MTP2920-100MC
MTP2920-100MC
    COILMX(迈翔)
    SMD,28x27x21.5mm
    10UH ±20% 30A
MTP2920-100MC 数据手册
SPECIFICATION FOR APPROVAL 产品规格承认书 High Current Power Inductor 大电流功率电感 CUSTOMER. MODEL NO. MTP2920系列 CUSTOMER'S PART NO. LILE NO. DATE. 2021.06.16 REVISION. A/0 CUSTOMER APPROVE DATE: DRAWING DRAWN BY CHECK BY APPROVAL BY DATE:2021.06.16 深圳市迈翔科技有限公司 SHENZHEN MOTTO TECHNOLOGY Co., Ltd 香港瑞德科技有限公司 IATF16949 / ISO9001 / ISO14000 黄冈市迈翔电子有限公司 Motto Technology park, niu e ling village no#214 xintian,nghua Town, Guanlan Street, Longhua District,Shenzhen TEL: +86 0755-8948751~2 89487610 Fax: +86 0755-61624574 Http://www.coilmx.com E-mail: sales@mottotech.com 1/8 深圳市迈翔科技有限公司 CUSTOMER MODEL NO. FILE NO. PART NO. MTP2920系列 REVISION A/0 DATE 2021.06.16 REVISIONS REW PROJECT CHANGE DESCRIPTION Date 2/8 深圳市迈翔科技有限公司 CUSTOMER MODEL NO. FILE NO. PART NO. MTP2920系列 REVISION A/0 DATE 2021.06.16 1.PRODUCT DIMENSION UNIT:mm A 28MAX B 27MAX C 21.5MAX D 10±0.2 >组立式设计,机构坚固定。高电感值,大电流低磁损,低阻抗,寄生电容小。 >扁平线绕组,实现极低的直流电阻 。温升电流饱和电流受环境条件影响小 。 2.ELECTRICAL REQUIREMENTS Inductance(uH) 电感值±20% DCR ( mΩ)MAX Saturationcurrent(A) 饱和电流 Temperature risecurrent (A)温升电流 100KHz/0.25V AT25℃ MICROTEST 6377 100KHz/0.25V 100KHz/0.25V MTP2920-1R5MC 1.5 2.5 >100 30 MTP2920-2R2MC 2.2 2.5 >100 30 MTP2920-3R3MC 3.3 2.5 >60 30 MTP2920-4R7MC 4.7 2.5 55 30 MTP2920-6R8MC 6.8 2.5 40 30 MTP2920-100MC 10 2.5 30 30 MTP2920-150MC 15 2.5 20 30 MTP2920-220MC 22 2.5 12 30 MTP2920-270MC 27 2.5 11 30 MTP2920-330MC 33 2.5 10 30 Part NO. 型号 3.CHARACTERISTICS (1). All test data is based on 25℃ ambient. (2). DC current(A)that will cause an approximate △T40℃ (3). DC current(A)that will cause L0 to drop approximately 30%Typ (4). Operating temperature range: -40℃~+125℃ (5).The part temperature (ambient + temp rise)should not exceed 125℃ under worst case operating conditions. circuit design, component.PWB trace size and thickness,airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the den application 4.SPECIAL REQUEST (1)Lettering XXXon top of the body. 3/8 深圳市迈翔科技有限公司 CUSTOMER MODEL NO. FILE NO. PART NO. MTP2920系列 REVISION A/0 DATE 2021.06.16 5.PRODUCT IDENTIFICATION MTP 2918 ① ①、 Series name ② - XXX ③ M ④ ②、 Product dimensions ③、 Inductance ④、 Tolerance: M±20%, N±30%. 6.ELECTRICAL SCHEMATICS 7.APPLICATION (1)Low profile,high current power supplies. (2)Battery powered devices. (3)DC/DC converters in distributed power systems. (4)DC/DC converters for field programmable gate array. 8.FEATURES (1)Assemblage design, sturdy structure. (2)High inductance, high current, low magnetic loss,low ESR, small parasitic capacitance. (3)Flat wire winding, achieve a low D.C. Resistance. (4)Temperature rise current and saturation current is less influenced by environment. 9.RECOMMENDED PCB LAYOUT 4/8 深圳市迈翔科技有限公司 CUSTOMER MODEL NO. FILE NO. PART NO. MTP2920系列 REVISION A/0 DATE 2021.06.16 10.Saturation current VS temperature rise current curve I(A) 0 5 10 15 20 25 30 L(μH) 1.630 1.63 1.620 1.61 1.580 1.56 1.550 △T(℃) 0 6 13.8 21.4 26.5 30.6 32.56 5/8 深圳市迈翔科技有限公司 CUSTOMER MODEL NO. FILE NO. PART NO. MTP2920系列 REVISION A/0 DATE 2021.06.16 11.可靠性Reliability 项目Item 规格与需求 Specification and Requirement 沾锡面积不得小于 95%上锡面 可焊性 Solder a bility test 振动测试 Vibration test 冲击测试 Shock test 冷热冲击 Thermal shock Terminals area must have 95% min solder coverage 感值变化:不超过±5% 且无破裂等机械损伤产生 Inductance change: Within±5% Without mechanical damage such as break 感值变化:不超过±5% 且无破裂等机械损伤产生 Inductance change: Within±5% Without mechanical damage such as break 感值变化:不超过±5% 且无破裂等机械损伤产生 Inductance change: Within±5% Without mechanical damage such as break 测试方法Test Method 上锡升温曲线Solder heat proof: (1) 预热:160±10℃持续90s Preheating: 160±10℃ for 90 seconds (2) 恒温时段:245±5℃持续2±0.5s Retention time: 245±5℃ for 2±0.5 seconds (1) 振动频率(10Hz 55Hz 10Hz)60s为一个周期 Vibration frequency: (10Hz to 55Hz to 10Hz) in 60 seconds as a period (2) 振动时间 Vibration time: 三维正交坐标系每个方向振动 (周期) 循环2小时 Period cycled for 2 hours in each of 3 mutual perpendicular directions (3) 振幅 Amplitude: 1.5 mm Max (1) 最大振幅 Peak value: 100G (2) 脉冲波长 Duration of pulse: 11ms (3) 三维正交坐标系每个方向正负方向冲击 3次 Times in each positive and negative direction of 3 mutual perpendicular directions (1)重复以上100个循环Repeat 100 cycle as follow (-55±2℃,30±3分钟) 室温5分钟 (-55±2℃,30±3 minutes) Room temperature,5 minutes (+125±2℃,30±3分钟) 室温5分钟 (+125±2℃,30±3 minutes) Room temperature,5 minutes (2)恢复:测试于标准条件下恢复 48+4/-0小时 (参考注释1) Recovery:48+4/-0 hours of recovery under the standard condition after the test. (see Note1) 感值变化:不超过±5% 且无破裂等机械损伤产生 Inductance change: Within±5% Without mechanical damage such as break (1)环境条件:85±2℃ Environment condition : 85±2℃ 应用电流:额定电流 Applied current: Rated current (2)持续时间:1000+4/-0 小时(参考注释1) Duration:1000+4/-0 hours (see Note1) 耐湿测试 Humidity Resistance 感值变化:不超过±5% 且无破裂等机械损伤产生 Inductance change: Within±5% Without mechanical damage such as break (1)环境条件:60±2℃ Environment condition : 60±2℃ 湿度:90~95% Humidity:90~95% 应用电流:额定电流 Applied current: Rated current (2)持续时间:1000+4/-0 小时(参考注释1) Duration:1000+4/-0 hours (see Note1) 低温存放测试Low temperature life test 感值变化:不超过±5% 且无破裂等机械损伤产生 Inductance change: Within±5% Without mechanical damage such as break (1)存储温度 Store temperature -55±2℃下存放 1000+4/-0 小时 -55±2℃for total 1000+4/-0 hours 高温存放测试High temperature life test 感值变化:不超过±5% 且无破裂等机械损伤产生 Inductance change: Within±5% Without mechanical damage such as break (1)存储温度 Store temperature +125±2℃下存放 1000+4/-0 小时 +125±2℃for total 1000+4/-0 hours 耐高温测试 High temperature life test 深圳市迈翔科技有限公司 6/8 CUSTOMER MODEL NO. FILE NO. PART NO. MTP2920系列 REVISION A/0 DATE 2021.06.16 12、包装 Packaging Quantity/Bundle:320PCS Quantity/Tray:40PCS Quantity/Bundle:320PCS Quantity/Carton:280PCS 包装数量packing quantity Product Series 产品系列 Quantity/Tray 数量/盘 Quantity/Bundle 数量/捆 Quantity/Carton 数量/箱 MTP2918 40PCS 320PCS 320PCS 7/8 深圳市迈翔科技有限公司 CUSTOMER MODEL NO. FILE NO. PART NO. MTP2920系列 REVISION A/0 DATE 2021.06.16 Reflow curve ※ Reflow Profile 1. Reflow Soldering Method 2. Soldering iron method :350±5℃ Max.3 seconds. 8/8
MTP2920-100MC 价格&库存
很抱歉,暂时无法提供与“MTP2920-100MC”相匹配的价格&库存,您可以联系我们找货
MTP2920-100MC
  • 1+15.23124
  • 10+12.88872
  • 30+11.43072
  • 100+9.92412
  • 500+9.24372
  • 1000+8.95212
库存:96
