • Weight: 6.89lb Length: 10" Width: 4" Height: 4" Thickness: .25" Edge: Square Edge - Deburred Shape: Rectangle Material: Copper Sheet/Plate C110 H02 (Half Hard) Temper Plating: Tin, Nickel and Silver Available Part Type: Grounding bus bar UL Certification: UL GROUNDING and BONDING EQUIPMENT - USA KDER.E326023; ISO 9001-2008 Kit Includes: Copper bar (SCGB-4) UL Recognized Polyester Standoff Insulators Stainless Steel Mounting Brackets 3/8" Stainless Steel Bolts 3/8" Stainless Steel Lock Washers Grounding Bus Bars and Kits * Note plating option is bare on these specifications. SCGB-5 • • • • • • • Weight: 3.88lb Length: 12" Width: 4" Thickness: .25" Edge: Square Edge - Deburred Shape: Rectangle Material: Copper Sheet/Plate C110 H02 (Half Hard) Temper • Plating: Tin, Nickel and Silver Available • Part Type: Grounding bus bar • UL Certification: UL GROUNDING and BONDING EQUIPMENT - USA KDER.E326023; ISO 9001-2008 SCGB-5KT • • • • • • • • • • • • • • • • • Weight: 5.15lb Length: 12" Width: 4" Height: 4" Thickness: .25" Edge: Square Edge - Deburred Shape: Rectangle Material: Copper Sheet/Plate C110 H02 (Half Hard) Temper Plating: Tin, Nickel and Silver Available Part Type: Grounding bus bar UL Certification: UL GROUNDING and BONDING EQUIPMENT - USA KDER.E326023; ISO 9001-2008 Kit Includes: Copper bar (SCGB-5) UL Recognized Polyester Standoff Insulators Stainless Steel Mounting Brackets 3/8" Stainless Steel Bolts 3/8" Stainless Steel Lock Washers Grounding Bus Bars and Kits * Note plating option is bare on these specifications. SCGB-6 • • • • • • • • • • Weight: 3.88lb Length: 12" Width: 4" Thickness: .25" Edge: Square Edge - Deburred Shape: Rectangle Material: Copper Sheet/Plate C110 H02 (Half Hard) Temper Plating: Tin, Nickel and Silver Available Part Type: Grounding bus bar UL Certification: UL GROUNDING and BONDING EQUIPMENT - USA KDER.E326023; ISO 9001-2008 SCGB-6KT • • • • • • • • • • • • • • • • • • Weight: 5.15lb Length: 12" Width: 4" Height: 4" Thickness: .25" Edge: Square Edge - Deburred Shape: Rectangle Material: Copper Sheet/Plate C110 H02 (Half Hard) Temper Plating: Tin, Nickel and Silver Available Part Type: Grounding bus bar UL Certification: UL GROUNDING and BONDING EQUIPMENT - USA KDER.E326023; ISO 9001-2008 Pattern Type: WX2500412 Kit Includes: Copper bar (SCGB-6) UL Recognized Polyester Standoff Insulators Stainless Steel Mounting Brackets 3/8" Stainless Steel Bolts 3/8" Stainless Steel Lock Washers Grounding Bus Bars and Kits * Note plating option is bare on these specifications. SCGB-7 • • • • • • • Weight: 5.15lb Length: 16" Width: 4" Thickness: .25" Edge: Square Edge - Deburred Shape: Rectangle Material: Copper Sheet/Plate C110 H02 (Half Hard) Temper • Plating: Tin, Nickel and Silver Available • Part Type: Grounding bus bar • UL Certification: UL GROUNDING and BONDING EQUIPMENT - USA KDER.E326023; ISO 9001-2008 SCGB-7KT • • • • • • • • • • • • • • • • • • Weight: 6.75lb Length: 16" Width: 4" Height: 4" Thickness: .25" Edge: Square Edge - Deburred Shape: Rectangle Material: Copper Sheet/Plate C110 H02 (Half Hard) Temper Amps: Meets requirements for an ampacity up to 1250 amps with 60 Hertz Plating: Tin, Nickel and Silver Available Part Type: Grounding bus bar UL Certification: UL GROUNDING and BONDING EQUIPMENT - USA KDER.E326023 Kit Includes: Copper bar (SCGB-7) UL Recognized Polyester Standoff Insulators Stainless Steel Mounting Brackets 5/8" Stainless Steel Bolts 5/8" Stainless Steel Lock Washers Grounding Bus Bars and Kits * Note plating option is bare on these specifications. SCGB-8 • • • • • • • • • • • Weight: 5.15lb Length: 16" Width: 4" Thickness: .25" Edge: Square Edge - Deburred Shape: Rectangle Material: Copper Sheet/Plate C110 H02 (Half Hard) Temper Amps: 1250 Amps using 60 Hz Plating: Tin, Nickel and Silver Available Part Type: Grounding bus bar UL Certification: UL GROUNDING and BONDING EQUIPMENT - USA KDER.E326023; ISO 9001-2008 SCGB-8KT • • • • • • • • • • • • • • • • • Weight: 6.75lb Length: 16" Width: 4" Height: 4" Thickness: .25" Edge: Square Edge - Deburred Shape: Rectangle Material: Copper Sheet/Plate C110 H02 (Half Hard) Temper Plating: Tin, Nickel and Silver Available Part Type: Grounding bus bar UL Certification: UL GROUNDING and BONDING EQUIPMENT - USA KDER.E326023; ISO 9001-2008 Kit Includes: Copper bar (SCGB-8) UL Recognized Polyester Standoff Insulators Stainless Steel Mounting Brackets 3/8" Stainless Steel Bolts 3/8" Stainless Steel Lock Washers Grounding Bus Bars and Kits * Note plating option is bare on these specifications. • • • • • • • SCGB-9 • • • • SCGB-9KT • • • • • • • • • • • • • • • • • Weight: 6.44lb Length: 20" Width: 4" Thickness: .25" Edge: Square Edge - Deburred Shape: Rectangle Material: Copper Sheet/Plate C110 H02 (Half Hard) Temper Amps: 1250 Amps using 60 Hz Plating: Tin, Nickel and Silver Available Part Type: Grounding bus bar UL Certification: UL GROUNDING and BONDING EQUIPMENT - USA KDER.E326023; ISO 9001-2008 Weight: 8lb Length: 20" Width: 4" Height: 4" Thickness: .25" Edge: Square Edge - Deburred Shape: Rectangle Material: Copper Sheet/Plate C110 H02 (Half Hard) Temper Plating: Tin, Nickel and Silver Available Part Type: Grounding bus bar UL Certification: UL GROUNDING and BONDING EQUIPMENT - USA KDER.E326023; ISO 9001-2008 Kit Includes: Copper bar (SCGB-9) UL Recognized Polyester Standoff Insulators Stainless Steel Mounting Brackets 3/8" Stainless Steel Bolts 3/8" Stainless Steel Lock Washers (3/8 LOCK) Grounding Bus Bars and Kits * Note plating option is bare on these specifications. SCGB-10 • • • • • • • Weight: 6.44lb Length: 20" Width: 4" Thickness: .25" Edge: Square Edge - Deburred Shape: Rectangle Material: Copper Sheet/Plate C110 H02 (Half Hard) Temper • Plating: Tin, Nickel and Silver Available • Part Type: Grounding bus bar • UL Certification: UL GROUNDING and BONDING EQUIPMENT - USA KDER.E326023; ISO 9001-2008 SCGB-10KT • • • • • • • • • • • • • • • • • • Weight: 8lb Length: 20" Width: 4" Height: 4" Thickness: .25" Edge: Square Edge - Deburred Shape: Rectangle Material: Copper Sheet/Plate C110 H02 (Half Hard) Temper Plating: Tin, Nickel and Silver Available Part Type: Grounding bus bar UL Certification: UL GROUNDING and BONDING EQUIPMENT - USA KDER.E326023; ISO 9001-2008 Pattern Type: WY2500420 Kit Includes: Copper bar (SCGB-10) UL Recognized Polyester Standoff Insulators Stainless Steel Mounting Brackets 3/8" Stainless Steel Bolts 3/8" Stainless Steel Lock Washers Grounding Bus Bars and Kits * Note plating option is bare on these specifications. SCGB-11 • • • • • • • • • • • SCGB-11KT • • • • • • • • • • • • • • • • • • Weight: 6.44lb Length: 20" Width: 4" Thickness: .25" Edge: Square Edge - Deburred Shape: Rectangle Material: Copper Sheet/Plate C110 H02 (Half Hard) Temper Plating: Tin, Nickel and Silver Flash Available Part Type: Grounding bus bar Brand: Storm Power Components UL Certification: UL GROUNDING and BONDING EQUIPMENT - USA KDER.E326023; ISO 9001-2008 Weight: 8lb Length: 20" Width: 4" Height: 4" Thickness: .25" Edge: Square Edge - Deburred Shape: Rectangle Material: Copper Sheet/Plate C110 H02 (Half Hard) Temper Plating: Tin Electroplated - Full Immersion Part Type: Grounding bus bar UL Certification: UL GROUNDING and BONDING EQUIPMENT - USA KDER.E326023; ISO 9001-2008 Pattern Type: CZ2500420 Kit Includes: Tin Plated Copper bar (SCGB-11-T) UL Recognized Polyester Standoff Insulators Stainless Steel Mounting Brackets 3/8" Stainless Steel Bolts 3/8" Stainless Steel Lock Washers Grounding Bus Bars and Kits * Note plating option is bare on these specifications. SCGB-12 • • • • • • • Weight: 7.728lb Length: 24" Width: 4" Thickness: .25" Edge: Square Edge - Deburred Shape: Rectangle Material: Copper Sheet/Plate C110 H02 (Half Hard) Temper • Plating: Tin, Nickel and Silver Available • Part Type: Grounding bus bar • UL Certification: UL GROUNDING and BONDING EQUIPMENT - USA KDER.E326023; ISO 9001-2008 SCGB-12KT • • • • • • • • • • • • • • • • • • Weight: 10.25lb Length: 24" Width: 4" Height: 4" Thickness: .25" Edge: Square Edge - Deburred Shape: Rectangle Material: Copper Sheet/Plate C110 H02 (Half Hard) Temper Plating: Tin, Nickel and Silver Available Part Type: Grounding bus bar UL Certification: UL GROUNDING and BONDING EQUIPMENT - USA KDER.E326023; ISO 9001-2008 Pattern Type: CZ2500424 Kit Includes: Tin Plated Copper bar (SCGB-12) UL Recognized Polyester Standoff Insulators Stainless Steel Mounting Brackets 3/8" Stainless Steel Bolts 3/8" Stainless Steel Lock Washers
SCGB-5 价格&库存
很抱歉,暂时无法提供与“SCGB-5”相匹配的价格&库存,您可以联系我们找货
SCGB-5
    • 1+1615.445261+202.65802
    库存:4
