LK6RGB126M3
LK6RGB126M3
    APEM(埃斐)
    SWITCHKEYLOCK2POSSPDT4A125V
LK6RGB126M3 数据手册
LK series Keylock Switches Distinctive features and specifications LK_U1807US Single and double pole options Up to four positions Momentary and maintained switching Multiple key pull position options 45° or 90° indexing ELECTRICAL SPECIFICATIONS GENERAL SPECIFICATIONS • Contact rating : 4A at 125 VAC or 28VDC, 2A at 250 VAC • Contact resistance : ≤ 10 mΩ • Insulation resistance : ≥109 MΩ • Dielectric strength : 1000 V RMS minimum at sea level • Electrical life : 6000 cycles at full load • Mechanical life : 6000 cycles at full load. • Operating temperature range : -30°C to +85°C AGENCY APPROVALS MATERIALS • Lock housing : Zinc alloy die casted, nickel plated • Cylinder : 4 disc tumbler, zinc alloy die casted, nickel plated • Keys : 2 single bitted keys, brass nickel plated • Contacts & terminals : Gold plated copper alloy • Body : Glass filled polyester File E83438 Dimensions : first dimensions are in mm while inches are shown in brackets. Refer to the following pages for further information. Mounting accessories : Standard hardware supplied : 1 nut. For spare keys please contact APEM. Packaging unit : 25 The company reserves the right to change specifications without notice. APEM www.apem.com 1 LK series Keylock Switches Overview LK 126 B SERIES Function 6 Maintained 5 Momentary Finish Key type Key options Hardware N Nickel plated G Black 126 Std N Nickel Key (std) M Overmoulded 3 Nut (std) 4 Clip Indexing Lock Maintained No of function Poles Configuration A SP B (std) DP C SP D (std) DP E SP F (std) DP G SP H (std) DP 7 SP J (std) DP N SP 8 (std) DP P SP Q (std) DP R SP S (std) DP 1 2 45° 3 1 2 45° 3 1 2 45° 3 1 3 2 1 3 2 45° 45° 1 90° 2 1 90° 2 1 90° 2 Terminals Connected Pos. 1 Pos. 2 Pos. 3 Pos. 4 8-1 1-2 2-3 8-1, 4-5 1-2, 5-6 2-3, 6-7 8-1 1-2 2-3 8-1, 4-5 1-2, 5-6 2-3, 6-7 8-1 1-2 2-3 8-1, 4-5 1-2, 5-6 2-3, 6-7 8-1 1-2 7-8 8-1, 4-5 1-2, 5-6 7-8, 3-4 8-1 1-2 7-8 8-1, 4-5 1-2, 5-6 7-8, 3-4 8-1 1-3 8-1, 4-5 1-3, 5-7 8-1 1-3 8-1, 4-5 1-3, 5-7 8-1 1-3 8-1, 4-5 1-3, 5-7 8-1 1-2 Key Pull Position 1 3 1&3 1 1, 2 & 3 1 2 1&2 1 2 9 DP 3 45° 2-3 3-4 1, 2, 3 & 4 4 Momentary No of Indexing Lock function Poles Configuration A (std) SP B DP E (std) SP F DP G SP Terminals Connected Pos. 1 Pos. 2 Pos. 3 Pos. 4 1 2 45° 1 2 3 1 2 45° 45°/90° 8-1 1-2 8-1, 4-5 1-2, 5-6 8-1 1-2 8-1, 4-5 Key Pull Position 1-2, 5-6 1 7-8 7-8, 3-4 7-1 1-2 6-7 8-1 1-2 7-8 8-1, 4-5 1-2, 5-6 7-8, 3-4 1 1&3 3 2 7 (std) SP J DP 1 3 2 45° www.apem.com 1 Key pull position Detent positions Momentary positions APEM LK series Keylock Switches Panel cut-out Ø19 (0.755) MODEL STRUCTURE + • 2, 3 and 4 position configuration • Maintained and momentary functions • Standard and overmoulded key • Nut or clip fixing Recomended Panel Layout 19 0.75 Standard Key Standard Nut 22 0 .87 Terminals 19 0.75 P1.0 42 1.65 5.250 0.21 4.300 0.17 16.203 0.64 Maintained 22.3° 16 0 .63 2.030 0 .08 90° 0.510 0.02 12.500 0.49 5.25 0.207 15.596 0.61 6.500 0.26 21.996 0.87 12.497 0.49 9.800 0.39 16 0.63 Momentary 22.3° 2.030 0 .08 90° 5.250 0 .21 15.596 0.61 6.500 0.26 21.996 0.87 OPTIONS 0.510 0.02 12.500 0.49 12.500 0.49 9.800 0.39 16 0.63 5 0.20 + Overmoulded Key Clip 22 0 .87 27 1.06 13.200 0.52 0.600 0 .02 7.600 0 .30 4.200 0 .17 23.800 0 .94 42.800 1.69 30 1.18 25 0.98 19.397 0.76 15.800 0.62 APEM www.apem.com 20.500 0 .81 16.300 0.64 3.100 0 .12 2.500 0 .10 3 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Apem: LK6RGB126M3 LK68GB126M3 LK6NGB126M3 LK6SGB126M3 LK6BGB126M3 LK6EGB126M3 LK68NB126N3 LK6QNB126N3 LK6NNB606N3 LK57GB126M3 LK57NB126N3 LK5AGB126M3 LK5ANB126N3 LK5BGB126M3 LK5BNB126N3 LK6PNB126N3 LK6QGB126M3 LK6RNB126N3 LK6SNB126N3 LK6HGB126M3 LK6HNB126N3 LK6JGB126M3 LK6JNB126N3 LK6NNB126N3 LK6PGB126M3 LK6DNB126N3 LK6ENB126N3 LK6FGB126M3 LK6FNB126N3 LK6GGB126M3 LK6GNB126N3 LK6AGB126M3 LK6ANB126N3 LK6BNB126N3 LK6CGB126M3 LK6CNB126N3 LK6DGB126M3 LK5JGB126M3 LK5JNB126N3 LK67GB126M3 LK67NB126N3 LK69GB126M3 LK69NB126N3 LK5EGB126M3 LK5ENB126N3 LK5FGB126M3 LK5FNB126N3 LK5GGB126M3 LK5GNB126N3
LK6RGB126M3 价格&库存
很抱歉,暂时无法提供与“LK6RGB126M3”相匹配的价格&库存,您可以联系我们找货
