ASDM40N60KQ-R
ASDM40N60KQ-R
    ASCEND(安森德)
    TO252-2L
    ASDM40N60KQ-R
ASDM40N60KQ-R 数据手册
ASDM40N60KQ 40V N-Channel MOSFET Product Summary General Features ● High density cell design for ultra low Rdson ● Fully characterized avalanche voltage and current ● Good stability and uniformity with high EAS ● Excellent package for good heat dissipation ● Special process technology for high ESD capability V DS 40 V R DS(on),Typ@ VGS=10 V 5.8 mΩ ID 60 A Application ● Load switching ● Hard switched and high frequency circuits ● Uninterruptible power supply TO-252-2L top view Schematic diagram Absolute Maximum Ratings (TC=25℃unless otherwise noted) Symbol Limit Unit Drain-Source Voltage Parameter VDS 40 V Gate-Source Voltage VGS ±20 V ID 60 A Drain Current-Continuous Drain Current-Continuous(TC=100℃) ID (100℃) 42 A Pulsed Drain Current IDM 240 A Maximum Power Dissipation PD 65 W 0.43 W/℃ EAS 400 mJ TJ,TSTG -55 To 175 ℃ RθJC 2.3 Derating factor Single pulse avalanche energy (Note 5) Operating Junction and Storage Temperature Range Thermal Characteristic (Note 2) Thermal Resistance,Junction-to-Case NOV 2018 Version1.0 1/8 ℃/W Ascend Semicondutor Co.,Ltd ASDM40N60KQ 40V N-Channel MOSFET Electrical Characteristics (TC=25℃unless otherwise noted) Parameter Symbol Condition Min Typ Max Unit Drain-Source Breakdown Voltage BVDSS VGS=0V ID=250μA 40 - - V Zero Gate Voltage Drain Current IDSS VDS=40V,VGS=0V - - 1 μA Gate-Body Leakage Current IGSS VGS=±20V,VDS=0V - - ±100 nA Gate Threshold Voltage VGS(th) VDS=VGS,ID=250μA 1.2 1.6 2.5 V Drain-Source On-State Resistance RDS(ON) VGS=10V, ID=20A - 5.8 7.5 mΩ Drain-Source On-State Resistance RDS(ON) VGS=4.5V, ID=20A - 7.5 9.5 mΩ gFS VDS=10V,ID=20A 15 - - S - 1800 - PF - 280 - PF - 190 - PF - 6.4 - nS Off Characteristics On Characteristics (Note 3) Forward Transconductance Dynamic Characteristics (Note4) Input Capacitance Clss Output Capacitance Coss Reverse Transfer Capacitance Switching Characteristics VDS=20V,VGS=0V, F=1.0MHz Crss (Note 4) Turn-on Delay Time td(on) Turn-on Rise Time tr VDD=20V,ID=2A,RL=1Ω - 17.2 - nS td(off) VGS=10V,RG=3Ω - 29.6 - nS - 16.8 - nS - 29 nC - 4.5 nC - 6.4 nC Turn-Off Delay Time Turn-Off Fall Time tf Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd VDS=20V,ID=20A, VGS=10V Drain-Source Diode Characteristics Diode Forward Voltage (Note 3) VSD Diode Forward Current (Note 2) IS Reverse Recovery Time VGS=0V,IS=10A trr Reverse Recovery Charge Qrr Forward Turn-On Time ton - 1.2 V - - 60 A TJ = 25°C, IF = 20A - 29 - nS (Note3) - 26 - nC di/dt = 100A/μs Intrinsic turn-on time is negligible (turn-on is dominated by LS+LD) Notes: 1. Repetitive Rating: Pulse width limited by maximum junction temperature. 2. Surface Mounted on FR4 Board, t ≤ 10 sec. 3. Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤ 2%. 4. Guaranteed by design, not subject to production 5. EAS condition : Tj=25℃,VDD=20V,VG=10V,L=1mH,Rg=25Ω, NOV 2018 Version1.0 2/8 Ascend Semicondutor Co.,Ltd ASDM40N60KQ 40V N-Channel MOSFET ID- Drain Current (A) Normalized On-Resistance Typical Electrical and Thermal Characteristics (Curves) TJ-Junction Temperature(℃) Vds Drain-Source Voltage (V) Figure 4 Rdson-JunctionTemperature ID- Drain Current (A) Vgs Gate-Source Voltage (V) Figure 1 Output Characteristics Qg Gate Charge (nC) Figure 2 Transfer Characteristics Figure 5 Gate Charge Is- Reverse Drain Current (A) Rdson On-Resistance(mΩ) Vgs Gate-Source Voltage (V) ID- Drain Current (A) Vsd Source-Drain Voltage (V) Figure 3 Rdson- Drain Current NOV 2018 Version1.0 Figure 6 Source- Drain Diode Forward 3/8 Ascend Semicondutor Co.,Ltd ASDM40N60KQ C Capacitance (pF) Power Dissipation (W) 40V N-Channel MOSFET TJ-Junction Temperature (℃) Figure 7 Capacitance vs Vds Figure 9 Power De-rating ID- Drain Current (A) Vds Drain-Source Voltage (V) TJ-Junction Temperature(℃) Figure 8 Safe Operation Area Figure 10 VGS(th) vs Junction Temperature r(t),Normalized Effective Transient Thermal Impedance Vds Drain-Source Voltage (V) Square Wave Pluse Duration(sec) Figure 11 Normalized Maximum Transient Thermal Impedance NOV 2018 Version1.0 4/8 Ascend Semicondutor Co.,Ltd ASDM40N60KQ 40V N-Channel MOSFET Test circuit 1) EAS Test Circuit 2) Gate Charge Test Circuit 3) Switch Time Test Circuit NOV 2018 Version1.0 5/8 Ascend Semicondutor Co.,Ltd ASDM40N60KQ 40V N-Channel MOSFET Ordering and Marking Information Ordering Device No. Marking Package Packing Quantity ASDM40N60KQ-R 40N60 TO-252 Tape&Reel 2500/Reel MARKING PACKAGE 40N60 TO-252 NOV 2018 Version1.0 6/8 Ascend Semicondutor Co.,Ltd ASDM40N60KQ 40V N-Channel MOSFET TO-252 Package Information Symbol Dimensions In Millimeters Dimensions In Inches Min. Max. Min. Max. A 2.200 2.400 0.087 0.094 A1 0.000 0.127 0.000 0.005 b 0.660 0.860 0.026 0.034 c 0.460 0.580 0.018 0.023 D 6.500 6.700 0.256 0.264 D1 5.100 5.460 0.201 0.215 D2 4.830 TYP. 0.190 TYP. E 6.000 6.200 0.236 0.244 e 2.186 2.386 0.086 0.094 L 9.800 10.400 0.386 0.409 L1 L2 2.900 TYP. 0.114 TYP. 1.400 L3 1.700 0.055 1.600 TYP. 0.067 0.063 TYP. L4 0.600 1.000 0.024 0.039 Φ 1.100 1.300 0.043 0.051 θ 0° 8° 0° 8° h 0.000 0.300 0.000 0.012 V NOV 2018 Version1.0 5.350 TYP. 0.211 TYP. 7/8 Ascend Semicondutor Co.,Ltd ASDM40N60KQ 40V N-Channel MOSFET IMPORTANT NOTICE Xi‘an Ascend Semiconductor incorporated MAKES NO WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, WITH REGARDS TO THIS DOCUMENT, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE (AND THEIR EQUIVALENTS UNDER THE LAWS OF ANY JURISDICTION). Xi‘an Ascend Semiconductor Incorporated and its subsidiaries reserve the right to make modifications, enhancements, improvements, corrections or other changes without further notice to this document and any product described herein. Xi‘an Ascend Semiconductor Incorporated does not assume any liability arising out of the application or use of this document or any product described herein; neither does Xi‘an Ascend Semiconductor Incorporated convey any license under its patent or trademark rights, nor the rights of others. Any Customer or user of this document or products described herein in such applications shall assume . all risks of such use and will agree to hold Ascendsemi Incorporated and all the companies whose products are represented on Xi‘an Ascend Semiconductor Incorporated website, harmless against all damages. Xi‘an Ascend Semiconductor Incorporated does not warrant or accept any liability whatsoever in respect of any products purchased through unauthorized sales channel. Should Customers purchase or use Xi‘an Ascend Semiconductor Incorporated products for any unintended or unauthorized application, Customers shall indemnify and hold Xi‘an Ascend Semiconductor Incorporated and its representatives harmless against all claims, damages, expenses, and attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized application. www.ascendsemi.com NOV 2018 Version1.0 8/8 Ascend Semicondutor Co.,Ltd
ASDM40N60KQ-R 价格&库存
很抱歉,暂时无法提供与“ASDM40N60KQ-R”相匹配的价格&库存,您可以联系我们找货
