851
851
    B&K
    CONN PLUG MICRO LOCK SLD LUG BLK
851 数据手册
Data sheet Deluxe EPROM Eraser Model 851 The model 851 is a heavy duty EPROM eraser that can simultaneously erase up to 40 twenty-four pin EPROM’s. It is constructed of an all-metal case plus an advanced designed chip drawer that prevents UV radiation from being a hazard to the user. The chip drawer is lined with conductive foam to prevent electrostatic damage to the chips. Features: ■ Indicator light when erasing ■ Power ■ One capacity year warranty Technical data subject to change © B&K Precision Corp. 2008 v022609 model 851 Timer Setting Timer Setting 30 min. 100-120VAC 50/60Hz UV bulb wattage Dimensions 10W 15.5 x 6 x 3.25" (394 x 150 x 80mm) 8.8 lbs. (4kg) safety switch inside the drawer shuts off unit whenever the drawer is opened ■ Large Specifications Weight One Year Warranty Accessories Supplied: User Manual, Power Cord w w w.bk prec ision.c om Tel.: 714.921.9095
很抱歉,暂时无法提供与“851”相匹配的价格&库存,您可以联系我们找货
